2.STM32F4/7点灯
2019-08-16来源: eefocus关键字:STM32F4  7  点灯  时钟使能
思路:1.时钟使能(开启GPIOA端口时钟使能) 2.GPIO配置(推挽输出模式,频率,速度等) 3.GPIO输出高电平(输出置位)
STM32F4:
推挽输出,输出低电平灯亮,输出高电平灯灭.
#include
void Delay(__IO uint32_t nCount){
while(nCount--);
void GPIO_Con(){
GPIO_InitTypeDef GPIO_Struct;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOF,ENABLE);
GPIO_Struct.GPIO_Pin=GPIO_Pin_9;
GPIO_Struct.GPIO_Mode=GPIO_Mode_OUT;
GPIO_Struct.GPIO_Speed=GPIO_Speed_100MHz;
GPIO_Struct.GPIO_OType=GPIO_OType_PP;
GPIO_Struct.GPIO_PuPd=GPIO_PuPd_UP;
GPIO_Init(GPIOF,&GPIO_Struct);
int main(void){
GPIO_Con();
   while(1){
GPIO_SetBits(GPIOF,GPIO_Pin_9);
Delay(1000);
GPIO_ResetBits(GPIOF,GPIO_Pin_9);
Delay(1000);
STMF7:
更多的使用HAL库函数。
#include
#include
#include
static int timecounts;
static void MX_GPIO_Init(void)
  GPIO_InitTypeDef GPIO_InitStruct;
  __HAL_RCC_GPIOI_CLK_ENABLE();
  HAL_GPIO_WritePin(GPIOI, GPIO_PIN_1, GPIO_PIN_RESET);
  GPIO_InitStruct.Pin = GPIO_PIN_1;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  HAL_GPIO_Init(GPIOI, &GPIO_InitStruct);
int main(){
    MX_GPIO_Init();
while(1){
  HAL_GPIO_WritePin(GPIOI, GPIO_PIN_1, GPIO_PIN_SET);
      HAL_Delay(500);
          HAL_Delay(500);
GPIO函数库:
1个初始化函数:void GPIO_Init(GPIO_TypeDef* GPIOx, GPIO_InitTypeDef* GPIO_InitStruct)
2个读取输入电平函数:uint8_t GPIO_ReadInputDataBit(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin)
                                   uint16_t GPIO_ReadInputData(GPIO_TypeDef* GPIOx)
2个读取输出电平函数:uint8_t GPIO_ReadOutputDataBit(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin)
                                      uint16_t GPIO_ReadOutputData(GPIO_TypeDef* GPIOx)
4个设置输出电平函数:void GPIO_SetBits(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin)
                                      void GPIO_ResetBits(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin)
                                      void GPIO_WriteBit(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin, BitAction BitVal)
                                      void GPIO_Write(GPIO_TypeDef* GPIOx, uint16_t PortVal)
针对管脚和针对端口的区别
编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic471316.html
上一篇:1.基于固件库建立STM32F4的工程模板
下一篇:3.STM32F4蜂鸣器
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
【STM32F103】中断综述
一、中断内核: STM32的中断很强大,每个外设都可以产生中断,F103在内核水平上搭载了异常响应系统,系统异常有8个(算上RESET和HardFault也就10个),外部中断有60个,但是根据NVIC(嵌套向量中断控制器,控制整个芯片中断相关的功能),IP(中断优先级寄存器)数组中预留了240个位置(NVIC结构如上图),可见眼光之远,用于扩展,这是STM32F103用不到这么多。如果以后要找跟内核相关的函数,都存在core_cm3.c和misc.c中,包括NVIC的函数的声明,但是其具体的库函数内容并不是和固件库头文件core_cm3.h一致(不在core_cm3.c),而是放在库函数的misc.c中,这点需要
发表于 2019-08-23
【STM32F103】中断综述
关于由CubeMx生成stm32f4+freertos,不正常分析之堆栈大小设置
freertos官方手册上有说,移植中出现的问题大多数是由堆栈设置不合理造成的,今天结合自身遇到问题分析一下1.任务堆栈设置过小,很容易造成硬件溢出,跳转到void HardFault_Handler(void);调试方法,可以通过调用函数,UBaseType_t uxTaskGetStackHighWaterMark( TaskHandle_t xTask );来跟踪剩余堆栈,不过在CubeMx中的Configuration->FreeRtos->Include parameters中使能uxTaskGetStackHighWaterMark函数;2.整体设置过小,TOTAL_HEAP_SIZE
发表于 2019-08-23
CubeMX Stm32F407生成一定周期的占空比不同的方波DMA+定时器
先上图如图 是我生成的一个波形  这个波形的占空比在连续的四个周期内分别是10%,20%,30%,40%, 并且按照这个顺序循环这里大致介绍一下实现的方式。使用的软件是Cubemx(库函肯定也可以实现)第一步是器件选型  这一部分不做介绍  用的是Stm32F407第二是时钟配置接下来是定时器配置 第三步就是生成代码了这里 需要在生成的代码里面加上一行开始的代码。
发表于 2019-08-23
STM32F103控制舵机
//TIM4 PWM部分初始化 //PWM输出初始化//arr:自动重装值//psc:时钟预分频数void TIM4_PWM_Init(u16 arr,u16 psc){   GPIO_InitTypeDef GPIO_InitStructure; TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure; TIM_OCInitTypeDef  TIM_OCInitStructure; RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE); //使能定时器3时钟
发表于 2019-08-23
基于STM32F103ZET6主控平台实现定时器TIM3的驱动
_Clock_Init(9);   //系统时钟设置 delay_init(72);     //延时初始化 uart_init(72,115200); //串口初始化为115200 LED_Init(); BEEP_Init(); TIM3_Init(4999,7199); while(1) { if(Wl_stat==0)//代表进入WHILE循环 { printf("Input While(1)-->rn"); Wl_stat=1; } LED1=!LED1; delay_ms(200); }} 第四步:编译通过后,烧录进STM32F103ZET6开发板,实现
发表于 2019-08-22
STM32f103ZET6定时器TIM3使用通道1输出PWM程序
总结:TIM3_CH1输出口为PA6(重映射为PB4),PB5位DS0接口。1.使用重映射之后,原始IO口不再有输出;本例子中,若使用部分重映射,则 PA6映射到PB4中,所以仅仅PB4有波形输出;飞线连接PB4与PB5即可观察PWM呼吸灯效果。2.使用IO口前务必初始化,本例子中开始仅仅初始化了PB5口,而没有初始化PA6导致一直验证失败;正点原子给出程序中是由通道2直接映射到PB5因此只需要初始化PB5口即可,不存在上述问题。3.除了正常输出输入信号之外,输出PWM以及其他功能均属于IO口的复用功能。#include "stm32f10x.h"#include "led.h"
发表于 2019-08-22
小广播
何立民专栏
单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
