datasheet
STM32小白入门(第11天)-------SPI协议
2019-07-10来源: eefocus关键字:STM32  SPI协议
一、定义
二、单机与多机通信
1、多机通信
2、单机通信
三、通信细节与过程
2、硬件原理图
uint16_t w25qxx_read_id(void){
uint16_t id=0;//片选引脚拉低W25QXX_SS=0;//发送0x90SPI1_SendByte(0x90);//发送24bit的地址,全为0SPI1_SendByte(0x00);SPI1_SendByte(0x00);SPI1_SendByte(0x00);//读取厂商id,参数可以为任意参数id = SPI1_SendByte(0xFF)<<8;//读取设备idid|= SPI1_SendByte(0xFF);//片选引脚拉高W25QXX_SS=1;return id;}
三、模拟SPI
在有些情况下没有硬件SPI的支持,只能通过IO口来模拟SPI时序图,参考代码如下:
uint8_t SPI1_SendByte(uint8_t byte)
uint32_t i=0;
uint8_t d=0;
for(i=0; i<8; i++)
//MSB,最高有效位发送数据
if(byte & (1<<(7-i)))
W25QXX_MOSI =1;
else
W25QXX_MOSI =0;
//设置SCLK引脚为低电平,这个时候,从机会开始读取MOSI引脚电平
W25QXX_SCLK=0;
delay_us(2);
//由于是同步事件,这个时候,从机通过MISO引脚已经输出数据给主机,主机可以读取MISO引脚电平值
if(W25QXX_MISO)
d|=1<<(7-i);
//设置SCLK引脚为高电平,告诉从机,我已经读物MISO引脚电平完毕
W25QXX_SCLK=1;
delay_us(2);
return d;
//SPI3初始化
void STM32_SPI3_Init(void)
GPIO_InitTypeDef  GPIO_InitStructure;
/*!< Enable GPIO clocks */
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC,ENABLE);
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD,ENABLE);
//SPI3 pins: MOSI=PC6 Reset PC11
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_6|GPIO_Pin_11;
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_OUT;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_UP;
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_100MHz;
GPIO_Init(GPIOC,&GPIO_InitStructure);
//SPI3 pins: SCK=PD7  MISO=PD6
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_6|GPIO_Pin_7;
GPIO_Init(GPIOD,&GPIO_InitStructure);
/* 配置MISO=PC8引脚为输入模式,*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_Init(GPIOC, &GPIO_InitStructure);
MFRC522_NSS = 1;  //片选置高电平
/*!< Deselect the FLASH: Chip Select high ,由于M4芯片还没有真正开始跟从机工作,先让片选引脚为高电平*/
MFRC522_SCLK = 1;    //启动SP3
//发与收
u8 SPI3_Send(u8 byte)
  uint32_t i=0;
  uint8_t d=0;
  for(i=0; i<8; i++)
      MFRC522_MOSI=1;
    else
      MFRC522_MOSI=0;
    MFRC522_SCLK=0;
    Delay1_us(1);
    if(MFRC522_MISO)
      d|=1<<(7-i);
    //设置SCLK引脚为高电平,告诉从机,我已经读取MISO引脚电平完毕
    MFRC522_SCLK=1;
    Delay1_us(1);
  return d;
关键字:STM32  SPI协议
编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic467310.html
上一篇:STM32小白入门(第13天)-------RTC实时时钟和闹钟事件
下一篇:STM32小白入门(第十天)-------看门狗watchdog
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
STM32解决:st-link连接下载程序的问题
STM32解决:Error: Flash Download failed - "Cortex-M3"本人由于使用普中科技的stm32 的开发板的 USB的下载的地方坏了,所以不得不使用arm仿真器 st-link 进行下载。鼓捣了半天下面总结一下几个问题:1、st-link的驱动下载首先你插上st-link的时候,电脑的设备管理器这个地方是有感叹号的,说明还没有装好驱动,所以我就在网上找啊找。终于根据:win8【笔者没这个系统,无法测试,请大家测试后报告】:http://pan.baidu.com/s/1sjJQxZn(转载来自:https://blog.csdn.net/imxiangzi/article
发表于 2019-07-19
解决stm32f103通过stlink不能烧录程序问题
问题:   stm32(stm32f103c8T6)开发板只能通过串口烧录程序,而st—link居然不行描述:解决:st-link固件升级用stm32cubemx快速开发时没有配置好调试模式重新生成代码就可以了如果还是不行的话,就得升级一下stlink固件了,具体升级方法可百度
发表于 2019-07-19
STM32下载不成功问题汇总
在某宝上买了五个最小系统核心板是STM32F103C8T6的芯片,刚拿到手准备下载程序调试,上电后板子自带LED闪烁,这是商家自己下载的示例程序,说明芯片工作着,用KEIL4进行下载自己程序,把自己编译好的程序下载。用的JLINK的四线下载调试下载口,SW的调试接口,点击下载后发现擦除成功,下载失败,提示:Load "..\Output\STM32-DEMO.axf" Set JLink Project File to "F:文件RFID程序电机USERJLinkSettings.ini"* JLink Info: Device "STM32
发表于 2019-07-19
STM32下载不成功问题汇总
STM32高级开发(11)-使用GDB调试你的工程
/scripts/target/stm32f4x_stlink.cfg在执行完此条指令后该终端就会一直执行OpenOCD的程序了,不要关闭它,我们再打开一个终端界面,进入我们的工程目录,比如我这里进入的就是我的libopencm3样例工程下的blink子工程目录。$ cd '/home/yangliu/workspace/libopencm3-my-example/blink'然后我们使用指令输入调试文件并打开GDB程序。$ arm-none-eabi-gdb blink.elf 然后我们在GDB的指令界面中,输入连接指令,连接本地的3333端口。(gdb)target remote localhost:3333此时
发表于 2019-07-19
STM32F4标准外设库模板工程建立与使用
SW4STM32安装其实固件库安装过程很简单,在第一次新建工程时会提示选择使用Stdperiph 驱动还是Cube HAL,由于Stm32官方大力推行Cube HAL固件库,所以Cube HAL的固件库直接可以从网上直接一键下载安装。然而对于老的StdPeriph固件库不能一键式下载安装,会提示出错。所以,我们需要自己下载一个.zip固件包,放在C:UsersLYAppDataRoamingAc6SW4STM32firmwares文件夹下,其中的LY就是计算机的用户名。然后新建工程时在选择Stdperiph固件时会自动解压缩,这样就能使用该库进行编译了。界面如下所示:工程配置器件与时钟或者,修改晶振与时钟,根据注释可以算得
发表于 2019-07-19
基于STM32的外设的GPIO外设设置总结
1、背景外设驱动的寄存器设置对于外设功能正常运行异常重要。现在对GPIO的配置进行总结。2、GPIO的配置总结复用GPIO配置GPIO设置为输出或者是复用模式时,需要设置输出速度;而无论设置为什么模式,都要对GPIO的内部上下拉进行设置。注意:在输入模式(普通输入/模拟输入)下,OTYPE和OSPEED参数无效!!
发表于 2019-07-19
小广播
何立民专栏
单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
