基于STM32F407 HAL库的Flash编程操作
2019-05-24来源: eefocus关键字:STM32F407  HAL库  Flash  编程操作
flash的初始化,解锁flash和清除一些flash的异常状态标识
uint16_t MEM_If_Init_FS(void)
    HAL_FLASH_Unlock();
    __HAL_FLASH_CLEAR_FLAG(FLASH_FLAG_EOP | FLASH_FLAG_OPERR | FLASH_FLAG_WRPERR |
                          FLASH_FLAG_PGAERR | FLASH_FLAG_PGPERR | FLASH_FLAG_PGSERR);
uint16_t MEM_If_DeInit_FS(void)
    HAL_FLASH_Lock();
flash 的檫除操作
uint16_t MEM_If_Erase_FS(uint32_t start_Add,uint32_t end_Add)
    /* USER CODE BEGIN 3 */
    uint32_t UserStartSector;
    uint32_t SectorError;
    FLASH_EraseInitTypeDef pEraseInit;
    /* Unlock the Flash to enable the flash control register access *************/
    MEM_If_Init_FS();
    /* Get the sector where start the user flash area */
    UserStartSector = GetSector(start_Add);
    pEraseInit.TypeErase = TYPEERASE_SECTORS;
    pEraseInit.Sector = UserStartSector;
    pEraseInit.NbSectors = GetSector(end_Add)-UserStartSector+1 ;
    pEraseInit.VoltageRange = VOLTAGE_RANGE_3;
    if (HAL_FLASHEx_Erase(&pEraseInit, &SectorError) != HAL_OK)
        /* Error occurred while page erase */
        return (1);
    return (USBD_OK);
    /* USER CODE END 3 */
擦除操作,先解锁,然后清空所需flash所在sector。注意这里的sector使用GetSector()函数获取的,是一个整型数字(对于F4就是0~11)。
其中的NbSectors是需要清除的sector的个数。
下面是获取sector的编号
我们先按照用户手册上写的在文件usbd_dfu_if.h中define一些需要用到的sector起始地址
#define ADDR_FLASH_SECTOR_0     ((uint32_t)0x08000000) /* Base @ of Sector 0, 16 Kbyte */
#define ADDR_FLASH_SECTOR_1     ((uint32_t)0x08004000) /* Base @ of Sector 1, 16 Kbyte */
#define ADDR_FLASH_SECTOR_2     ((uint32_t)0x08008000) /* Base @ of Sector 2, 16 Kbyte */
#define ADDR_FLASH_SECTOR_3     ((uint32_t)0x0800C000) /* Base @ of Sector 3, 16 Kbyte */
#define ADDR_FLASH_SECTOR_4     ((uint32_t)0x08010000) /* Base @ of Sector 4, 64 Kbyte */
#define ADDR_FLASH_SECTOR_5     ((uint32_t)0x08020000) /* Base @ of Sector 5, 128 Kbyte */
#define ADDR_FLASH_SECTOR_6     ((uint32_t)0x08040000) /* Base @ of Sector 6, 128 Kbyte */
#define ADDR_FLASH_SECTOR_7     ((uint32_t)0x08060000) /* Base @ of Sector 7, 128 Kbyte */
#define ADDR_FLASH_SECTOR_8     ((uint32_t)0x08080000) /* Base @ of Sector 8, 128 Kbyte */
#define ADDR_FLASH_SECTOR_9     ((uint32_t)0x080A0000) /* Base @ of Sector 9, 128 Kbyte */
#define ADDR_FLASH_SECTOR_10    ((uint32_t)0x080C0000) /* Base @ of Sector 10, 128 Kbyte */
#define ADDR_FLASH_SECTOR_11    ((uint32_t)0x080E0000) /* Base @ of Sector 11, 128 Kbyte */
再在usbd_dfu_if.c文件末尾添加函数:
  * @brief  Gets the sector of a given address
  * @param  Address: Flash address
  * @retval The sector of a given address
static uint32_t GetSector(uint32_t Address)
  uint32_t sector = 0;
  if((Address < ADDR_FLASH_SECTOR_1) && (Address >= ADDR_FLASH_SECTOR_0))
    sector = FLASH_SECTOR_0;
  else if((Address < ADDR_FLASH_SECTOR_2) && (Address >= ADDR_FLASH_SECTOR_1))
    sector = FLASH_SECTOR_1;
  else if((Address < ADDR_FLASH_SECTOR_3) && (Address >= ADDR_FLASH_SECTOR_2))
    sector = FLASH_SECTOR_2;
  else if((Address < ADDR_FLASH_SECTOR_4) && (Address >= ADDR_FLASH_SECTOR_3))
    sector = FLASH_SECTOR_3;
  else if((Address < ADDR_FLASH_SECTOR_5) && (Address >= ADDR_FLASH_SECTOR_4))
    sector = FLASH_SECTOR_4;
  else if((Address < ADDR_FLASH_SECTOR_6) && (Address >= ADDR_FLASH_SECTOR_5))
    sector = FLASH_SECTOR_5;
  else if((Address < ADDR_FLASH_SECTOR_7) && (Address >= ADDR_FLASH_SECTOR_6))
    sector = FLASH_SECTOR_6;
  else if((Address < ADDR_FLASH_SECTOR_8) && (Address >= ADDR_FLASH_SECTOR_7))
    sector = FLASH_SECTOR_7;
  else if((Address < ADDR_FLASH_SECTOR_9) && (Address >= ADDR_FLASH_SECTOR_8))
    sector = FLASH_SECTOR_8;
  else if((Address < ADDR_FLASH_SECTOR_10) && (Address >= ADDR_FLASH_SECTOR_9))
    sector = FLASH_SECTOR_9;
  else if((Address < ADDR_FLASH_SECTOR_11) && (Address >= ADDR_FLASH_SECTOR_10))
    sector = FLASH_SECTOR_10;
  else
    sector = FLASH_SECTOR_11;
  return sector;
flash写入操作
uint16_t MEM_If_Write_FS(uint8_t *src, uint8_t *dest, uint32_t Len)
    uint32_t i = 0;
    for(i = 0; i < Len; i+=4)
        /* Device voltage range supposed to be [2.7V to 3.6V], the operation will
           be done by byte */
        if(HAL_FLASH_Program(FLASH_TYPEPROGRAM_WORD, (uint32_t)(dest+i), *(uint32_t*)(src+i)) == HAL_OK)
            /* Check the written value */
            if(*(uint32_t *)(src + i) != *(uint32_t*)(dest+i))
                /* Flash content doesn't match SRAM content */
                return 2;
        else
            /* Error occurred while writing data in Flash memory */
            return 1;
    return (HAL_OK);
flash读出操作
uint8_t *MEM_If_Read_FS (uint8_t *src, uint8_t *dest, uint32_t Len)
    /* Return a valid address to avoid HardFault */
    /* USER CODE BEGIN 4 */
    uint32_t i = 0;
    uint8_t *psrc = src;
    for(i = 0; i < Len; i++)
        dest[i] = *psrc++;
    return HAL_OK;
    /* USER CODE END 4 */
关键字:STM32F407  HAL库  Flash  编程操作 编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic462830.html 本网站转载的所有的文章、图片、音频视频文件等资料的版权归版权所有人所有,本站采用的非本站原创文章及图片等内容无法一一联系确认版权者。如果本网所选内容的文章作者及编辑认为其作品不宜公开自由传播,或不应无偿使用,请及时通过电子邮件或电话通知我们,以迅速采取适当措施,避免给双方造成不必要的经济损失。
上一篇:IAR中设置了中断向量偏移时进行仿真的注意事项
下一篇:STM32F407各定时器的时钟频率
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
STM32F0 ADC学习
开始时候使用的是stdlib的库,最近发现cube库用的越来越广泛了,遂开始使用cube库来完成ADC的多通道采集实验。ADC 的driver 在STM32F0XX_HAL_DRIVER当中,有stm32f0xx_hal_adc.c文件中,我们可以在stm32f0xx_hal_conf.h中开启 宏定义 ADC 模块。ADC有三种工作模式,polling interruptDMA我这里使用了polling的方式来获取多通道的数据。首先是要声明两个参数设置的结构体ADC_HandleTypeDef             AdcHandle
发表于 2019-10-09
STM32F030 使用内部时钟和外部时钟
p;  /* Wait till PLL is ready */  while((RCC->CR & RCC_CR_PLLRDY) == 0)  {  }   /* Select PLL as system clock source */  RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));  RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;       /* Wait till PLL is
发表于 2019-10-09
STM32F030F4P6单片机由外部时钟改为内部时钟的步骤
一.看程序运行的时候初始化时钟部分: 二.查看systeminit定义如下: 这就是打开的函数内容这就是使用外部时钟的配置,也就是库函数的默认配置):static void SetSysClock(void){  __IO uint32_t StartUpCounter = 0, HSEStatus = 0;    /* SYSCLK, HCLK, PCLK configuration ----------------------------------------*//* Enable HSE */ //打开外部时钟开关&nbs
发表于 2019-10-09
STM32F4(Flash读保护)
1,目的在实际的产品发布中,如果不对储存在单片机Flash中的程序做一些保护的话,就有可能被一些不法公司,通过仿真器(J-Link,ST-Link等)把Flash中的程序读取回来,得到bin文件或hex文件,然后去山寨产品。所以我们需要对程序进行保护,一种比较简单可靠的方法就是把Flash设置成读保护。2,开发环境1,适用芯片:STM32F4全部芯片2,固件库:STM32F4xx_DSP_StdPeriph_Lib_V1.8.03,IDE:MDK5173,程序源码/**************************************************************** * Function
发表于 2019-10-09
stm32F103 DMA通道
发表于 2019-10-09
stm32F103 DMA通道
小广播
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
