STM32串口发送数据详解
2016-10-10来源: eefocus关键字:STM32  串口  发送数据
串口的中断方式:
* @brief Enables or disables the specified USART interrupts.
* @param USARTx: where x can be 1 or 2 to select the USART peripheral.
* @param USART_IT: specifies the USART interrupt sources to be enabled or disabled.
* This parameter can be one of the following values:
* @arg USART_IT_WU: Wake up interrupt. //唤醒中断
* @arg USART_IT_CM: Character match interrupt.//字符匹配中断
* @arg USART_IT_EOB: End of block interrupt. //块结束中断
* @arg USART_IT_RTO: Receive time out interrupt. //接收超时中断
* @arg USART_IT_CTS: CTS change interrupt. //CTS变化中断
* @arg USART_IT_LBD: LIN Break detection interrupt. //终止检测中断
* @arg USART_IT_TXE: Tansmit Data Register empty interrupt. //发送数据寄存器空中断
* @arg USART_IT_TC: Transmission complete interrupt. //发送完成中断
* @arg USART_IT_RXNE: Receive Data register not empty interrupt. //接收寄存器非空中断
* @arg USART_IT_IDLE: Idle line detection interrupt. //空闲线检测中断
* @arg USART_IT_PE: Parity Error interrupt. //奇偶校验错误中断
* @arg USART_IT_ERR: Error interrupt(Frame error, noise error, overrun error) //错误中断
* @param NewState: new state of the specified USARTx interrupts.
* This parameter can be: ENABLE or DISABLE.
* @retval None
首先把数据手册的这部分内容贴出来
Character transmission procedure
1. Program the M bits in USARTx_CR1 to define the word length.
2. Select the desired baud rate using the USARTx_BRR register.
3. Program the number of stop bits in USARTx_CR2.
4. Enable the USART by writing the UE bit in USARTx_CR1 register to 1.
5. Select DMA enable (DMAT) in USARTx_CR3 if Multi buffer Communication is to take
place. Configure the DMA register as explained in multibuffer communication.
6. Set the TE bit in USARTx_CR1 to send an idle frame as first transmission.
7. Write the data to send in the USARTx_TDR register (this clears the TXE bit). Repeat
this for each data to be transmitted in case of single buffer.
8. After writing the last data into the USARTx_TDR register, wait until TC=1. This
indicates that the transmission of the last frame is complete. This is required for
instance when the USART is disabled or enters the Halt mode to avoid corrupting the
last transmission.
字符传输过程
1。方案中USARTx_CR1的M位来定义字长。
2。选择所需的波特率使用USARTx_BRR寄存器。
3。计划在USARTx_CR2停止位的数目。
4。通过写寄存器1 USARTx_CR1在UE位使能USART的。
5。选择DMA使能(DMAT)在USARTx_CR3如果多缓冲器通信是采取
地方。配置DMA寄存器在多缓冲器通信解释。
6。设置在USARTx_CR1的TE位发送空闲帧作为第一次传输。
7。写入要发送的数据在USARTx_TDR寄存器(这将清除TXE位)。重复
这对每个数据进行的情况下单个缓冲器的传输。
8。写在最后一个数据到USARTx_TDR寄存器后,等到TC=1。这
表示最后帧的传输完成。这是必需的
例如当USART被禁用或进入暂停模式,以避免破坏
最后一次传输。
STM32串口发送数据详解 - 大海 - 大海的博客
首先仔细看看这个发送的数据时序图。
发现,USART_TDR没有数据的时候,也就是空,TXE会被置位,当往USART_TDR写数据的时候,TXE低
列出TXE,TCflag变化的条件
TXE:只要USART_TDR没有数据就被置位
TCflag:只有TXline数据全部发送出去才会中断。
发送过程:往USART_TDR里面写数据->TXline往外发送。
也就是TCflag置位会晚于TXEflag一个字符的时间。
字符传输过程
(转)
1、 使能串口发送TE,此时USART_DR为空,此时应查询TXE是否置1,TXE置1,TX脚先发送一个空闲帧,把F1帧写入USART_DR,TXE被清零。因为这时正在发送空闲帧,所以写入USART_DR的数据被放入TDR寄存器,还没有拷贝到移位寄存器。
2、 在空闲帧发送完后,TDR寄存器中的数据被拷贝到移位寄存器,此时应查询TXE是否置1,TXE置1,表示TDR已空,可以放入下一个数据。此时在TX脚上将会发送F1帧的数据,同时软件把F2帧的数据写入USART_DR,TXE被清零。
3、 在F1帧的停止位发送完后,因为TDR寄存器中的F2还没被拷入移位寄存器,所以此时TXE仍为0,TC不置1.此时应查询TXE是否置1,TXE置1,表示TDR已空,可以放入下一个数据。此时在TX脚上将会发送F2帧的数据,同时软件把F3帧的数据写入USART_DR,TXE被清零。
4、 在F2帧的停止位发送完后,因为TDR寄存器中的F3还没被拷入移位寄存器,所以此时TXE仍为0,TC不置1.此时应查询TXE是否置1,TXE置1,表示TDR已空,后面没有数据写入USART_DR,TXE保持高电平,此时在TX脚上将会发送F3帧的数据。
5、 在F3帧的停止位发送完后,因为此时TXE为1,所以TC标志会置1.如果TCIE为1,将会产生中断。
串口发送注意几点:
1、 如果正在发送数据,写数据进USART_DR将会把数据写到TDR缓冲寄存器,在本次发送完成后,再把TDR中的数据拷贝进移位寄存器。
2、 如果当前没有发送数据,写数据进USART_DR将会把数据直接放到移位寄存器,不经过TDR,TXE被清零,然后发送开始,TXE被硬件置1。
3、 只有当一帧数据的停止位发送完成并且TXE为1,TC才会被置1
关键字:STM32  串口  发送数据
编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/article_2016101030298.html
上一篇:STM32配置时钟时注意设置FLASH等待周期
下一篇:STM32几种启动文件理解
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
STM32解决:st-link连接下载程序的问题
STM32解决:Error: Flash Download failed - "Cortex-M3"本人由于使用普中科技的stm32 的开发板的 USB的下载的地方坏了,所以不得不使用arm仿真器 st-link 进行下载。鼓捣了半天下面总结一下几个问题:1、st-link的驱动下载首先你插上st-link的时候,电脑的设备管理器这个地方是有感叹号的,说明还没有装好驱动,所以我就在网上找啊找。终于根据:win8【笔者没这个系统,无法测试,请大家测试后报告】:http://pan.baidu.com/s/1sjJQxZn(转载来自:https://blog.csdn.net/imxiangzi/article
发表于 2019-07-19
解决stm32f103通过stlink不能烧录程序问题
问题:   stm32(stm32f103c8T6)开发板只能通过串口烧录程序,而st—link居然不行描述:解决:st-link固件升级用stm32cubemx快速开发时没有配置好调试模式重新生成代码就可以了如果还是不行的话,就得升级一下stlink固件了,具体升级方法可百度
发表于 2019-07-19
STM32下载不成功问题汇总
在某宝上买了五个最小系统核心板是STM32F103C8T6的芯片,刚拿到手准备下载程序调试,上电后板子自带LED闪烁,这是商家自己下载的示例程序,说明芯片工作着,用KEIL4进行下载自己程序,把自己编译好的程序下载。用的JLINK的四线下载调试下载口,SW的调试接口,点击下载后发现擦除成功,下载失败,提示:Load "..\Output\STM32-DEMO.axf" Set JLink Project File to "F:文件RFID程序电机USERJLinkSettings.ini"* JLink Info: Device "STM32
发表于 2019-07-19
STM32下载不成功问题汇总
STM32高级开发(11)-使用GDB调试你的工程
/scripts/target/stm32f4x_stlink.cfg在执行完此条指令后该终端就会一直执行OpenOCD的程序了,不要关闭它,我们再打开一个终端界面,进入我们的工程目录,比如我这里进入的就是我的libopencm3样例工程下的blink子工程目录。$ cd '/home/yangliu/workspace/libopencm3-my-example/blink'然后我们使用指令输入调试文件并打开GDB程序。$ arm-none-eabi-gdb blink.elf 然后我们在GDB的指令界面中,输入连接指令,连接本地的3333端口。(gdb)target remote localhost:3333此时
发表于 2019-07-19
STM32F4标准外设库模板工程建立与使用
SW4STM32安装其实固件库安装过程很简单,在第一次新建工程时会提示选择使用Stdperiph 驱动还是Cube HAL,由于Stm32官方大力推行Cube HAL固件库,所以Cube HAL的固件库直接可以从网上直接一键下载安装。然而对于老的StdPeriph固件库不能一键式下载安装,会提示出错。所以,我们需要自己下载一个.zip固件包,放在C:UsersLYAppDataRoamingAc6SW4STM32firmwares文件夹下,其中的LY就是计算机的用户名。然后新建工程时在选择Stdperiph固件时会自动解压缩,这样就能使用该库进行编译了。界面如下所示:工程配置器件与时钟或者,修改晶振与时钟,根据注释可以算得
发表于 2019-07-19
基于STM32的外设的GPIO外设设置总结
1、背景外设驱动的寄存器设置对于外设功能正常运行异常重要。现在对GPIO的配置进行总结。2、GPIO的配置总结复用GPIO配置GPIO设置为输出或者是复用模式时,需要设置输出速度;而无论设置为什么模式,都要对GPIO的内部上下拉进行设置。注意:在输入模式(普通输入/模拟输入)下,OTYPE和OSPEED参数无效!!
发表于 2019-07-19
小广播
何立民专栏
单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
