stm32数据类型
2019-11-18来源: eefocus关键字:stm32  数据类型  变量类型
stm32编程过程经常定义变量类型,经常担心数据运算过程中 超过变量类型范围。因为在编程过程中,不同的CPU,其数据类型的意义各不相同,所以一定要注意相应变量数据类型的定义和转换,否则在计算中可能会出现不确定的错误。所以下面列出常见数据类型:
一、C语言数据类型
stm32使用的数据类型定义在 stm32f30x.h中
This file contains all the peripheral registers definitions, bits
  *          definitions and memory mapping for STM32F30x devices.
整型定义:
#include "core_cm4.h" /* Cortex-M4 processor and core peripherals */
#include "system_stm32f4xx.h"
#include
/** @addtogroup Exported_types
/*!< STM32F10x Standard Peripheral Library old types (maintained for legacy purpose) */
typedef int32_t s32;
typedef int16_t s16;
typedef int8_t s8;
typedef const int32_t sc32; /*!< Read Only */
typedef const int16_t sc16; /*!< Read Only */
typedef const int8_t sc8; /*!< Read Only */
typedef __IO int32_t vs32;
typedef __IO int16_t vs16;
typedef __IO int8_t vs8;
typedef __I int32_t vsc32; /*!< Read Only */
typedef __I int16_t vsc16; /*!< Read Only */
typedef __I int8_t vsc8; /*!< Read Only */
typedef uint32_t u32; /*常用类型*/
typedef uint16_t u16;
typedef uint8_t u8;
typedef const uint32_t uc32; /*!< Read Only */
typedef const uint16_t uc16; /*!< Read Only */
typedef const uint8_t uc8; /*!< Read Only */
typedef __IO uint32_t vu32;
typedef __IO uint16_t vu16;
typedef __IO uint8_t vu8;
typedef __I uint32_t vuc32; /*!< Read Only */
typedef __I uint16_t vuc16; /*!< Read Only */
typedef __I uint8_t vuc8; /*!< Read Only */
浮点型:
#if !defined(__STRICT_ANSI__) || defined(__USE_C99_MATH)
/* C99 additions */
typedef float float_t;
typedef double double_t;
注:还有float 浮点型 编译器中不能看到其定义(估计已编译了)。
而uint32_t 、uint16_t、uint8_t在哪里定义?在stdint.h文件中,详见下面:
/* exact-width signed integer types */
typedef signed char int8_t;
typedef signed short int int16_t;
typedef signed int int32_t;
typedef signed __int64 int64_t;
/* exact-width unsigned integer types */
typedef unsigned char uint8_t;
typedef unsigned short int uint16_t;
typedef unsigned int uint32_t;
typedef unsigned __int64 uint64_t;
/* minimum values of exact-width signed integer types */
#define INT8_MIN -128 /* s8 占用1个byte,数据范围 -2^7 到 (2^7-1) */
#define INT16_MIN -32768 /* s16 占用2个byte,数据范围 -2^15 到 (2^15-1) */
#define INT32_MIN (~0x7fffffff) /* -2147483648 is unsigned s32 占用 4个byte,数据范围 -2^31 到 (2^31-1) */
#define INT64_MIN __ESCAPE__(~0x7fffffffffffffffll) /* -9223372036854775808 is unsigned int64_t占用8个byte,数据范围 -2^63 到 (2^63-1) */
/* maximum values of exact-width signed integer types */
#define INT8_MAX 127
#define INT16_MAX 32767
#define INT32_MAX 2147483647
#define INT64_MAX __ESCAPE__(9223372036854775807ll)
/* maximum values of exact-width unsigned integer types */
#define UINT8_MAX 255 /* u8 占用1个byte, 数据范围 0 - 2^8*/
#define UINT16_MAX 65535 /* u16 占用2个byte, 数据范围 0 - 2^16*/
#define UINT32_MAX 4294967295u /* u32 占用4个byte, 数据范围 0 - 2^32*/
#define UINT64_MAX __ESCAPE__(18446744073709551615ull)
由上述可知:
1、有符号整型
s32 占用 4个byte,数据范围 -2^31 到 (2^31-1)2^31  = 2147483647
int64_t占用8个byte,数据范围 -2^63 到 (2^63-1)    2^63 = 9223372036854775807ll
2、无符号整型
u32 占用4个byte, 数据范围 0 - 2^32 2^32  = 4294967295
uint64_t 占用8个byte, 数据范围 0 - 2^64 2^64  = 18446744073709551615
3、浮点型
float ——4个byte,有符号型,可以表达负数/小数; Float 类型至少要能精确表示到小数点后6位。
double——8个byte,有符号型,可以表达负数/小数;Double 类型至少要能精确到小数点后 10 位。
关键字:stm32  数据类型  变量类型 编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic480334.html 本网站转载的所有的文章、图片、音频视频文件等资料的版权归版权所有人所有,本站采用的非本站原创文章及图片等内容无法一一联系确认版权者。如果本网所选内容的文章作者及编辑认为其作品不宜公开自由传播,或不应无偿使用,请及时通过电子邮件或电话通知我们,以迅速采取适当措施,避免给双方造成不必要的经济损失。
上一篇:stm32f0_GPIO
下一篇:stm32f4xx 加密
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
74LS164 for stm32 源码
:74LS164.c---------------------------------------------------------------------------------------------------------------------------------------------#include "stm32f10x.h"#include "stm32f10x_rcc.h"#include "stm32f10x_gpio.h"#include "74LS164.h"/* 延时模块82615468 sp-320-12 * */static void delay(u32 t){ u32 i; while(t--) for (i = 0; i < 1; i++);}void Ls164Init(void){ GPIO_InitTypeDef
发表于 2019-12-11
STM32 SysTick定时器应用【worldsing笔记】
SysTick是CM内核独立的定时器,时钟可以用内核内部的,也可以用芯片厂家(ST)的时钟,参考《Cortex-M3权威指南》的第13章: 另外也可以考《STM32F10xxx Cortex-M3 programming manual.pdf》第4章CM3系统外设,从手册来看,ST应该只提供了内核外部时钟,而外部时钟又分成两种:HCLK/8 和 HCLK,  ST官方提供了库直接可以操作SYSTICK,但不同的版本使用起来有些区别: 在V2.0的版本中对SysTick的操作是使用的stm32f10x_systick.c和stm32f10x_systick.h void
发表于 2019-12-11
Keil uCos 2.52 stm32 【worldsing笔记】
;    RevBit(LED_GPIO->ODR, 12)           /*LED 状态反转                              */ 2、stm32 Lib V3.5
发表于 2019-12-11
stm32_CAN总线知识
一、CAN总线的特点:bxCAN主要特点● 支持CAN协议2.0A和2.0B主动模式● 波特率最高可达1兆位/秒● 支持时间触发通信功能发送● 3个发送邮箱● 发送报文的优先级特性可软件配置● 记录发送SOF时刻的时间戳接收● 3级深度的2个接收FIFO● 可变的过滤器组:─ 在互联型产品中,CAN1和CAN2分享28个过滤器组─ 其它STM32F103xx系列产品中有14个过滤器组● 标识符列表● FIFO溢出处理方式可配置● 记录接收SOF时刻的时间戳时间触发通信模式● 禁止自动重传模式● 16位自由运行定时器● 可在最后2个数据字节发送时间戳管理● 中断可屏蔽● 邮箱占用单独1块地址空间,便于提高软件效率双CAN● CAN1
发表于 2019-12-11
stm32_CAN总线知识
STM8L051F3_03_CLK应用
本文介绍STM8L的CLK相关知识。内容分为以下几部分:CLK简介系统时钟频率切换1、CLK简介STM8L051F3的时钟控制系统设计时非常稳定的,同时也很容易使用,它可以使得MUC在低消耗下获仍然保持优性能。用户可以通过管理分配到CPU&外设的时钟来达到降低功耗。STM8L051F3有一个安全无干扰的时钟切换机制允许用户切换系统时钟源,同时可以通过预分频器来控制系统时钟频率。时钟结构图如下:注:STM8L051F3的Peripheral Clock enable是13 bit,没有LCD外设STM8L051F3的系统时钟源有以下4种:16MHz内部高速(出厂已校准)RC时钟HSI1~16MHz外部高速振荡器时钟
发表于 2019-12-11
STM8L051F3_03_CLK应用
低功耗版STM8L051的一个诡异配置
为了做个低功耗项目,从最便宜的STM8S003切换到低功耗系列里较便宜的STM8L051;在STM8S003上调通了HALT休眠处理后,最低待机电流是67uA;用了STM8L051后,实测能到2uA;但是后来遇到个诡异的问题,TIMER4莫名其妙不动作,好像不计时了。开关中断,改初始化配置,都没用,很奇怪。最后发现,是init'初始化的时候,没有给TIMER4配置CLK时钟源,导致的,原来的代码并没有写TIM4,        CLK_SYSCLKDivConfig(CLK_SYSCLKDiv_4);
发表于 2019-12-11
小广播
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
