datasheet
STM32初学笔记1之RCC(下)
2016-10-10来源: eefocus关键字:STM32  RCC
前面写过一篇文章:STM32初学笔记之RCC(1),在这一篇文章中介绍了系统时钟的设置的几个函数,刚刚突然想追踪SystemInit()的时候才发现,原来我写的这个所谓的RCC_ClkConfig.C和RCC_ClkConfig.H文件一点用处都没有,因为这个在库源文件system_stm32f10x.c中全部都有,而且比我的那个好用很多,所以,哎,我有百忙了。下面就具体显示一下我的这个函数追踪过程吧。
1、首先在主函数中添加一下一条语句:
STM32初学笔记之RCC(2) - rezone2010 - 重新分区
2、将光标移动到SystemInit()函数上,单击右键,选择"go to the definition of 'SystemInit'"
3、我们可以看到这个函数位于system_stm32f10x.c当中
这个函数的详细内容复制到如下:
  * @brief  Setup the microcontroller system
  *         Initialize the Embedded Flash Interface, the PLL and update the
  *         SystemCoreClock variable.
  * @note   This function should be used only after reset.
  * @param  None
  * @retval None
void SystemInit (void)
  /* Reset the RCC clock configuration to the default reset state(for debug purpose) */
  /* Set HSION bit */
  RCC->CR |= (uint32_t)0x00000001;
  /* Reset SW, HPRE, PPRE1, PPRE2, ADCPRE and MCO bits */
#ifndef STM32F10X_CL
  RCC->CFGR &= (uint32_t)0xF8FF0000;
#else
  RCC->CFGR &= (uint32_t)0xF0FF0000;
#endif /* STM32F10X_CL */
  /* Reset HSEON, CSSON and PLLON bits */
  RCC->CR &= (uint32_t)0xFEF6FFFF;
  /* Reset HSEBYP bit */
  RCC->CR &= (uint32_t)0xFFFBFFFF;
  /* Reset PLLSRC, PLLXTPRE, PLLMUL and USBPRE/OTGFSPRE bits */
  RCC->CFGR &= (uint32_t)0xFF80FFFF;
#ifdef STM32F10X_CL
  /* Reset PLL2ON and PLL3ON bits */
  RCC->CR &= (uint32_t)0xEBFFFFFF;
  /* Disable all interrupts and clear pending bits  */
  RCC->CIR = 0x00FF0000;
  /* Reset CFGR2 register */
  RCC->CFGR2 = 0x00000000;
#elif defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || (defined STM32F10X_HD_VL)
  RCC->CIR = 0x009F0000;
#else
#if defined (STM32F10X_HD) || (defined STM32F10X_XL) || (defined STM32F10X_HD_VL)
  #ifdef DATA_IN_ExtSRAM
    SystemInit_ExtMemCtl();
  #endif /* DATA_IN_ExtSRAM */
#endif
  /* Configure the System clock frequency, HCLK, PCLK2 and PCLK1 prescalers */
  /* Configure the Flash Latency cycles and enable prefetch buffer */
  SetSysClock();
#ifdef VECT_TAB_SRAM
  SCB->VTOR = SRAM_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal SRAM. */
#else
  SCB->VTOR = FLASH_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal FLASH. */
#endif
4、我们可以看到SystemInit()函数当中又调用了一个叫SetSysClock()的函数(在上面代码中用红色字体标注),我们接着追踪SetSysClock()的函数,我们看到这个函数还是位于system_stm32f10x.c当中:
5、我们可以看到这个设置系统时钟的函数中通过宏定义的方式共有6个函数可以调用,但是我们在追踪函数的时候,只能追踪到其中的一个,原因是在system_stm32f10x.c源文件的开始处有一个声明系统时钟频率的宏定义:
用户可以根据自己的需要在这个地方修改系统的时钟频率。
6、在知道这个系统时钟频率之后,我们就可以在第4点的基础上追踪函数了:
我们可以看到这个设置系统时钟频率的函数仍然位于system_stm32f10x.c源文件当中,找到这个函数以后继续往上翻页,我们可以看到SetSysClock()中出现的函数全都在这里出现了,因此我们可以由此得出结论:在STM32标准外设库的所有时钟频率设置全都放置在system_stm32f10x.c源文件当中,因此用户完全没有必要再去纠结这个系统频率的设置了,用户唯一需要做的就是根据需要修改设置系统时钟频率的宏定义(如下图所示)。(哈哈!我想我这一个结论对大家肯定能起到很大的帮助作用的,但是对我来说得出的结论就是我这一周白做了很多事情,无用功太多呀!。)STM32初学笔记之RCC(2) - rezone2010 - 重新分区
关键字:STM32  RCC
编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/article_2016101030296.html
上一篇:STM32初学笔记2之Systick
下一篇:STM32配置时钟时注意设置FLASH等待周期
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
STM32解决:st-link连接下载程序的问题
STM32解决:Error: Flash Download failed - "Cortex-M3"本人由于使用普中科技的stm32 的开发板的 USB的下载的地方坏了,所以不得不使用arm仿真器 st-link 进行下载。鼓捣了半天下面总结一下几个问题:1、st-link的驱动下载首先你插上st-link的时候,电脑的设备管理器这个地方是有感叹号的,说明还没有装好驱动,所以我就在网上找啊找。终于根据:win8【笔者没这个系统,无法测试,请大家测试后报告】:http://pan.baidu.com/s/1sjJQxZn(转载来自:https://blog.csdn.net/imxiangzi/article
发表于 2019-07-19
解决stm32f103通过stlink不能烧录程序问题
问题:   stm32(stm32f103c8T6)开发板只能通过串口烧录程序,而st—link居然不行描述:解决:st-link固件升级用stm32cubemx快速开发时没有配置好调试模式重新生成代码就可以了如果还是不行的话,就得升级一下stlink固件了,具体升级方法可百度
发表于 2019-07-19
STM32下载不成功问题汇总
在某宝上买了五个最小系统核心板是STM32F103C8T6的芯片,刚拿到手准备下载程序调试,上电后板子自带LED闪烁,这是商家自己下载的示例程序,说明芯片工作着,用KEIL4进行下载自己程序,把自己编译好的程序下载。用的JLINK的四线下载调试下载口,SW的调试接口,点击下载后发现擦除成功,下载失败,提示:Load "..\Output\STM32-DEMO.axf" Set JLink Project File to "F:文件RFID程序电机USERJLinkSettings.ini"* JLink Info: Device "STM32
发表于 2019-07-19
STM32下载不成功问题汇总
STM32高级开发(11)-使用GDB调试你的工程
/scripts/target/stm32f4x_stlink.cfg在执行完此条指令后该终端就会一直执行OpenOCD的程序了,不要关闭它,我们再打开一个终端界面,进入我们的工程目录,比如我这里进入的就是我的libopencm3样例工程下的blink子工程目录。$ cd '/home/yangliu/workspace/libopencm3-my-example/blink'然后我们使用指令输入调试文件并打开GDB程序。$ arm-none-eabi-gdb blink.elf 然后我们在GDB的指令界面中,输入连接指令,连接本地的3333端口。(gdb)target remote localhost:3333此时
发表于 2019-07-19
STM32F4标准外设库模板工程建立与使用
SW4STM32安装其实固件库安装过程很简单,在第一次新建工程时会提示选择使用Stdperiph 驱动还是Cube HAL,由于Stm32官方大力推行Cube HAL固件库,所以Cube HAL的固件库直接可以从网上直接一键下载安装。然而对于老的StdPeriph固件库不能一键式下载安装,会提示出错。所以,我们需要自己下载一个.zip固件包,放在C:UsersLYAppDataRoamingAc6SW4STM32firmwares文件夹下,其中的LY就是计算机的用户名。然后新建工程时在选择Stdperiph固件时会自动解压缩,这样就能使用该库进行编译了。界面如下所示:工程配置器件与时钟或者,修改晶振与时钟,根据注释可以算得
发表于 2019-07-19
基于STM32的外设的GPIO外设设置总结
1、背景外设驱动的寄存器设置对于外设功能正常运行异常重要。现在对GPIO的配置进行总结。2、GPIO的配置总结复用GPIO配置GPIO设置为输出或者是复用模式时,需要设置输出速度;而无论设置为什么模式,都要对GPIO的内部上下拉进行设置。注意:在输入模式(普通输入/模拟输入)下,OTYPE和OSPEED参数无效!!
发表于 2019-07-19
小广播
何立民专栏
单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
