MSP4301602显示Ⅱ
2020-02-15来源: eefocus关键字:MSP430  1602显示  液晶显示
1602液晶显示
#include
#define CPU_F ((double)8000000)
#define delay_us(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0))
#define delay_ms(x) __delay_cycles((long)(CPU_F*(double)x/1000.0))
#define uchar unsigned char
#define uint  unsigned int
#define ulong unsigned long
#define P10 3
#define P11 6
#define P12 7
#define RS_CLR P3OUT &= ~(1 << P10)        //RS置低
#define RS_SET P3OUT |= (1 << P10)         //RS置高
#define RW_CLR P3OUT &= ~(1 << P11)        //RW置低
#define RW_SET P3OUT |= (1 << P11)         //RW置高
#define EN_CLR P3OUT &= ~(1 << P12)        //E置低
#define EN_SET P3OUT |= (1 << P12)         //E置高
#define DataPort      P4OUT                 //P4口为数据口
#define KeyPort         P1IN                              //独立键盘接在P14~P17
#define LED             P2OUT                             //LED灯接在P2上
uchar key;
uchar temp,keynum = 0;
int shi=23,fen=59,miao=58;
//                    系统时钟初始化
void Clock_Init()
  uchar i;
  BCSCTL1&=~XT2OFF;                 //打开XT振荡器
  BCSCTL2|=SELM1+SELS;              //MCLK为8MHZ,SMCLK为8MHZ
  do{
    IFG1&=~OFIFG;                   //清除震荡标志
    for(i=0;i<100;i++)
       _NOP();                      //延时等待
  while((IFG1&OFIFG)!=0);           //如果标志为1,则继续循环等待
  IFG1&=~OFIFG;
//              MSP430内部看门狗初始化
void WDT_Init()
   WDTCTL = WDTPW + WDTHOLD;       //关闭看门狗
// 初始化IO口子程序
void Port_init()
        P1SEL = 0x00;                   //P2普通IO功能
        P1DIR = 0x0F;                   //P24~P27输入模式,外部电路已接上拉电阻
        P2SEL = 0x00;                   //P5口普通IO功能
        P2DIR = 0xFF;
//        LED = 0X00;                     //P5口输出模式
P4SEL = 0x00;
        P4DIR = 0xFF;
        P3SEL = 0x00;
        P3DIR|= BIT3 + BIT6 + BIT7;     //控制口设置为输出模式
// 显示屏命令写入函数
void LCD_write_com(unsigned char com)
RS_CLR;
RW_CLR;
EN_SET;
DataPort = com;                 //命令写入端口
delay_ms(5);
EN_CLR;
// 显示屏数据写入函数
void LCD_write_data(unsigned char data)
RS_SET;
RW_CLR;
EN_SET;
DataPort = data;                //数据写入端口
delay_ms(5);
EN_CLR;
// 显示屏清空显示
void LCD_clear(void)
LCD_write_com(0x01);            //清屏幕显示
delay_ms(5);
// 写入时分秒
void LCD_write_sfm(uchar add,uchar dat)
  uchar a,b;
  a = dat/10;
  b = dat%10;
  LCD_write_com(0xc0 + add);
  LCD_write_data(a+0x30);
  LCD_write_data(b+0x30);
// 显示屏字符串写入函数
void LCD_write_str(unsigned char x,unsigned char y,unsigned char *s)
    if (y == 0)
    LCD_write_com(0x80 + x);        //第一行显示
    else
    LCD_write_com(0xC0 + x);        //第二行显示
    while (*s)
    LCD_write_data( *s);
    s ++;
// 显示屏单字符写入函数
void LCD_write_char(unsigned char x,unsigned char y,unsigned char data)
    if (y == 0)
    else
    LCD_write_data( data);
// 显示屏初始化函数
void LCD_init(void)
    LCD_write_com(0x38); //显示模式设置
    delay_ms(5);
    LCD_write_com(0x08); //显示关闭
    delay_ms(5);
    LCD_write_com(0x01); //显示清屏
    delay_ms(5);
    LCD_write_com(0x06); //显示光标移动设置
    delay_ms(5);
    LCD_write_com(0x0C); //显示开及光标设置
    delay_ms(5);
// 时钟显示
void clock(void)
  miao++;
  if(miao==60)
    miao=0;
    fen++;
    if(fen==60)
      fen=0;
      shi++;
      if(shi==24)
        shi=0;
      LCD_write_sfm(2,shi);
    LCD_write_sfm(5,fen);
  LCD_write_sfm(8,miao);
// 按键检测
uchar Key_Scan(void)
  uchar key_check;
  uchar key_checkin;
  key_checkin=KeyPort;          //读取IO口状态,判断是否有键按下
  key_checkin&= 0xF0;          //读取IO口状态,判断是否有键按下
  if(key_checkin!=0xF0)            //IO口值发生变化则表示有键按下
      delay_ms(20);                  //键盘消抖,延时20MS
      if(key_checkin!=0xF1)
          key_check=KeyPort;
          switch (key_check & 0xF0)
              case 0xE0:key=1;break;
              case 0xD0:key=2;break;
              case 0xB0:key=3;break;
              case 0x70:key=4;break;
  return key;
//      主程序
void main(void)
     WDT_Init();                         //看门狗设置
//     Clock_Init();                       //系统时钟设置
     Port_init();                        //系统初始化,设置IO口属性
     delay_ms(100);                      //延时100ms
[1] [2]
关键字:MSP430  1602显示  液晶显示 编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic488311.html 本网站转载的所有的文章、图片、音频视频文件等资料的版权归版权所有人所有,本站采用的非本站原创文章及图片等内容无法一一联系确认版权者。如果本网所选内容的文章作者及编辑认为其作品不宜公开自由传播,或不应无偿使用,请及时通过电子邮件或电话通知我们,以迅速采取适当措施,避免给双方造成不必要的经济损失。
上一篇:MSP4301602显示Ⅰ
下一篇:MSP430 IIC通信
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
msp430g2553单片机 感应温度的呼吸灯
//程序烧进板子后先进入led灯交替闪烁的待机模式;按下按键后,进入应用模式,绿灯开始呼吸;此时温度上升后绿灯呼吸加快,温度下降后呼吸又会变慢。当温度过高时红灯亮#include  "msp430g2553.h"#define     LED1                  BIT0#define     LED2
发表于 2020-02-08
MSP430 LaunchPad IO外部中断
#include <msp430g2231.h>int main( void ){  // Stop watchdog timer to prevent time out reset  WDTCTL = WDTPW + WDTHOLD;    P1DIR |= 0x01;//设置P1.0口为输出  P1IE  |= 0x08;//使能P1.3中断  P1IES |= 0x08;//P1.3口下降沿触发中断  P1IFG &= ~0x08;//中断标志位清零    _EINT();//开总中断
发表于 2020-02-08
MSP430的IO配置
MSP430单片机一般有多组IO口,P1、P2、P3、P4、P5和P6等。在单片机所有的端口都有控制输入输出方向和进行输入、输出的能力。其中P1、P2组端口具有中断寄存器,能够响应外部中断,大部分端口拥有第二功能。每一个端口都有PxDIR(信号方向)、PxIN(输入)、PxOUT(输出)和PxSEL(功能选择)4个寄存器。P1、P2 可以配置为输入信号上升沿或者下降沿触发中断,但固定的电平不会引起中断,中断所使用的寄存器为:PxIE(中断使能)、PxIES(中断触发沿)、PxIFG(中断标志)。还有一个寄存器PxREN,这个寄存器主要是配置单片机内部的上下拉电阻,注意,早期的单片机并没有内部上下拉电阻。PxDIR:信号方向
发表于 2020-02-08
MSP430的IO配置
MSP430G2553(一)IO外部中断说明
这一篇文章将说明MSP430G2553的IO中断配置,整个P1的IO都可以配置IO中断,但中断处理函数只有一个,MSP430和大多数MCU一样提供上升沿、下降沿选择。在Launchpad上有按键S2,接在P1.3口,当按下后P1.3将接入高电平,从而触发中断。所有寄存器的具体名称和地址,可以查看M430G2553 datasheet 第 21页中对于P1的寄存器定义在实例代码中,配置了P1.3和P1.6的LED灯,当按下P1.3的按键产生中断,LED灯将切换点亮1.按键的中断配置要配置按键中断,需要先设置P1.3口为输入,并且设置上拉电阻以保障稳定性,P1DIR &= ~BIT3;//设置P1.3为输入
发表于 2020-02-08
MSP430利用IO中断方式来实现按键检测
/**********************************************************************************MSP430F14-利用IO中断方式实现按键检测程序*********** 以下是结合MC430F14开发板来实现的按键检处理程序实验。分别使用了采个三个按键接到MSP430的通用IO口,按任意一个按键可以使板上的LED反转。例程中,单片机一直处于最低功耗状态,用户可以通过按下按键后唤醒单片机。单片机唤醒后再进行去抖动动作,同时执行键处理程序;处理完后再次进入LPM4低功耗模式。在本程序中用户可以灵活地修改程序来实现你相关的功能。本程序适用
发表于 2020-02-08
MSP430x149x之----------外部中断
外部中断IO口中断MSP430x149x的6组IO口中,只有P0、P1才具有外部中断功能。设置IO口中断,并书写中断服务函数设置步骤:1. 设置相应IO口的方向为输入,即 在PXDIR 中的相应位置0。2. 设置相应IO口为普通引脚,即PXSEL 中相应位置0。3. 开启相应的IO口中断,即PXIE中的相应位置1。4. 设置中断触发方式,即PxIES中, 0为上升沿,1为下降沿。5. 开启外部总中断,即_EINT();。6. 书写中断服务程序。中断服务子程序的格式:#pragma vector = PORTx_VECTOR_interrupt void IRQ_PORT(void)   ; 中断服务函数名自定
发表于 2020-02-08
小广播
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2020 EEWORLD.com.cn, Inc. All rights reserved
