stm32 C语言的数据类型说明
2019-11-19来源: eefocus关键字:stm32  C语言  数据类型说
stm32编程过程经常定义变量类型,经常担心数据运算过程中 超过变量类型范围。因为在编程过程中,不同的CPU,其数据类型的意义各不相同,所以一定要注意相应变量数据类型的定义和转换,否则在计算中可能会出现不确定的错误。所以下面列出常见数据类型:
一、C语言数据类型
stm32使用的数据类型定义在 stm32f4xx.h中
整型定义:
#include "core_cm4.h"             /* Cortex-M4 processor and core peripherals */
#include "system_stm32f4xx.h"
#include
/** @addtogroup Exported_types
/*!< STM32F10x Standard Peripheral Library old types (maintained for legacy purpose) */
typedef int32_t  s32;
typedef int16_t s16;
typedef int8_t  s8;
typedef const int32_t sc32;  /*!< Read Only */
typedef const int16_t sc16;  /*!< Read Only */
typedef const int8_t sc8;   /*!< Read Only */
typedef __IO int32_t  vs32;
typedef __IO int16_t  vs16;
typedef __IO int8_t   vs8;
typedef __I int32_t vsc32;  /*!< Read Only */
typedef __I int16_t vsc16;  /*!< Read Only */
typedef __I int8_t vsc8;   /*!< Read Only */
typedef uint32_t  u32;    /*常用类型*/
typedef uint16_t u16;
typedef uint8_t  u8;
typedef const uint32_t uc32;  /*!< Read Only */
typedef const uint16_t uc16;  /*!< Read Only */
typedef const uint8_t uc8;   /*!< Read Only */
typedef __IO uint32_t  vu32;
typedef __IO uint16_t vu16;
typedef __IO uint8_t  vu8;
typedef __I uint32_t vuc32;  /*!< Read Only */
typedef __I uint16_t vuc16;  /*!< Read Only */
typedef __I uint8_t vuc8;   /*!< Read Only */
浮点型:
#if !defined(__STRICT_ANSI__) || defined(__USE_C99_MATH)
  /* C99 additions */
  typedef float float_t;
  typedef double double_t;
注:还有float 浮点型 编译器中不能看到其定义(估计已编译了)。
而uint32_t 、uint16_t、uint8_t在哪里定义?在stdint.h文件中,详见下面:
    /* exact-width signed integer types */
typedef   signed          char int8_t;
typedef   signed short     int int16_t;
typedef   signed           int int32_t;
typedef   signed       __int64 int64_t;
    /* exact-width unsigned integer types */
typedef unsigned          char uint8_t;
typedef unsigned short     int uint16_t;
typedef unsigned           int uint32_t;
typedef unsigned       __int64 uint64_t;
    /* minimum values of exact-width signed integer types */
#define INT8_MIN                   -128     /* s8 占用1个byte,数据范围 -2^7  到 (2^7-1)  */
#define INT16_MIN                -32768 /* s16 占用2个byte,数据范围 -2^15 到 (2^15-1) */
#define INT32_MIN          (~0x7fffffff)   /* -2147483648 is unsigned   s32 占用 4个byte,数据范围 -2^31 到 (2^31-1)   */
#define INT64_MIN  __ESCAPE__(~0x7fffffffffffffffll) /* -9223372036854775808 is unsigned  int64_t占用8个byte,数据范围 -2^63 到 (2^63-1) */
    /* maximum values of exact-width signed integer types */
#define INT8_MAX                    127
#define INT16_MAX                 32767
#define INT32_MAX            2147483647
#define INT64_MAX  __ESCAPE__(9223372036854775807ll)
    /* maximum values of exact-width unsigned integer types */
#define UINT8_MAX                   255 /* u8  占用1个byte, 数据范围 0 - 2^8*/
#define UINT16_MAX                65535 /* u16 占用2个byte, 数据范围 0 - 2^16*/
#define UINT32_MAX           4294967295u /* u32 占用4个byte, 数据范围 0 - 2^32*/
#define UINT64_MAX __ESCAPE__(18446744073709551615ull)
由上述可知:
1、有符号整型
s32 占用 4个byte,数据范围 -2^31 到 (2^31-1)2^31  = 2147483647
int64_t占用8个byte,数据范围 -2^63 到 (2^63-1)    2^63 = 9223372036854775807ll
2、无符号整型
u32 占用4个byte, 数据范围 0 - 2^32 2^32  = 4294967295
uint64_t 占用8个byte, 数据范围 0 - 2^64 2^64  = 18446744073709551615
3、浮点型
    float ——4个byte,有符号型,可以表达负数/小数; Float 类型至少要能精确表示到小数点后6位。
   double——8个byte,有符号型,可以表达负数/小数;Double 类型至少要能精确到小数点后 10 位。
二、不同数据类型混合运算
在C语言中,不同类型的数据间是可以混合运算的。在进行运算时,不同类型的数据要先转换成同一类型,然后进行运算。转换的规则如下:
注意:箭头的方向只表示数据类型级别的高低,由低向高转换,这个转换过程是一步到位的。
(三)数据类型转换规则
各类数据类型的转换,分为两种方式:隐式(编译软件自动完成),显式(程序强制转换)
隐式转换规则:
字符必须先转换为整数(C语言规定字符类型数据和整型数据之间可以通用)
   short型转换为int型(同属于整型)
   float型数据在运算时一律转换为双精度(double)型,以提高运算精度(同属于实型)
   赋值时,一律是右部值转换为左部类型
[注]
     当整型数据和双精度数据进行运算时,C先将整型数据转换成双精度型数据,再进行运算,结果为双精度类型数据
     当字符型数据和实型数据进行运算时,C先将字符型数据转换成实型数据,然后进行计算,结果为实型数据
显式转换规则:
例:(int)(x+y);
注:强制类型转换时,得到一个所需要的中间变量,原来变量的类型未发生变化。
关键字:stm32  C语言  数据类型说 编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic480475.html 本网站转载的所有的文章、图片、音频视频文件等资料的版权归版权所有人所有,本站采用的非本站原创文章及图片等内容无法一一联系确认版权者。如果本网所选内容的文章作者及编辑认为其作品不宜公开自由传播,或不应无偿使用,请及时通过电子邮件或电话通知我们,以迅速采取适当措施,避免给双方造成不必要的经济损失。
上一篇:使用Ulink2的JTAG与SWD 调试stm32 区别
下一篇:stm32常用数据类型 U8、U16、U32到底代表什么?
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
ST推出经济好用的STM8 Nucleo-32开发板
内核,集成大容量的片上存储器,包括高达128KB的闪存,并与STM32 MCU系列共享最新的外设接口,例如,定时器、模拟外设、CAN2.0B和数字接口。在设计开发对功耗、空间和成本有严格限制的智能传感器、执行器等产品时,STM8 MCU是人气之选。 STM8 Nucleo-32开发板的首款上市产品NUCLEO-8S207K8集成一个32引脚STM8S207K8 MCU,功能包括12个大电流输出端口和多个捕获比较通道。
发表于 2019-12-05
STM8S开发环境搭建IAR For STM8
***********************************************************************************************************************************/   本文采用的是STM8S-Discovery开发板,开发板上半部分为ST Link调试器,芯片采用的是STM32F103C8,下半部分是STM8S105C6的开发板。    对于STM8的开发环境,主要采用两种,一种是IAR For STM8,另一种是官方的ST Toolset。ST Toolset中包含了两个工具STVD(ST Visual Develop)和STVP(ST
发表于 2019-12-05
STM8S内部时钟切换问题解决
/************************************************************************************************************************************ Name    : STM8S内部时钟切换问题解决* Author  : MingMing* Release : 2013/12/28* Update  : 2013/12/29* E-mail  : clint.wang@foxmail.com
发表于 2019-12-05
STM8S内部时钟切换问题解决
STM8S存储器的读写操作
/************************************************************************************************************************************ Name    : STM8S存储器的读写操作* Author  : MingMing* Release : 2014/1/2* Update  : 2014/1/2* E-mail  : clint.wang@foxmail.com
发表于 2019-12-05
stm8l051 halt之后外部中断唤醒问题
最近用到stm8l051 halt,在halt之后开启了外部中断,有时灵,有时不灵,设置下降沿触发,但是按键(低有效)放开了才会从HALT退出,最后发现在进去外部中断的时候一直在外部中断里面不退出。在外部中断程序里面把端口的外部中断和端口使能的外部中断功能关闭,问题解决,可以在下降沿从halt退出。1、开启halt,其他代码省略,只贴halt部分:    /* 禁止TIM3 */    TIM3->SR1 = (uint8_t)(~(uint8_t)TIM3_IT_Update);    CLK_PeripheralClockConfig
发表于 2019-12-05
STM8L052低功耗模式
Stm8L系列单片机的低功耗有五种模式:§ wait模式§ Lowpower run模式§ Lowpower wait模式§ Active-haltwith full RTC模式§ Halt模式最低功耗的就是就是halt模式。这里也主要总结一下如何进入halt模式,进入以后可以通过什么方式唤醒,以及有很多客户会关心的如何自动唤醒。Halt模式进入很简单,执行一条halt指令,调用库函数也就是halt()就行了。但是进入前要注意把所有的中断挂起标志给清除掉。要是不清零又恰巧有中断标志的时候进入该模式也会被立马唤醒。进入这种模式,所有的外设全都关闭了,所有时钟关闭。这时候它自己是醒不过来的,只能靠掐人中(给个外部中断)或者重新复活
发表于 2019-12-05
小广播
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
