datasheet
小熊stm32学习总结:stm32f407 GPIO_PinAFConfig 函数
2019-08-15来源: eefocus关键字:stm32  stm32f407  GPIO_PinAFConfig  函数
备用功能配置(除ADC和DAC外的所有非GPIO功能),使用函数
void GPIO_PinAFConfig(GPIO_TypeDef* GPIOx, uint16_t GPIO_PinSource, uint8_t GPIO_AF)
*          This GPIO_AF can be one of the following values:
  *            @arg GPIO_AF_RTC_50Hz: Connect RTC_50Hz pin to AF0 (default after reset)
  *            @arg GPIO_AF_MCO: Connect MCO pin (MCO1 and MCO2) to AF0 (default after reset)
  *            @arg GPIO_AF_TAMPER: Connect TAMPER pins (TAMPER_1 and TAMPER_2) to AF0 (default after reset)
  *            @arg GPIO_AF_SWJ: Connect SWJ pins (SWD and JTAG)to AF0 (default after reset)
  *            @arg GPIO_AF_TRACE: Connect TRACE pins to AF0 (default after reset)
  *            @arg GPIO_AF_TIM1: Connect TIM1 pins to AF1
  *            @arg GPIO_AF_TIM2: Connect TIM2 pins to AF1
  *            @arg GPIO_AF_TIM3: Connect TIM3 pins to AF2
  *            @arg GPIO_AF_TIM4: Connect TIM4 pins to AF2
  *            @arg GPIO_AF_TIM5: Connect TIM5 pins to AF2
  *            @arg GPIO_AF_TIM8: Connect TIM8 pins to AF3
  *            @arg GPIO_AF_TIM9: Connect TIM9 pins to AF3
  *            @arg GPIO_AF_TIM10: Connect TIM10 pins to AF3
  *            @arg GPIO_AF_TIM11: Connect TIM11 pins to AF3
  *            @arg GPIO_AF_I2C1: Connect I2C1 pins to AF4
  *            @arg GPIO_AF_I2C2: Connect I2C2 pins to AF4
  *            @arg GPIO_AF_I2C3: Connect I2C3 pins to AF4
  *            @arg GPIO_AF_SPI1: Connect SPI1 pins to AF5
  *            @arg GPIO_AF_SPI2: Connect SPI2/I2S2 pins to AF5
  *            @arg GPIO_AF_SPI3: Connect SPI3/I2S3 pins to AF6
  *            @arg GPIO_AF_I2S3ext: Connect I2S3ext pins to AF7
  *            @arg GPIO_AF_USART1: Connect USART1 pins to AF7
  *            @arg GPIO_AF_USART2: Connect USART2 pins to AF7
  *            @arg GPIO_AF_USART3: Connect USART3 pins to AF7
  *            @arg GPIO_AF_UART4: Connect UART4 pins to AF8
  *            @arg GPIO_AF_UART5: Connect UART5 pins to AF8
  *            @arg GPIO_AF_USART6: Connect USART6 pins to AF8
  *            @arg GPIO_AF_CAN1: Connect CAN1 pins to AF9
  *            @arg GPIO_AF_CAN2: Connect CAN2 pins to AF9
  *            @arg GPIO_AF_TIM12: Connect TIM12 pins to AF9
  *            @arg GPIO_AF_TIM13: Connect TIM13 pins to AF9
  *            @arg GPIO_AF_TIM14: Connect TIM14 pins to AF9
  *            @arg GPIO_AF_OTG_FS: Connect OTG_FS pins to AF10
  *            @arg GPIO_AF_OTG_HS: Connect OTG_HS pins to AF10
  *            @arg GPIO_AF_ETH: Connect ETHERNET pins to AF11
  *            @arg GPIO_AF_FSMC: Connect FSMC pins to AF12
  *            @arg GPIO_AF_OTG_HS_FS: Connect OTG HS (configured in FS) pins to AF12
  *            @arg GPIO_AF_SDIO: Connect SDIO pins to AF12
  *            @arg GPIO_AF_DCMI: Connect DCMI pins to AF13
  *            @arg GPIO_AF_EVENTOUT: Connect EVENTOUT pins to AF15
4.使用GPIO_ReadInputData(GPIO_TypeDef* GPIOx)和GPIO_ReadInputDataBit(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin)读输入信号
5.使用GPIO_SetBits()/GPIO_ResetBits()设置输出引脚
6.上电或复位后,引脚备用功能都没启用(JTAG引脚除外),为悬浮输入状态
7.LSE引脚OSC32_IN 和OSC32_OUT(PC14 and PC15)的优先级高于GPIO
8.HSE引脚OSC_IN/OSC_OUT (PH0 / PH1)的优先级高于GPIO
编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic471176.html
上一篇:小熊arm学习总结:iar7.3建立工程报错
下一篇:小熊STM32学习总结:STM32的定时器--输入捕捉模式
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
基于stm32f103的矩阵键盘
我现在的任务是做一个8*8的矩阵键盘,制PCB版之前,我用电路板搭了一个3*3的矩阵键盘来模拟一下,设置PA0、PA1、PA2为PP输出,设置P3、P4、P5下拉输入。大多数的芯片内部上拉或下拉电阻都是弱上拉或弱下拉,stm32f103的内部也一样,内部上拉或下拉的电阻阻值约为40K,这样可以方便外部调整,但是,在作为一些通讯引脚时,可能会出现上电时数据不稳定的问题,如I2C通讯,解决的办法是在外部在加上一个较强的上拉或下拉即可。具体程序如下:#include <stm32f10x.h>#include "usart.h"void KeyBoard_Init(void)//按键初始化
发表于 2019-08-16
基于 STM32F407 使用 4*4 矩阵键盘
写在前面:这是我第一次开始写博客,可能写的不是很好,也请大家谅解。本人现在大三,以前在学习过程中遇到过各种各样的问题,关于51单片机,STM32单片机,最近在学习ARM11的Tiny6410以后还会更新一些C/C++/Qt等等方面的东西关于写博客这件事,其实 一直想写博客记录下来,但是因为某些原因(懒),so , 没有写。现在开始,以后遇到单片机上或者编程上遇到的问题,并且自己很好地解决了,我就会在这里记录下来。希望通过博客记录我的学习历程并希望我所解决问题的过程能够帮到需要的人,一起加油吧!!!我是在STM32F407开发板上使用的4*4 矩阵键盘下面是我所使用的开发板1、首先介绍一下4*4矩阵键盘扫描原理
发表于 2019-08-16
基于STM32F407最小系统板三种矩阵键盘实现方法
0xe0:return 0xe7; case 0xd0:return 0xd7; case 0xb0:return 0xb7; case 0x70:return 0x77; } } if(mode) key =1; if((GPIO_ReadInputData(GPIOA)&0xF0)==0xF0) key =1; return 0;}比较:三种方案其实,第二种方案比较通用,第一种比较简单易懂,前两种都比较好,因为按键按下不松开,并不会影响CPU一直停留在while()循环里啥都不干。最后的实验效果:之前用的板子是STM32F107,数据手册中的GPIO口一些输出输入方式的配置与STM32F407
发表于 2019-08-16
STM32笔记(二)(寄存器)——矩阵键盘
      矩阵键盘是我第一个需要动手焊接东西的实验,是3*3的键盘,焊了一个下午。因为是第一次焊东西,有多处不足,但最后也勉强能用。键盘的电路是组长设计的,希望下一次我能自己独立设计电路。键盘外观正面背面  外观略显粗糙。。。。主要代码       矩阵键盘最主要的一部分代码就是按键扫描部分,通过一个扫描函数对高低电平进行判断,从而确定按键的位置。用过串口输出案件编号1~9。key.c代码void KEY_Init1(void){ RCC->APB2ENR|=1<<3;      JTAG_S
发表于 2019-08-16
STM32 学习笔记 一.矩阵键盘
刚刚接触STM32,感觉和arduino完全是两个难度,如果说arduino是乐高积木,那我感觉STM32就跟盖楼一样,哈哈,是真的难,真的极具挑战性,可能是我刚开始学觉得难,到后面熟练了应该会好一些,言归正传,就讲一讲我们学长给我们下的任务矩阵键盘。学长学姐们做的是九键的矩阵键盘,我们做的是四键的,难度其实相差不大,换汤不换药的类型,原理就是一二号线通高电平,三四号线低电平,然后交换,让一二号低电平,三四号高电平这样就可以确定是哪个按键被按下。OK上代码key.c函数#include "key.h"#include "delay.h"#include "usart.h"
发表于 2019-08-16
STM32 学习笔记 一.矩阵键盘
STM32 矩阵键盘通过串口输出
STM32F103C8T6 4*4矩阵键盘 通过串口输出,可以用来写密码锁程序的思路如下:1、首先需要配置的是矩阵键盘:配置两个函数:  KEY44_Init(矩阵键盘初始化)和key44_Scan(扫描并获取值)   。2、其次,设置串口(本文设置为STM32F103C8T6的串口三): 我们需要对USART进行初始化设置,详细请见下文。3、然后就开始写我们的主函数:主函数比较简单。因为程序已经分装了。4、最后我们要实现按下一个键,串口打出一个字符(按下1键,打出1)——————————————————————————————————————————————————-下边为程序:所用芯片
发表于 2019-08-16
小广播
何立民专栏
单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
