MSP432学习笔记:GPIO的使用与配置
2019-10-10来源: eefocus关键字:MSP432  GPIO  使用与配置
有官方提供的库函数中有以下库函数,让我们来一一解答。
个人认为GPIO函数主要分两类一类是GPIO中断配置函数
主要有以下几个参数设置大同小异,selectedPort可选有
GPIO_PORT_P1
GPIO_PORT_P2
GPIO_PORT_PA
而selectedPins可选有
GPIO_PIN0
GPIO_PIN1
GPIO_PIN2
GPIO_PIN3
GPIO_PIN4
GPIO_PIN5
GPIO_PIN6
GPIO_PIN7
GPIO_PIN8
GPIO_PIN9
GPIO_PIN10
GPIO_PIN11
GPIO_PIN12
GPIO_PIN13
GPIO_PIN14
GPIO_PIN15
//GPIO中断标志位清除
void GPIO_clearInterruptFlag (uint_fast8_t selectedPort, uint_fast16_t selectedPins)
//GPIO边沿触发方式,edgeSelect有以下选择:GPIO_HIGH_TO_LOW_TRANSITION(下降沿触发)
GPIO_LOW_TO_HIGH_TRANSITION(上升沿触发)
void GPIO_interruptEdgeSelect (uint_fast8_t selectedPort, uint_fast16_t selectedPins,
uint_fast8_t edgeSelect)
//GPIO中断使能关闭
void GPIO_disableInterrupt (uint_fast8_t selectedPort, uint_fast16_t selectedPins)
//GPIO中断使能
void GPIO_enableInterrupt (uint_fast8_t selectedPort, uint_fast16_t selectedPins)
//GPIO获取中断使能标志位,返回(unsigned int)的一个数据
uint_fast16_t GPIO_getEnabledInterruptStatus (uint_fast8_t selectedPort)
//GPIO获取IO中断标志位,返回(unsigned int)的一个数据
uint_fast16_t GPIO_getInterruptStatus (uint_fast8_t selectedPort, uint_fast16_t selectedPins)
void GPIO_registerInterrupt (uint_fast8_t selectedPort, void(intHandler)(void))
//第二类就是普通GPIO口配置函数
uint8_t GPIO_getInputPinValue (uint_fast8_t selectedPort, uint_fast16_t selectedPins)
void GPIO_setAsInputPin (uint_fast8_t selectedPort, uint_fast16_t selectedPins)
void GPIO_setAsInputPinWithPullDownResistor (uint_fast8_t selectedPort, uint_fast16_t
selectedPins)
void GPIO_setAsInputPinWithPullUpResistor (uint_fast8_t selectedPort, uint_fast16_t
selectedPins)
void GPIO_setAsOutputPin (uint_fast8_t selectedPort, uint_fast16_t selectedPins)
void GPIO_setAsPeripheralModuleFunctionInputPin (uint_fast8_t selectedPort, uint_fast16_t
selectedPins, uint_fast8_t mode)
void GPIO_setAsPeripheralModuleFunctionOutputPin (uint_fast8_t selectedPort,
uint_fast16_t selectedPins, uint_fast8_t mode)
void GPIO_setDriveStrengthHigh (uint_fast8_t selectedPort, uint_fast8_t selectedPins)
void GPIO_setDriveStrengthLow (uint_fast8_t selectedPort, uint_fast8_t selectedPins)
void GPIO_setOutputHighOnPin (uint_fast8_t selectedPort, uint_fast16_t selectedPins)
void GPIO_setOutputLowOnPin (uint_fast8_t selectedPort, uint_fast16_t selectedPins)
void GPIO_toggleOutputOnPin (uint_fast8_t selectedPort, uint_fast16_t selectedPins)
void GPIO_unregisterInterrupt (uint_fast8_t selectedPort)
关键字:MSP432  GPIO  使用与配置 编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic476742.html 本网站转载的所有的文章、图片、音频视频文件等资料的版权归版权所有人所有,本站采用的非本站原创文章及图片等内容无法一一联系确认版权者。如果本网所选内容的文章作者及编辑认为其作品不宜公开自由传播,或不应无偿使用,请及时通过电子邮件或电话通知我们,以迅速采取适当措施,避免给双方造成不必要的经济损失。
上一篇:MSP432学习笔记:时钟(一)
下一篇:MSP432学习笔记:CCS的环境配置(库函数的导入)
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
一步步教你使用TI MSP430 LaunchPad
1、用USB线连接电脑PC和目标板LaunchPad。Windows会自动搜索驱动,当然,一般来说,都是安装失败的。2、LaunchPad套件并没有提供光盘,驱动在哪里?IAR for MSP430已经集成了TI USB FET的驱动,所以,我们先把IAR for MSP430给安装上,驱动也就有了。这里驱动路径如下:D:ProgramsIAR SystemsEmbedded Workbench 6.0 Evaluation430driversTIUSBFET至于软件安装时的注册/和谐问题,大家都是很有办法的,你懂的。3、安装了IAR for MSP430之后,重新拔插USB,Windows 7会自动重新搜索驱动,一般是可以安装
发表于 2019-10-21
MSP430学习笔记3——MSP430的寻址模式
汇编语言指令的基本构成 显然汇编指令由操作数和操作码组成。 1、那什么是操作码呢? 操作码:指明CPU要执行什么样的操作。是一条指令必不可少的部分,在汇编语言中用助记符表示。   2、什么是操作数呢? 操作数:指明参与操作的数据或数据所在的地方。 3、寻址方式 因此寻址方式就是指在汇编语言中需指明操作数所在的地方。MSP430共有七种寻址方式。   使用示例
发表于 2019-10-21
MSP430常见问题之LCD 显示驱动类
Q1:晶体一般都是接32768,然后使用液晶很正常。我打算将晶体接6M的替换32768,那么液晶还能正常显示吗A1:看你所用的LCM 模块时序极限是多少HZ,然后看6M情况下,MSP430去驱动LCM 时,程序时间会不会超过这个极限频率,如果超过,得加延时。Q2:I/O 怎样直接驱动LCD,如何做?A2:建议采用带LCD 驱动的芯片。可采用MSP430F4xx系列的芯片。如果不用带LCD 驱动的芯片,可以用IO 口仿LCD 的波形,比较复杂些,不过也能做出来。可以到TI 网站上去下载关于LCD 的应用报告。Q3:段式液晶和点阵式液晶区别和不同的应用?A3:段式液晶显示的信息较少,但是便宜,驱动电路简单。点阵液晶,显示信息丰富
发表于 2019-10-21
MSP430 Launchpad串行/并行12864显示
#include "msp430g2553.h"#define uint unsigned int#define uchar unsigned char /***************************************** RS--->>P2.0 RW--->>P2.1 E---->>P2.2    PSB-->>P2.3   PAUSE>>P2.4 RES-->>P
发表于 2019-10-21
MSP430F5529之捕获模式下的HCSR04超声测距(粗略)
前段时间需要用MSP430F5529,因为是个菜鸟,很多都不会,遇到了很多问题,百度好多东西都是千篇一律的,好些东西都是Ctrl+c,Ctrl+v。而有很多老鸟,可能说不定也是菜鸟一个呢!!一副为了你好的样子,你看手册啊,手册不会吗?你用示波器打啊,示波器不会吗?你什么单位啊,示波器都没有吗?所以才打算在把这个捕获模式搞清楚后发一篇自己的心得吧.。发了半天牢骚,正文如下。要用捕获我们得搞清楚捕获的原理是什么,捕获的原理是通过计数器,记录从使能开始到设定的沿的数值(也可以理解为时间)。在设定为捕获模式下,使能过后,计数器TA0R就开始计数了,在单步调试过程中,可以通过观察CCS里面的Registers各个寄存器的变化来深入的理解
发表于 2019-10-21
浅谈msp430f5529入门(1)——时钟模块DCO
;                    // Set DCO Multiplier for 8MHz // (N + 1) * FLLRef = Fdco // (249 + 1) * 32768 = 8MHz __bic_SR_register(SCG0);                // Enable the FLL control loop关于msp430f5529时钟模块的DCO的分享就到这里。感谢阅读,若有疑问或错误,请留言指出。
发表于 2019-10-21
小广播
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
