STM32流水灯的几种实现方法
2019-10-21来源: eefocus关键字:STM32  流水灯  实现方法
#include “stm32f10x.h”
void RCC_Configuration(void);//2
void GPIO_Configuration(void);//GPIO
void Delay(u32 count)
u32 i=0;
for(;i
int main(void)
{ RCC_Configuration();//3
LED_Init();
while(1)
GPIO_SetBits(GPIOA,GPIO_Pin_0);//第一灯亮
Delay(800000); //延时
GPIO_ResetBits(GPIOA,GPIO_Pin_0); //第一灯灭
Delay(800000); //延时
GPIO_SetBits(GPIOA,GPIO_Pin_1); //第二灯亮
Delay(800000); //延时
GPIO_ResetBits(GPIOA,GPIO_Pin_1); //第二灯灭
Delay(800000); //延时
GPIO_SetBits(GPIOA,GPIO_Pin_2); //第三灯亮
Delay(800000); //延时
GPIO_ResetBits(GPIOA,GPIO_Pin_2); //第三灯灭
Delay(800000); //延时
GPIO_SetBits(GPIOA,GPIO_Pin_3); //第四灯亮
Delay(800000); //延时
GPIO_ResetBits(GPIOA,GPIO_Pin_3); //第四灯灭
Delay(800000); //延时
GPIO_SetBits(GPIOA,GPIO_Pin_4);//
Delay(800000); //延时
GPIO_ResetBits(GPIOA,GPIO_Pin_4); //
Delay(800000); //延时
GPIO_SetBits(GPIOA,GPIO_Pin_5);//
Delay(800000); //延时
GPIO_ResetBits(GPIOA,GPIO_Pin_5); //
Delay(800000); //延时
GPIO_SetBits(GPIOA,GPIO_Pin_6);//
Delay(800000); //延时
GPIO_ResetBits(GPIOA,GPIO_Pin_6); //
Delay(800000); //延时
GPIO_SetBits(GPIOA,GPIO_Pin_7);//
Delay(800000); //延时
GPIO_ResetBits(GPIOA,GPIO_Pin_7); //
Delay(800000); //延时
GPIO_SetBits(GPIOA,GPIO_Pin_8);//
Delay(800000); //延时
GPIO_ResetBits(GPIOA,GPIO_Pin_8); //
Delay(800000); //延时
GPIO_SetBits(GPIOA,GPIO_Pin_9);//
Delay(800000); //延时
GPIO_ResetBits(GPIOA,GPIO_Pin_9); //
Delay(800000); //延时
GPIO_SetBits(GPIOA,GPIO_Pin_10);//
Delay(800000); //延时
GPIO_ResetBits(GPIOA,GPIO_Pin_10); //
Delay(800000); //延时
GPIO_SetBits(GPIOA,GPIO_Pin_11);//
Delay(800000); //延时
GPIO_ResetBits(GPIOA,GPIO_Pin_11); //
Delay(800000); //延时
GPIO_SetBits(GPIOA,GPIO_Pin_12);//
Delay(800000); //延时
GPIO_ResetBits(GPIOA,GPIO_Pin_12); //
Delay(800000); //延时
GPIO_SetBits(GPIOA,GPIO_Pin_13);//
Delay(800000); //延时
GPIO_ResetBits(GPIOA,GPIO_Pin_13); //
Delay(800000); //延时
GPIO_SetBits(GPIOA,GPIO_Pin_14);//
Delay(800000); //延时
GPIO_ResetBits(GPIOA,GPIO_Pin_14); //
Delay(800000); //延时
GPIO_SetBits(GPIOA,GPIO_Pin_15);//
Delay(800000); //延时
GPIO_ResetBits(GPIOA,GPIO_Pin_15); //
  Delay(800000); //延时
void LED_Init(void)//GPIO
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
GPIO_InitTypeDef   GPIO_InitStructure;         //结构体
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOA, &GPIO_InitStructure);
void RCC_Configuration(void) //1
ErrorStatus HSEStartUpStatus;
RCC_DeInit();
RCC_HSEConfig(RCC_HSE_ON);
HSEStartUpStatus = RCC_WaitForHSEStartUp();
if(HSEStartUpStatus == SUCCESS)
RCC_HCLKConfig(RCC_SYSCLK_Div1);
  RCC_PCLK2Config(RCC_HCLK_Div1);
  RCC_PCLK1Config(RCC_HCLK_Div2);
FLASH_SetLatency(FLASH_Latency_2);
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
RCC_PLLCmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
while(RCC_GetSYSCLKSource() != 0x08);
流水灯还有几中实现方法如
用函数GPIO_Write 位置1 再左移 实现流水灯
关键字:STM32  流水灯  实现方法 编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic477809.html 本网站转载的所有的文章、图片、音频视频文件等资料的版权归版权所有人所有,本站采用的非本站原创文章及图片等内容无法一一联系确认版权者。如果本网所选内容的文章作者及编辑认为其作品不宜公开自由传播,或不应无偿使用,请及时通过电子邮件或电话通知我们,以迅速采取适当措施,避免给双方造成不必要的经济损失。
上一篇:STM32学习探究:流水灯的实现
下一篇:stm32入门——跑马灯(基于stm32f103zet6)
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
STM8L低功耗调试总结
STM8L低功耗调试资料准备功耗数据目标实现低功耗资料准备在调试STM单片机相关功能时,习惯性的进入到STM官方论坛进行资料下载。调试STM8功耗也不例外,找到STM8L的应用笔记,选择最热,先看看官方提供的STM8入门文档,入门资料可以选择中文或者英文(STM8L和STM8AL入门)。资料里面有一段话,对功耗调试相当重要:6.6 不使用的 I/O 和特性微控制器都是为多种应用设计的,通常一个应用不会使用 100 % 的微控制器资源。为了避免不必要的功率消耗 (对电池供电应用特别重要),同时提高 EMC 性能,闲置时钟、计数器或 I/O 都不应浮空。 I/O 应该外部强制 (上拉或者下拉到闲置 I/O 引脚),并且不使用的功能应
发表于 2019-11-14
STM8L低功耗调试总结
STM8的停机模式
首先,STM8有三种低功耗模式,即等待、活跃停机和停机。具体它们三者有什么区别自己看官方手册去吧,这里只讲停机模式的应用,其他的一笔带过!一、进入的方式:等待模式进入用的指令是WFI,而活跃停机和停机用的都是halt(),所不同的是,在执行halt指令之前,如果开启了AWU,则是活跃停机,反之则是停机。还有一点要说明的是,在停机模式下独立看门狗是不能养的,而只能养窗口看门狗。二、具体进入的步骤:1、首先,你声明一个标志位,名字自己取。这个标志位是用来判断系统是该处于运行模式还是处于停机模式的。我这里用fPowerOn_flag,如下:bool fPowerOn_flag = FALSE;有了这个标志位以后就写下面的部分了:int
发表于 2019-11-14
halt低功耗模式
1. stm8l152有5种低功耗模式,wait mode, low power run mode, low power wait mode, active-halt mode, halt mode.2. 在halt模式下,cpu和外设时钟停止,可以通过外部中断或者复位来唤醒。3. 本实验设计为:led灯亮,紧接着进入halt模式,有按键时,中断,快速唤醒,led灯灭。     PWR_FastWakeUpCmd(ENABLE);  //快速唤醒使能     //所有IO输出低电平    GPIO_Init(GPIOA
发表于 2019-11-14
STM8L051低功耗模式测试文档
STM8L051的五种低功耗模式wait ,low power run mode,low power wait mode,Ative-Halt mode,Halt mode。WAIT  mode  在等待模式,CPU的时钟是停止的,被选择的外设继续运行。WAIT mode 分为两种方式:WFE,WFI。WFE是等待事件发生,才从等待模式中唤醒。WFI是等待中断发生,才从等待模式中唤醒。low power run mode  在低功耗运行模式下,CPU和被选择的外设在工作,程序执行在LSI或者LSE下,从RAM中执行程序,Flash和EEPROM都要停止运行。电压被配置成Ultra Low Power
发表于 2019-11-14
stm8l 低功耗 halt_active模式
第一次尝试做低功耗,芯片stm8l,用的半halt模式1、关于唤醒,可以用外部中断和RTC(stm8l不同的模式用的唤醒方式均不同)2、关于省电,如果没达到理想的电流,一般都是gpio口问题,没用到的都悬浮输入或输出低都是可以的,用到的统一量一下电平,看看哪个状态不对
发表于 2019-11-14
STM8L EXITB一个端口两个中断的实现
void EXTI_Config(void){     EXTI_DeInit();       EXTI_SetPinSensitivity(EXTI_Pin_5,EXTI_Trigger_Falling);     ITC_SetSoftwarePriority(EXTI5_IRQn, ITC_PriorityLevel_1);    GPIO_Init(KEY_PORT, KEY_RT_PIN, GPIO_Mode_In_PU_IT);    EXTI_SetPinSensitivity(
发表于 2019-11-14
小广播
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
