datasheet
nRF24L01 AVR 发送接收驱动程序
2015-09-08来源: eefocus关键字:nRF24L01  AVR  发送接收  驱动程序
#include
#include
#include "12864.h"
  智芯锐电子技术社区:http://www.zhixinrui.com
//spi标志
#define DDR_SPI DDRB
#define DD_MOSI 5
#define DD_MISO 6
#define DD_SCK 7
#define DD_SS 4
#define CE PB3
#define IRQ PB2
//--------------------------------NRF24L01接口定义--------------------------------
//#define NRF24L01_MISO          PB6  //输入0
#define   Hign_24L01_MISO    PORTB|=(1 << PB6)
#define   Low_24L01_MISO     PORTB &= ~(1 << PB6)
#define   Read_24L01_MISO    PINB & (1 << PB6)
//#define NRF24L01_MOSI         PB5       //输出1
#define   Hign_24L01_MOSI    PORTB |= (1 << PB5)
#define   Low_24L01_MOSI     PORTB &= ~(1 << PB5)
#define   Read_24L01_MOSI    PINB & (1 << PB5)
//#define NRF24L01_SCK    PB7      //输出1
#define   Hign_24L01_SCK    PORTB |= (1 << PB7)
#define   Low_24L01_SCK     PORTB &= ~(1 << PB7)
#define   Read_24L01_SCK    PINB & (1 << PB7);
//#define NRF24L01_CSN       PB4       //输出1
#define   Low_24L01_CSN     PORTB &= ~(1 << PB4)
#define   Hign_24L01_CSN    PORTB |= (1 << PB4)
//#define NRF24L01_CE         PB3       //输出1
#define   Hign_24L01_CE    PORTB |= (1 << PB3)
#define   Low_24L01_CE     PORTB &= ~(1 << PB3)
#define   Read_24L01_CE    PINB & (1 << PB3)
//*********************************************NRF24L01*************************************
#define TX_ADR_WIDTH    5       // 发送地址长度,最大长度为5 5*8=40 bit
#define RX_ADR_WIDTH    5       // 接收地址长度
#define TX_PLOAD_WIDTH  32      // 发送字节长度,
#define RX_PLOAD_WIDTH  32      // 接收字节长度
 uchar TX_ADDRESS[TX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01};  //发送地址
 uchar RX_ADDRESS[RX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01}; //接收地址
//***************************************NRF24L01寄存器指令*******************************************************
#define READ_REG        0x00    // 读寄存器指令
#define WRITE_REG       0x20    // 写寄存器指令
#define RD_RX_PLOAD     0x61    // 读取接收数据指令
#define WR_TX_PLOAD     0xA0    // 写待发数据指令
#define FLUSH_TX        0xE1    // 冲洗发送 FIFO指令
#define FLUSH_RX        0xE2    // 冲洗接收 FIFO指令
#define REUSE_TX_PL     0xE3    // 定义重复装载数据指令
#define NOP             0xFF    // 保留
//*************************************SPI(nRF24L01)寄存器地址****************************************************
#define CONFIG          0x00  // 配置收发状态,CRC校验模式以及收发状态响应方式
#define EN_AA           0x01  // 自动应答功能设置
#define EN_RXADDR       0x02  // 可用信道设置
#define SETUP_AW        0x03  // 收发地址宽度设置
#define SETUP_RETR      0x04  // 自动重发功能设置
#define RF_CH           0x05  // 工作频率设置
#define RF_SETUP        0x06  // 发射速率、功耗功能设置
#define STATUS          0x07  // 状态寄存器
#define OBSERVE_TX      0x08  // 发送监测功能
#define CD              0x09  // 地址检测
#define RX_ADDR_P0      0x0A  // 频道0接收数据地址
#define RX_ADDR_P1      0x0B  // 频道1接收数据地址
#define RX_ADDR_P2      0x0C  // 频道2接收数据地址
#define RX_ADDR_P3      0x0D  // 频道3接收数据地址
#define RX_ADDR_P4      0x0E  // 频道4接收数据地址
#define RX_ADDR_P5      0x0F  // 频道5接收数据地址
#define TX_ADDR         0x10  // 发送地址寄存器
#define RX_PW_P0        0x11  // 接收频道0接收数据长度
#define RX_PW_P1        0x12  // 接收频道0接收数据长度
#define RX_PW_P2        0x13  // 接收频道0接收数据长度
#define RX_PW_P3        0x14  // 接收频道0接收数据长度
#define RX_PW_P4        0x15  // 接收频道0接收数据长度
#define RX_PW_P5        0x16  // 接收频道0接收数据长度
#define FIFO_STATUS     0x17  // FIFO栈入栈出状态寄存器设置
//*******  void spi_init()  初始化SPI
void spi_init()
 Hign_24L01_CSN;
 DDR_SPI = (1<
 DDR_SPI&=~((1<
 SPCR=(1<
 SPSR=0;
//*******  uchar SPI_RW(uchar date)  读写SPI
 SPDR=date;
    while(!(SPSR&(1<
    return SPDR;
//*******uchar SPI_Read(uchar reg)  读24L01寄存器
 uchar reg_val;
 Low_24L01_CSN;
 SPI_RW(reg);
 reg_val = SPI_RW(0);
 Hign_24L01_CSN;
 return(reg_val);
//*******  uchar SPI_RW_Reg(uchar reg, uchar value)
//          写24L01寄存器
 uchar status;
 Low_24L01_CSN;
 status = SPI_RW(reg);
 SPI_RW(value);
 Hign_24L01_CSN;
 return(status);
//*******  uchar SPI_Read_Buf(uchar reg, uchar *pBuf, uchar bites)
//          读24L01 寄存器BUFF
 uint status1,uchar_ctr;
 Low_24L01_CSN;
 status1 = SPI_RW(reg);
 for(uchar_ctr=0;uchar_ctr
  pBuf[uchar_ctr] = SPI_RW(0);
 Hign_24L01_CSN;
 return(status1);
//*******  uchar SPI_Write_Buf(uchar reg, uchar *pBuf, uchar bites)
//          写24L01 寄存器BUFF
 uchar status1,uchar_ctr;
 Low_24L01_CSN;             //SPI使能
 for(uchar_ctr=0; uchar_ctr
 SPI_RW(*pBuf++);
 Hign_24L01_CSN;           //关闭SPI
 return(status1);        //
//*******  void SetRX_Mode(void)
//          接收模式设置
 Low_24L01_CE;
 SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, RX_ADDRESS, RX_ADR_WIDTH); //写接收地址
 SPI_RW_Reg(WRITE_REG + EN_AA, 0x01);      //0通道自动应答
 SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01);  //数据通道0
 SPI_RW_Reg(WRITE_REG + RF_CH,0);        //射频通道
 SPI_RW_Reg(WRITE_REG + RX_PW_P0, RX_PLOAD_WIDTH);//写通道0 接受数据长度
 SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07); //0db 1M
 SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); //接收模式
 Hign_24L01_CE;        //开始接收
 delayus(200);//注意不能太小
//*******  uchar nRF24L01_RxPacket(uchar* rx_buf)
//          接收数据包
    uchar sta,flag=0;
    sta=SPI_Read(STATUS);      // 读取状态寄存其来判断数据接收状况
    if(sta&0x40)                 // 判断是否接收到数据RX_DR==1?
       Low_24L01_CE;   // StandBy I模式
       SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH);// read receive payload from RX_FIFO buffer
       flag =1;   //读取数据完成标志
    SPI_RW_Reg(WRITE_REG+STATUS,sta);   //接收到数据后RX_DR,TX_DS,MAX_PT都置高为1,通过写1来清楚中断标志
    return (flag);
//*******  void nRF24L01_TxPacket(uchar * tx_buf)
//          发送数据包
void nRF24L01_TxPacket(  uchar * tx_buf)
   uchar sta=0;
   uchar flag=0;
   Low_24L01_CE;   //StandBy I模式
   SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH);
   SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // 装载接收端地址
   SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH);     // 装载数据
   SPI_RW_Reg(WRITE_REG + SETUP_RETR, 0x1f); //500+86us
   SPI_RW_Reg(WRITE_REG + RF_CH, 0);        //
   SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e);      // IRQ收发完成中断响应,16位CRC,主发送
   delayms(2);
   Hign_24L01_CE;   //置高CE,激发数据发送
   delayus(10);
   Low_24L01_CE;
void init_NRF24L01(void)
  spi_init();
  Low_24L01_CE;    // 空闲模式
  Hign_24L01_CSN;   // SPI 关闭
  Low_24L01_SCK;   // 关闭时钟
编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/2015/0908/article_22068.html
上一篇:ATmega16熔丝位设定
下一篇:AVR单片机的DS18B20 C语言程序
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
STM32--SPI配置nrf24l01调试笔记
二void NRF24L01_TX_Mode(void){                                                            NRF24L01_CE=0;          NRF24L01
发表于 2019-07-11
STM32--使用SPI1和SPI3配置nrf24l01
正点原子自带的nrf24l01的例程是SPI2的,现在我使用了SPI1和SPI3来配置nrf24l01,芯片型号是STM32F103ZET6。使用SPI1配置nrf24l01spi.c//这里针是对SPI1的初始化void SPI1_Init(void){    GPIO_InitTypeDef GPIO_InitStructure;    SPI_InitTypeDef  SPI_InitStructure;    RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA, ENABLE );//PORTA时钟使能
发表于 2019-04-28
STM32F030C6+nrf24l01 SPI配置
void SPI1_Init(void){ GPIO_InitTypeDef GPIO_InitStructure; SPI_InitTypeDef  SPI1_InitStructure; RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE); //PB13:SCK PB14:MISO PB15:MOSI GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15; GPIO_InitStr
发表于 2019-02-15
STM32驱动NRF24L01
1. 简介NRF24L01是 nordic 的无线通信芯片,它具有以下特点:1) 2.4G 全球开放的 ISM 频段(2.400 - 2.4835GHz),免许可证使用;2)最高工作速率 2Mbps,高校的 GFSK 调制,抗干扰能力强;3) 125 个可选的频道,满足多点通信和调频通信的需要;4)内置 CRC 检错和点对多点的通信地址控制;5)低工作电压(1.9~3.6V),待机模式下状态为 26uA;掉电模式下为 900nA;6)可设置自动应答,确保数据可靠传输;7)工作于EnhancedShockBurst 具有Automatic packet handling,Auto packet transaction
发表于 2019-01-09
STM32驱动NRF24L01
stm32之nRF24L01无线模块(1):SPI2到SPI1的移植
(GPIOG,GPIO_Pin_6)#define NRF24L01_CE_CLR GPIO_ResetBits(GPIOG,GPIO_Pin_6)    在移植的时候,这种预定义很容易忽略,忘了的话根本就不会开始SPI通信,自然也就没有现象了。4.库函数的改变    在SPI2的函数中,只要是涉及写寄存器的部分,就要看下到底写的是SPI2还是SPI1的寄存器,当然,这里有一个很明显的特点,就是stm32官方的库函数一般是通用的,像下面这个SPI命令函数SPI_Cmd(SPI_TypeDef* SPIx, FunctionalState NewS
发表于 2018-10-16
stm32之nRF24L01无线模块(2):无线模块的地址
    可能刚开始接触nRF24L01的童鞋都会注意到例程函数中有两个定义的地址const u8 TX_ADDRESS[TX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01}; //发送地址const u8 RX_ADDRESS[RX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01};     这个非常让人疑惑,为什么地址还是数组,而且网上一搜,几乎所有的例程地址都是这一个,为什么呢,换一个不行吗?下面我们从数据手册和实验两个方面来分析,这里注意下,由于Enhanced ShockBurst
发表于 2018-10-16
小广播
何立民专栏
单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
