datasheet
STM32开发笔记76: 初始化RTC后死机的原因
2019-07-13来源: eefocus关键字:STM32  初始化RTC  死机
项目开发中只要初始化RTC,则系统死机。其初始化步骤可参考日志:STM32开发笔记44:RTC驱动程序的移植。按照日志STM32开发笔记75: 使用STM32CubeMX点亮一个LED使用STM32CubeMX直接生成程序则运行正常。
分析原因在于,少移植了2个函数:HAL_RTC_MspInit和HAL_RTC_MspDeInit。这两个函数的实现非常简单,可以靠STM32CubeMX直接生成。
void HAL_RTC_MspInit(RTC_HandleTypeDef *hrtc)
  __HAL_RCC_RTC_ENABLE();
  HAL_NVIC_SetPriority(RTC_IRQn, 0x0, 0);
  HAL_NVIC_EnableIRQ(RTC_IRQn);
void HAL_RTC_MspDeInit(RTC_HandleTypeDef *hrtc)
   __HAL_RCC_RTC_DISABLE();
将这2个函数直接植入rtc.cpp即可,这样就得到了完善的rtc.h和rtc.cpp。
#ifndef RTC_H_
#define RTC_H_
#include "stdint.h"
#if (defined STM32F091xC) || (defined STM32F070x6)
#include "stm32f0xx_hal.h"
#elif (defined STM32L053xx)
#include "stm32l0xx_hal.h"
#endif
#ifdef __cplusplus
extern "C"{
class CRtc
public:
RTC_HandleTypeDef hRTC;
public:
CRtc(void);
void EnterStopRtcMode(uint8_t u8_Second);
#endif
#endif
#include "include.h"
RTC_HandleTypeDef* pRTC = NULL;
CRtc::CRtc(void)
  this->hRTC.Instance = RTC;
pRTC = &this->hRTC;
this->hRTC.Init.HourFormat = RTC_HOURFORMAT_24;
this->hRTC.Init.AsynchPrediv = 124;
this->hRTC.Init.SynchPrediv = 295;
this->hRTC.Init.OutPut = RTC_OUTPUT_DISABLE;
this->hRTC.Init.OutPutRemap = RTC_OUTPUT_REMAP_NONE; //不进行输出引脚重映射
this->hRTC.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
this->hRTC.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;
if (HAL_RTC_Init(&this->hRTC) != HAL_OK)
Target.ErrorHandler(__FILE__, __LINE__);
void CRtc::EnterStopRtcMode(uint8_t u8_Second)
HAL_RTCEx_DeactivateWakeUpTimer(&hRTC);
  HAL_RTCEx_SetWakeUpTimer_IT(&hRTC, (uint32_t)u8_Second * 2312, RTC_WAKEUPCLOCK_RTCCLK_DIV16);
  HAL_PWR_EnterSTOPMode(PWR_LOWPOWERREGULATOR_ON, PWR_STOPENTRY_WFI);
void RTC_IRQHandler(void)
  HAL_RTCEx_WakeUpTimerIRQHandler(pRTC);
除此之外,我们还需对RTC进行配置,和设置中断服务处理函数。
  * @file    stm32l0xx_hal_conf.h
  * @author  MCD Application Team
  * @brief   HAL configuration template file.
  *          This file should be copied to the application folder and renamed
  *          to stm32l0xx_hal_conf.h.
  * @attention
© Copyright (c) 2016 STMicroelectronics.
  * All rights reserved.
  * This software component is licensed by ST under BSD 3-Clause license,
  * the "License"; You may not use this file except in compliance with the
  * License. You may obtain a copy of the License at:
  *                        opensource.org/licenses/BSD-3-Clause
/* Define to prevent recursive inclusion -------------------------------------*/
#ifndef __STM32L0xx_HAL_CONF_H
#define __STM32L0xx_HAL_CONF_H
#ifdef __cplusplus
 extern "C" {
#endif
/* Exported types ------------------------------------------------------------*/
/* Exported constants --------------------------------------------------------*/
/* ########################## Module Selection ############################## */
  * @brief This is the list of modules to be used in the HAL driver
#define HAL_MODULE_ENABLED
/*#define HAL_ADC_MODULE_ENABLED    */
/*#define HAL_CRYP_MODULE_ENABLED    */
/*#define HAL_COMP_MODULE_ENABLED    */
/*#define HAL_CRC_MODULE_ENABLED    */
/*#define HAL_DAC_MODULE_ENABLED    */
/*#define HAL_FIREWALL_MODULE_ENABLED   */
/*#define HAL_I2S_MODULE_ENABLED    */
#define HAL_IWDG_MODULE_ENABLED
/*#define HAL_LCD_MODULE_ENABLED    */
/*#define HAL_LPTIM_MODULE_ENABLED    */
/*#define HAL_RNG_MODULE_ENABLED    */
#define HAL_RTC_MODULE_ENABLED
/*#define HAL_SPI_MODULE_ENABLED    */
#define HAL_TIM_MODULE_ENABLED
/*#define HAL_TSC_MODULE_ENABLED    */
#define HAL_UART_MODULE_ENABLED
/*#define HAL_USART_MODULE_ENABLED    */
/*#define HAL_IRDA_MODULE_ENABLED    */
/*#define HAL_SMARTCARD_MODULE_ENABLED  */
/*#define HAL_SMBUS_MODULE_ENABLED    */
/*#define HAL_WWDG_MODULE_ENABLED    */
/*#define HAL_PCD_MODULE_ENABLED */
/*#define HAL_EXTI_MODULE_ENABLED    */
#define HAL_GPIO_MODULE_ENABLED
#define HAL_DMA_MODULE_ENABLED
#define HAL_I2C_MODULE_ENABLED
#define HAL_RCC_MODULE_ENABLED
#define HAL_FLASH_MODULE_ENABLED
#define HAL_PWR_MODULE_ENABLED
#define HAL_CORTEX_MODULE_ENABLED
/* ########################## Oscillator Values adaptation ####################*/
  * @brief Adjust the value of External High Speed oscillator (HSE) used in your application.
  *        This value is used by the RCC HAL module to compute the system frequency
  *        (when HSE is used as system clock source, directly or through the PLL).
#if !defined  (HSE_VALUE)
  #define HSE_VALUE    ((uint32_t)12000000U) /*!< Value of the External oscillator in Hz */
#endif /* HSE_VALUE */
#if !defined  (HSE_STARTUP_TIMEOUT)
  #define HSE_STARTUP_TIMEOUT    ((uint32_t)100U)   /*!< Time out for HSE start up, in ms */
#endif /* HSE_STARTUP_TIMEOUT */
  * @brief Internal Multiple Speed oscillator (MSI) default value.
  *        This value is the default MSI range value after Reset.
#if !defined  (MSI_VALUE)
  #define MSI_VALUE    ((uint32_t)2097000U) /*!< Value of the Internal oscillator in Hz*/
#endif /* MSI_VALUE */
  * @brief Internal High Speed oscillator (HSI) value.
  *        (when HSI is used as system clock source, directly or through the PLL).
#if !defined  (HSI_VALUE)
  #define HSI_VALUE    ((uint32_t)16000000U) /*!< Value of the Internal oscillator in Hz*/
#endif /* HSI_VALUE */
  * @brief Internal High Speed oscillator for USB (HSI48) value.
#if !defined  (HSI48_VALUE)
#define HSI48_VALUE ((uint32_t)48000000U) /*!< Value of the Internal High Speed oscillator for USB in Hz.
                                             The real value may vary depending on the variations
                                             in voltage and temperature.  */
#endif /* HSI48_VALUE */
  * @brief Internal Low Speed oscillator (LSI) value.
#if !defined  (LSI_VALUE)
 #define LSI_VALUE  ((uint32_t)37000U)       /*!< LSI Typical Value in Hz*/
#endif /* LSI_VALUE */                      /*!< Value of the Internal Low Speed oscillator in Hz
                                             in voltage and temperature.*/
  * @brief External Low Speed oscillator (LSE) value.
  *        This value is used by the UART, RTC HAL module to compute the system frequency
#if !defined  (LSE_VALUE)
  #define LSE_VALUE    ((uint32_t)32768U) /*!< Value of the External oscillator in Hz*/
#endif /* LSE_VALUE */
#if !defined  (LSE_STARTUP_TIMEOUT)
  #define LSE_STARTUP_TIMEOUT  ((uint32_t)5000U)   /*!< Time out for LSE start up, in ms */
#endif /* LSE_STARTUP_TIMEOUT */
/* Tip: To avoid modifying this file each time you need to use different HSE,
   ===  you can define the HSE value in your toolchain compiler preprocessor. */
/* ########################### System Configuration ######################### */
  * @brief This is the HAL system configuration section
#define  VDD_VALUE                    ((uint32_t)3300U) /*!< Value of VDD in mv */
#define  TICK_INT_PRIORITY            ((uint32_t)0U)    /*!< tick interrupt priority */
#define USE_RTOS 0U
[1] [2]
关键字:STM32  初始化RTC  死机
编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic467679.html
上一篇:【stm32f0】stm32 总中断的打开与关闭
下一篇:STM32开发笔记75: 使用STM32CubeMX点亮一个LED
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
STM32解决:st-link连接下载程序的问题
STM32解决:Error: Flash Download failed - "Cortex-M3"本人由于使用普中科技的stm32 的开发板的 USB的下载的地方坏了,所以不得不使用arm仿真器 st-link 进行下载。鼓捣了半天下面总结一下几个问题:1、st-link的驱动下载首先你插上st-link的时候,电脑的设备管理器这个地方是有感叹号的,说明还没有装好驱动,所以我就在网上找啊找。终于根据:win8【笔者没这个系统,无法测试,请大家测试后报告】:http://pan.baidu.com/s/1sjJQxZn(转载来自:https://blog.csdn.net/imxiangzi/article
发表于 2019-07-19
解决stm32f103通过stlink不能烧录程序问题
问题:   stm32(stm32f103c8T6)开发板只能通过串口烧录程序,而st—link居然不行描述:解决:st-link固件升级用stm32cubemx快速开发时没有配置好调试模式重新生成代码就可以了如果还是不行的话,就得升级一下stlink固件了,具体升级方法可百度
发表于 2019-07-19
STM32下载不成功问题汇总
在某宝上买了五个最小系统核心板是STM32F103C8T6的芯片,刚拿到手准备下载程序调试,上电后板子自带LED闪烁,这是商家自己下载的示例程序,说明芯片工作着,用KEIL4进行下载自己程序,把自己编译好的程序下载。用的JLINK的四线下载调试下载口,SW的调试接口,点击下载后发现擦除成功,下载失败,提示:Load "..\Output\STM32-DEMO.axf" Set JLink Project File to "F:文件RFID程序电机USERJLinkSettings.ini"* JLink Info: Device "STM32
发表于 2019-07-19
STM32下载不成功问题汇总
STM32高级开发(11)-使用GDB调试你的工程
/scripts/target/stm32f4x_stlink.cfg在执行完此条指令后该终端就会一直执行OpenOCD的程序了,不要关闭它,我们再打开一个终端界面,进入我们的工程目录,比如我这里进入的就是我的libopencm3样例工程下的blink子工程目录。$ cd '/home/yangliu/workspace/libopencm3-my-example/blink'然后我们使用指令输入调试文件并打开GDB程序。$ arm-none-eabi-gdb blink.elf 然后我们在GDB的指令界面中,输入连接指令,连接本地的3333端口。(gdb)target remote localhost:3333此时
发表于 2019-07-19
STM32F4标准外设库模板工程建立与使用
SW4STM32安装其实固件库安装过程很简单,在第一次新建工程时会提示选择使用Stdperiph 驱动还是Cube HAL,由于Stm32官方大力推行Cube HAL固件库,所以Cube HAL的固件库直接可以从网上直接一键下载安装。然而对于老的StdPeriph固件库不能一键式下载安装,会提示出错。所以,我们需要自己下载一个.zip固件包,放在C:UsersLYAppDataRoamingAc6SW4STM32firmwares文件夹下,其中的LY就是计算机的用户名。然后新建工程时在选择Stdperiph固件时会自动解压缩,这样就能使用该库进行编译了。界面如下所示:工程配置器件与时钟或者,修改晶振与时钟,根据注释可以算得
发表于 2019-07-19
基于STM32的外设的GPIO外设设置总结
1、背景外设驱动的寄存器设置对于外设功能正常运行异常重要。现在对GPIO的配置进行总结。2、GPIO的配置总结复用GPIO配置GPIO设置为输出或者是复用模式时,需要设置输出速度;而无论设置为什么模式,都要对GPIO的内部上下拉进行设置。注意:在输入模式(普通输入/模拟输入)下,OTYPE和OSPEED参数无效!!
发表于 2019-07-19
小广播
何立民专栏
单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
