//SPI1 读写一个字节
//TxData:要写入的字节
//返回值:读取到的字节
u8 SPI2_ReadWriteByte(u8 TxData)
while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) == RESET){}//等待发送区空
SPI_I2S_SendData(SPI2, TxData); //通过外设SPIx发送一个byte 数据
while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET){} //等待接收完一个byte
return SPI_I2S_ReceiveData(SPI2); //返回通过SPIx最近接收的数据
/*uint8_t sFLASH_SendByte(uint8_t byte)
//!< Loop while DR register in not emplty
while (SPI_I2S_GetFlagStatus(sFLASH_SPI, SPI_I2S_FLAG_TXE) == RESET);
//!< Send byte through the SPI1 peripheral
SPI_I2S_SendData(sFLASH_SPI, byte);
//!< Wait to receive a byte
while (SPI_I2S_GetFlagStatus(sFLASH_SPI, SPI_I2S_FLAG_RXNE) == RESET);
//!< Return the byte read from the SPI bus
return SPI_I2S_ReceiveData(sFLASH_SPI);
//以下是SPI模块的初始化代码,配置成主机模式
//SPI口初始化
//这里针是对SPI1的初始化
void SPI2_Init(void)
GPIO_InitTypeDef GPIO_InitStructure;
SPI_InitTypeDef SPI_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);//使能GPIOB时钟
RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);//使能SPI2时钟
//GPIOFB3,4,5初始化设置
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;//PB3~5复用功能输出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化
//这里只针对SPI口初始化
RCC_APB1PeriphResetCmd(RCC_APB1Periph_SPI2,ENABLE);//复位SPI1
RCC_APB1PeriphResetCmd(RCC_APB1Periph_SPI2,DISABLE);//停止复位SPI1
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; //设置SPI单向或者双向的数据模式:SPI设置为双线双向全双工
SPI_InitStructure.SPI_Mode = SPI_Mode_Master; //设置SPI工作模式:设置为主SPI
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; //设置SPI的数据大小:SPI发送接收8位帧结构
SPI_InitStructure.SPI_CPOL = SPI_CPOL_High; //串行同步时钟的空闲状态为高电平
SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge; //串行同步时钟的第二个跳变沿(上升或下降)数据被采样
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //NSS信号由硬件(NSS管脚)还是软件(使用SSI位)管理:内部NSS信号有SSI位控制
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2; //定义波特率预分频的值:波特率预分频值为256
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //指定数据传输从MSB位还是LSB位开始:数据传输从MSB位开始
SPI_InitStructure.SPI_CRCPolynomial = 7; //CRC值计算的多项式
SPI_Init(SPI2, &SPI_InitStructure); //根据SPI_InitStruct中指定的参数初始化外设SPIx寄存器
SPI_Cmd(SPI2, ENABLE); //使能SPI外设
SPI2_ReadWriteByte(0xff);//启动传输
void W25QXX_Init(void)
//GPIOB14
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;//PB12
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//输出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//100MHz
//W25QXX_CS=1; //SPI FLASH不选中
GPIO_SetBits(GPIOB,GPIO_Pin_12);
SPI2_Init(); //初始化SPI
//W25QXX_TYPE=W25QXX_ReadID(); //读取FLASH ID.
#define EN_FLASH() GPIO_ResetBits(GPIOB,GPIO_Pin_12)
#define DIS_FLASH() GPIO_SetBits(GPIOB,GPIO_Pin_12);
//读取W25QXX的状态寄存器
//BIT7 6 5 4 3 2 1 0
//SPR RV TB BP2 BP1 BP0 WEL BUSY
//SPR:默认0,状态寄存器保护位,配合WP使用
//TB,BP2,BP1,BP0:FLASH区域写保护设置
//WEL:写使能锁定
//BUSY:忙标记位(1,忙;0,空闲)
//默认:0x00
u8 W25QXX_ReadSR(void)
u8 byte=0;
//W25QXX_CS=0; //使能器件
//GPIO_ResetBits(GPIOD,GPIO_Pin_0);
EN_FLASH();
SPI2_ReadWriteByte(W25X_ReadStatusReg); //发送读取状态寄存器命令
byte=SPI2_ReadWriteByte(0Xff); //读取一个字节
//W25QXX_CS=1; //取消片选
DIS_FLASH();
return byte;
//写W25QXX状态寄存器
//只有SPR,TB,BP2,BP1,BP0(bit 7,5,4,3,2)可以写!!!
void W25QXX_Write_SR(u8 sr)
EN_FLASH();
SPI2_ReadWriteByte(W25X_WriteStatusReg); //发送写取状态寄存器命令
SPI2_ReadWriteByte(sr); //写入一个字节
DIS_FLASH();
//W25QXX写使能
//将WEL置位
void W25QXX_Write_Enable(void)
EN_FLASH();
SPI2_ReadWriteByte(W25X_WriteEnable); //发送写使能
DIS_FLASH();
//等待空闲
void W25QXX_Wait_Busy(void)
while((W25QXX_ReadSR()&0x01)==0x01) IWDG_ReloadCounter(); //feed dog ; // 等待BUSY位清空
//擦除一个扇区
//Dst_Addr:扇区地址 根据实际容量设置
//擦除一个山区的最少时间:150ms
void W25QXX_Erase_Sector(u32 Dst_Addr)
//监视falsh擦除情况,测试用
Dst_Addr*=4096;
W25QXX_Write_Enable(); //SET WEL
W25QXX_Wait_Busy();
EN_FLASH();
SPI2_ReadWriteByte(W25X_SectorErase); //发送扇区擦除指令
SPI2_ReadWriteByte((u8)((Dst_Addr)>>16)); //发送24bit地址
SPI2_ReadWriteByte((u8)((Dst_Addr)>>8));
SPI2_ReadWriteByte((u8)Dst_Addr);
DIS_FLASH(); //取消片选
W25QXX_Wait_Busy(); //等待擦除完成
//SPI在一页(0~65535)内写入少于256个字节的数据
//在指定地址开始写入最大256字节的数据
//pBuffer:数据存储区
//WriteAddr:开始写入的地址(24bit)
//NumByteToWrite:要写入的字节数(最大256),该数不应该超过该页的剩余字节数!!!
void W25QXX_Write_Page(u8* pBuffer,u32 WriteAddr,u16 NumByteToWrite)
u16 i;
EN_FLASH();
SPI2_ReadWriteByte(W25X_PageProgram); //发送写页命令
SPI2_ReadWriteByte((u8)((WriteAddr)>>16)); //发送24bit地址
SPI2_ReadWriteByte((u8)((WriteAddr)>>8));
SPI2_ReadWriteByte((u8)WriteAddr);
for(i=0;i //W25QXX_CS=1; //取消片选 DIS_FLASH(); W25QXX_Wait_Busy(); //等待写入结束 } //读取SPI FLASH //在指定地址开始读取指定长度的数据 //pBuffer:数据存储区 //ReadAddr:开始读取的地址(24bit) //NumByteToRead:要读取的字节数(最大65535) void W25QXX_Read(u8* pBuffer,u32 ReadAddr,u16 NumByteToRead) { u16 i; EN_FLASH(); //使能器件 SPI2_ReadWriteByte(W25X_ReadData); //发送读取命令 SPI2_ReadWriteByte((u8)((ReadAddr)>>16)); //发送24bit地址 SPI2_ReadWriteByte((u8)((ReadAddr)>>8)); SPI2_ReadWriteByte((u8)ReadAddr); for(i=0;i { pBuffer[i]=SPI2_ReadWriteByte(0XFF); //循环读数 } DIS_FLASH(); }
上一篇:STM32通信接口(一)串口
下一篇:基于STM32的DS18B20驱动
