STM32F030 使用内部时钟和外部时钟
2019-10-09来源: eefocus关键字:STM32F030  内部时钟  外部时钟
static void SetSysClock(void)
  __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
  /* SYSCLK, HCLK, PCLK configuration ----------------------------------------*/
#if defined (PLL_SOURCE_HSI)
  /* At this stage the HSI is already enabled */
  /* Enable Prefetch Buffer and set Flash Latency */
  FLASH->ACR = FLASH_ACR_PRFTBE | FLASH_ACR_LATENCY;
  /* HCLK = SYSCLK */
  RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
  /* PCLK = HCLK */
  RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE_DIV1;
  /* PLL configuration = (HSI/2) * 12 = ~48 MHz */
  RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
  RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSI_Div2 | RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLMULL12);
  /* Enable PLL */
  RCC->CR |= RCC_CR_PLLON;
  /* Wait till PLL is ready */
  while((RCC->CR & RCC_CR_PLLRDY) == 0)
  /* Select PLL as system clock source */
  RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
  RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
  /* Wait till PLL is used as system clock source */
  while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)RCC_CFGR_SWS_PLL)
#else
 #if defined (PLL_SOURCE_HSE)
  /* Enable HSE */
  RCC->CR |= ((uint32_t)RCC_CR_HSEON);
 #elif defined (PLL_SOURCE_HSE_BYPASS)
  /* HSE oscillator bypassed with external clock */
  RCC->CR |= (uint32_t)(RCC_CR_HSEON | RCC_CR_HSEBYP);
 #endif /* PLL_SOURCE_HSE */
  /* Wait till HSE is ready and if Time out is reached exit */
  do
    HSEStatus = RCC->CR & RCC_CR_HSERDY;
    StartUpCounter++;
  } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
  if ((RCC->CR & RCC_CR_HSERDY) != RESET)
    HSEStatus = (uint32_t)0x01;
  else
    HSEStatus = (uint32_t)0x00;
  if (HSEStatus == (uint32_t)0x01)
    /* HCLK = SYSCLK */
    /* PCLK = HCLK */
    /* PLL configuration = HSE * 6 = 48 MHz */
    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_PREDIV1 | RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLMULL6);
    /* Enable PLL */
  else
  { /* If HSE fails to start-up, the application will have wrong clock
         configuration. User can add here some code to deal with this error */
#endif /* PLL_SOURCE_HSI */
关键字:STM32F030  内部时钟  外部时钟 编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic476479.html 本网站转载的所有的文章、图片、音频视频文件等资料的版权归版权所有人所有,本站采用的非本站原创文章及图片等内容无法一一联系确认版权者。如果本网所选内容的文章作者及编辑认为其作品不宜公开自由传播,或不应无偿使用,请及时通过电子邮件或电话通知我们,以迅速采取适当措施,避免给双方造成不必要的经济损失。
上一篇:STM32F030F4P6单片机由外部时钟改为内部时钟的步骤
下一篇:基于ARM平台的钢琴游戏 实现琴键按下效果
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
stm32f103 c6t6 CAN总线的配置
KEIl5 环境下 中文显示复制过来有问题又懒得打字
发表于 2019-11-13
STM8L051F3_01_GPIO应用
本章介绍STM8L051F3的GPIO相关知识。内容分为以下几部分:GPIO简介点亮LED1、GPIO简介GPIO:通用输入/输出口,用于芯片与外部进行数据传输;STM8L051F3的一个I/O端口最多可以有8个Pins(引脚),每个引脚可以独立地配置为数字输入或数字输出。此外,一些I/O端口可能有一些复用功能如模拟输入、外部中断、片上外设的输入输出等,一个引脚不能同时使用多种复用功能。每个I/O端口都分配有一个输出数据寄存器、输入数据寄存器、数据方向寄存器、两个配置寄存器,一个I/O端口工作在输入或输出状态取决于数据方向寄存器。STM8L051F3的GPIO主要性能如下:端口的位(引脚)能独立配置可选择的输入模式:浮空输入
发表于 2019-11-13
STM32F0x2 IWDG(独立看门狗)
单片机系统在外界的干扰下会出现程序跑飞的现象导致出现死循环,看门狗电路就是为了避免这种情况的发生。看门狗的作用就是在一定时间内(通过定时计数器实现)没有接收喂狗信号(表示 MCU 已经挂了),便实现处理器的自动复位重启(发送复位信号)。 以下为stm32f042单片机独立看门狗相关代码:/***********************************************************函数描述:初始化独立看门狗,timeout为1s*函数:void IWDG_Init(unsigned char usb_sw) *参数:无*作者:*日期
发表于 2019-11-12
STM32F1小白系列之四、独立看门狗(IWDG)
:T(ms) == [(4 * 2^pre_Scaler) * reload] / 40;    IWDG_ReloadCounter();//第一次喂狗    IWDG_Enable();//使能看门狗}//喂狗APIvoid feed_iwdg(void){    IWDG_ReloadCounter();//喂狗,使STM32重新加载【IWDG_RLR中的值】到【看门狗计数器里面】。}2、直接配置寄存器/*    函数功能:初始化独立看门狗    函数名:init_iwdg    返回值:void
发表于 2019-11-12
stm32f0 hal adc配置
Clock Prescaler:和系统时钟同步并且二分频Sampling Time :采样时间,采样时间是你通过寄存器告诉STM32采样模拟量的时间,设置越长越精确
发表于 2019-11-11
stm32f0 hal adc配置
STM32F0xx_看门狗(独立+窗口)配置详细过程
Ⅰ、概述对于看门狗,我觉得做单片机或者嵌入式开发的人员来说并不陌生,今天总结STM32F0看门狗的功能,F0的看门狗有两种:独立和窗口看门狗。今天提供两种看门狗的软件工程实例,供大家下载。两种看门狗各有各的特点,应用在不同的场合,下面将分别简单总结一下独立和窗口看门狗的功能。Ⅱ、下载文章提供的“软件工程”都是在硬件板子上进行多次测试、并保证没问题才上传至360云盘,请放心下载测试,如有问题请检查一下你的板子是否有问题。ST标准外设库和参考手册、数据手册等都可以在ST官网下载,你也可以到我的360云盘下载。关于F0系列芯片的参考手册有多个版本(针对F0不同芯片),但有一个通用版本,就是“STM32F0x128参考手册V8(英文
发表于 2019-11-08
小广播
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
