datasheet
【STM32CubeMX】2,STM32CubeMX常用的自动生成函数
2019-08-14来源: eefocus关键字:STM32CubeMX  自动生成函数  头文件
1,在#include "stm32f1xx_hal.h" 的头文件中,
常用     void HAL_Delay(uint32_t Delay);
2,GPIO.H
void  HAL_GPIO_Init(GPIO_TypeDef  *GPIOx, GPIO_InitTypeDef *GPIO_Init);
void  HAL_GPIO_DeInit(GPIO_TypeDef  *GPIOx, uint32_t GPIO_Pin);
GPIO_PinState HAL_GPIO_ReadPin(GPIO_TypeDef *GPIOx, uint16_t GPIO_Pin);
void HAL_GPIO_WritePin(GPIO_TypeDef *GPIOx, uint16_t GPIO_Pin, GPIO_PinState PinState);
void HAL_GPIO_TogglePin(GPIO_TypeDef *GPIOx, uint16_t GPIO_Pin);
HAL_StatusTypeDef HAL_GPIO_LockPin(GPIO_TypeDef *GPIOx, uint16_t GPIO_Pin);
void HAL_GPIO_EXTI_IRQHandler(uint16_t GPIO_Pin);
void HAL_GPIO_EXTI_Callback(uint16_t GPIO_Pin);
3,USart
/* IO operation functions *******************************************************/
HAL_StatusTypeDef HAL_UART_Transmit(UART_HandleTypeDef *huart, uint8_t *pData, uint16_t Size, uint32_t Timeout);
HAL_StatusTypeDef HAL_UART_Receive(UART_HandleTypeDef *huart, uint8_t *pData, uint16_t Size, uint32_t Timeout);
HAL_StatusTypeDef HAL_UART_Transmit_IT(UART_HandleTypeDef *huart, uint8_t *pData, uint16_t Size);
HAL_StatusTypeDef HAL_UART_Receive_IT(UART_HandleTypeDef *huart, uint8_t *pData, uint16_t Size);
HAL_StatusTypeDef HAL_UART_Transmit_DMA(UART_HandleTypeDef *huart, uint8_t *pData, uint16_t Size);
HAL_StatusTypeDef HAL_UART_Receive_DMA(UART_HandleTypeDef *huart, uint8_t *pData, uint16_t Size);
HAL_StatusTypeDef HAL_UART_DMAPause(UART_HandleTypeDef *huart);
HAL_StatusTypeDef HAL_UART_DMAResume(UART_HandleTypeDef *huart);
HAL_StatusTypeDef HAL_UART_DMAStop(UART_HandleTypeDef *huart);
/* Transfer Abort functions */
HAL_StatusTypeDef HAL_UART_Abort(UART_HandleTypeDef *huart);
HAL_StatusTypeDef HAL_UART_AbortTransmit(UART_HandleTypeDef *huart);
HAL_StatusTypeDef HAL_UART_AbortReceive(UART_HandleTypeDef *huart);
HAL_StatusTypeDef HAL_UART_Abort_IT(UART_HandleTypeDef *huart);
HAL_StatusTypeDef HAL_UART_AbortTransmit_IT(UART_HandleTypeDef *huart);
HAL_StatusTypeDef HAL_UART_AbortReceive_IT(UART_HandleTypeDef *huart);
void HAL_UART_IRQHandler(UART_HandleTypeDef *huart);
void HAL_UART_TxCpltCallback(UART_HandleTypeDef *huart);
void HAL_UART_TxHalfCpltCallback(UART_HandleTypeDef *huart);
void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart);
void HAL_UART_RxHalfCpltCallback(UART_HandleTypeDef *huart);
void HAL_UART_ErrorCallback(UART_HandleTypeDef *huart);
void HAL_UART_AbortCpltCallback (UART_HandleTypeDef *huart);
void HAL_UART_AbortTransmitCpltCallback (UART_HandleTypeDef *huart);
void HAL_UART_AbortReceiveCpltCallback (UART_HandleTypeDef *huart);
/* Peripheral Control functions  ************************************************/
HAL_StatusTypeDef HAL_LIN_SendBreak(UART_HandleTypeDef *huart);
HAL_StatusTypeDef HAL_MultiProcessor_EnterMuteMode(UART_HandleTypeDef *huart);
HAL_StatusTypeDef HAL_MultiProcessor_ExitMuteMode(UART_HandleTypeDef *huart);
HAL_StatusTypeDef HAL_HalfDuplex_EnableTransmitter(UART_HandleTypeDef *huart);
HAL_StatusTypeDef HAL_HalfDuplex_EnableReceiver(UART_HandleTypeDef *huart);
/** @addtogroup UART_Exported_Functions_Group4
/* Peripheral State functions  **************************************************/
HAL_UART_StateTypeDef HAL_UART_GetState(UART_HandleTypeDef *huart);
uint32_t HAL_UART_GetError(UART_HandleTypeDef *huart);
编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic471047.html
上一篇:【STM32CubeMX】1,STM32之GPIO端口输入模式配置
下一篇:【STM32CubeMX】3,STM32的HAL库运用小方法
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
STM32F429-DISCO上手,stm32cubeMX与IAR学习,中断及Printf
stm32f429及stm32f439已经带有LTDC控制器,意味着可以输出RGB888及RGB565的图像信号,这与以往的单片机CPU8080接口LCD有很大不同,也是入手STM32F429-DISCO的原因,价格不贵,mouser上不含税150,淘宝180,非常适合学习。STM推出了一个叫STM32CUBEMX的软件,可以用来配置将要用到的模块,配置时钟树,输出源文件,相当给力。(不过貌似也有童鞋说坑,个人觉得挺好用的)芯片选型后配置JTAG(SWD),一个HSE(8MHz),两个GPIO_OUT,一个GPIO_IRQ(都是板子上有的东西)配置时钟树,有问题的会自动标成红色,特别要记下的就是SYSCLK(系统时钟),没什么好说
发表于 2019-08-15
【STM32CubeMX】15,NVIC,中断优先级
以前虽然用到了中断,但很少用到中断优先级。现在必须有了,比如急停之类的。http://www.waveshare.net/study/article-641-1.html抢占优先级是用来判断一个中断是否可以打断另外一个中断的中断服务程序抢先运行。 响应优先级是用来判断抢占优先级相同的几个中断那个中断会优先响应。中断优先级分组是为了给抢占式优先级和响应优先级在中断优先级寄丛器的四个比特位分配各个优先级数字所占的位数。例如3位用于抢占优先级(优先级有2^3=8种优先级),1位用于响应优先级(优先级有2^1=2种优先级)。 中断服务函数里面就调用了GPIO外部中断处理
发表于 2019-08-14
【STM32CubeMX】11,STM32之CAN回环测试,过滤器的匹配设置
1,因为自己目前只有一块板子有CAN模块,所以先做CAN的回环测试。主要参考http://www.stm32cube.com/question/33下面的代码测试可以使用1-1,在CAN的编程中,主要是注意四大结构体,这几个都是自动生成的,1、CAN_HandleTypeDef  hcan1;// CAN handle Structure definition首先定义CAN的处理结构体,hcan1内部包括了3、CanTxMsgTypeDef; 4、CanRxMsgTypeDef;的头地址2、CAN_FilterConfTypeDef  sFilterConfig;// CAN filter
发表于 2019-08-14
【STM32CubeMX】10,STM32之FSMC 之TFTLCD,移植,显示变量
1,学了这章之后,主要掌握了怎么移植标准库的函数2,对.c .h文件的#include文件的修改3,在LCD中,最关键的是读写命令地址的书写4,LCD的初始化可以看给的参考例程5,变量的显示sprintf函数https://baike.baidu.com/item/sprintf/9703430?fr=aladdinhttp://www.openedv.com/posts/list/61386.htm6,在stm32 例子的 c语言 程序中看到这样一句 *(__IO uint16_t *) (((uint32_t)0x60020000) ) 7,fsmc目前还没怎么操作它,看以后怎么用吧
发表于 2019-08-14
1,当在hal头文件中看到该函数时,还不理解,直接复制百度就好如HAL_UART_Transmit(),有些论坛讲解的非常详细2,hal_adc.c文件一般都是详细解释,hal_adc.h文件都是关键函数的综述,这个对于快速上手非常重要
发表于 2019-08-14
ARM映像文件 he 编译器自动生成的启动函数
) ===========================================================     编译的结果完全符合推测,只有ZI数据相差了1个字节。这个字节正是未初始化的一个字符型变量“a”所引起的。 注意:如果一个变量被初始化为0,则该变量的处理方法与未初始化华变量一样放在ZI区域。   [page] 即:ARM C程序中,所有的未初始化变量都会被自动初始化为0。 总结: 1)C中的指令以及常量被编译后是RO类型数据。 2)C中的未被初始化或初始化为0的变量编译后是ZI类型数据。 3) C中的已被初始化成非0值的变量编译
发表于 2015-08-24
小广播
何立民专栏
单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
