stm32驱动超声波模块
2019-08-19来源: eefocus关键字:stm32驱动  超声波模块  中断服务
#define HCSR04_PORT   GPIOB
#define HCSR04_CLK    RCC_APB2Periph_GPIOB
#define HCSR04_TRIG   GPIO_Pin_8
#define HCSR04_ECHO   GPIO_Pin_9
#define TRIG_Send(n)  do{
if(n == 0)
GPIO_ResetBits(HCSR04_PORT,HCSR04_TRIG);
else if(n == 1)
GPIO_SetBits(HCSR04_PORT,HCSR04_TRIG);
}while(0)
#define ECHO_Reci     GPIO_ReadInputDataBit(GPIOB,HCSR04_ECHO)
void UltrasonicInit(void)
GPIO_InitTypeDef GPIO_InitStructure;
RCC_APB2PeriphClockCmd(HCSR04_CLK, ENABLE);
//IO初始化
GPIO_InitStructure.GPIO_Pin   = HCSR04_TRIG;       //发送电平引脚
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_Out_PP;//推挽输出
GPIO_Init(HCSR04_PORT, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin  = HCSR04_ECHO;     //返回电平引脚
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入
GPIO_ResetBits(HCSR04_PORT,HCSR04_ECHO);
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;     //生成用于定时器设置的结构体
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM6, ENABLE);   //使能对应RCC时钟
//配置定时器基础结构体
TIM_DeInit(TIM6);
TIM_TimeBaseStructure.TIM_Period = (1000-1);          //设置在下一个更新事件装入活动的自动重装载寄存器周期的值         计数到1000为1ms
TIM_TimeBaseStructure.TIM_Prescaler =(72-1);          //设置用来作为TIMx时钟频率除数的预分频值  1M的计数频率 1US计数
TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;//不分频
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //TIM向上计数模式
TIM_TimeBaseInit(TIM6, &TIM_TimeBaseStructure);       //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位
TIM_ClearFlag(TIM6, TIM_FLAG_Update);                 //清除更新中断,免得一打开中断立即产生中断
TIM_ITConfig(TIM6,TIM_IT_Update,ENABLE);              //打开定时器更新中断
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
NVIC_InitStructure.NVIC_IRQChannel = TIM6_IRQn;            //选择串口1中断
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;  //抢占式中断优先级设置为1
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;         //响应式中断优先级设置为1
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;            //使能中断
NVIC_Init(&NVIC_InitStructure);
TIM_Cmd(TIM6,DISABLE);
//定时器6中断服务程序
u32 msHcCount = 0;
void TIM6_IRQHandler(void)   //TIM6中断
if (TIM_GetITStatus(TIM6, TIM_IT_Update) != RESET)  //检查TIM3更新中断发生与否
TIM_ClearITPendingBit(TIM6, TIM_IT_Update);       //清除TIMx更新中断标志
msHcCount++;
static void OpenTimerForHc()    //打开定时器
TIM_SetCounter(TIM6,0);      //清除计数
msHcCount = 0;
TIM_Cmd(TIM6, ENABLE);       //使能TIMx外设
static void CloseTimerForHc()  //关闭定时器
TIM_Cmd(TIM6, DISABLE);      //使能TIMx外设
//获取定时器时间
u32 GetEchoTimer(void)
u32 t = 0;
t = msHcCount*1000;                  //将MS转换成US
t += TIM_GetCounter(TIM6);           //得到总的US
TIM6->CNT = 0;                       //将TIM6计数寄存器的计数值清零
return t;
//一次获取超声波测距数据 两次测距之间需要相隔一段时间,隔断回响信号
//为了消除余震的影响,取五次数据的平均值进行加权滤波。
float Hcsr04GetLength(void )
u32 t = 0;
int i = 0;
float lengthTemp = 0;
float sum = 0;
while(i!=5)
/*发送一个20ms的脉冲*/
TRIG_Send(1);
osDelay(20);
TRIG_Send(0);
while(ECHO_Reci == 0);     //等待接收口高电平输出(超声波发出)
OpenTimerForHc();          //打开定时器
while(ECHO_Reci == 1);     //等待超声波返回
CloseTimerForHc();         //关闭定时器
t = GetEchoTimer();        //获取时间,分辨率为1US
lengthTemp = ((float)t*17/1000.0);//cm
sum = lengthTemp + sum ;
 i = i + 1;
lengthTemp = sum/5.0;
return lengthTemp;
编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic471644.html
上一篇:STM32单片机连接HC_SR04超声波模块测距
下一篇:基于STM32F103循迹小车
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
stm32驱动DHT11温湿度模块使用方法和问题小结
最近在总结做过的几个项目,今天小结一下DHT11模块的使用。对DHT11的使用,就是编写时序和stm32进行通信。DHT11和stm32是通过一根线进行通信的,双方通过这根线上的电平变化来识别各种信号。DHT11每次传输数据会输出40bit的数据,即5个字节,它们的含义如下:每一位bit是0还是1是通过高电平的持续时间来判断的,如下两张图所示,‘0’和‘1’都是先持续50us的低电平,而后持续一段时间高电平,‘0’的高电平会持续26-28us,‘1’的电平会持续70us,因此你在判断每位数据是’0’还是’1’时,有两种方法,一种是看持续时间,显然高电平持续时间超过28us的就是’1’;另一种方法是选取一个时间点,比如在高电平开始
发表于 2019-08-14
ADIS16203角度传感器的stm32驱动实现要点
特征。ADIS16203提供下列嵌入式特性,无需外部电路,并提供简化的系统接口:可配置报警功能辅助12位模数转换器(ADC)辅助12位数模转换器(DAC)可配置数字I/O端口数字自测功能二、怎样从datasheet里面提取与驱动编写有关的信息1.spi的通讯速率从时序规格表可知该芯片的spi通讯速率最快是2.5MHz,普通模式是1MHz。2.SPI的极性和相位从时序图可知该芯片的相位CPHA=1(时钟空闲时高电平),极性CPOL=1(上升沿采样)3.CS片选信号由上图可知CS是低电平有效。4.spi一个数据帧的位数由图可知一个数据帧是16位的。5.spi发送数据位的顺序由图可知是先发高位(MSB)6.spi的读写控制由图可知控制
发表于 2019-08-14
STM32驱动LCD12864显示屏
我们做一个电子产品,往往需要实现人机交互的功能。那么人机交互的方式除了输出到上位机通过电脑去显示,显示器也是一个很不错的方式,可用于一些不能使用电脑的场合。LCD12864显示器中的一种,具有价格低廉,操作简单的优点。今天就为大家带来一个STM32驱动12864的例程,使用SPI串行通信,仅仅需要三根数据线就可以完成通信。废话不多说,进入正题。接线:         RS----PB15RW----PB14EN----PB13PSB---GND1.初始化IO口以及显示屏void Lcd_Init(void) {
发表于 2019-07-30
详细介绍STM32驱动程序库STM32F1xx_DFP中的文件含义及其作用
嵌入式应用程序的开发可以基于微控制器厂商提供的驱动程序库,也可以针对外设寄存器直接编写驱动程序。使用厂商提供的驱动程序库进行开发,简单、快捷,兼容性好,便于移植,但代码略多;直接针对寄存器编程进行开发(建议利用头文件stm32f10x.h定义的寄存器结构和位定义),费时耗力,但能够深入理解原理,代码简洁高效。所以,建议初学者从驱动程序库入手,逐渐深入到寄存器编程。MDK-ARM开发工具本身已经包含了STM32固件库,并可以通过软件包安装程序进行更新。STM32F1xxx_DFP.2.0.0的驱动程序主要在如下目录中:F:Keil_v5ARMPackKeilSTM32F1xx_DFP2.0.0Device,包含了开发所必须的基本代码
发表于 2019-07-30
STM32 之四 标准外设版 USB 驱动 + MSC(Host) + Fatfs 移植
写在前面现在,网上关于STM32的USB的文章数不胜数。写这篇文章仅仅是对于自我学习的一个记录。主要是对实际学习中遇到的一些棘手问题做个备忘录。使用的芯片为STM32F407VG 。目前,ST的USB驱动有两套,一套是早期的独立版USB驱动,官方培训文档中称为Legacy library,最新版为2.2.0;一套为针对其Cube系列的驱动,根据芯片不同可能有区别,具体见对应芯片的Cube驱动包,官方培训文档中称为Cube library。 本文使用的为Legacy libraryUSB驱动。更详细的请参考博文STM32 之 USB IP(USB模块) 详解。HAL库 + Legacy library USB库两个混用目前
发表于 2019-07-29
基于stm32f10x的超声波模块HC-SR04的测距示例
一.所需材料:1任何一种型号的stm32f10x的微控制器2.HC-SR04模块3.安装串口驱动与串口助手(这里用的火哥的串口调试助手)4.ST-link或者串口等下载方式都可以二。超声波原理网上一大堆,这里我就大体说一下:单片机先给TRIG一个大于10us的高电平,然后模块ECHO引脚会发出一个高电平,检测高电平的时间乘声速便可算出距离。这里ECHO发出也接收,所以检测的时间,假设按秒算,然后乘170便是以m为单位的距离。三.源代码分析1.接口定义://由于只是用的定时器的基本计时功能,所以IO口随便找两个便可以#define HCSR04_PORT
发表于 2019-08-20
小广播
何立民专栏
单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
