基于51单片机智能锁原理图PCB+源程序
2019-11-15来源: 51hei关键字:51单片机  智能锁
Altium Designer画的原理图和PCB图如下:
单片机源程序如下:
#include
#include
#include "STC12C5A60S2.h"
#include "main.h"
#include "delay.h"
#include "lcd1602.h"
#include "key.h"
#include "IAPEEPROM.h"
sbit motor=P2^1;
sbit led=P2^2;
sbit buzz=P2^3;
uchar code Start[]           ={"==CODED CLOCK== "};
uchar code Pwd[]      ={"Password:       "};
uchar code Ture[]           ={" Password ture! "};
uchar code Err[]            ={"Error try again!"};
uchar code Wait1[]          ={"     Please     "};
uchar code Wait2[]          ={"wait for 5 min! "};
uchar code InputOld[] ={"Input Old:      "};
uchar code InputNew1[]={"Input New 6 Bit:"};
uchar code InputNew2[]={"Input New Again:"};
uchar code Success[]  ={"    SUCCESS!    "};
uchar code Del[]            ={"                "};
uchar code Open[]           ={"======*==*======"};
uchar code Open1[]           ={"*=====OPEN=====*"};
uchar idata Password[6];
uchar idata InputData[20];
uchar idata TempPassword[20];
uchar idata NewPasswordTemp[6];
uchar N=0;                   //更改密码时的状态 0:输入旧密码 1:输入新密码 2:再次输入新密码
uchar ErrorCont=0;                         //输入密码错误次数计数
uchar State=0;               //0:输入开锁密码状态 1:更改密码状态
uchar Door=0;                                 //0:门锁着 1:门开着
uchar time_1s=0;        //背光
uchar keydown_flag=0;
uchar time_20ms=0;
uchar KeyCodeing(uchar keydown)
        uchar keyval=0;
                if(keydown==11)        //0~9
                        keyval=0;
                if(keydown==14)
                        keyval=1;
                if(keydown==10)
                        keyval=2;
                if(keydown==6)
                        keyval=3;
                if(keydown==13)
                        keyval=4;
                if(keydown==9)
                        keyval=5;
                if(keydown==5)
                        keyval=6;
                if(keydown==12)
                        keyval=7;
                if(keydown==8)
                        keyval=8;
                if(keydown==4)
                        keyval=9;
                if(keydown==15) //确认
                        keyval=10;
                if(keydown==7) //删除
                        keyval=11;
                if(keydown==3) //清零
                        keyval=12;
                if(keydown==0)  //关门
                        keyval=13;
                if(keydown==2)  //返回
                        keyval=14;
                if(keydown==1) // 更改密码
                        keyval=15;
        return keyval;
void Timer0_Init()
        TMOD|=0x01;
        TL0 = (65536-20000)%256;                // 20ms
        TH0 = (65536-20000)/256;                //
        TF0 = 0;
        ET0=1;
        TR0 = 1; //开始计时
uchar PwdCompare(uchar *password,uchar *temppassword)
        uchar n=0,m=0,pass=0;
                if(strlen(temppassword)==6)//等长密码判断
                        for(n=0;n<6;n++)
                                if(temppassword[n]!=password[n])
                                        return 0;
                        return 1;
                else if(strlen(temppassword)>6) //虚位密码判断
                        for(m=0;m
                                if(temppassword[m]!=password[n])
                                        n=0;
                                        pass=0;
[1] [2] [3] [4] [5] [6] [7]
关键字:51单片机  智能锁 编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic480092.html 本网站转载的所有的文章、图片、音频视频文件等资料的版权归版权所有人所有,本站采用的非本站原创文章及图片等内容无法一一联系确认版权者。如果本网所选内容的文章作者及编辑认为其作品不宜公开自由传播,或不应无偿使用,请及时通过电子邮件或电话通知我们,以迅速采取适当措施,避免给双方造成不必要的经济损失。
上一篇:ESP8266+51单片机WIFI控制多路遥控开关程序设计
下一篇:lcd1602显示的单片机子程序 模块化可多次调用
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
基于51单片机的定时器程序设计
这个基于51单片机的定时器设计,使用共阴数码管显示,如果要换成共阳数码管只需要将程序内数组改为共阳数码管的数组,38译码器LSA,LSB,LSC分别接单片机的P2^2,P2^3,P2^4,蜂鸣器使用的是无源蜂鸣器,接单片机P1^5,三个低电平触发按键分别接的P3^1,P3^2,P3^3. sbit LSA=P2^2;sbit LSB=P2^3;sbit LSC=P2^4;sbit key0=P3^1;  //定义P31口是k0sbit key1=P3^0;  //定义P33口是k1sbit key2=P3^2;  //定义P33口是k2sbit beep=P1
发表于 2020-01-20
基于51单片机的定时器程序设计
基于热敏电阻的单片机温度测量系统设计
本课题用一种基于单片机的数据采集系统方案,该方案根据热敏电阻随温度变化而变化的特性,采用串联分压电路。单片机采集热敏电阻的电压,通过A/D转换将模拟量电压信号转换成数字量电压信号,经过查表转换得到温度值,控制液晶屏实时显示温度值。本系统中所用到的器件是STC89C52单片机、NTC热敏电阻和LCD1602液晶显示屏。原理图如下单片机源程序如下:#include<reg52.h>#include<intrins.h>#define uchar unsigned char#define uint unsigned intsbit rs=P0^5;sbit rw=P0^6;sbit e=
发表于 2020-01-20
基于热敏电阻的单片机温度测量系统设计
STC89C52RC单片机+串口+红外控制16路舵机程序
只有控制16路舵机的程序,现在发上来提供参考舵机可以通过串口控制,也可以用红外控制单片机源程序如下:#include "PCA9685_TJ.h"#include <stdio.h>#include <math.h>/*使用说明:        在main主程序                PCA9685_init();        在main主程序的while加入
发表于 2020-01-20
51单片机交通灯系统设计(流程框图+硬件+源码)
:STC公司生产的8051内核,CMOS工艺;1.2.2数码管显示模块的选择方案和论证:选择的是共阳的数码管,单片机的驱动能力不是很强,故此选择共阳数码管;。1.2.3Led灯的选择方案与论证:通过一个Led灯的电流大约是10ms。1.3 电路设计最终方案2.1  表数的产生由定时器T0产生TH0=0xFC;TL0=0x67; 每1ms中断一下,对整个项目的标志量改变一下它的值。2.2  略;3.1 电路设计框图3.2系统硬件描述主要的硬件是89C51这个芯片进行输入输出控制。3.3主要单元电路的设计3.3.1单片机主控模块的设计3.3.2数码管模块的设计3.3.3Led灯模块的设计3.3.4
发表于 2020-01-20
基于单片机的天然气泄漏报警系统设计论文
2.1所示,该系统以STC89C52单片机为核心,天然气检测报警系统要完成天然气信号采集处理、显示和控制报警3大功能。可分为电源模块、天然气信号采集模块、A/D转换模块、声光报警模块、数码管显示模块和单片机控制模块。STC89C52单片机是51系列单片机的一个成员,是8051单片机的升级版,和51系列单片机的指令和输出管脚相兼容。气体检测模块依靠MQ-4传感器和ADC0832转换芯片、显示模块依靠数码管完成显示功能。       图2.1天然气泄露检测报警系统结构框图图2.3.3报警器各模块的功能(1)电源模块:提供电源、保护电路、电压变换、稳压;(2)天然气信号采集模块:实时采集
发表于 2020-01-20
基于单片机的天然气泄漏报警系统设计论文
第一次偿试51单片机做个100分钟倒计时定时器
偿试着做了个100分钟倒计时定时器,原理图和代码都是东拼西凑来的(自己不会写啊),侵删制作出来的实物图如下: 电路原理图如下: 单片机源程序如下:#include <reg52.h>#include <intrins.H>#define uchar unsigned char#define uint  unsigned  int        uchar duan[16]={0xc0
发表于 2020-01-20
小广播
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2020 EEWORLD.com.cn, Inc. All rights reserved
