MSP430 IIC通信
2020-02-15来源: eefocus关键字:MSP430  IIC通信  器件地址
#include
#define OP_READ 0xa1                    //器件地址读
#define OP_WRITE 0xa0                   //器件地址写
#define uchar unsigned char
#define uint unsigned int
#define SDA_OUT P1DIR |= BIT3
#define SDA_IN P1DIR &= ~BIT3
#define SCL_OUT P1DIR |= BIT2
#define SCL_IN P1DIR &= ~BIT2
#define SDA_H P1OUT |= BIT3
#define SDA_L P1OUT &= ~BIT3
#define SCL_H P1OUT |= BIT2
#define SCL_L P1OUT &= ~BIT2
#define wei_h P5OUT |= BIT5
#define wei_l P5OUT &= BIT5
#define duan_l P6OUT &= ~BIT6
#define duan_h P6OUT |= BIT6
uchar table[16] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
uchar miao;
uchar write;
int num;
void delayus(uint z)
  uint i,j;
  for(i = 0;i<20;i++)
    for(j=0;j
void start()
  SDA_OUT;
  SCL_OUT;
  SDA_H;
  SCL_H;
  delayus(1);
  SDA_L;
  delayus(2);
  SCL_L;
void stop()
  SDA_OUT;
  SCL_OUT;
  SDA_L;
  delayus(2);
  SCL_H;
  delayus(2);
  SDA_H;
void Ack24()
  SDA_OUT;
  SCL_OUT;
  SDA_H;
  SCL_H;
  delayus(2);
  SDA_IN;
  while(P1IN & BIT3)
      SCL_L;
  delayus(2);
//mcu读取数据
uchar read_byte()
  uchar i,read_data;
  SDA_OUT;
  SCL_OUT;
  for(i = 0;i<8;i++)
    SDA_H;
    delayus(1);
    SCL_H;
    SDA_IN;
    read_data <<= 1;
    if(P1IN & BIT3)
      read_data |= 0x01;
      SDA_OUT;
      SCL_L;
  return(read_data);
void write_byte(uint dat)
  uchar i;
  SDA_OUT;
  SCL_OUT;
  for(i = 0;i<8;i++)
    if(dat&0x80)
      SDA_H;
    else
      SDA_L;
    delayus(2);
    SCL_H;
    delayus(2);
    SCL_L;
    delayus(2);
    dat <<= 1;
  SCL_L;
  delayus(2);
  SDA_H;
  delayus(2);
//向指定地址写数据
void write_dat(uchar addr,uchar write_data)
  SDA_OUT;
  SCL_OUT;
  SDA_H;
  SCL_H;
  start();
  write_byte(OP_WRITE);
  Ack24();
  write_byte(addr);
  Ack24();
  write_byte(write_data);
  Ack24();
  stop();
  delayus(1000);
//从指定地址读数据
uchar read_random(uint random_addr)
  uchar i;
  SDA_OUT;
  SCL_OUT;
  SDA_H;
  SCL_H;
  start();
  Ack24();
  write_byte(random_addr);
  Ack24();
  start();
  write_byte(OP_READ);
  Ack24();
  i = read_byte();
  stop();
  return i;
void display(uchar dat)
  P4OUT = table[dat];
  duan_h;
  duan_l;
  P4OUT = ~(1 << num);
  wei_h;
  wei_l;
void Clock(void)
  miao++;
  if(miao==10)
    miao=0;
void main( void )
  P1DIR = 0XFF,P1OUT = 0XFF;
  P2DIR = 0XFF,P2OUT = 0XFF;
  P3DIR = 0XFF,P3OUT = 0XFF;
  P4DIR = 0XFF,P4OUT = 0XFF;
  P5DIR = 0XFF,P5OUT = 0XFF;
  P6DIR = 0XFF,P6OUT = 0XFF;
  SDA_OUT;
  SCL_OUT;
  SDA_H;
  SCL_L;
  // Stop watchdog timer to prevent time out reset
  WDTCTL = WDTPW + WDTHOLD;
  CCR0 = 32768 -1;
  TACTL = TASSEL_1 + MC_1;
  CCTL0 |= CCIE;
  _EINT();
  miao = read_random(3);
  if(miao>9) miao=0;
  while(1)
    display(miao);
    if(write==1)
      write = 0;
      write_dat(3,miao);
    LPM3;
#pragma vector = TIMERA0_VECTOR
__interrupt void TimerA_ISR(void)
  Clock();
  write = 1;
  LPM3_EXIT;
关键字:MSP430  IIC通信  器件地址 编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic488312.html 本网站转载的所有的文章、图片、音频视频文件等资料的版权归版权所有人所有,本站采用的非本站原创文章及图片等内容无法一一联系确认版权者。如果本网所选内容的文章作者及编辑认为其作品不宜公开自由传播,或不应无偿使用,请及时通过电子邮件或电话通知我们,以迅速采取适当措施,避免给双方造成不必要的经济损失。
上一篇:MSP4301602显示Ⅱ
下一篇:MSP430 12864显示
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
msp430g2553单片机 感应温度的呼吸灯
//程序烧进板子后先进入led灯交替闪烁的待机模式;按下按键后,进入应用模式,绿灯开始呼吸;此时温度上升后绿灯呼吸加快,温度下降后呼吸又会变慢。当温度过高时红灯亮#include  "msp430g2553.h"#define     LED1                  BIT0#define     LED2
发表于 2020-02-08
MSP430 LaunchPad IO外部中断
#include <msp430g2231.h>int main( void ){  // Stop watchdog timer to prevent time out reset  WDTCTL = WDTPW + WDTHOLD;    P1DIR |= 0x01;//设置P1.0口为输出  P1IE  |= 0x08;//使能P1.3中断  P1IES |= 0x08;//P1.3口下降沿触发中断  P1IFG &= ~0x08;//中断标志位清零    _EINT();//开总中断
发表于 2020-02-08
MSP430的IO配置
MSP430单片机一般有多组IO口,P1、P2、P3、P4、P5和P6等。在单片机所有的端口都有控制输入输出方向和进行输入、输出的能力。其中P1、P2组端口具有中断寄存器,能够响应外部中断,大部分端口拥有第二功能。每一个端口都有PxDIR(信号方向)、PxIN(输入)、PxOUT(输出)和PxSEL(功能选择)4个寄存器。P1、P2 可以配置为输入信号上升沿或者下降沿触发中断,但固定的电平不会引起中断,中断所使用的寄存器为:PxIE(中断使能)、PxIES(中断触发沿)、PxIFG(中断标志)。还有一个寄存器PxREN,这个寄存器主要是配置单片机内部的上下拉电阻,注意,早期的单片机并没有内部上下拉电阻。PxDIR:信号方向
发表于 2020-02-08
MSP430的IO配置
MSP430G2553(一)IO外部中断说明
这一篇文章将说明MSP430G2553的IO中断配置,整个P1的IO都可以配置IO中断,但中断处理函数只有一个,MSP430和大多数MCU一样提供上升沿、下降沿选择。在Launchpad上有按键S2,接在P1.3口,当按下后P1.3将接入高电平,从而触发中断。所有寄存器的具体名称和地址,可以查看M430G2553 datasheet 第 21页中对于P1的寄存器定义在实例代码中,配置了P1.3和P1.6的LED灯,当按下P1.3的按键产生中断,LED灯将切换点亮1.按键的中断配置要配置按键中断,需要先设置P1.3口为输入,并且设置上拉电阻以保障稳定性,P1DIR &= ~BIT3;//设置P1.3为输入
发表于 2020-02-08
MSP430利用IO中断方式来实现按键检测
/**********************************************************************************MSP430F14-利用IO中断方式实现按键检测程序*********** 以下是结合MC430F14开发板来实现的按键检处理程序实验。分别使用了采个三个按键接到MSP430的通用IO口,按任意一个按键可以使板上的LED反转。例程中,单片机一直处于最低功耗状态,用户可以通过按下按键后唤醒单片机。单片机唤醒后再进行去抖动动作,同时执行键处理程序;处理完后再次进入LPM4低功耗模式。在本程序中用户可以灵活地修改程序来实现你相关的功能。本程序适用
发表于 2020-02-08
MSP430x149x之----------外部中断
外部中断IO口中断MSP430x149x的6组IO口中,只有P0、P1才具有外部中断功能。设置IO口中断,并书写中断服务函数设置步骤:1. 设置相应IO口的方向为输入,即 在PXDIR 中的相应位置0。2. 设置相应IO口为普通引脚,即PXSEL 中相应位置0。3. 开启相应的IO口中断,即PXIE中的相应位置1。4. 设置中断触发方式,即PxIES中, 0为上升沿,1为下降沿。5. 开启外部总中断,即_EINT();。6. 书写中断服务程序。中断服务子程序的格式:#pragma vector = PORTx_VECTOR_interrupt void IRQ_PORT(void)   ; 中断服务函数名自定
发表于 2020-02-08
小广播
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2020 EEWORLD.com.cn, Inc. All rights reserved
