STM32F103 UART4 DMA接收
2019-07-22来源: eefocus关键字:STM32F103  UART4  DMA接收
//网上找了老半天也找不到UART4-DMA的程序,自己调试成功了,特地分享一下
uint8_t UART4_Rx_buffer[512],UART4_Rx_num;
void UART4_Config(void)
GPIO_InitTypeDef GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
DMA_InitTypeDef DMA_InitStructure; //定义DMA初始化结构体DMA_InitStructure
// NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0); //选择NVIC优先级分组0
RCC_APB1PeriphClockCmd(RCC_APB1Periph_UART4, ENABLE);
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA2, ENABLE);
//串口4所使用管脚输出输入定义
//定义UART4 Tx (PC.10)脚为复用推挽输出
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;         //IO口的第2脚
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;   //IO口复用推挽输出
GPIO_Init(GPIOC, &GPIO_InitStructure);            //初始化串口1输出IO口
//定义 UART4 Rx (PC.11)为悬空输入
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;           //IO口的第3脚
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//IO口悬空输入
GPIO_Init(GPIOC, &GPIO_InitStructure);               //初始化串口1输入IO口
//串口4参数初始化定义部分,串口1参数为9600 , 8 ,1 ,N  接收中断方式
USART_InitStructure.USART_BaudRate = 9600;                  //设定传输速率
USART_InitStructure.USART_WordLength = USART_WordLength_8b; //设定传输数据位数
USART_InitStructure.USART_StopBits = USART_StopBits_1;      //设定停止位个数
USART_InitStructure.USART_Parity = USART_Parity_No ;        //不用校验位
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//不用流量控制
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;                //使用接收和发送功能
USART_Init(UART4, &USART_InitStructure);      //初始化串口4
USART_ITConfig(UART4, USART_IT_IDLE,ENABLE);  //使能串口4接收中断
USART_Cmd(UART4, ENABLE);                     //使能串口4
USART_ClearFlag(UART4, USART_FLAG_TC);        // 清标志(后增加)
DMA_DeInit(DMA2_Channel3); //重置DMA 2通道配置
DMA_InitStructure.DMA_PeripheralBaseAddr = 0x40004C04; //外设地址
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)UART4_Rx_buffer; //内存地址
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //外设作为数据目的地
DMA_InitStructure.DMA_BufferSize = 512; //DMA缓存大小:BufferSize
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //外设地址寄存器不递增
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;   //内存地址寄存器递增
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte; //外设数据宽度为8位
DMA_InitStructure.DMA_MemoryDataSize = DMA_PeripheralDataSize_Byte; //内存数据宽度为8位
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //工作在正常缓存模式
DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh; //设置DMA通道优先级为高
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; //禁止DMA通道设置为内存至内存传输
DMA_Init(DMA2_Channel3, &DMA_InitStructure); //初始化
  DMA_ITConfig(DMA2_Channel3, DMA_IT_TC, ENABLE);
DMA_ITConfig(DMA2_Channel3, DMA_IT_TE, ENABLE);
USART_DMACmd(UART4, USART_DMAReq_Rx, ENABLE);
DMA_Cmd(DMA2_Channel3, ENABLE);
//使能串口4中断
NVIC_InitStructure.NVIC_IRQChannel = UART4_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
NVIC_InitStructure.NVIC_IRQChannel = DMA2_Channel3_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
void UART4_IRQHandler(void)
uint16_t i;
uint16_t Data_Len;
if(USART_GetITStatus(UART4, USART_IT_IDLE) != RESET)    //如果为中断
DMA_Cmd(DMA2_Channel3, DISABLE);
Data_Len=512-DMA_GetCurrDataCounter(DMA2_Channel3);
USART_PutStr(USART1,UART4_Rx_buffer,Data_Len);
UART4_Rx_num=0;
DMA_ClearFlag(DMA2_FLAG_GL3 | DMA2_FLAG_TC3 | DMA2_FLAG_TE3 | DMA2_FLAG_HT3); //清标志
DMA2_Channel3->CNDTR = 512;                //重装填
DMA_Cmd(DMA2_Channel3, ENABLE);            //处理完,重开DMA
//读SR后读DR清除IDLE
i = UART4->SR;
i = UART4->DR;
if(i) i=0;
if(Data_Len) Data_Len=0;
if(USART_GetITStatus(UART4, USART_IT_PE | USART_IT_FE | USART_IT_NE) != RESET){    //出错
USART_ClearITPendingBit(UART4, USART_IT_PE | USART_IT_FE | USART_IT_NE);
USART_ClearITPendingBit(UART4, USART_IT_TC);
USART_ClearITPendingBit(UART4, USART_IT_IDLE);
void DMA2_Channel3_IRQHandler(void)
	USART_PutStr(USART1," DMA23:rn",9);
DMA_ClearITPendingBit(DMA2_IT_TC3);
DMA_ClearITPendingBit(DMA2_IT_TE3);
DMA_Cmd(DMA2_Channel3, DISABLE);         //关闭DMA,防止处理其间有数据
编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic468712.html
上一篇:STM32 Uart 实现printf函数
下一篇:STM32CubeMX 4 解锁UART模块
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
基于STM32F103ZET6主控平台实现定时器TIM3的驱动
_Clock_Init(9);   //系统时钟设置 delay_init(72);     //延时初始化 uart_init(72,115200); //串口初始化为115200 LED_Init(); BEEP_Init(); TIM3_Init(4999,7199); while(1) { if(Wl_stat==0)//代表进入WHILE循环 { printf("Input While(1)-->rn"); Wl_stat=1; } LED1=!LED1; delay_ms(200); }} 第四步:编译通过后,烧录进STM32F103ZET6开发板,实现
发表于 2019-08-22
STM32f103ZET6定时器TIM3使用通道1输出PWM程序
总结:TIM3_CH1输出口为PA6(重映射为PB4),PB5位DS0接口。1.使用重映射之后,原始IO口不再有输出;本例子中,若使用部分重映射,则 PA6映射到PB4中,所以仅仅PB4有波形输出;飞线连接PB4与PB5即可观察PWM呼吸灯效果。2.使用IO口前务必初始化,本例子中开始仅仅初始化了PB5口,而没有初始化PA6导致一直验证失败;正点原子给出程序中是由通道2直接映射到PB5因此只需要初始化PB5口即可,不存在上述问题。3.除了正常输出输入信号之外,输出PWM以及其他功能均属于IO口的复用功能。#include "stm32f10x.h"#include "led.h"
发表于 2019-08-22
stm32f0设置tim2单脉冲模式-tim1内部触发
/***************************************************************************************************************以下TIM1和TIM2的设置实现TIM1输出40hz,占空比7%即高电平输出180us,TIM2输出单脉冲,周期360us,占空比50%,TIM2的触发是TIM1的OC1REF信号。TIM2设置单脉冲需设置的参数:  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;    TIM_SelectOnePulseMode(TIM2,TIM_OPMode_Single);//单脉冲  TIM_SelectInputTrigger(TIM2, TIM_TS_ITR0);//定时器1内部触发
发表于 2019-08-22
STM32F103 使用TIM3产生四路PWM
为PC6、PC7、PC8、PC9*******************************************************************************/#include"stm32f10x.h"void RCC_Cfg(void);void GPIO_Cfg(void);void TIM_Cfg(void);void NVIC_Cfg(void);void delay_ms(u32 i);void PWM_Cfg(float dutyfactor1,float dutyfactor2,float dutyfactor3,float dutyfactor4); int
发表于 2019-08-22
STM32F10 OLED液晶显示(IIC)
2019年7月27日做小车的第六天。今天我实现了一个新的功能 OLED显示汉字。刚开始学习这个显示汉字的时候也是一头污水,代码啊大部分看不懂,看OLED讲解的那个视频反复看了好几遍。还是没什么思路。但是那自己慢慢的开始修改自带的源代码,尝试的去做,从显示点、线、字符、字符串一步步的开始进行,随着这个一步步的学会,显示汉字那,哈哈,原理也是差不多。大致思路也就是调用.c中的函数,设置里面的变量,去调出自己想要的字符,汉字的代码(这些代码都是在一个数组里)先说说重要的,怎么显示出汉字:比如我们想让OLED显示屏显示一个字符串:“CODE”,主函数是这么两条语句:OLED_ShowString(63,48,“CODE:”,16
发表于 2019-08-22
STM32F103_SD卡FatFs文件系统移植
;       status = RES_OK;            break;至此diskio.c移植完成三、ffconfig.h需要修改的参数如下:  //准许使用文件字符串函数: f_gets(), f_putc(), f_puts() and/  f_printf()#define    _USE_STRFUNC    1    //支持格式化函数f_mkfs()#define    _USE_MKFS
发表于 2019-08-22
小广播
何立民专栏
单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
