4位数码管流水灯时钟程序
2020-01-19来源: 51hei关键字:4位数码管  流水灯  时钟程序
根据数码管和流水灯显示时间,温度等。流水灯有多种样式。
单片机源程序如下:
#include "STC15F2K.h"
#include "intrins.h"
#include
#define uchar unsigned char
#define uint unsigned int
sfr ADC_LOW2    =   0xBE;           //ADC低2位结果
#define ADC_POWER   0x80            //ADC电源控制位
#define ADC_FLAG    0x10            //ADC完成标志
#define ADC_START   0x08            //ADC起始控制位
#define ADC_SPEEDLL 0x00            //540个时钟
#define ADC_SPEEDL  0x20            //360个时钟
#define ADC_SPEEDH  0x40            //180个时钟
#define ADC_SPEEDHH 0x60            //90个时钟
sbit S1=P3^3;
sbit S2=P3^4;
sbit S3=P3^5;
sbit S4=P3^6;
sbit S5=P3^7;
sbit S6=P1^2;
sbit S7=P1^3;
sbit S8=P1^4;
sbit S9=P1^5;
sbit S10=P1^6;
sbit S11=P1^7;
sbit S12=P5^4;
sbit bell=P3^0;
sbit set=P1^0;
sbit jia=P1^1;
uchar dat1[]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xf8,0X80,0X90,0xff,0xc6};
uchar dat2[]={0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0X00,0X10,0xff};//有小数点
uchar dat3[9]={0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF};//
uchar dat4[9]={0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF};//
uchar t_led0[8]={0};
uchar t_led1[8]={0};
uchar table[4]={1,2,3,4};
uchar xg=0;
char t=0;
int t1;
char ps=0;
char flag=1;
int sudu1=0,sudu2=0;
unsigned int temp[2];
int ld;
extern void init_ds1302_io();
extern void init_ds1302();
extern void read_time();
extern void write_time();
extern void read_nao();
extern uchar miao;
extern uchar fen;
extern uchar shi;
extern uchar nfen;
extern uchar nshi;
void Delayms(uint t)
        uchar i;
        while(t--)
           for(i=0;i<100;i++);
void display()
        S12=0;S1=1;
        P2=dat1[table[0]];
        Delayms(2);
        S1=0;S2=1;
        if(flag==0)P2=dat2[table[1]];
        if(flag==1)P2=dat1[table[1]];
        Delayms(2);
        S2=0;S3=1;
        P2=dat1[table[2]];
        Delayms(2);
        S3=0;S4=1;
        P2=dat1[table[3]];
        Delayms(2);
        P2=0xff;
        S4=0;S5=1;
        P2=dat3[t_led0[0]]&dat4[t_led1[0]];
        Delayms(2);
        P2=0xff;
        S5=0;S6=1;
        P2=dat3[t_led0[1]]&dat4[t_led1[1]];
        Delayms(2);
        P2=0xff;
        S6=0;S7=1;
        P2=dat3[t_led0[2]]&dat4[t_led1[2]];
        Delayms(2);
        P2=0xff;
        S7=0;S8=1;
        P2=dat3[t_led0[3]]&dat4[t_led1[3]];
        Delayms(2);
        P2=0xff;
        S8=0;S9=1;
        P2=dat3[t_led0[4]]&dat4[t_led1[4]];
        Delayms(2);
        P2=0xff;
        S9=0;S10=1;
        P2=dat3[t_led0[5]]&dat4[t_led1[5]];
        Delayms(2);
        P2=0xff;
        S10=0;S11=1;
        P2=dat3[t_led0[6]]&dat4[t_led1[6]];
        Delayms(2);
        P2=0xff;
        S11=0;S12=1;
        P2=dat3[t_led0[7]]&dat4[t_led1[7]];
        Delayms(2);
        S1=S2=S3=S4=S5=S6=S7=S8=S9=S10=S11=S12=1;
        P2=0xff;
        S1=S2=S3=S4=S5=S6=S7=S8=S9=S10=S11=S12=0;
        Delayms(2);
void init()
    TMOD= 0x01;
    TL0 = (65536-20000)/256;        //设置定时初值
    TH0 = (65536-20000)%256;        //设置定时初值
    ET0 = 1;
    TR0 = 1;
    EA = 1;
char menu=0;
bit nf=0;
bit gk=0;
void key()
        uchar i;
        if(jia==0 && menu==0)
                while(jia==0);
                xg++;
                nf=0;
                if(xg==2){dat4[0]=0XFF;dat4[1]=0XFF;dat4[2]=0XFF;dat4[3]=0XFF;dat4[4]=0XFF;dat4[5]=0XFF;dat4[6]=0XFF;dat4[7]=0XFF;dat4[8]=0XFF;}
                if(xg==3){dat3[0]=0xFE;dat3[1]=0xFC;dat3[2]=0xF8;dat3[3]=0xF0;dat3[4]=0xE0;dat3[5]=0xC0;dat3[6]=0x80;dat3[7]=0x00;dat3[8]=0xFF;}
                if(xg==5)
                        sudu1=0;sudu2=0;
                        for(i=0;i<9;i++)
                                //dat3[i]=0XFF;
                                dat4[i]=0XFE;
                        dat3[0]=0X01;dat3[1]=0X03;dat3[2]=0X07;dat3[3]=0X0F;dat3[4]=0X1F;dat3[5]=0X3F;dat3[6]=0X7F;dat3[7]=0XFF;dat3[8]=0x00;
                if(xg==6)
                        sudu1=0;sudu2=0;
                        for(i=0;i<9;i++)
                                dat3[i]=0XFF;
                                dat4[i]=0XFC;
                        for(i=0;i<8;i++){t_led0[i]=8;}
                        for(i=0;i<8;i++){t_led1[i]=0;}
                if(xg==7)
                        sudu1=0;sudu2=0;
                        for(i=0;i<9;i++)
                                dat3[i]=0XFF;
                                dat4[i]=0XFF;
                        for(i=0;i<8;i++){t_led0[i]=i;}
                        for(i=0;i<8;i++){t_led1[i]=i;}
                if(xg==8)
                        sudu1=0;sudu2=0;
                        for(i=0;i<9;i++)
dat3[i]=0XFF;
[1] [2] [3] [4] [5] [6] [7]
关键字:4位数码管  流水灯  时钟程序 编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic486144.html 本网站转载的所有的文章、图片、音频视频文件等资料的版权归版权所有人所有,本站采用的非本站原创文章及图片等内容无法一一联系确认版权者。如果本网所选内容的文章作者及编辑认为其作品不宜公开自由传播,或不应无偿使用,请及时通过电子邮件或电话通知我们,以迅速采取适当措施,避免给双方造成不必要的经济损失。
上一篇:stc15系列STC内部EEPROM的读写
下一篇:DS3231温度读取实验 附单片机源程序
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
MSP430F5438A+TM1650四位数码管显示+16位AD转换器ADS1110
MSP430F5438A读取16位AD转换器ADS1110的采集值,通过TM1650串行驱动四位数码管进行显示。开发环境采用IAR,数码管采用共阴极四位数码管,TM1650位串行控制方式,只需要2个IO口既可以实现数据的显示,可以极大的减少IO口的占用。系统电路图、TM1650数码管模块和程序如下所示。/////////////////////////////主函数//////////////////////////////////////void main(){ // uint  j,p;  WDTCTL = WDTPW + WDTHOLD;
发表于 2020-02-20
TM1637四位数码管模块驱动(TM1637.h头文件)51单片机C语言
TM1637四位数码管模块是一个带时钟点的4位共阳数码管(0.36英寸)的显示模块,驱动芯片为TM1637,驱动方式为IIC,因此只需2根信号线即可使单片机控制4位8段数码管(数码管8级灰度可调)。控制接口:共4个引脚(GND、VCC、DIO、CLK),GND为地,VCC为供电电源,DIO为数据输入输出脚,CLK为时钟信号脚。 TM1637.h单片机源程序如下:sbit CLK= P3^4;   //定义模拟IIC总线的时钟线sbit DIO = P3^5;   //定义模拟IIC总线的数据线  code unsigned char tab[] =
发表于 2020-02-06
AVR单片机8位数码管显示的程序实现(两种方法介绍)
本文为大家介绍两个AVR单片机8位数码管显示的程序实现。AVR单片机595驱动8位数码管的显示的电路实现主程序代码#include >#include //GCC中的延时函数头文件#include “hc595.h”//unsigned char Led_Disbuf[10]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F}; //共阴极unsigned char Led_Disbuf[10]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90}; //共阳极unsigned char ComBuf
发表于 2020-01-09
AVR单片机8位数码管显示的程序实现
我们接着来完成 数码管的显示实验。现在我们开始动手编写程序;根据前面的介绍,我们应该已经能够知道编写一个 的C语言程序的基本步骤和方法了。下面给出这个程序的主程序文件,在这个程序中我们应该能够知道这个程序都包含了那几块,具体来说我们应该能够在这个程序中把以下几个部分找出来:预编译语句、 的定义、函数的声明、主函数、函数定义。如果你还不能够准确找出这几部分,那么需要把前面的内容再详细阅读一下。主程序代码#include < /io.h> //io端口寄存器配置文件,必须包含#include <util/delay.h> //GCC中的延时函数头文件#include "
发表于 2020-01-06
两个74HC595驱动8位数码管程序+Proteus仿真
两个74HC595共用了,6个IO口,简单的定时器时钟,主要是74HC595的控制。仿真: 单片机源码:#include<reg52.h>#include<intrins.h>typedef unsigned char uchar;typedef unsigned int uint;#define date P0#define count 50000#define TH_0 (65536-count)/256#define TL_0 (65536-count)%256uchar diss[8];uchar code distab[17] = {0x3f,0x06,0x5b,0x4f,0x66,0x6
发表于 2019-12-26
PWM控制亮度的流水灯c51程序
#include <Reg52.h>//--重定义函数变量--//#define uchar unsigned char#define uint  unsigned int#define ulong unsigned long        /* 定义常量 */#define FOSC 12000000L                //主时钟#define T50us (65536-FOSC/12/1000000*50)      &nbs
发表于 2020-02-19
小广播
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2020 EEWORLD.com.cn, Inc. All rights reserved
