STM32F4系统时钟设置之二
2019-06-13来源: eefocus关键字:STM32F4  系统时钟  设置
STM32F407系统时钟配置
时钟树
方法一,采用官方库提供的配置(这里外部晶振25MHz,系统配置为168MHz)
STM32F4启动与STM32F10X不同,时钟已经默认配置好
启动代码,文件:startup_stm32f4xx.s
Reset handler
Reset_Handler    PROC
                 EXPORT  Reset_Handler             [WEAK]
        IMPORT  SystemInit
        IMPORT  __main
                 LDR     R0, =SystemInit
                 BLX     R0
                 LDR     R0, =__main
                 BX      R0
                 ENDP
可以看出,在进入main函数之前,系统调用了SystemInit函数.
SystemInit函数分析:SystemInit函数位于system_stm32f4xx.c文件中.此文件提供几个宏定义可以设置各个时钟:
/************************* PLL Parameters *************************************/
/* PLL_VCO = (HSE_VALUE or HSI_VALUE / PLL_M) * PLL_N */
#define PLL_M      25
#define PLL_N      336
/* SYSCLK = PLL_VCO / PLL_P */
#define PLL_P      2
/* USB OTG FS, SDIO and RNG Clock =  PLL_VCO / PLLQ */
#define PLL_Q      7
而晶振频率则是在文件stm32f4xx.h中进行设置:
外部晶振:
#if !defined  (HSE_VALUE)
  #define HSE_VALUE    ((uint32_t)25000000) /*!< Value of the External oscillator in Hz */
#endif /* HSE_VALUE */
内部晶振:
#if !defined  (HSI_VALUE)
  #define HSI_VALUE    ((uint32_t)16000000) /*!< Value of the Internal oscillator in Hz*/
#endif /* HSI_VALUE */
综上,可以得出默认配置中:
锁相环压腔振荡器时钟PLL_VCO = 25 / 25 * 336 = 336MHz
系统时钟SYSCLK = 336 / 2 = 168MHz
USB,SD卡时钟 = 336 / 7 = 48MHz
SystemInit函数代码:
  * @brief  Setup the microcontroller system
  *         Initialize the Embedded Flash Interface, the PLL and update the
  *         SystemFrequency variable.
  * @param  None
  * @retval None
void SystemInit(void)
  /* FPU settings ------------------------------------------------------------*/
  #if (__FPU_PRESENT == 1) && (__FPU_USED == 1)
    SCB->CPACR |= ((3UL << 10*2)|(3UL << 11*2));  /* set CP10 and CP11 Full Access */
  #endif
  /* Reset the RCC clock configuration to the default reset state ------------*/
  /* Set HSION bit */
  RCC->CR |= (uint32_t)0x00000001;
  /* Reset CFGR register */
  RCC->CFGR = 0x00000000;
  /* Reset HSEON, CSSON and PLLON bits */
  RCC->CR &= (uint32_t)0xFEF6FFFF;
  /* Reset PLLCFGR register */
  RCC->PLLCFGR = 0x24003010;
  /* Reset HSEBYP bit */
  RCC->CR &= (uint32_t)0xFFFBFFFF;
  /* Disable all interrupts */
  RCC->CIR = 0x00000000;
#ifdef DATA_IN_ExtSRAM
  SystemInit_ExtMemCtl();
#endif /* DATA_IN_ExtSRAM */
  /* Configure the System clock source, PLL Multiplier and Divider factors,
     AHB/APBx prescalers and Flash settings ----------------------------------*/
  SetSysClock();
  /* Configure the Vector Table location add offset address ------------------*/
#ifdef VECT_TAB_SRAM
  SCB->VTOR = SRAM_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal SRAM */
#else
  SCB->VTOR = FLASH_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal FLASH */
#endif
SetSysClock函数分析,在SetSysClock函数中,配置了系统时钟,PLL倍频以及分频系数:
  * @brief  Configures the System clock source, PLL Multiplier and Divider factors,
  *         AHB/APBx prescalers and Flash settings
  * @Note   This function should be called only once the RCC clock configuration
  *         is reset to the default reset state (done in SystemInit() function).
  * @param  None
  * @retval None
static void SetSysClock(void)
/*            PLL (clocked by HSE) used as System clock source                */
  __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
  /* Enable HSE */
  RCC->CR |= ((uint32_t)RCC_CR_HSEON);
  /* Wait till HSE is ready and if Time out is reached exit */
  do
    HSEStatus = RCC->CR & RCC_CR_HSERDY;
    StartUpCounter++;
  } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
  if ((RCC->CR & RCC_CR_HSERDY) != RESET)
    HSEStatus = (uint32_t)0x01;
  else
    HSEStatus = (uint32_t)0x00;
  if (HSEStatus == (uint32_t)0x01)
    /* Select regulator voltage output Scale 1 mode, System frequency up to 168 MHz */
    RCC->APB1ENR |= RCC_APB1ENR_PWREN;
    PWR->CR |= PWR_CR_VOS;
    /* HCLK = SYSCLK / 1*/
    RCC->CFGR |= RCC_CFGR_HPRE_DIV1;
    /* PCLK2 = HCLK / 2*/
    RCC->CFGR |= RCC_CFGR_PPRE2_DIV2;
    /* PCLK1 = HCLK / 4*/
    RCC->CFGR |= RCC_CFGR_PPRE1_DIV4;
    /* Configure the main PLL */
    RCC->PLLCFGR = PLL_M | (PLL_N << 6) | (((PLL_P >> 1) -1) << 16) |   (RCC_PLLCFGR_PLLSRC_HSE) | (PLL_Q << 24);
    /* Enable the main PLL */
    RCC->CR |= RCC_CR_PLLON;
    /* Wait till the main PLL is ready */
    while((RCC->CR & RCC_CR_PLLRDY) == 0)
    /* Configure Flash prefetch, Instruction cache, Data cache and wait state */
    FLASH->ACR = FLASH_ACR_ICEN |FLASH_ACR_DCEN |FLASH_ACR_LATENCY_5WS;
    /* Select the main PLL as system clock source */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
    RCC->CFGR |= RCC_CFGR_SW_PLL;
    /* Wait till the main PLL is used as system clock source */
    while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS ) != RCC_CFGR_SWS_PLL);
  else
  /* If HSE fails to startup, the application will have wrong clock configuration. User can add here some code to deal with this error */
如果外部时钟启动失败,系统会使用内部时钟
默认配置:
HCLK = SYSCLK / 1 = 168MHz
PCLK2 = HCLK / 2 = 84MHz
PCLK1 = HCLK / 4 = 42MHz
方法二,根据需要重新进行配置(这里外部晶振25MHz,系统配置为168MHz)
自己根据自己外部晶振大小和需要进行配置
void RCC_Config(void)
    RCC_DeInit();    //RCC寄存器初始化
    RCC_HSEConfig(RCC_HSE_ON);    //使用外部时钟
    if(RCC_WaitForHseStartUp() == SUCCESS)     //等待外部时钟启动
        RCC_PLLCmd(DISABLE);    //配置PLL前应先关闭主PLL
        RCC_SYSCLKConfig(RCC_SYSCLKSOURCE_PLLCLK);    //选择PLL时钟为系统时钟
        RCC_HCLKConfig(RCC_SYSCLK_Div1);    //HCLK(AHB)时钟为系统时钟1分频
        RCC_PCLK1Config(RCC_HCLK_Div4);    //PCLK(APB1)时钟为HCLK时钟8分频
        RCC_PCLK2Config(RCC_HCLK_Div2);    //PCLK(APB2)时钟为HCLK时钟2分频
        RCC_PLLConfig(RCC_PLLSource_HSE,25,336,2,7);    //PLL时钟配置,外部晶振为25MHz,系统配置为168MHz
        RCC_PLLCmd(ENABLE);    //PLL时钟开启
while(RCC_GetFlagStatus(RCC_FLAG_PLLRD
[1] [2]
关键字:STM32F4  系统时钟  设置
编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic464497.html
上一篇:STM32软件复位的实现方法
下一篇:STM32F407时钟设置
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
第38章 I2S—音频播放与录音输入—零死角玩转STM32-F429系列
本章参考资料:《STM32F4xx 中文参考手册》、《STM32F4xx规格书》、库帮助文档《stm32f4xx_dsp_stdperiph_lib_um.chm》及《I2S BUS》。若对I2S通讯协议不了解,可先阅读《I2S BUS》文档的内容学习。关于音频编译码器WM8978,请参考其规格书《WM8978_v4.5》来了解。38.1 I2S简介Inter-IC Sount Bus(I2S)是飞利浦半导体公司(现为恩智浦半导体公司)针对数字音频设备之间的音频数据传输而制定的一种总线标准。在飞利浦公司的I2S标准中,既规定了硬件接口规范,也规定了数字音频数据的格式。38.1.1 数字音频技术现实生活中的声音是通过一定介质传播
发表于 2019-09-19
第50章 读写内部FLASH—零死角玩转STM32-F429系列
本章参考资料:《STM32F4xx 中文参考手册》、《STM32F4xx规格书》、库说明文档《stm32f4xx_dsp_stdperiph_lib_um.chm》。50.1 STM32的内部FLASH简介在STM32芯片内部有一个FLASH存储器,它主要用于存储代码,我们在电脑上编写好应用程序后,使用下载器把编译后的代码文件烧录到该内部FLASH中,由于FLASH存储器的内容在掉电后不会丢失,芯片重新上电复位后,内核可从内部FLASH中加载代码并运行,见图 501。图 501 STM32的内部框架图除了使用外部的工具(如下载器)读写内部FLASH外,STM32芯片在运行的时候,也能对自身的内部FLASH进行读写
发表于 2019-09-19
第49章 在SRAM中调试代码—零死角玩转STM32-F429系列
本章参考资料:《STM32F4xx 中文参考手册》、《STM32F4xx规格书》、《Cortex-M3权威指南》、《Cortex-M4 Technical Reference Manual》(跟M3大部分是相同的,读英文不习惯可先参考《Cortex-M3权威指南》)。学习本章时,配合《STM32F4xx 中文参考手册》"存储器和总线结构"及"嵌入式FLASH接口"章节一起阅读,效果会更佳,特别是涉及到寄存器说明的部分。49.1 在RAM中调试代码一般情况下,我们在MDK中编写工程应用后,调试时都是把程序下载到芯片的内部FLASH运行测试的,代码的CODE及RW-data的内容被写入
发表于 2019-09-19
第48章 MDK的编译过程及文件类型全解—零死角玩转STM32-F429
;bsp_led.c"文件中有一个LED_GPIO_Config函数,而它内部调用了"stm32f4xx_gpio.c"的GPIO_Init函数,经过armcc编译后,LED_GPIO_Config及GPIO_Iint函数都成了指令代码,分别存储在bsp_led.o及stm32f4xx_gpio.o文件中,这些指令在*.o文件都没有指定地址,仅包含了内容、大小以及调用的链接信息,而经过链接器后,链接器给它们都分配了特定的地址,并且把地址根据调用指向链接起来。图 4832 具体的链接过程ELF文件头接下来我们看看具体文件的内容,使用fromelf文件可以查看*.o、*.axf及*.lib文件的ELF信息。使用命令行,切换
发表于 2019-09-19
第47章 QR-Decoder-OV5640二维码识别—零死角玩转STM32-F429系列
本章参考资料:《STM32F4xx 中文参考手册》、《STM32F4xx规格书》、库帮助文档《stm32f4xx_dsp_stdperiph_lib_um.chm》。关于开发板配套的OV5640摄像头参数可查阅《ov5640datasheet》配套资料获知。STM32F4芯片具有浮点运算单元,适合对图像信息使用DSP进行基本的图像处理,其处理速度比传统的8、16位机快得多,而且它还具有与摄像头通讯的专用DCMI接口,所以使用它驱动摄像头采集图像信息并进行基本的加工处理非常适合。本章讲解如何使用二维码识别库进行二维码的识别。47.1 二维码简介二维码,又称二维条码或二维条形码,二维条码是用某种特定的几何图形按一定规律在平面(二维方向
发表于 2019-09-19
第44章 MPU6050传感器—姿态检测—零死角玩转STM32-F429系列
本章参考数据:《STM32F4xx参考手册》、《STM32F4xx规格书》、库说明文档《stm32f4xx_dsp_stdperiph_lib_um.chm》。关于MPU6050的参考资料:《MPU-60X0寄存器》、《MPU6050数据手册》以及官方驱动《motion_driver_6.12》。本章讲解的内容跨领域的知识较多,若您感兴趣,请自行查阅各方面的资料,对比学习。44.1 姿态检测1.    基本认识在飞行器中,飞行姿态是非常重要的参数,见图 441,以飞机自身的中心建立坐标系,当飞机绕坐标轴旋转的时候,会分别影响偏航角、横滚角及俯仰角。图 441 表示飞机姿态的偏航角、横滚角及俯仰角假如我们知道飞机
发表于 2019-09-19
小广播
何立民专栏
单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
