单片机成长之路(51基础篇) - 018 keil51的STARTUP.A51
2020-01-15来源: eefocus关键字:单片机  51基础篇  keil51  STARTUP  A51
STARTUP.A51原始文件:
  1 $NOMOD51;Ax51宏汇编器控制命令,禁止预定义的8051。使编译器不使能预定义的;8051符号,避免产生重复定义的错误。
  2 ;------------------------------------------------------------------------------
  3 ;  This file is part of the C51 Compiler package
  4 ;  Copyright (c) 1988-2005 Keil Elektronik GmbH and Keil Software, Inc.
  5 ;  Version 8.01
  6 ;
  7 ;  *** <<< Use Configuration Wizard in Context Menu >>> ***
  8 ;------------------------------------------------------------------------------
  9 ;  STARTUP.A51:  This code is executed after processor reset.
 10 ;
 11 ;  To translate this file use A51 with the following invocation:
 12 ;
 13 ;     A51 STARTUP.A51
 14 ;
 15 ;  To link the modified STARTUP.OBJ file to your application use the following
 16 ;  Lx51 invocation:
 17 ;
 18 ;     Lx51 your object file list, STARTUP.OBJ  controls
 19 ;
 20 ;------------------------------------------------------------------------------
 21 ;
 22 ;  User-defined Power-On Initialization of Memory
 23 ;
 24 ;  With the following EQU statements the initialization of memory
 25 ;  at processor reset can be defined:
 26 ;
 27 ; IDATALEN: IDATA memory size <0x0-0x100>
 28 ;      Note: The absolute start-address of IDATA memory is always 0
 29 ;            The IDATA space overlaps physically the DATA and BIT areas.
 30 IDATALEN        EQU     80H
 31 ;
 32 ; XDATASTART: XDATA memory start address <0x0-0xFFFF>
 33 ;      The absolute start address of XDATA memory
 34 XDATASTART      EQU     0
 35 ;
 36 ; XDATALEN: XDATA memory size <0x0-0xFFFF>
 37 ;      The length of XDATA memory in bytes.
 38 XDATALEN        EQU     0
 39 ;
 40 ; PDATASTART: PDATA memory start address <0x0-0xFFFF>
 41 ;      The absolute start address of PDATA memory
 42 PDATASTART      EQU     0H
 43 ;
 44 ; PDATALEN: PDATA memory size <0x0-0xFF>
 45 ;      The length of PDATA memory in bytes.
 46 PDATALEN        EQU     0H
 47 ;
 48 ;
 49 ;------------------------------------------------------------------------------
 50 ;
 51 ; Reentrant Stack Initialization
 52 ;
 53 ;  The following EQU statements define the stack pointer for reentrant
 54 ;  functions and initialized it:
 55 ;
 56 ; Stack Space for reentrant functions in the SMALL model.
 57 ;  IBPSTACK: Enable SMALL model reentrant stack
 58 ;      Stack space for reentrant functions in the SMALL model.
 59 IBPSTACK        EQU     0       ; set to 1 if small reentrant is used.
 60 ;  IBPSTACKTOP: End address of SMALL model stack <0x0-0xFF>
 61 ;      Set the top of the stack to the highest location.
 62 IBPSTACKTOP     EQU     0xFF +1     ; default 0FFH+1
 63 ;
 64 ;
 65 ; Stack Space for reentrant functions in the LARGE model.
 66 ;  XBPSTACK: Enable LARGE model reentrant stack
 67 ;      Stack space for reentrant functions in the LARGE model.
 68 XBPSTACK        EQU     0       ; set to 1 if large reentrant is used.
 69 ;  XBPSTACKTOP: End address of LARGE model stack <0x0-0xFFFF>
 70 ;      Set the top of the stack to the highest location.
 71 XBPSTACKTOP     EQU     0xFFFF +1   ; default 0FFFFH+1
 72 ;
 73 ;
 74 ; Stack Space for reentrant functions in the COMPACT model.
 75 ;  PBPSTACK: Enable COMPACT model reentrant stack
 76 ;      Stack space for reentrant functions in the COMPACT model.
 77 PBPSTACK        EQU     0       ; set to 1 if compact reentrant is used.
 78 ;
 79 ;    PBPSTACKTOP: End address of COMPACT model stack <0x0-0xFFFF>
 80 ;      Set the top of the stack to the highest location.
 81 PBPSTACKTOP     EQU     0xFF +1     ; default 0FFH+1
 82 ;
 83 ;
 84 ;------------------------------------------------------------------------------
 85 ;
 86 ;  Memory Page for Using the Compact Model with 64 KByte xdata RAM
 87 ;  Compact Model Page Definition
 88 ;
 89 ;  Define the XDATA page used for PDATA variables.
 90 ;  PPAGE must conform with the PPAGE set in the linker invocation.
 91 ;
 92 ; Enable pdata memory page initalization
 93 PPAGEENABLE     EQU     0       ; set to 1 if pdata object are used.
 94 ;
 95 ; PPAGE number <0x0-0xFF>
 96 ; uppermost 256-byte address of the page used for PDATA variables.
 97 PPAGE           EQU     0
 98 ;
 99 ; SFR address which supplies uppermost address byte <0x0-0xFF>
100 ; most 8051 variants use P2 as uppermost address byte
101 PPAGE_SFR       DATA    0A0H
102 ;
103 ;
104 ;------------------------------------------------------------------------------
105
106 ; Standard SFR Symbols
107 ACC     DATA    0E0H
108 B       DATA    0F0H
109 SP      DATA    81H
110 DPL     DATA    82H
111 DPH     DATA    83H
112
113                 NAME    ?C_STARTUP
114
115
116 ?C_C51STARTUP   SEGMENT   CODE
117 ?STACK          SEGMENT   IDATA
118
119                 RSEG    ?STACK
120                 DS      1
121
122                 EXTRN CODE (?C_START)
123                 PUBLIC  ?C_STARTUP
124
125                 CSEG    AT      0
126
[1] [2] [3] [4]
关键字:单片机  51基础篇  keil51  STARTUP  A51 编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic485768.html 本网站转载的所有的文章、图片、音频视频文件等资料的版权归版权所有人所有,本站采用的非本站原创文章及图片等内容无法一一联系确认版权者。如果本网所选内容的文章作者及编辑认为其作品不宜公开自由传播,或不应无偿使用,请及时通过电子邮件或电话通知我们,以迅速采取适当措施,避免给双方造成不必要的经济损失。
上一篇:单片机成长之路(51基础篇) - 020 51单片机寄存器功能一览表
下一篇:单片机成长之路(51基础篇) - 016 常见总线类型
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
AT90S8515单片机SPI驱动74LS595源程序
AT90S8515使用SPI驱动74LS595。我这里使用了SS口线PB.4,作为74LS595的锁存信号,关键是把PB.4设置为输出。74LS595驱动发光管显示加1计数,我用SPI最高速度,所以显示16位计数高八位,低八位太快,看不清楚。单片机源程序如下://ICC-AVR application builder : 2020/3/30 22:23:31// Target : 8515// Crystal: 8.0000Mhz#include <io8515v.h>#include <macros.h>#define SS_ON PORTB |= BIT(4);
发表于 2020-09-16
AT90S8515<font color='red'>单片机</font>SPI驱动74LS595源程序
avr单片机秒表Proteus仿真程序 tm1637数码管显示
单片机源程序如下:/***版权所有(c)2018,艁ukasz Marcin Podkalicki*2009年12月13日            *简单定时器(启动/复位/停止),使用基于TM1637的一个按钮和7段显示模块。              *            *注意,这个ATtiny13项目使用的内部时钟并不精确
发表于 2020-09-16
avr<font color='red'>单片机</font>秒表Proteus仿真程序 tm1637数码管显示
基于MSP430F149的阻抗测量系统设计
  引 言  医学阻抗测量是利用生物组织与器官的电特性及其变化,提取与生物体生理、病理状况相关的生物医学信息的一种检测技术。它通常借助于驱动电极向检测对象送入一微小的交变电流(或电压)信号,同时测量两极的电压(或电流)信号,从而计算出相应阻抗,然后应用于不同目的。  本设计利用MSP430F149自带的串口通过RS485进行远距离实时传输,上位机可将实时数据进行曲线绘制、数据保存等处理。  1 系统结构  系统采用TI公司的MSP430F149单片机。该单片机有60 KB Flash、2 KB RAM,具有强大的数据处理能力。单片机通过向AD9852发送频率字、幅度字从而控制正弦波的频率、幅度。正弦波经过电流转电压、功率放大等电路
发表于 2020-09-16
单片机、ARM、MCU、DSP、FPGA、嵌入式的定义、特征及关系详解
首先,“嵌入式”这是个概念,准确的定义没有,各个书上都有各自的定义。但是主要思想是一样的,就是相比较PC机这种通用系统来说,嵌入式系统是个专用系统,结构精简,在硬件和软件上都只保留需要的部分,而将不需要的部分裁去。所以嵌入式系统一般都具有便携、低功耗、性能单一等特性。然后,MCU、DSP、FPGA这些都属于嵌入式系统的范畴,是为了实现某一目的而使用的工具。MCU 俗称”单片机“经过这么多年的发展,早已不单单只有普林斯顿结构的51了,性能也已得到了很大的提升。因为MCU必须顺序执行程序,所以适于做控制,较多地应用于工业。而ARM本是一家专门设计MCU的公司,由于技术先进加上策略得当,这两年单片机市场份额占有率巨大。ARM
发表于 2020-09-16
51单片机控制+MAX7219+DS1302 电子钟
/***************************************************程序名称:  MAX7219 C语言控制程序                          *程序功能: 3线串行控制8位共阴数码管                       &n
发表于 2020-09-16
基于单片机内部定时器中断计数器设计
电源电路就是单片机的供电电路,一般是3.3V或者5V,具体多少要参考各种型号的单片机的工作电压,通常情况下是5V,这里是指通常情况下。整体设计思路:单片机中断初始化程序应完成du如下工作:1、对TMOD赋值,以确定T0和T1的工作方式。2、计算初值,并将其写入TH0、TL0或TH1、TL1。3、中断方式时,则对IE赋值,开放中断。4、使TR0或TR1置位,启动定时/计数器定时或计数。整体设计思路单片机的中断为向量中断,即一响应中断就转入固定入口地址执行中断服务程序。各中断源服务程序的入口地址两个中断入口间只相隔8字节,难以安放一个完整的中断服务程序。因此,通常在中断入口地址处放置一条无条件转移指令,使程序执行转向中断服务程序入口
发表于 2020-09-16
基于<font color='red'>单片机</font>内部定时器中断计数器设计
小广播
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2020 EEWORLD.com.cn, Inc. All rights reserved
