STM32 之 UART1(2)
2016-10-06来源: eefocus关键字:STM32  UART1
(2)Init_External_Device.c
C语言: Codee#14663
#include "includes.h"
                             == 全局变量 ==
//=== UART1_RX变量,TX变量 ===========================================
unsigned char Uart1_Rx ;       // 接受一个字符变量
unsigned char Uart1_Tx ;       // 发送一个字符变量
//=== 精确延时 =======================================================
vu32 TimingDelay;              // 精确延时在SysTick中断里用的计数变量
* Function Name : RCC_Configuration
* Description    : Configures the different system clocks.
* Input          : None
* Output         : None
* Return         : None
void RCC_Configuration(void)
ErrorStatus HSEStartUpStatus;
//将外设 RCC寄存器重设为缺省值
RCC_DeInit();
//设置外部高速晶振(HSE)
RCC_HSEConfig(RCC_HSE_ON);
//等待 HSE 起振
HSEStartUpStatus = RCC_WaitForHSEStartUp();
if(HSEStartUpStatus == SUCCESS)
    //预取指缓存使能
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
     //设置代码延时值
    //FLASH_Latency_2 2 延时周期
    FLASH_SetLatency(FLASH_Latency_2);
    //设置 AHB 时钟(HCLK)
    //RCC_SYSCLK_Div1 AHB 时钟 = 系统时钟
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
     //设置高速 AHB 时钟(PCLK2)
    //RCC_HCLK_Div2 APB1 时钟 = HCLK / 2
    RCC_PCLK2Config(RCC_HCLK_Div2);
    //设置低速 AHB 时钟(PCLK1)
    RCC_PCLK1Config(RCC_HCLK_Div2);
    // PLLCLK = 8MHz * 9 = 72 MHz
    //设置 PLL 时钟源及倍频系数
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    //使能或者失能 PLL
    RCC_PLLCmd(ENABLE);
    //等待指定的 RCC 标志位设置成功 等待PLL初始化成功
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    //设置系统时钟(SYSCLK) 设置PLL为系统时钟源
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    //等待PLL成功用作于系统时钟的时钟源
    // 0x00:HSI 作为系统时钟
    // 0x04:HSE作为系统时钟
    // 0x08:PLL作为系统时钟
    while(RCC_GetSYSCLKSource() != 0x08)
//RCC_APB2PeriphClockCmd(RCC_APB2Periph_ALL, ENABLE);
//使能或者失能 APB2 外设时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE);
// Enable USART1 clocks
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
* Function Name : SysTick_Config   SysTick设置
* Description    : Configures SysTick
* Input          : None
* Output         : None
* Return         : None
void SysTick_Config(void)
    /* Disable SysTick Counter */
    SysTick_CounterCmd(SysTick_Counter_Disable);
    /* Disable the SysTick Interrupt */
    SysTick_ITConfig(DISABLE);
    /* Configure HCLK clock as SysTick clock source */
    SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK_Div8);
    /* SysTick interrupt each 1000 Hz with HCLK equal to 72MHz */
    SysTick_SetReload(9000);
    /* Enable the SysTick Interrupt */
    SysTick_ITConfig(ENABLE);
* Function Name : NVIC_Configuration
* Description    : Configures NVIC and Vector Table base location.
* Input          : None
* Output         : None
* Return         : None
void NVIC_Configuration(void)
NVIC_InitTypeDef NVIC_InitStructure1_UART1;
//===== Default ======================================================
#ifdef VECT_TAB_RAM
    /* Set the Vector Table base location at 0x20000000 */
    NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else /* VECT_TAB_FLASH */
    /* Set the Vector Table base location at 0x08000000 */
    NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
//===== NVIC_UART1 ===================================================
    /* Configure the NVIC Preemption Priority Bits */
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
    /* Enable the USART1 Interrupt */
NVIC_InitStructure1_UART1.NVIC_IRQChannel = USART1_IRQChannel;   // 配置使能指定的IRQ(Interrupt ReQuest中断请求)通道
NVIC_InitStructure1_UART1.NVIC_IRQChannelPreemptionPriority = 0; // 配置IRQ的 组 优先级
NVIC_InitStructure1_UART1.NVIC_IRQChannelSubPriority = 0;        // 配置IRQ的 从 优先级
NVIC_InitStructure1_UART1.NVIC_IRQChannelCmd = ENABLE;           // 配置IRQ 使能
NVIC_Init(&NVIC_InitStructure1_UART1);                           // 初始化 UART1_IRQ
* Function Name : UART1_Configuration
* Description    : Configures the uart1
* Input          : None
* Output         : None
* Return         : None
void UART1_Configuration(void)
USART_InitTypeDef USART_InitStructure_UART1;
/* USART1 configured as follow:
        - BaudRate = 9600 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
USART_InitStructure_UART1.USART_BaudRate = 9600;                                         // 配置UART1 波特率为9600
USART_InitStructure_UART1.USART_WordLength = USART_WordLength_8b;                        // 配置UART1 传输过程中每一帧的数据位数为 8位
USART_InitStructure_UART1.USART_StopBits = USART_StopBits_1;                             // 配置UART1 发送停止位 为1个
USART_InitStructure_UART1.USART_Parity = USART_Parity_No ;                               // 配置UART1 奇偶效验模式 为无奇偶效验
USART_InitStructure_UART1.USART_HardwareFlowControl = USART_HardwareFlowControl_None;    // 配置UART1 硬件流控制 为无硬件流控制
USART_InitStructure_UART1.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;                    // 配置UART1 使能发射和接受模式
/* Configure the USART1*/
USART_Init(USART1, &USART_InitStructure_UART1);          // 初始化UART1
/* Enable USART1 Receive and Transmit interrupts */
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);           // 配置UART1接受中断使能
/* Enable the USART1 */
USART_Cmd(USART1, ENABLE);                               // 使能UART1
* Function Name : GPIO_Configuration
* Description    : Configures the different GPIO ports.
* Input          : None
* Output         : None
* Return         : None
void GPIO_Configuration(void)
GPIO_InitTypeDef GPIO_InitStructure_LED_PORTB;
GPIO_InitTypeDef GPIO_InitStructure_KEY_PORTA;
GPIO_InitTypeDef GPIO_InitStructure_KEY_PORTB;
GPIO_InitTypeDef GPIO_InitStructure_KEY_PORTC;
GPIO_InitTypeDef GPIO_InitStructure_UART1_TX_PORTA;
GPIO_InitTypeDef GPIO_InitStructure_UART1_RX_PORTA;
//==== LED =======================================================
GPIO_InitStructure_LED_PORTB.GPIO_Pin = GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15 ;
GPIO_InitStructure_LED_PORTB.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure_LED_PORTB.GPIO_Mode = GPIO_Mode_Out_PP;   //推挽输出
GPIO_Init(GPIOB, &GPIO_InitStructure_LED_PORTB);
//==== KEY =======================================================
GPIO_InitStructure_KEY_PORTA.GPIO_Pin = GPIO_Pin_0 ;
GPIO_InitStructure_KEY_PORTA.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure_KEY_PORTA.GPIO_Mode = GPIO_Mode_IPU ;     //上拉输入
GPIO_Init(GPIOA, &GPIO_InitStructure_KEY_PORTA);
GPIO_InitStructure_KEY_PORTB.GPIO_Pin = GPIO_Pin_7 ;
GPIO_InitStructure_KEY_PORTB.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure_KEY_PORTB.GPIO_Mode = GPIO_Mode_IPU;      //上拉输入
GPIO_Init(GPIOB, &GPIO_InitStructure_KEY_PORTB);
GPIO_InitStructure_KEY_PORTC.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15 ;
GPIO_InitStructure_KEY_PORTC.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure_KEY_PORTC.GPIO_Mode = GPIO_Mode_IPU;      //上拉输入
GPIO_Init(GPIOC, &GPIO_InitStructure_KEY_PORTC);
//==== UART1 ======================================================
      // Configure USART1_Tx as alternate function push-pull
GPIO_InitStructure_UART1_TX_PORTA.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure_UART1_TX_PORTA.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure_UART1_TX_PORTA.GPIO_Mode = GPIO_Mode_AF_PP;         //复用推挽输出
GPIO_Init(GPIOA, &GPIO_InitStructure_UART1_TX_PORTA);
      // Configure USART1_Rx as input floating
GPIO_InitStructure_UART1_RX_PORTA.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure_UART1_RX_PORTA.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure_UART1_RX_PORTA.GPIO_Mode = GPIO_Mode_IN_FLOATING;   // 悬浮输入
GPIO_Init(GPIOA, &GPIO_InitStructure_UART1_RX_PORTA);
* Function Name : 精确延时函数
void Delay_Ms(u32 nTime)
/* Enable the SysTick Counter */
SysTick_CounterCmd(SysTick_Counter_Enable);
TimingDelay = nTime;
while(TimingDelay != 0);
/* Clear SysTick Counter */
SysTick_CounterCmd(SysTick_Counter_Clear);
关键字:STM32  UART1
编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/article_2016100630110.html
上一篇:STM32 之 ADC_DMA
下一篇:STM32 之 UART1(1)
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
STM32解决:st-link连接下载程序的问题
STM32解决:Error: Flash Download failed - "Cortex-M3"本人由于使用普中科技的stm32 的开发板的 USB的下载的地方坏了,所以不得不使用arm仿真器 st-link 进行下载。鼓捣了半天下面总结一下几个问题:1、st-link的驱动下载首先你插上st-link的时候,电脑的设备管理器这个地方是有感叹号的,说明还没有装好驱动,所以我就在网上找啊找。终于根据:win8【笔者没这个系统,无法测试,请大家测试后报告】:http://pan.baidu.com/s/1sjJQxZn(转载来自:https://blog.csdn.net/imxiangzi/article
发表于 2019-07-19
解决stm32f103通过stlink不能烧录程序问题
问题:   stm32(stm32f103c8T6)开发板只能通过串口烧录程序,而st—link居然不行描述:解决:st-link固件升级用stm32cubemx快速开发时没有配置好调试模式重新生成代码就可以了如果还是不行的话,就得升级一下stlink固件了,具体升级方法可百度
发表于 2019-07-19
STM32下载不成功问题汇总
在某宝上买了五个最小系统核心板是STM32F103C8T6的芯片,刚拿到手准备下载程序调试,上电后板子自带LED闪烁,这是商家自己下载的示例程序,说明芯片工作着,用KEIL4进行下载自己程序,把自己编译好的程序下载。用的JLINK的四线下载调试下载口,SW的调试接口,点击下载后发现擦除成功,下载失败,提示:Load "..\Output\STM32-DEMO.axf" Set JLink Project File to "F:文件RFID程序电机USERJLinkSettings.ini"* JLink Info: Device "STM32
发表于 2019-07-19
STM32下载不成功问题汇总
STM32高级开发(11)-使用GDB调试你的工程
/scripts/target/stm32f4x_stlink.cfg在执行完此条指令后该终端就会一直执行OpenOCD的程序了,不要关闭它,我们再打开一个终端界面,进入我们的工程目录,比如我这里进入的就是我的libopencm3样例工程下的blink子工程目录。$ cd '/home/yangliu/workspace/libopencm3-my-example/blink'然后我们使用指令输入调试文件并打开GDB程序。$ arm-none-eabi-gdb blink.elf 然后我们在GDB的指令界面中,输入连接指令,连接本地的3333端口。(gdb)target remote localhost:3333此时
发表于 2019-07-19
STM32F4标准外设库模板工程建立与使用
SW4STM32安装其实固件库安装过程很简单,在第一次新建工程时会提示选择使用Stdperiph 驱动还是Cube HAL,由于Stm32官方大力推行Cube HAL固件库,所以Cube HAL的固件库直接可以从网上直接一键下载安装。然而对于老的StdPeriph固件库不能一键式下载安装,会提示出错。所以,我们需要自己下载一个.zip固件包,放在C:UsersLYAppDataRoamingAc6SW4STM32firmwares文件夹下,其中的LY就是计算机的用户名。然后新建工程时在选择Stdperiph固件时会自动解压缩,这样就能使用该库进行编译了。界面如下所示:工程配置器件与时钟或者,修改晶振与时钟,根据注释可以算得
发表于 2019-07-19
基于STM32的外设的GPIO外设设置总结
1、背景外设驱动的寄存器设置对于外设功能正常运行异常重要。现在对GPIO的配置进行总结。2、GPIO的配置总结复用GPIO配置GPIO设置为输出或者是复用模式时,需要设置输出速度;而无论设置为什么模式,都要对GPIO的内部上下拉进行设置。注意:在输入模式(普通输入/模拟输入)下,OTYPE和OSPEED参数无效!!
发表于 2019-07-19
小广播
何立民专栏
单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
