基于51单片机的pwm直流电机调速
2020-02-08来源: 51hei关键字:51单片机  pwm  直流电机调速
仿真原理图如下
单片机源程序如下:
#include
* 定时器初值
#define T0HIGH        0xec
#define T0LOWW        0x8a
typedef unsigned char        u8;
typedef unsigned int        u16;
typedef unsigned long        u32;
typedef bit                                BOOL;
* 单片机管脚定义
sbit KEY_ON_PIN = P2^0;
sbit KEY_INC_PIN = P2^1;
sbit KEY_DEC_PIN = P2^2;
sbit MOTO_LEFT = P3^6;
sbit MOTO_RIGHT = P3^7;
* 按键定义
#define KEY_NULL                0xff
#define KEY_LONG_PERIOD        25
#define KEY_CONTINUE_PERIOD        20
#define KEY_DOWN                0x80
#define KEY_CONTINUE        0x40
#define KEY_UP                        0x20
#define KEY_STATE_INIT                0
#define KEY_STATE_WOBBLE        1
#define KEY_STATE_PRESS                2
#define KEY_STATE_LONG                3
#define KEY_STATE_CONTINUE        4
#define KEY_STATE_RELEASE        5
#define KEY_ON_VALUE                1
#define KEY_INC_VALUE                2
#define KEY_DEC_VALUE                3
#define KEY_ON                (KEY_ON_VALUE | KEY_DOWN)
#define KEY_INC                (KEY_INC_VALUE | KEY_DOWN)
#define KEY_INC_CON        (KEY_INC_VALUE | KEY_CONTINUE)
#define KEY_DEC                (KEY_DEC_VALUE | KEY_DOWN)
#define KEY_DEC_CON        (KEY_DEC_VALUE | KEY_CONTINUE)
* 常量定义
#define true        1
#define false        0
#define MOTO_ON                MOTO_LEFT = false;
                                        MOTO_RIGHT = true
#define MOTO_OFF        MOTO_LEFT = true;
                                        MOTO_RIGHT = true
* 全局变量定义
code u8 DisCode[] = {0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8, 0x80, 0x90, 0xff};
u8 PWMpercent = 0;
u8 DisNum[4] = {0x0a, 0x0a, 0x0a, 0x00};
u8 DisPosition = 0;
u8 SecCount = 0;
u8 u10msNum = 0;
BOOL b10msEvent = false;
BOOL b100msEvent = false;
BOOL b1secEvent = false;
BOOL MotoStart = false;
BOOL MotoRun = false;
void Key_Prosess(void);
void Dynamic_Display(void);
void Speed_Display(void);
* 主函数
main()
        TMOD = 0x01;
        TH0 = T0HIGH;
        TL0 = T0LOWW;
        TR0 = 1;
        ET0 = 1;
        EA = 1;
        P1 = 0x00;
        while(1)
                if(true == b10msEvent)        //10毫秒定时标志
                        b10msEvent = false;
                        Key_Prosess();                //按键扫描
                        Dynamic_Display();                //动态显示
                        if(true == MotoStart)        //如果电机启动
                                if(true == MotoRun)
                                        if(--u10msNum == 0)                //如果电机转动时间到,停止电机
                                                MotoRun = false;
                                                MOTO_OFF;
                                if(true == b1secEvent)                //PWM周期为1秒,1秒钟时间到,开始下一个周期
                                        b1secEvent = false;
                                        MotoRun = true;
                                        MOTO_ON;
                                        u10msNum = PWMpercent;
* 清显示
void Num_Clear(void)
        u8 i;
        for(i=0; i<3; i++)
                DisNum[i] = 0x0a;
        DisNum[3] = 0x00;
* 读键值
u8 Key_Scan(void)
        if(KEY_ON_PIN == false)
                return KEY_ON_VALUE;
        if(KEY_INC_PIN == false)
                return KEY_INC_VALUE;
        if(KEY_DEC_PIN == false)
                return KEY_DEC_VALUE;
        return KEY_NULL;
* 按键状态扫描
u8 GetKey(void)
        static u8 KeyState = KEY_STATE_INIT;
        static u8 KeyTimeCount = 0;
        static u8 LastKey = KEY_NULL;        //保存按键释放时候的键值
        u8 KeyTemp = KEY_NULL ;
        KeyTemp = Key_Scan();
        switch(KeyState)
                case KEY_STATE_INIT:        //初始状态
                        if(KEY_NULL != KeyTemp)        //有键按下
                                KeyState = KEY_STATE_WOBBLE;        //进入消抖
                        break;
                case KEY_STATE_WOBBLE:        //消抖
                        KeyState = KEY_STATE_PRESS;
                        break;
[1] [2]
关键字:51单片机  pwm  直流电机调速 编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic487574.html 本网站转载的所有的文章、图片、音频视频文件等资料的版权归版权所有人所有,本站采用的非本站原创文章及图片等内容无法一一联系确认版权者。如果本网所选内容的文章作者及编辑认为其作品不宜公开自由传播,或不应无偿使用,请及时通过电子邮件或电话通知我们,以迅速采取适当措施,避免给双方造成不必要的经济损失。
上一篇:手把手教你单片机串口通信-基础篇
下一篇:基于51单片机的数字电容测量仪设计
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
9课:单片机数据传递类指令
(R1)=12H(A)=30H(34H)=34HMOV 45H,34HMOV DPTR,#6712HMOV 12H,DPHMOV R0,DPLMOV A,@R0(45H)=34H(DPTR)=6712H(12H)=67H(R0)=12H(A)=67H说明:用括号括起来代表内容,如(23H)则代表内部RAM23H单元中的值,(A)则代表累加器A单元中的值。进入DOS状态,进入WAVE所在的目录,例D:WAVE键入MCS51,出现如下画面<单片机数据传递指令>图1按File->Open,出现对话框后,在Name处输入一个文件名(见图2),如果是下面列表中已存在的,则打开这个文件,如果不存在这个文件,则新建一个文件(见图
发表于 2020-03-10
9课:单片机数据传递类指令
8课:单片机寻址方式与指令系统
通过前面的学习,我们已经了解了单片机内部的结构,并且也已经知道,要控制单片机,让它为我们干学,要用指令,我们已学了几条指令,但很零散,从现在开始,我们将要系统地学习8051单片机的指令部份。一、概述1、指令的格式我们已知,要让计算机做事,就得给计算机以指令,并且我们已知,计算机很“笨”,只能懂得数字,如前面我们写进机器的75H,90H,00H等等,所以指令的第一种格式就是机器码格式,也说是数字的形式。但这种形式实在是为难我们人了,太难记了,于是有另一种格式,助记符格式,如MOV P1,#0FFH,这样就好记了。 这两种格式之间的关系呢,我们不难理解,本质上它们完全等价,只是形式不一样而已。2、汇编我们写指令使用汇编格式,而计算机
发表于 2020-03-10
7课:单片机的特殊功能寄存器
通过前面的学习,我们已知单片机的内部有ROM、有RAM、有并行I/O口,那么,除了这些东西之外,单片机内部究竟还有些什么,这些个零碎的东西怎么连在一起的,让我们来对单片机内部的寄存器作一个完整的功能分析吧!下图中我们能看出,在51单片机内部有一个CPU用来运算、控制,有四个并行I/O口,分别是P0、P1、P2、P3,有ROM,用来存放程序,有RAM,用来存放中间结果,此外还有定时/计数器,串行I/O口,中断系统,以及一个内部的时钟电路。在一个51单片机的内部包含了这么多的东西。对上面的图进行进一步的分析,我们已知,对并行I/O口的读写只要将数据送入到对应I/O口的锁存器就能了,那么对于定时/计数器,串行I/O口
发表于 2020-03-10
7课:单片机的特殊功能寄存器
6课:单片机并行口结构
”。2、输入结构这是并行口的一位的输出结构示意图,再看,除了输出之外,还有两根线,一根从外部管脚接入,另一根从锁存器的输出接出,分别标明读管脚和读锁存器。这两根线是用于从外部接收信号的,为什么要两根呢?原来,在51单片机中输入有两种方式,分别称为‘读管脚’和‘读锁存器’,第一种方式是将管脚作为输入,那是真正地从外部管脚读进输入的值,第二种方式是该管脚处于输出状态时,有时需要改变这一位的状态,则并不需要真正地读管脚状态,而只是读入锁存器的状态,然后作某种变换后再输出。请注意输入结构图,如果将这一根引线作为输入口使用,我们并不能保证在任何时刻都能得到正确的结果(为什么?)参考图2输入示意图。接在外部的开关如果打开,则应当是输入1,而如果闭合开关
发表于 2020-03-10
6课:单片机并行口结构
5课:单片机延时程序分析
是多长时间吧。设一个单片机工作于12M晶体震荡器,它的时钟周期是1/12(微秒)。它的一个机器周期是12*(1/12)也就是1微秒。(请计算一个工作于6M晶体震荡器的单片机,它的机器周期是多少)。MCS-51单片机的所有指令中,有一些完成得比较快,只要一个机器周期就行了,有一些完成得比较慢,得要2个机器周期,还有两条指令要4个机器周期才行。这也不难再解,不是吗?我让你扫地的执行要完成总得比要你完成擦黑板的指令时间要长。为了恒量指令执行时间的长短,又引入一个新的概念:指令周期。所谓指令周期就是指执行一条指令的时间。INTEL对每一条指令都给出了它的指令周期数,这些数据,大部份不需要我们去记忆,但是有一些指令是需要记住的,如DJNZ指令是双周
发表于 2020-03-10
5课:单片机延时程序分析
单片机模拟I2C总线及24C02(I2C EEPROM)读写实例
;*//************************************************************************//* Name:AT24C02存储器的读写程序,用到I2C总线,含相对独立的I2C总线读写函数 *//* Language: C51单片机编程语言                                          *//* Platform: Win98,Intel Celeron 433 Processor,伟福仿真器,仿真8751     *//* Author
发表于 2020-03-10
小广播
何立民专栏 单片机及嵌入式宝典
更多每日新闻
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2020 EEWORLD.com.cn, Inc. All rights reserved
