datasheet
STM32 RCC实验MCO脚输出时钟波形
2016-10-10来源: eefocus关键字:STM32  RCC实  MCO脚  时钟波形
一:rcc设置使用内部HSI时钟,SYSclk 64M    MCO输出32M
1:
void RCC_Configuration(void)
  ErrorStatus HSEStartUpStatus;
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();     //??RCC?????÷?è?????±????
  /* Enable HSE */
  //RCC_HSEConfig(RCC_HSE_ON);    //?è???????????§??
RCC_HSEConfig(RCC_HSE_OFF);
RCC_HSICmd(ENABLE);                        //??????
  //RCC_HSICmd(DISABLE);                        //??????
  /* Wait till HSE is ready */     //HSE  ?????????§??
  //HSEStartUpStatus = RCC_WaitForHSEStartUp();       //????HSE????
       while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET)
 // if(HSEStartUpStatus == SUCCESS)
    /* HCLK = SYSCLK *///?è??AHB?±??=?????±??    ?¨RCC_SYSCLK_Div1??·?????????
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK *///?è??????APB2?±??(×??ó72MHZ)
    RCC_PCLK2Config(RCC_HCLK_Div1);    //RCC_HCLK_Div1   ??·?????RCC_HCLK_Div2  2·???
    /* PCLK1 = HCLK/2 *///?è??????APB1?±???¨×??ó36MHZ??
    RCC_PCLK1Config(RCC_HCLK_Div2);
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2);
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* PLLCLK = 8MHz * 9 = 72 MHz */
    //RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    //?????±????8/2=4M   4*16 = 64        hsi  =  64m  (MAX)
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2 , RCC_PLLMul_16);
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while(RCC_GetSYSCLKSource() != 0x08)
2:设置MCO引脚PA8
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP ;
 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;  // ×???????????50MHz
  GPIO_Init(GPIOA, &GPIO_InitStructure);
注意: A8引脚使用复用推挽输出模式,我使用推挽输出的时候波形没出来,推挽输出只能输出TTL,复用推挽可以输出时钟波形
3:设置MCO模式
RCC_MCOConfig(RCC_MCO_PLLCLK_Div2);  //因为端口最大50M所以要PLL    2分频
二:rcc设置使用外部HSE时钟,SYSclk 72M    MCO输出36M
只要改变RCC设置即可,其他不变
编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/article_2016101030303.html
上一篇:STM32输入捕获,实现红外解码,支持长按
下一篇:STM32中断优先级理解及先占优先级和从优先级
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
STM32解决:st-link连接下载程序的问题
STM32解决:Error: Flash Download failed - "Cortex-M3"本人由于使用普中科技的stm32 的开发板的 USB的下载的地方坏了,所以不得不使用arm仿真器 st-link 进行下载。鼓捣了半天下面总结一下几个问题:1、st-link的驱动下载首先你插上st-link的时候,电脑的设备管理器这个地方是有感叹号的,说明还没有装好驱动,所以我就在网上找啊找。终于根据:win8【笔者没这个系统,无法测试,请大家测试后报告】:http://pan.baidu.com/s/1sjJQxZn(转载来自:https://blog.csdn.net/imxiangzi/article
发表于 2019-07-19
解决stm32f103通过stlink不能烧录程序问题
问题:   stm32(stm32f103c8T6)开发板只能通过串口烧录程序,而st—link居然不行描述:解决:st-link固件升级用stm32cubemx快速开发时没有配置好调试模式重新生成代码就可以了如果还是不行的话,就得升级一下stlink固件了,具体升级方法可百度
发表于 2019-07-19
STM32下载不成功问题汇总
在某宝上买了五个最小系统核心板是STM32F103C8T6的芯片,刚拿到手准备下载程序调试,上电后板子自带LED闪烁,这是商家自己下载的示例程序,说明芯片工作着,用KEIL4进行下载自己程序,把自己编译好的程序下载。用的JLINK的四线下载调试下载口,SW的调试接口,点击下载后发现擦除成功,下载失败,提示:Load "..\Output\STM32-DEMO.axf" Set JLink Project File to "F:文件RFID程序电机USERJLinkSettings.ini"* JLink Info: Device "STM32
发表于 2019-07-19
STM32下载不成功问题汇总
STM32高级开发(11)-使用GDB调试你的工程
/scripts/target/stm32f4x_stlink.cfg在执行完此条指令后该终端就会一直执行OpenOCD的程序了,不要关闭它,我们再打开一个终端界面,进入我们的工程目录,比如我这里进入的就是我的libopencm3样例工程下的blink子工程目录。$ cd '/home/yangliu/workspace/libopencm3-my-example/blink'然后我们使用指令输入调试文件并打开GDB程序。$ arm-none-eabi-gdb blink.elf 然后我们在GDB的指令界面中,输入连接指令,连接本地的3333端口。(gdb)target remote localhost:3333此时
发表于 2019-07-19
STM32F4标准外设库模板工程建立与使用
SW4STM32安装其实固件库安装过程很简单,在第一次新建工程时会提示选择使用Stdperiph 驱动还是Cube HAL,由于Stm32官方大力推行Cube HAL固件库,所以Cube HAL的固件库直接可以从网上直接一键下载安装。然而对于老的StdPeriph固件库不能一键式下载安装,会提示出错。所以,我们需要自己下载一个.zip固件包,放在C:UsersLYAppDataRoamingAc6SW4STM32firmwares文件夹下,其中的LY就是计算机的用户名。然后新建工程时在选择Stdperiph固件时会自动解压缩,这样就能使用该库进行编译了。界面如下所示:工程配置器件与时钟或者,修改晶振与时钟,根据注释可以算得
发表于 2019-07-19
基于STM32的外设的GPIO外设设置总结
1、背景外设驱动的寄存器设置对于外设功能正常运行异常重要。现在对GPIO的配置进行总结。2、GPIO的配置总结复用GPIO配置GPIO设置为输出或者是复用模式时,需要设置输出速度;而无论设置为什么模式,都要对GPIO的内部上下拉进行设置。注意:在输入模式(普通输入/模拟输入)下,OTYPE和OSPEED参数无效!!
发表于 2019-07-19
小广播
何立民专栏
单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
