arm 力天电子lpc2148无字库12864显示一行多个汉字(串行)
2019-05-20来源: eefocus关键字:arm  lpc2148  12864  串行
力天电子lpc2148开发板中配的12864小屏是不带字库的,并且没有所谓的左右屏,上下屏之分,是一个整屏.(是北京集粹电子设备有限公司生产的,资料详见
http://download.csdn.net/detail/yueniaoshi/4508801 此资料是12864的数据手册
http://download.csdn.net/detail/yueniaoshi/4507741 此资料介绍的12864的更进一步介绍
http://download.csdn.net/detail/yueniaoshi/4507754 此资料介绍的是驱动函数
http://download.csdn.net/detail/yueniaoshi/4507775 此资料介绍的是小小日历钟,这个里面的函数更全一点)
(再说点题外话,当初买板子的时候老板服务很周到,也很热心,问什么说什么!可是一旦板子买回来了,有些地方不懂的时候,想问问老板,就变得爱理不理了啊,美哦办法啊!谁让咱是菜鸟呢?没人说,咱就自己想办法解决吧!)
#include
//管脚宏定义
#define  SCLK 0x01<<24  //595时钟端
#define  MISO 0x01<<5   //数据输入端
#define  MOSI 0x01<<6   //数据输出端
#define  RCK  0x01<<7   //SO12864时钟输入端
//LCD Define
#define LCD_A 1<<30  //命令数据选择端,高电平:数据  低电平:命令
#define LCD_CLK 1<<4 //时钟端
#define LCD_DATA MOSI //数据端
#define B_LED   1<<13 //背光
#define Sclk_L() IO0CLR |=LCD_CLK //时钟高电平
#define Sclk_H() IO0SET |=LCD_CLK //时钟低电平
#define Res_L()  HC595_DATA &=~(1<<2);Write595() //复位低电平
#define Res_H()  HC595_DATA |=(1<<2); Write595() //复位高电平
#define Data_L() IO0CLR |=LCD_DATA //数据低电平
#define Data_H() IO0SET |=LCD_DATA //数据高电平
#define CS_L() HC595_DATA &=~1; Write595() //片选低电平
#define CS_H() HC595_DATA |=1;  Write595() //片选高电平
#define Write_C() IO0CLR |=LCD_A //选择写命令
#define Write_D() IO0SET |=LCD_A //选择写数据
#define Writecommand
//#define pgm_read_byte
//#define LcdCls
//函数声明
void Delayn(unsigned long n);
void Write595();
void HC595_Init(void);
void Lcd_Init(void);
void Lcd_display_HZ(unsigned char x,unsigned char y,unsigned char *p);
void LcdCls(unsigned char data);
void Setxy(unsigned char x,unsigned char y);
void show_string1616(unsigned char x,unsigned char y,unsigned *string,unsigned char string_lenth);
//全局变量
unsigned int HC595_DATA=0xFFFFFFFF;
unsigned int title[]={6,5,0,7,2}; //"老婆我爱你",取的值是由模中各个字所在的位置决定的
unsigned char HZ[][32]=
{{0x20,0x24,0x24,0x24,0xFE,0x23,0x22,0x20,0xFF,0x20,0x22,0xAC,0x20,0x30,0x20,0x00,
0x00,0x08,0x48,0x84,0x7F,0x02,0x21,0x10,0x09,0x06,0x1A,0x61,0x80,0xE0,0x00,0x00},  //"我"(0)
{0x00,0xFC,0xFC,0x84,0x84,0xFE,0xFE,0x14,0x90,0x10,0x10,0xFF,0xFF,0x10,0x18,0x00,
0x00,0x3F,0x1F,0x10,0x10,0x3F,0x3F,0x00,0x00,0x23,0x60,0xFF,0x7F,0x00,0x00,0x00},  //时(1)
{0x40,0x20,0xF8,0x07,0x40,0x20,0x18,0x0F,0x08,0xC8,0x08,0x08,0x28,0x18,0x00,0x00,
0x00,0x00,0xFF,0x00,0x00,0x08,0x04,0x43,0x80,0x7F,0x00,0x01,0x06,0x0C,0x00,0x00},  //"你"(2)
{0x00,0x20,0x18,0xCF,0xC7,0x44,0x44,0xFC,0xFC,0x44,0x44,0x64,0x46,0x04,0x00,0x00,
0x04,0x04,0x04,0x07,0x07,0x04,0x04,0xFF,0xFF,0x04,0x04,0x04,0x04,0x06,0x04,0x00}, //年(3)
{0x00,0x00,0x00,0x00,0xFF,0xFE,0x22,0x22,0x22,0x22,0x22,0xFF,0xFE,0x04,0x00,0x00,
0x00,0x80,0x40,0x70,0x1F,0x07,0x02,0x02,0x02,0x42,0x42,0xFF,0x7F,0x00,0x00,0x00},  //月(4)
{0x00,0x84,0xC9,0x22,0x06,0x80,0x7E,0x12,0x32,0x52,0x9F,0x52,0x32,0x0A,0x06,0x00,
0x04,0x04,0x87,0x84,0x4D,0x54,0x26,0x24,0x26,0x55,0x4C,0x85,0x06,0x06,0x04,0x00},  //"婆"(5)
{0x40,0x40,0x48,0x48,0x48,0x48,0x7F,0xC8,0x4C,0x68,0x50,0x48,0x4C,0x60,0x40,0x00,
0x40,0x20,0x10,0x08,0x04,0x7E,0x91,0x90,0x88,0x88,0x84,0x86,0x80,0xE0,0x00,0x00},  //"老"(6)
{0x40,0xB0,0x92,0x96,0x9A,0x92,0xF2,0x9E,0x92,0x91,0x99,0x95,0x91,0x50,0x30,0x00,
0x00,0x00,0x40,0x30,0x8C,0x83,0x46,0x2A,0x12,0x2A,0x26,0x42,0xC0,0x40,0x00,0x00}};//"爱"(7)
//主函数
int main(void)
  HC595_Init();                                          //初始化74HC595
  IO0DIR |=LCD_A|B_LED|LCD_CLK; //初始化IO口
  Lcd_Init();                                               //初始化液晶屏
  LcdCls(0x00);                                       //清屏
  Delayn(10000000);
  show_string1616(16,0,title,5);
  //Lcd_display_HZ(6,2,ZHONG);     //在第2页,第6列开始显示一个"钟"
  while(1); //stop
//初始化595接口
  IO0DIR |= MOSI|RCK;
  IO1DIR |= SCLK;
  IO1CLR |= SCLK;
  IO0DIR |= RCK;
  HC595_DATA =0xFFFFFFFF;Write595();
//写字节
void WriteByte(unsigned char data)
  unsigned char i;
  //IO0CLR;
  for(i=0;i<8;i++)
    if(data&0x01) IO0SET=MOSI;
    else IO0CLR =MOSI;
    IO1SET=SCLK;
    data>>=1;
    IO1CLR=SCLK;
    //IO0SET=RCK;
 //刷新595的数据
void Write595()
  IO0CLR=RCK;
  WriteByte(HC595_DATA&0xff);
  WriteByte((HC595_DATA&0xff00)>>8);
  WriteByte((HC595_DATA&0xff0000)>>16);
  WriteByte((HC595_DATA&0xff000000)>>24);
  IO0SET=RCK;
//延时周期数
while(n--);
//向SPI总线上写一个字节的数据
void LCDWriteByte(unsigned char data)
  unsigned char i,s;
  s=data;
  for(i=0;i<8;i++)
  { //Delayn(1000000); //自己加的
    if(s&0x80) Data_H();
    else  Data_L();
    Sclk_H();
    s<<=1;
    Sclk_L();
//向液晶屏写数据
void WriteData(unsigned char Data)
  Write_D();
  CS_L();
  LCDWriteByte(Data);
  CS_H();
//向液晶屏写命令
void WriteCommand(unsigned char Command)
  Write_C();
  CS_L();
  LCDWriteByte(Command);
  CS_H();
//打开液晶背光  0:关闭 1:打开
void Lcd_BackLed(unsigned char on)
  if(on==1)
    IO0CLR=B_LED; //打开背光
  else if(on==0)
    IO0SET=B_LED; //关闭背光
//液晶复位
void Lcd_Reset(void)
  Res_L();
  Delayn(10000000);
  Res_H();
//列顺序翻转,左右翻转 0:正常 1:翻转
void Lcd_ColRev(unsigned char i)
  WriteCommand(0xa0|(i&0x01));
//清屏
  unsigned char i,j;
  for(i=0;i<9;i++)
    Setxy(0,i);
    for(j=0;j<128;j++)
      WriteData(data);
//液晶初始化
void Lcd_Init(void)
  Lcd_Reset();                 //液晶复位
  //Lcd_BackLed(0);
  Lcd_BackLed(1);          //打开液晶背光
  WriteCommand(0xaf); //打开显示
  WriteCommand(0x40); //指定显示RAM的行地址,起始行为:0然后63,62,....2,1依次减小
  WriteCommand(0xa1); //ADC正常???
  WriteCommand(0xa6); //没有反白,正常显示
  WriteCommand(0xa4); //全屏显示
  WriteCommand(0xa2); //设置LCD的偏压比
  WriteCommand(0xc0); //正常:意思是下端为0,往上依次为63,62....
  WriteCommand(0x2f); //电源设置
  WriteCommand(0x24); //粗调对比度
  WriteCommand(0x81); //
  WriteCommand(0x24); //跟上一行一起相当于细调对比度
  Lcd_ColRev(1);     //左右翻转
//选择列x,页y
  unsigned char tmp=0;
  y=y&0x0F;    //把页号变换为0XB0……0XB7的页定位码
  y=y|0xb0;
  tmp=x;
  tmp>>=4;     //变换出列号的定位码高低4位
  tmp|=0x10;
  x&=0x0F;
  WriteCommand(y);  //写页定位码
  WriteCommand(tmp);//写列定位码(高)
  WriteCommand(x);  //写列定位码(低)
//显示汉字 x是列,y是页,p指向字模数组
void Lcd_display_HZ(unsigned char x,unsigned char y,unsigned char *p)  //p是汉字的首地址
    unsigned char i;
    WriteCommand(0xa4);
    Setxy(x,y);      //起始列,页
    for(i=0;i<16;i++)
      WriteData(*p++);//显示上半个汉字
    y+=1;
    Setxy(x,y);     //到下页起点
    for(i=16;i<32;i++)
      WriteData(*p++); //显示下半个汉字
//16点阵字串显示string_lenth个HZ[j]
  unsigned char i,j;
  for(i=0;i
    j=*string;
    Lcd_display_HZ(x,y,HZ[j]);
    string++;
    x+=16;
    if(x>=128) //跳到下一页
      x=0;
      y+=1;
关键字:arm  lpc2148  12864  串行 编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic462261.html 本网站转载的所有的文章、图片、音频视频文件等资料的版权归版权所有人所有,本站采用的非本站原创文章及图片等内容无法一一联系确认版权者。如果本网所选内容的文章作者及编辑认为其作品不宜公开自由传播,或不应无偿使用,请及时通过电子邮件或电话通知我们,以迅速采取适当措施,避免给双方造成不必要的经济损失。
上一篇:arm 力天电子lpc2148无字库12864显示多行多个汉字(串行)
下一篇:arm力天电子 lpc2148 无字库的12864显示一个汉字(串行)
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
ARM七种异常源和异常处理流程(四大步三小步)
                                                    ARM异常处理(处理器对特定的异常事件进行的处理)的进入过程(硬件自动完成):四大步(两备份两修改)三小步:(1)拷贝 CPSR (当前程序状态寄存器current program status register)到 SPSR_<mode>(保存当前
发表于 2020-03-08
arm开发板的一些常用命令
这写记录是我经常忘记的东西:做个笔记在这里1、reboot 是重启的意思。2、source 是使那些修改的文件立即生效,避免了重启之后才能生效的问题,例如我们修改了/etc/profiile,修改之后不能立即生效。这时我们输入 source /etc/profile 就可以生效了这些以后还会继续更新。3、chmod -R 777 /home/edu/practice 设置practice文件夹里面的所有的文件权限为7774、压缩单个文件:gzip -v etc.c   生成的压缩名为:etc.c.gz5、压缩多个文件:gzip -v  *     //压缩当前目录下的所有文
发表于 2020-03-08
ARM处理器的未定义指令异常处理过程分析
在前面的两篇文章中已经介绍了ARM处理器的工作模式和ARM异常中断处理流程。这篇文章我们通过代码来详细介绍ARM处理器未定义指令的异常中断处理;当发生未定义指令异常中断时,CPU进入未定义指令模式。可以通过读取CPSR寄存器的值来判定是否真的进入了未定义指令模式。开发板:tiny4412;工具链版本:gcc version 4.5.1 (ctng-1.8.1-FA)主要设置以下几个文件:start.S文件,详细内容如下:.text.global _start_start: b reset /* vector 0x46000000 reset*/ ldr pc, _undefined_instruction
发表于 2020-03-08
【ARM裸板】启动文件与栈的简略分析
unsigned int *)0x56000054; *pGPFCON = 0x100; *pGPFDAT = 0; return 0;}3.问题函数的调用规则ATPCS:ARM-THUMB procedure call standard(ARM-Thumb过程调用标准)参考文章 Arm汇编学习笔记(六)——函数调用栈空间以及fp寄存器3.1 为什么要设置栈?因为C函数所需保存局部变量保存LR等寄存器(返回地址)调用者如何传递参数给被调用者被调用者如何传返回这给调用者怎么从栈中恢复那些寄存器调用者和被调用者通过r0-r3寄存器传递参数和返回值在函数中,r4-r11可能被使用,所以:在入口保存他们,在出口恢复他们高标号寄存器存放在高地
发表于 2020-03-08
【ARM裸板】启动文件与栈的简略分析
【ARM裸板】S3C2440 时钟设置与分析
由时钟树分析,时钟源通过选择器接入给MPLL(Main PLL)与UPLL(USB PLL)经过MPLL得到FCLK提供给CPU[ARM920T]FCLK分别通过HDIVN与PDIVN分频得到HCLK与PCLKHCLK接入给AHB总线,再给各种高速设备(Nand Flash、内存控制器、中断控制器…)PCLK接入给APB总线,再给各种低速设别(I2C、PWM、GPIO、UART…)1.时钟源最大值2.时钟源2.1 两种时钟源1.晶振2.外部引脚时钟输入2.2 选择时钟源通过改变OM[3:2]引脚来选择时钟源JZ2440 OM[3:2]接入GND,则主时钟源与USB时钟源都选择外部晶振3.上电时钟分析复位等待, 等待电源稳定
发表于 2020-03-08
【ARM裸板】内存控制器、SDRAM基础与代码重定位
1.CPU如何控制外设?CPU控制相应外设的寄存器,有外设控制器发出特定的波形2.CPU如何选择寄存器?CPU通过内存控制器选择发出地址addr根据地址选择不同的模块CPU内存控制器读写数据3.外设共用地址、数据总线,如何互不干扰?通过片选CS引脚,选择不同的外设4.谁控制片选引脚发出地址addr根据地址发出片选信号CPU内存控制器使能相应的外设由芯片手册得知:当CPU发出地址是0x00000000时 nGCS0为低电平选择(有效)5.CPU如何读写数据的方向?通过外设芯片的读写引脚控制6.CPU不同位宽设备如何连接并读取数据【内存控制器】6.1 连接方式8bit ROM (从A0开始对应连接)16bit ROM (A0不接,从A1
发表于 2020-03-06
小广播
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2020 EEWORLD.com.cn, Inc. All rights reserved
