datasheet
Tiny210驱动之USB设备驱动程序
2018-10-12来源: eefocus关键字:Tiny210驱动  USB设备  驱动程序
usbmouse_as_key.c驱动源码:
//参考源码: drivers\hid\usbhid\usbmouse.c
#include "linux/kernel.h"
#include "linux/slab.h"
#include "linux/module.h"
#include "linux/init.h"
#include "linux/usb/input.h"
#include "linux/hid.h"
static struct input_dev *uk_dev;
static char *usb_buf;
static dma_addr_t usb_buf_phys;
static int len;
static struct urb *uk_urb;
static struct usb_device_id usbmouse_as_key_id_table [] = {
    {   USB_INTERFACE_INFO(USB_INTERFACE_CLASS_HID, USB_INTERFACE_SUBCLASS_BOOT,
        USB_INTERFACE_PROTOCOL_MOUSE)
    //{USB_DEVICE(0x1234,0x5678)},
    { }    // Terminating entry
static void usbmouse_as_key_irq(struct urb *urb)
    static unsigned char pre_val;
#if 0
    int i;
    static int cnt = 0;
    printk("data cnt %d: ", ++cnt);
    for (i = 0; i < len; i++)
        printk("x ", usb_buf[i]);
    printk("\n");
#endif
    // USB鼠标数据含义
    // data[0]: bit0-左键, 1-按下, 0-松开
    //          bit1-右键, 1-按下, 0-松开
    //          bit2-中键, 1-按下, 0-松开
    if ((pre_val & (1<<0)) != (usb_buf[0] & (1<<0)))
        // 左键发生了变化
        input_event(uk_dev, EV_KEY, KEY_L, (usb_buf[0] & (1<<0)) ? 1 : 0);
        input_sync(uk_dev);
    if ((pre_val & (1<<1)) != (usb_buf[0] & (1<<1)))
        // 右键发生了变化
        input_event(uk_dev, EV_KEY, KEY_S, (usb_buf[0] & (1<<1)) ? 1 : 0);
        input_sync(uk_dev);
    if ((pre_val & (1<<2)) != (usb_buf[0] & (1<<2)))
        // 中键发生了变化
        input_event(uk_dev, EV_KEY, KEY_ENTER, (usb_buf[0] & (1<<2)) ? 1 : 0);
        input_sync(uk_dev);
    pre_val = usb_buf[0];
    // 重新提交urb
    usb_submit_urb(uk_urb, GFP_KERNEL);
static int usbmouse_as_key_probe(struct usb_interface *intf, const struct usb_device_id *id)
    struct usb_device *dev = interface_to_usbdev(intf);
    struct usb_host_interface *interface;
    struct usb_endpoint_descriptor *endpoint;
    int pipe;
    interface = intf->cur_altsetting;
    endpoint = &interface->endpoint[0].desc;
    // a. 分配一个input_dev
    uk_dev = input_allocate_device();
    // b. 设置
    // b.1 能产生哪类事件
    set_bit(EV_KEY, uk_dev->evbit);
    set_bit(EV_REP, uk_dev->evbit);
    // b.2 能产生哪些事件
    set_bit(KEY_L, uk_dev->keybit);
    set_bit(KEY_S, uk_dev->keybit);
    set_bit(KEY_ENTER, uk_dev->keybit);
    // c. 注册
    input_register_device(uk_dev);
    // d. 硬件相关操作
    // 数据传输3要素: 源,目的,长度
    // 源: USB设备的某个端点
    pipe = usb_rcvintpipe(dev, endpoint->bEndpointAddress);
    // 长度:
    len = endpoint->wMaxPacketSize;
    // 目的:
    usb_buf = usb_alloc_coherent(dev, len, GFP_ATOMIC, &usb_buf_phys);
    // 使用"3要素"
    // 分配usb request block
    uk_urb = usb_alloc_urb(0, GFP_KERNEL);
    // 使用"3要素设置urb"
    usb_fill_int_urb(uk_urb, dev, pipe, usb_buf, len, usbmouse_as_key_irq, NULL, endpoint->bInterval);
    uk_urb->transfer_dma = usb_buf_phys;
    uk_urb->transfer_flags |= URB_NO_TRANSFER_DMA_MAP;
    // 使用URB
    return 0;
static void usbmouse_as_key_disconnect(struct usb_interface *intf)
    //printk("disconnect usbmouse!\n");
    usb_kill_urb(uk_urb);
    usb_free_urb(uk_urb);
    usb_free_coherent(dev, len, usb_buf, usb_buf_phys);
    input_unregister_device(uk_dev);
    input_free_device(uk_dev);
// 1. 分配/设置usb_driver
static struct usb_driver usbmouse_as_key_driver = {
    .name         = "usbmouse_as_key_",
    .probe         = usbmouse_as_key_probe,
    .disconnect = usbmouse_as_key_disconnect,
    .id_table      = usbmouse_as_key_id_table,
static int usbmouse_as_key_init(void)
    // 2. 注册
    usb_register(&usbmouse_as_key_driver);
    return 0;
static void usbmouse_as_key_exit(void)
    usb_deregister(&usbmouse_as_key_driver);
module_init(usbmouse_as_key_init);
module_exit(usbmouse_as_key_exit);
MODULE_LICENSE("GPL");
编辑:什么鱼 引用地址:http://www.eeworld.com.cn/mcu/2018/ic-news101241696.html
上一篇:Tiny210块设备驱动之内存模拟磁盘
下一篇:Tiny210触摸屏之一线触摸屏驱动
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
Tiny210驱动之LED测试
first_drv.c驱动源码:#include "linux/device.h"#include "linux/module.h"#include "linux/kernel.h"#include "linux/fs.h"#include "linux/init.h"#include "linux/delay.h"#include "asm/uaccess.h"#include "asm/irq.h"#include "asm/io.h"stati
发表于 2018-10-12
Tiny210驱动之KEY测试
second_drv.c驱动源码:#include "linux/device.h"#include "linux/module.h"#include "linux/kernel.h"#include "linux/fs.h"#include "linux/init.h"#include "linux/delay.h"#include "asm/uaccess.h"#include "asm/irq.h"#include "asm/io.h"stati
发表于 2018-10-12
Tiny210驱动之按键中断实验
[5] = {    {S5PV210_GPH2(3), 0x01},    {S5PV210_GPH3(0), 0x02},    {S5PV210_GPH3(1), 0x03},    {S5PV210_GPH3(2), 0x04},    {S5PV210_GPH3(3), 0x05},};// 确定按键值 static irqreturn_t buttons_irq(int irq, void *dev_id){
发表于 2018-10-12
Tiny210驱动之按键poll机制
;struct pin_desc pins_desc[5] = {    {S5PV210_GPH2(3), 0x01},    {S5PV210_GPH3(0), 0x02},    {S5PV210_GPH3(1), 0x03},    {S5PV210_GPH3(2), 0x04},    {S5PV210_GPH3(3), 0x05},};// 确定按键值static irqreturn_t buttons_irq(int
发表于 2018-10-12
Tiny210驱动之按键异步通知
, 0x84, 0x85 static unsigned char key_val;struct pin_desc pins_desc[5] = {    {S5PV210_GPH2(3), 0x01},    {S5PV210_GPH3(0), 0x02},    {S5PV210_GPH3(1), 0x03},    {S5PV210_GPH3(2), 0x04},    {S5PV210_GPH3(3), 0x05
发表于 2018-10-12
Tiny210按键互斥锁、原子变量驱动
, 0x84 static unsigned char key_val;// 键值: 按下时, 0x01, 0x02, 0x03, 0x04, 0x05 // 键值: 松开时, 0x81, 0x82, 0x83, 0x84, 0x85 static unsigned char key_val;struct pin_desc pins_desc[5] = {    {S5PV210_GPH2(3), 0x01},    {S5PV210_GPH3(0), 0x02},    {S5PV210
发表于 2018-10-12
小广播
何立民专栏
单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
