MSP430按键控制串口发送数据
2020-02-12来源: eefocus关键字:MSP430  按键控制  串口  发送数据
#include
//MSP430G2553  - 使用USCI_A0,Up Mode, DCO SMCLK
//  介绍: 该程序利用USCI_A0来与计算机通信 通过接在P1.3口的按键来实现按一次发送一个数据
//  波特率9600,数据格式8N1
//  ACLK = 32768, SMCLK = 32768  MCLK =  DCO-16M
//               MSP430G2553
//        /||              XIN|-
//         --|RST          XOUT|-
//           |         P1.0/TA1|-->led
//  使用 MSP430 LaunchPad , MSP430G2553芯片
//CCS5.2编译通过,P1.3内部上拉一定要开启,不然会没反应
void CLK_Init(void);
void USCIA0_Init(void);
void GPIO_Init(void);
void putchar(unsigned char tx_data);
void putstr(char *s);
unsigned char RX_DATA;
char *string1="Hello430!";
char string2[]="iamzhanhaibo!n";    //n是换行符
void main(void)
    WDTCTL = WDTPW + WDTHOLD;        // Stop WDT
    CLK_Init();
    GPIO_Init();
    USCIA0_Init();
    //_EINT();//开总中断
    __bis_SR_register(LPM0_bits + GIE);       // Enter LPM0, interrupts enabled
// Echo back RXed character, confirm TX buffer is ready first
#pragma vector=PORT1_VECTOR
__interrupt void P1_3ISR(void)
    P1IFG &= ~BIT3;//中断标志位清零
    P1OUT ^= BIT6;//P1.6状态翻转
    IE2 &= ~UCA0RXIE;   //发送时先关闭接收中断,不接收
    while (!(IFG2&UCA0TXIFG));                // USCI_A0 TX buffer ready? 等待TX buffer为空
    UCA0TXBUF = 0x08;                    // TX -> RXed character  发送字符c
    IE2 |= UCA0RXIE;    //发送完了打开接收中断
/*#pragma vector=USCIAB0RX_VECTOR
__interrupt void USCI0RX_ISR(void)
    UCA0TXBUF = UCA0RXBUF;                    // TX -> RXed character  发送接收到的数据
    RX_DATA=UCA0RXBUF;
    if(RX_DATA&0x01){
        P1OUT |= BIT0;
        putstr(string1);
        putstr(string2);
    else
        P1OUT &= ~BIT0;
void putchar(unsigned char tx_data)    //发送字符函数
    UCA0TXBUF = tx_data;                    // TX -> RXed character  发送字符c
void putstr(char *s)   //发送字符串函数
    //如果没有发完,就继续循环发送
    while((*s)!=''){
        putchar(*s);
        s++;
    P1DIR = BIT0 + BIT6;    //p1.0,p1.6外接LED为输出状态
    P1OUT &= ~(BIT0 + BIT6);
    P1SEL  = BIT1 + BIT2 ;           // P1.1 = RXD, P1.2=TXD
    P1SEL2 = BIT1 + BIT2;             //第二外围模式选择
    P1REN |= BIT3; //pull up
    P1OUT |= BIT3;
    P1IE  |= BIT3;       //P1.3中断使能
    P1IES |= BIT3;       //P1.3下降沿有效
    P1IFG &= ~BIT3;      //P1.3中断标志位清零
void CLK_Init(void)
    BCSCTL3 |= LFXT1S_0;
    if (CALBC1_1MHZ ==0xFF || CALDCO_1MHZ == 0xFF){
        while(1);
    BCSCTL1 = CALBC1_1MHZ;          // Set DCO 为1MHz
    DCOCTL = CALDCO_1MHZ;
    UCA0CTL1 |= UCSSEL_1;      //ACLK
    UCA0BR0 = 3;                              // ACLK 32768Hz 9600   32768Hz/9600 = 3.41
    UCA0BR1 = 0;                              // 32768Hz 9600
    UCA0MCTL = UCBRS1 + UCBRS0;               // Modulation UCBRSx = 3  模式控制寄存器
    UCA0CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**  初始化释放,可以操作
    IE2 |= UCA0RXIE;                          // Enable USCI_A0 RX interrupt  接收中断使能
关键字:MSP430  按键控制  串口  发送数据 编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic487924.html 本网站转载的所有的文章、图片、音频视频文件等资料的版权归版权所有人所有,本站采用的非本站原创文章及图片等内容无法一一联系确认版权者。如果本网所选内容的文章作者及编辑认为其作品不宜公开自由传播,或不应无偿使用,请及时通过电子邮件或电话通知我们,以迅速采取适当措施,避免给双方造成不必要的经济损失。
上一篇:msp430f5529串口通信
下一篇:msp430串口接收调试
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
msp430g2553单片机 感应温度的呼吸灯
//程序烧进板子后先进入led灯交替闪烁的待机模式;按下按键后,进入应用模式,绿灯开始呼吸;此时温度上升后绿灯呼吸加快,温度下降后呼吸又会变慢。当温度过高时红灯亮#include  "msp430g2553.h"#define     LED1                  BIT0#define     LED2
发表于 2020-02-08
MSP430 LaunchPad IO外部中断
#include <msp430g2231.h>int main( void ){  // Stop watchdog timer to prevent time out reset  WDTCTL = WDTPW + WDTHOLD;    P1DIR |= 0x01;//设置P1.0口为输出  P1IE  |= 0x08;//使能P1.3中断  P1IES |= 0x08;//P1.3口下降沿触发中断  P1IFG &= ~0x08;//中断标志位清零    _EINT();//开总中断
发表于 2020-02-08
MSP430的IO配置
MSP430单片机一般有多组IO口,P1、P2、P3、P4、P5和P6等。在单片机所有的端口都有控制输入输出方向和进行输入、输出的能力。其中P1、P2组端口具有中断寄存器,能够响应外部中断,大部分端口拥有第二功能。每一个端口都有PxDIR(信号方向)、PxIN(输入)、PxOUT(输出)和PxSEL(功能选择)4个寄存器。P1、P2 可以配置为输入信号上升沿或者下降沿触发中断,但固定的电平不会引起中断,中断所使用的寄存器为:PxIE(中断使能)、PxIES(中断触发沿)、PxIFG(中断标志)。还有一个寄存器PxREN,这个寄存器主要是配置单片机内部的上下拉电阻,注意,早期的单片机并没有内部上下拉电阻。PxDIR:信号方向
发表于 2020-02-08
MSP430的IO配置
MSP430G2553(一)IO外部中断说明
这一篇文章将说明MSP430G2553的IO中断配置,整个P1的IO都可以配置IO中断,但中断处理函数只有一个,MSP430和大多数MCU一样提供上升沿、下降沿选择。在Launchpad上有按键S2,接在P1.3口,当按下后P1.3将接入高电平,从而触发中断。所有寄存器的具体名称和地址,可以查看M430G2553 datasheet 第 21页中对于P1的寄存器定义在实例代码中,配置了P1.3和P1.6的LED灯,当按下P1.3的按键产生中断,LED灯将切换点亮1.按键的中断配置要配置按键中断,需要先设置P1.3口为输入,并且设置上拉电阻以保障稳定性,P1DIR &= ~BIT3;//设置P1.3为输入
发表于 2020-02-08
MSP430利用IO中断方式来实现按键检测
/**********************************************************************************MSP430F14-利用IO中断方式实现按键检测程序*********** 以下是结合MC430F14开发板来实现的按键检处理程序实验。分别使用了采个三个按键接到MSP430的通用IO口,按任意一个按键可以使板上的LED反转。例程中,单片机一直处于最低功耗状态,用户可以通过按下按键后唤醒单片机。单片机唤醒后再进行去抖动动作,同时执行键处理程序;处理完后再次进入LPM4低功耗模式。在本程序中用户可以灵活地修改程序来实现你相关的功能。本程序适用
发表于 2020-02-08
MSP430x149x之----------外部中断
外部中断IO口中断MSP430x149x的6组IO口中,只有P0、P1才具有外部中断功能。设置IO口中断,并书写中断服务函数设置步骤:1. 设置相应IO口的方向为输入,即 在PXDIR 中的相应位置0。2. 设置相应IO口为普通引脚,即PXSEL 中相应位置0。3. 开启相应的IO口中断,即PXIE中的相应位置1。4. 设置中断触发方式,即PxIES中, 0为上升沿,1为下降沿。5. 开启外部总中断,即_EINT();。6. 书写中断服务程序。中断服务子程序的格式:#pragma vector = PORTx_VECTOR_interrupt void IRQ_PORT(void)   ; 中断服务函数名自定
发表于 2020-02-08
小广播
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2020 EEWORLD.com.cn, Inc. All rights reserved
