单片机步进电机转速控制程序(速度LED显示)
2020-02-08来源: elecfans关键字:单片机  步进电机  转速控制  速度LED显示
单片机源程序如下:
//数码管位 高位-----低位
//四个按键控制步进电机:正转,反转,加1,减1
//上电时电机启动,数码管上显示速度最小档1,加减档位均能通过数码管显示出来,电机采用单双八拍方式
//电机转速一共10档,通过按键调节转速
//电机正转时最高位数码管显示0,反转时显示1
#include
#define uchar unsigned char
#define uint unsigned int
#define led P0//数码管段选
#define haha P2
sbit s1 = P1^0;
sbit s2 = P1^1;
sbit s3 = P3^0;
sbit s4 = P3^1;
sbit s5 = P3^2;//按键定义,s1正转,s2反转,s3加1,s4减1
sbit wei3 = P2^3;sbit wei2 = P2^2;sbit wei1 = P2^1;sbit wei0 = P2^0;//数码管位选定义
sbit a = P2^7;sbit b = P2^6;sbit c = P2^5;sbit d = P2^4;//脉冲信号输入端定义
uchar code tab[11]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff};//共阳数码管驱动信号0---9,不显示
uchar code time_counter[10][2]={{0xda,0x1c},{0xde,0xe4},{0xe1,0xec},{0xe5,0xd4},{0xe9,0xbc},  //9.7 ----1ms
                                                            {0xed,0xa4},{0xf1,0x8c},{0xf5,0x74},{0xf9,0x5c},{0xfc,0x18}};
uchar code qudong[8]={0x80,0xc0,0x40,0x60,0x20,0x30,0x10,0x90};
uchar num1 = 0;//控制取励磁信号变量
uchar num2 = 8;
char k=0;//加减档位控制,1为最小档
char pause=1;//暂停时保存之前的转速,开机默认1
bit flag1 = 0;//初始正转,正反转标志
uchar buf[4]={0,10,0,0};//数码管显示缓存,正转,不显示,不显示,显示1档位,高----低
//================================定时器0/1初始化函数================================
void T0_T1_init()
        TMOD = 0x11;//定时器0/1均工作于方式1,16位计时方式
           TH1 = time_counter[k-1][0];
        TL1 = time_counter[k-1][1];//定时器1,定时10ms用于步进电机转速控制
        TR1 = 0;
        ET1= 1;//开定时器中断
        EA = 1;//开总中断
//================================ms级延时函数=======================================
void delay1m(uint x)
    uint i,j;
    for(i=0;i
             for(j=0;j<120;j++);   //数120 次,约1 ms
void display()
        wei3=1;wei2=1;wei1=1;wei0=0;led = tab[buf[3]];delay1m(1);led=0xff;
    wei3=1;wei2=1;wei1=0;wei0=1;led = tab[buf[2]];delay1m(1);led=0xff;
    wei3=1;wei2=0;wei1=1;wei0=1;led = tab[buf[1]];delay1m(1);led=0xff;
        wei3=0;wei2=1;wei1=1;wei0=1;led = tab[buf[0]];delay1m(1);led=0xff;
//================================主函数=============================================
void main()
        T0_T1_init();
        buf[1] = 10;//不显示
        while(1)
                display();
                if(s1 == 0)
                        delay1m(3);
                        if(s1 == 0)
                                flag1 = 0;//正转
                                buf[0] = 0;//最高位显示0
                //                haha = 0x00;//停止
                        while(!s1) display();
                if(s2 == 0 )
                        delay1m(3);
                        if(s2 == 0)
                                flag1 = 1;//反转
                                buf[0] = 1;//最高位显示1
                //                haha = 0x00;//停止
                        while(!s2) display();
                if(s3 == 0)           //速度加1档
                        delay1m(3);
                        if(s3 == 0)
                                k++;
                                TR1=1;
                                if(k > 10 )
                                        k = 1;
                                buf[2]= k/10;
                                buf[3]= k%10;
                        while(!s3) display();
                if(s4 == 0)         //速度减1档
                        delay1m(3);
                        if(s4 == 0)
                                k--;
                                TR1=1;
                                if(k <= 0)
                                        k = 10;
                                buf[2]= k/10;
                                buf[3]= k%10;
                        while(!s4) display();
                if(s5==0)
                        delay1m(3);
                        if(s5==0)
                                if(TR1==1)
                                        pause=k;
[1] [2]
关键字:单片机  步进电机  转速控制  速度LED显示 编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic487577.html 本网站转载的所有的文章、图片、音频视频文件等资料的版权归版权所有人所有,本站采用的非本站原创文章及图片等内容无法一一联系确认版权者。如果本网所选内容的文章作者及编辑认为其作品不宜公开自由传播,或不应无偿使用,请及时通过电子邮件或电话通知我们,以迅速采取适当措施,避免给双方造成不必要的经济损失。
上一篇:STC单片机+DM134实现LED多段控制
下一篇:基于52单片机控制编码器显示程序
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
9课:单片机数据传递类指令
单片机数据传递类指令(3)以直接地址为目的操作数的指令MOV direct,A 例: MOV 20H,AMOV direct,Rn MOV 20H,R1MOV direct1,direct2 MOV 20H,30HMOV direct,@Ri MOV 20H,@R1MOV direct,#data MOV 20H,#34H(4)以间接地址为目的操作数的指令MOV @Ri,A 例:MOV @R0,AMOV @Ri,direct MOV @R1,20HMOV @Ri,#data MOV @R0,#34H(5)十六位数的传递指令MOV DPTR,#data168051是一种8位机,这是唯一的一条16位立即
发表于 2020-03-10
9课:单片机数据传递类指令
8课:单片机寻址方式与指令系统
通过前面的学习,我们已经了解了单片机内部的结构,并且也已经知道,要控制单片机,让它为我们干学,要用指令,我们已学了几条指令,但很零散,从现在开始,我们将要系统地学习8051单片机的指令部份。一、概述1、指令的格式我们已知,要让计算机做事,就得给计算机以指令,并且我们已知,计算机很“笨”,只能懂得数字,如前面我们写进机器的75H,90H,00H等等,所以指令的第一种格式就是机器码格式,也说是数字的形式。但这种形式实在是为难我们人了,太难记了,于是有另一种格式,助记符格式,如MOV P1,#0FFH,这样就好记了。 这两种格式之间的关系呢,我们不难理解,本质上它们完全等价,只是形式不一样而已。2、汇编我们写指令使用汇编格式,而计算机
发表于 2020-03-10
7课:单片机的特殊功能寄存器
通过前面的学习,我们已知单片机的内部有ROM、有RAM、有并行I/O口,那么,除了这些东西之外,单片机内部究竟还有些什么,这些个零碎的东西怎么连在一起的,让我们来对单片机内部的寄存器作一个完整的功能分析吧!下图中我们能看出,在51单片机内部有一个CPU用来运算、控制,有四个并行I/O口,分别是P0、P1、P2、P3,有ROM,用来存放程序,有RAM,用来存放中间结果,此外还有定时/计数器,串行I/O口,中断系统,以及一个内部的时钟电路。在一个51单片机的内部包含了这么多的东西。对上面的图进行进一步的分析,我们已知,对并行I/O口的读写只要将数据送入到对应I/O口的锁存器就能了,那么对于定时/计数器,串行I/O口
发表于 2020-03-10
7课:单片机的特殊功能寄存器
6课:单片机并行口结构
上两次我们做过两个实验,都是让P1.0这个管脚使灯亮,我们能设想:既然P1.0能让灯亮,那么其它的管脚可不能呢?看一下图1,它是8031单片机管脚的说明,在P1.0旁边有P1.1,P1.2….P1.7,它们是否都能让灯亮呢?除了以P1开头的外,还有以P0,P2,P3开头的,数一下,一共是32个管脚,前面我们以学过7个管脚,加上这32个这39个了。它们都以P字开头,只是后面的数字不一样,它们是否有什么联系呢?它们能不能都让灯亮呢?在我们的实验板上,除了P10之外,还有P11 -> P17都与LED相连,下面让我们来做一个实验,程序如下:MAIN: MOV P1,#0FFHLCALL DELAYMOV P1,#00HLCALL
发表于 2020-03-10
6课:单片机并行口结构
5课:单片机延时程序分析
;      ;(10)〈单片机延时程序〉MOV:这是一条指令,意思是传递数据。说到传递,我们都很清楚,传东西要从一本人的手上传到另一本人的手上,也就是说要有一个接受者,一个传递者和一样东西。从指令MOV R7,#250中来分析,R7是一个接受者,250是被传递的数,传递者在这条指令中被省略了(注意:并不是每一条传递指令都会省的,事实上大部份数据传递指令都会有传递者)。它的意义也很明显:将数据250送到R7中去,因此执行完这条指令后,R7单元中的值就应当是250。在250前面有个#号,这又是什么意思呢?这个#就是用来说明250就是一个被传递的东西本身,而不是传递者。那么MOV R6,#250是什么
发表于 2020-03-10
5课:单片机延时程序分析
单片机模拟I2C总线及24C02(I2C EEPROM)读写实例
/*     51系列单片机在使用时,有时需要模拟I2C总线,                      *//*   这里举出一个实例(读写串行EEPROM芯片at2402)
发表于 2020-03-10
小广播
何立民专栏 单片机及嵌入式宝典
更多每日新闻
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2020 EEWORLD.com.cn, Inc. All rights reserved
