datasheet
Tiny210驱动之LCD驱动程序
2018-10-12来源: eefocus关键字:Tiny210驱动  LCD驱动
lcd驱动源码:
// 注意:本驱动是给S70的LCD写的驱动,若为其他的LCD,应该修改时钟和时序
#include "linux/module.h"
#include "linux/kernel.h"
#include "linux/errno.h"
#include "linux/string.h"
#include "linux/mm.h"
#include "linux/slab.h"
#include "linux/delay.h"
#include "linux/fb.h"
#include "linux/init.h"
#include "linux/dma-mapping.h"
#include "linux/interrupt.h"
#include "linux/platform_device.h"
#include "linux/clk.h"
#include "linux/cpufreq.h"
#include "asm/io.h"
#include "asm/div64.h"
#include "asm/mach/map.h"
#include "mach/regs-gpio.h"
#define MHZ (1000*1000)
#define PRINT_MHZ(m)             ((m) / MHZ), ((m / 1000) % 1000)
// LCD参数
#define VSPW       9
#define VBPD       13
#define LINEVAL   479
#define VFPD       21
#define HSPW       19
#define HBPD       25
#define HOZVAL   799
#define HFPD       209
#define LeftTopX   0
#define LeftTopY   0
#define RightBotX  799
#define RightBotY  479
// LCD控制寄存器
static unsigned long *vidcon0;  // video control 0
static unsigned long *vidcon1;  // video control 1
static unsigned long *vidcon2;  // video control 2
static unsigned long *vidtcon0; // video time control 0
static unsigned long *vidtcon1; // video time control 1
static unsigned long *vidtcon2; // video time control 2
static unsigned long *wincon0;  // window control 0
static unsigned long *vidosd0a; // video window 0 position control
static unsigned long *vidosd0b; // video window 0 position control1
static unsigned long *vidosd0c; // video window 0 position control
static unsigned long *vidw00add0b0; // window 0 buffer start address, buffer 0
static unsigned long *vidw00add1b0; // window 0 buffer end address, buffer 0
static unsigned long *vidw00add2;     // window 0 buffer size
static unsigned long *wpalcon;
static unsigned long *shadowcon;
// 用于LCD的GPIO
static unsigned long *gpf0con;
static unsigned long *gpf1con;
static unsigned long *gpf2con;
static unsigned long *gpf3con;
static unsigned long *gpd0con;
static unsigned long *gpd0dat;
//时钟
static unsigned long *clk_gate_block;
static unsigned long *display_control;
static struct fb_info *tiny_lcd;
static u32 pseudo_pal[16];
static inline unsigned int chan_to_field(unsigned int chan, struct fb_bitfield *bf)
    chan &= 0xffff;
    chan >>= 16 - bf->length;
    return chan << bf->offset;
static int tiny_lcdfb_setcolreg(unsigned int regno, unsigned int red,
                 unsigned int green, unsigned int blue,
                 unsigned int transp, struct fb_info *info)
    unsigned int val;
    if (regno > 16)
        return 1;
    // 用red,green,blue三原色构造出val
    val  = chan_to_field(red,     &info->var.red);
    val |= chan_to_field(green, &info->var.green);
    val |= chan_to_field(blue,   &info->var.blue);
    //((u32 *)(info->pseudo_palette))[regno] = val;
    pseudo_pal[regno] = val;
    return 0;
static struct fb_ops tiny_lcdfb_ops = {
    .owner            = THIS_MODULE,
    .fb_setcolreg  = tiny_lcdfb_setcolreg,
    .fb_fillrect       = cfb_fillrect,
    .fb_copyarea  = cfb_copyarea,
    .fb_imageblit = cfb_imageblit,
static int tiny_lcd_init(void)
    struct clk        *tiny_clk;
    // 1. 分配一个fb_info
    tiny_lcd = framebuffer_alloc(0, NULL);
    // 2. 设置
    // 2.1 设置固定的参数
    strcpy(tiny_lcd->fix.id, "tiny_lcd");
    //tiny_lcd->fix.smem_start = ;  //显存的物理起始地址
    tiny_lcd->fix.smem_len = 800*480*4;
    tiny_lcd->fix.type = FB_TYPE_PACKED_PIXELS;
    tiny_lcd->fix.visual = FB_VISUAL_TRUECOLOR;
    tiny_lcd->fix.line_length = 800*4;
    // 2.2 设置可变的参数
    tiny_lcd->var.xres           = 800;
    tiny_lcd->var.yres           = 480;
    tiny_lcd->var.xres_virtual   = 800;
    tiny_lcd->var.yres_virtual   = 480;
    tiny_lcd->var.bits_per_pixel = 32;
    //RGB = 8:8:8
    tiny_lcd->var.red.offset     = 16;
    tiny_lcd->var.red.length     = 8;
    tiny_lcd->var.green.offset   = 8;
    tiny_lcd->var.green.length   = 8;
    tiny_lcd->var.blue.offset    = 0;
    tiny_lcd->var.blue.length    = 8;
    tiny_lcd->var.activate       = FB_ACTIVATE_NOW;
    // 2.3 设置操作函数
    tiny_lcd->fbops = &tiny_lcdfb_ops;
    // 2.4 其他的设置
    //tiny_lcd->screen_base = ; //显存的虚拟起始地址
    tiny_lcd->screen_size = 800*480*4;
    tiny_lcd->pseudo_palette = pseudo_pal;
    // 3. 硬件相关的操作
    // 3.1 配置GPIO用于LCD
    gpf0con = ioremap(0xE0200120,4);
    gpf1con = ioremap(0xE0200140,4);
    gpf2con = ioremap(0xE0200160,4);
    gpf3con = ioremap(0xE0200180,4);
    gpd0con = ioremap(0xE02000A0,4);
    gpd0dat = ioremap(0xE02000A4,4);
    *gpf0con = 0x22222222;        // GPF0[7:0]
    *gpf1con = 0x22222222;        // GPF1[7:0]
    *gpf2con = 0x22222222;        // GPF2[7:0]
    *gpf3con = 0x22222222;        // GPF3[7:0]
    *gpd0con |= 1<<4;
    *gpd0dat |= 1<<1;
    // 3.2 使能时钟
    tiny_clk = clk_get(NULL, "lcd");
    if (!tiny_clk || IS_ERR(tiny_clk)) {
        printk(KERN_INFO "failed to get lcd clock source\n");
    clk_enable(tiny_clk);
    printk("Tiny_LCD clock got enabled :: $ld.$03ld Mhz\n", PRINT_MHZ(clk_get_rate(tiny_clk))); //$为%
    // 3.3 根据LCD手册设置LCD控制器, 比如VCLK的频率等
    display_control = ioremap(0xe0107008,4);
    vidcon0  = ioremap(0xF8000000,4);
    vidcon1  = ioremap(0xF8000004,4);
    wincon0  = ioremap(0xF8000020,4);
    vidosd0a = ioremap(0xF8000040,4);
    vidosd0b = ioremap(0xF8000044,4);
    vidosd0c = ioremap(0xF8000048,4);
    vidw00add0b0  = ioremap(0xF80000A0,4);
    vidw00add1b0  = ioremap(0xF80000D0,4);
    vidw00add2    = ioremap(0xF8000100,4);
    vidtcon0      = ioremap(0xF8000010,4);
    vidtcon1      = ioremap(0xF8000014,4);
    vidtcon2      = ioremap(0xF8000018,4);
    wpalcon       = ioremap(0xF80001A0,4);
    shadowcon     = ioremap(0xF8000034,4);
    // Display path selection
    // 10: RGB=FIMD I80=FIMD ITU=FIMD
    *display_control = 2<<0;
    // CLKVAL_F[13:6]:该值需要修改,因为看错手册了
    //                  HCLKD=166.75MHz,DCLK(min) = 20ns(50MHz)
    //                VCLK = 166.75 / (4+1) = 33.35MHz
    // CLKDIR  [4]:1 = Divided by CLKVAL_F
    // ENVID   [1]:1 = Enable the video output and the Display control signal.
    // ENVID_F [0]:1 = Enable the video output and the Display control signal.
    *vidcon0 &= ~((3<<26) | (1<<18) | (0xff<<6)  | (1<<2));     // RGB I/F, RGB Parallel format,
    *vidcon0 |= ((4<<6) | (1<<4) );
    // Divided by CLKVAL_F,vclk== HCLK / (CLKVAL+1) = 166.75/5 = 33.35MHz
    // 设置极性(要修改)
    // IVDEN [4]:0 = Normal
    // IVSYNC[5]:1 = Inverted
    // IHSYNC[6]:1 = Inverted
    // IVCLK [7]:0 = Video data is fetched at VCLK falling edge
    *vidcon1 &= ~(1<<7);              // 在vclk的下降沿获取数据
    *vidcon1 |= ((1<<6) | (1<<5));  // HSYNC极性反转, VSYNC极性反转
    // 设置时序(需要修改)
    *vidtcon0 = (VBPD << 16) | (VFPD << 8) | (VSPW << 0);
    *vidtcon1 = (HBPD << 16) | (HFPD << 8) | (HSPW << 0);
    // 设置屏幕的大小
    // LINEVAL[21:11]:多少行   = 480
    // HOZVAL [10:0] :水平大小 = 800
    *vidtcon2 = (LINEVAL << 11) | (HOZVAL << 0);
    // WSWP_F   [15] :1    = Swap Enable(为什么要使能),很关键的一位,能够解决掉重影问题
    // BPPMODE_F[5:2]:1011 = unpacked 24 BPP (non-palletized R:8-G:8-B:8 )
    // ENWIN_F  [0]:  1    = Enable the video output and the VIDEO control signal.
    *wincon0 &= ~(0xf << 2);
    //wincon0 |= (0xB<<2);
    *wincon0 |= (0xB<<2)|(1<<15);
    // 窗口0,左上角的位置(0,0)
    // 窗口0,右下角的位置(0,0)
    *vidosd0a = (LeftTopX<<11) | (LeftTopY << 0);
    *vidosd0b = (RightBotX<<11) | (RightBotY << 0);
    // 大小
    *vidosd0c = (LINEVAL + 1) * (HOZVAL + 1);
    // 分配显存
    tiny_lcd->screen_base = dma_alloc_writecombine(NULL, tiny_lcd->fix.smem_len,
        &tiny_lcd->fix.smem_start, GFP_KERNEL);
    *vidw00add0b0 = tiny_lcd->fix.smem_start;                                           //显存的物理起始地址
    *vidw00add1b0 = tiny_lcd->fix.smem_start + tiny_lcd->fix.smem_len; //显存的物理结束地址
    //vidw00add2 = 800*4;
    //vidw00add1b0 = (((HOZVAL + 1)*4 + 0) * (LINEVAL + 1)) & (0xffffff); //显存的物理结束地址
    // C0_EN_F  0  Enables Channel 0.
    // 0 = Disables 1 = Enables
    *shadowcon = 0x1;
    // LCD控制器开启
    *vidcon0 |= 0x3; // 开启总控制器
    *wincon0 |= 1;    // 开启窗口0
    //4.注册
    register_framebuffer(tiny_lcd);
    return 0;
static void tiny_lcd_exit(void)
    unregister_framebuffer(tiny_lcd);
    dma_free_writecombine(NULL, tiny_lcd->fix.smem_len, &(tiny_lcd->fix.smem_start), GFP_KERNEL);
    iounmap(gpf0con);
    iounmap(gpf1con);
    iounmap(gpf2con);
    iounmap(gpf3con);
    iounmap(gpd0con);
    iounmap(gpd0dat);
    iounmap(display_control);
    iounmap(vidcon0);
    iounmap(vidcon1);
    iounmap(vidtcon2);
    iounmap(wincon0);
    iounmap(vidosd0a);
    iounmap(vidosd0b);
    iounmap(vidosd0c);
    iounmap(vidw00add0b0);
    iounmap(vidw00add1b0);
    iounmap(vidw00add2);
    iounmap(vidtcon0);
    iounmap(vidtcon1);
    iounmap(shadowcon);
    framebuffer_release(tiny_lcd);
module_init(tiny_lcd_init);
module_exit(tiny_lcd_exit);
MODULE_LICENSE("GPL");
关键字:Tiny210驱动  LCD驱动
编辑:什么鱼 引用地址:http://www.eeworld.com.cn/mcu/2018/ic-news101241699.html
上一篇:Tiny210触摸屏之触摸屏控制器驱动
下一篇:Tiny210按键分层分离(总线-驱动-设备模型)
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
Tiny210驱动之LED测试
first_drv.c驱动源码:#include "linux/device.h"#include "linux/module.h"#include "linux/kernel.h"#include "linux/fs.h"#include "linux/init.h"#include "linux/delay.h"#include "asm/uaccess.h"#include "asm/irq.h"#include "asm/io.h"stati
发表于 2018-10-12
Tiny210驱动之KEY测试
second_drv.c驱动源码:#include "linux/device.h"#include "linux/module.h"#include "linux/kernel.h"#include "linux/fs.h"#include "linux/init.h"#include "linux/delay.h"#include "asm/uaccess.h"#include "asm/irq.h"#include "asm/io.h"stati
发表于 2018-10-12
Tiny210驱动之按键中断实验
[5] = {    {S5PV210_GPH2(3), 0x01},    {S5PV210_GPH3(0), 0x02},    {S5PV210_GPH3(1), 0x03},    {S5PV210_GPH3(2), 0x04},    {S5PV210_GPH3(3), 0x05},};// 确定按键值 static irqreturn_t buttons_irq(int irq, void *dev_id){
发表于 2018-10-12
Tiny210驱动之按键poll机制
;struct pin_desc pins_desc[5] = {    {S5PV210_GPH2(3), 0x01},    {S5PV210_GPH3(0), 0x02},    {S5PV210_GPH3(1), 0x03},    {S5PV210_GPH3(2), 0x04},    {S5PV210_GPH3(3), 0x05},};// 确定按键值static irqreturn_t buttons_irq(int
发表于 2018-10-12
Tiny210驱动之按键异步通知
, 0x84, 0x85 static unsigned char key_val;struct pin_desc pins_desc[5] = {    {S5PV210_GPH2(3), 0x01},    {S5PV210_GPH3(0), 0x02},    {S5PV210_GPH3(1), 0x03},    {S5PV210_GPH3(2), 0x04},    {S5PV210_GPH3(3), 0x05
发表于 2018-10-12
Tiny210按键互斥锁、原子变量驱动
, 0x84 static unsigned char key_val;// 键值: 按下时, 0x01, 0x02, 0x03, 0x04, 0x05 // 键值: 松开时, 0x81, 0x82, 0x83, 0x84, 0x85 static unsigned char key_val;struct pin_desc pins_desc[5] = {    {S5PV210_GPH2(3), 0x01},    {S5PV210_GPH3(0), 0x02},    {S5PV210
发表于 2018-10-12
小广播
何立民专栏
单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
