STM8的福利--Atomthreads实时操作系统
2020-01-16来源: eefocus关键字:STM8  Atomthreads  实时操作系统
Atomthreads是开源的实时操作系统。诞生之初就是给STM8s设计的,而且作者还在不断更新,我看最近的主要修改是加入更多MCU的支持。算法上没有变化。所以我取了1.3的版本,足够用了。
我使用的是STM8S105K4的最小系统。有16Kflash可以使用。这个大小放下原生的atomthreads是够的。
这个实时系统包含了操作系统所有最基本的接口
mutex
semaphore
timer
queue
255级优先级的强占是调度
同优先级时间片轮转
等等。绝对算是完整的操作系统。
并且源代码有所有API调用的例子,这绝对是福利,节约大家时间。要造汽车,绝对不需要每次都从车轮造起。当今世界要站在巨人的肩膀上前进。
回到atomthreads的内部,它需要一个心跳timer,系统默认使用了TIM1这个STM8中功能最强的timer。如果你的系统中要用TIM1做更复杂的事情,那么你可以改用其他的TIM2/TIM3来做心跳。
NO_REG_SAVE void main ( void )
    int8_t status;
     * Note: to protect OS structures and data during initialisation,
     * interrupts must remain disabled until the first thread
     * has been restored. They are reenabled at the very end of
     * the first thread restore, at which point it is safe for a
     * reschedule to take place.
    /* Initialise the OS before creating our threads */
    status = atomOSInit(&idle_thread_stack[IDLE_STACK_SIZE_BYTES - 1], IDLE_STACK_SIZE_BYTES);
    if (status == ATOM_OK)
        /* Enable the system tick timer */
        archInitSystemTickTimer();
        /* Create an application thread */
        status = atomThreadCreate(&main_tcb,
                     TEST_THREAD_PRIO, main_thread_func, 0,
                     &main_thread_stack[MAIN_STACK_SIZE_BYTES - 1],
                     MAIN_STACK_SIZE_BYTES);
             * First application thread successfully created. It is
             * now possible to start the OS. Execution will not return
             * from atomOSStart(), which will restore the context of
             * our application thread and start executing it.
             * Note that interrupts are still disabled at this point.
             * They will be enabled as we restore and execute our first
             * thread in archFirstThreadRestore().
            atomOSStart();
    /* There was an error starting the OS if we reach here */
    while (1)
另外内核默认是会打印debug message。提供printf函数。底层是通过UART2实现。所以调试atomthreads,你需要把UART接出来,通过PL2303转接到PC USB。
static void main_thread_func (uint32_t param)
    uint32_t test_status;
    int sleep_ticks;
    /* Compiler warnings */
    param = param;
    /* Initialise UART (9600bps) */
    if (uart_init(9600) != 0)
        /* Error initialising UART */
    /* Put a message out on the UART */
    printf("Gon");
添加自己的中断服务程序 ISR,要注意,在进入和退出时,分别调用atomIntEnter()和atomIntExit(TRUE)。这两个函数时系统调度器要用到的
#if defined(__IAR_SYSTEMS_ICC__)
#pragma vector = 13
#endif
INTERRUPT void TIM1_SystemTickISR (void)
#if defined(__RCSTM8__)
interrupt 11
#endif
    /* Call the interrupt entry routine */
    atomIntEnter();
    /* Call the OS system tick handler */
    atomTimerTick();
    /* Ack the interrupt (Clear TIM1:SR1 register bit 0) */
    TIM1->SR1 = (uint8_t)(~(uint8_t)TIM1_IT_UPDATE);
    /* Call the interrupt exit routine */
    atomIntExit(TRUE);
另外atomthreads的底层硬件操作实际是调用意法半导体的标准库函数。只不过作者为了让代码精简,只拿出了用到的函数。
为了对代码管理,本人在Kelvin Lawson的基础上开发了自己的分支。又由于我主要使用IAR编译器,所有所有的修改都基于这个开发环境。
关键字:STM8  Atomthreads  实时操作系统 编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic485841.html 本网站转载的所有的文章、图片、音频视频文件等资料的版权归版权所有人所有,本站采用的非本站原创文章及图片等内容无法一一联系确认版权者。如果本网所选内容的文章作者及编辑认为其作品不宜公开自由传播,或不应无偿使用,请及时通过电子邮件或电话通知我们,以迅速采取适当措施,避免给双方造成不必要的经济损失。
上一篇:stm8L051使用库建工程
下一篇:STM8都支持哪些RTOS操作系统?
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
STM8 GPIO 学习(驱动LED、Button)
STM8中GPIO寄存器有:输出寄存器(ODR),输入寄存器(IDR),方向寄存器(DDR),控制寄存器1(CR1)和控制寄存器2(CR2).后面三个寄存器组和可以配置为8种GPIO的模式定义如下:/**  * @brief General Purpose I/Os (GPIO)  */typedef struct GPIO_struct{  __IO uint8_t ODR; /*!< Output Data Register */  __IO uint8_t IDR; /*!< Input Data Register */  __IO uint8_t DDR
发表于 2020-01-19
STM8单片机STVD环境新建工程笔记
;workspace10.修改workspace的路径为我们自己新建的STVDcosmic下。11.项目名称、路径、编译器设置如下 STM8想用C语言编程,很多人都是用的STVD+COSMIC,安装cxstm8_FSE_stm32_32K.exe软件。这里说说STVD的编译的事情,STVD本身只支持汇编语言,想用C还得借助COSMIC,所以一些设置是必须的,就是在STVD下面选择COSMIC的编译文件(这个根据软件版本自行设置),下图用我的举例单单是把两个软件安装好,编译路径配置好,编译的时候肯定还会出现STM8官方头文件找不到的错误,网上也有解决办法,就是要把头文件复制到自己的工程下,在工程下面把头文件添加进来,这样每个工程都得弄一次,实在是
发表于 2020-01-19
STM8单片机STVD环境新建工程笔记
stm8使用iar刚开始烧录ok,用着用着就下载失败解决方案
用iar写代码的时候,用stlink 下载,再排除接线和烧录器问题,基本上都是要重新用stvp烧录下错误提示:Failed to set configuration with MCU name STM8S207MB: SWIM error [30006] xxxxxxx要是嫌麻烦,可以直接用svtp开发也行1.配置iar 输出s19格式点击rebuild all 生成.s19文件文件在Debug/Exe下打开ST Visual Programmer(STVP)并设置硬件连接方式和MCU型号,这里以ST-Link连接STM8S003F为例用swim方式导入要烧录的.s19文件,设置是否锁定芯片(可以不设置)点击下载按钮Program
发表于 2020-01-19
stm8系列通过option_byte 来实现端口的remaping
最近在调 stm8,发现需要用到端口映射,研究下用option byte来修改首先确定需求需要使用PC6来发射方波,用到定时器1的ch1需要激活重定向三种方式可以实现,一种是通过IAR for stm8,一种是stvp,一种是在程序执行的时候去改通过程序写flash,这儿先介绍软件的方式IAR 改option byte打开IAR打开option bytes右击 选择 激活保存到制定位置右击打开option找到地方,勾选之后,在重新rebuil all 然后烧录就行了stvp这个就简单了打开,选择型号,点开option byte下拉框选一下,然后电机这个按钮就行了打完收工
发表于 2020-01-19
IAR for stm8安装破解
1.下载安装包和注册机链接:https://pan.baidu.com/s/1maBEtoyps2HhcdGYxmZUcA提取码:31dn复制这段内容后打开百度网盘手机App,操作更方便哦百度云下载下来这个样子:2.双点击EWSTM8-3104-Autorun安装同意,下一步到结束 。。。 中间会装几个驱动,装就是了装完退出,打完收工3. 注册IAR for STM8是一个收费的软件,官方严厉打击盗版,若你是商业用途,建议购买正版软件。当然,我这里是针对个人开发学习的朋友而言,进行非商业用途的使用。3.1 打开上面安装好的IAR for STM8软件(没有创建桌面快捷方式,可以从开始菜单打开软件)。 Help ->
发表于 2020-01-19
IAR for stm8安装破解
STM32 下载程序时,往flash固定位置写数据配置
1.就像参数定义时使用下面语句const unsigned char Flash_user_data[16] __attribute__((at(0X08080000))) ={            0x01,0x02,0x03,0x04,               0x01,0x01,0x03,0x03,
发表于 2020-01-19
小广播
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2020 EEWORLD.com.cn, Inc. All rights reserved
