51单片机智能时钟设计
2020-02-17来源: 51hei关键字:51单片机  智能时钟  控制系统
                        aj1=0;
                        cd=3;
                        xieshijian(tiaozheng[0]*10+tiaozheng[1],tiaozheng[2]*10+tiaozheng[3],tiaozheng[4]*10+tiaozheng[5],tiaozheng[6]*10+tiaozheng[7],tiaozheng[8]*10+tiaozheng[9],tiaozheng[10]*10+tiaozheng[11],shijian[12]);
                        ms1=0;//按键1按下松开,去3级菜单
        while(cd==15)//第15级菜单 日位闪烁
                if(ms1>0&&ms1<300)        xianshi(2,0,tiaozheng[0],tiaozheng[1]+17,tiaozheng[2],tiaozheng[3]+17,tiaozheng[4],tiaozheng[5]);
                if(ms1>300&&ms1<600)  xianshi(2,0,tiaozheng[0],tiaozheng[1]+17,tiaozheng[2],tiaozheng[3]+17,28,28);
                if(ms1>600) ms1=0;
                if(ms1>300&&changan==1) ms1=0;
                if(anjian3==0&&aj3==0)//检测按键3
                  delay(5);
                  if(anjian3==0) aj3=1,ms2=0;
          if(anjian3==1&&aj3==1)
                        tiaozheng[5]++;
                        if(tiaozheng[5]==10) tiaozheng[4]++,tiaozheng[5]=0;
                        if(runnian==1&&yue==2&&tiaozheng[4]==3) tiaozheng[4]=0,tiaozheng[5]=1;
                        if(runnian==0&&yue==2&&tiaozheng[4]==2&&tiaozheng[5]==9) tiaozheng[4]=0,tiaozheng[5]=1;
                        if(yue==1&&tiaozheng[4]==3&&tiaozheng[5]==2) tiaozheng[4]=0,tiaozheng[5]=1;
                        if(yue==0&&tiaozheng[4]==3&&tiaozheng[5]==1) tiaozheng[4]=0,tiaozheng[5]=1;
                        changan=0;
                        aj3=0;//按键1按下松开,日++
                if(aj3==1&&ms2>=700) changan=1,ms2=0;//检测长按时间0.5s
                if(aj3==1&&changan==1&&ms2>=100)//快加
                        tiaozheng[5]++;
                        ms2=0;
                if(anjian4==0&&aj4==0)//检测按键4
                  delay(5);
                  if(anjian4==0) aj4=1,ms2=0;
          if(anjian4==1&&aj4==1)
                        tiaozheng[5]--;
                        if(tiaozheng[5]>100) tiaozheng[4]--,tiaozheng[5]=9;
                        if(runnian==1&&yue==2&&tiaozheng[4]==0&&tiaozheng[5]==0) tiaozheng[4]=2,tiaozheng[5]=9;
                        if(runnian==0&&yue==2&&tiaozheng[4]==0&&tiaozheng[5]==0) tiaozheng[4]=2,tiaozheng[5]=8;
                        if(yue==1&&tiaozheng[4]==0&&tiaozheng[5]==0) tiaozheng[4]=3,tiaozheng[5]=1;
                        if(yue==0&&tiaozheng[4]==0&&tiaozheng[5]==0) tiaozheng[4]=3,tiaozheng[5]=0;
                        changan=0;
                        aj4=0;//按键1按下松开,日--
                if(aj4==1&&ms2>=700) changan=1,ms2=0;//检测长按时间0.5s
                if(aj4==1&&changan==1&&ms2>=100)//快减
                        tiaozheng[5]--;
                        ms2=0;
                if(anjian2==0&&aj2==0)//检测按键2
                        delay(5);
                        if(anjian2==0) aj2=1;
                if(anjian2==1&&aj2==1)
                        aj2=0;
                        cd=13;
                        ms1=0;//按键2按下松开,去13级菜单
                if(anjian1==0&&aj1==0)//检测按键1
                        delay(5);
                        if(anjian1==0) aj1=1;
                if(anjian1==1&&aj1==1)
                        aj1=0;
                        cd=3;
[1].. [6] [7] [8] [9] [10] [11] [12] [13] [14] ..[17]
关键字:51单片机  智能时钟  控制系统 编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic488503.html 本网站转载的所有的文章、图片、音频视频文件等资料的版权归版权所有人所有,本站采用的非本站原创文章及图片等内容无法一一联系确认版权者。如果本网所选内容的文章作者及编辑认为其作品不宜公开自由传播,或不应无偿使用,请及时通过电子邮件或电话通知我们,以迅速采取适当措施,避免给双方造成不必要的经济损失。
上一篇:基于51单片机的步进电机控制以及仿真
下一篇:51单片机12864显示的电子密码锁源码
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
51单片机实验8:led点阵(1):点亮一个点
开发板led点阵模块电路图如下:74HC595:74HC595是一个8位串行输入、并行输出的位移缓存器。芯片第11角为数据输入时钟线,上升沿有效。芯片第12脚为输出存储器锁存时钟线,上升沿有效。芯片第13脚为输出有效(低电平)。芯片第14脚为串行数据输入。为表示出输入74HC595的8位二进制数,开发板加入了led模块(图一中绿色所示)。若要使led发光,则需将JP595接vcc。OE为输出有效控制端,低电平有效,所以务必将JOE短接片短接到GND端。_nop_();函数为延时一个机器周期,所对应头文件为intrins.h#include<reg52.h>#include<intrins.h>#define
发表于 2020-05-08
51单片机 4个独立按键控制LED灯 (protues仿真)(C语言版)
}}void main(){while(1){key();}}四、运行程序后成功后,打开proteus右键单击单片机AT89C51,找到编辑,然后添加hex文件
发表于 2020-05-08
51单片机课程设计——led点阵广告牌程序设计
上学期期末的课设题目是led点阵广告牌,当时的要求如下:(1)能够显示不同字符的LED点阵广告牌;(2)按键切换不同的显示效果(如闪烁,静止,平移等);(3)按键切换不同的显示内容;(4)能够显示图形或自定义字符;(5)其他功能(创新部分);(6)系统调试、分析、总结与功能实现。当时用的是我用是的普中科技的STC90C51RD+的单片机,不过只要是51单片机,换哪个51内核的芯片都可以,只要电路和程序匹配就可以。我用的那款普中科技的51单片机可以直接连线决定线路的布置,不需要自己去重新焊一个电路板。然后我根据任务要求连接了电路,写了对应的程序,还有proteus仿真。另外,觉得有趣可以点个赞;有什么有趣的想法可以评论一下,我感兴趣
发表于 2020-05-08
51单片机 基于LED点阵的9~0倒计数
#include <reg52.h>sbit ADDR0 = P1^0;sbit ADDR1 = P1^1;sbit ADDR2 = P1^2;sbit ADDR3 = P1^3;sbit ENLED = P1^4;unsigned char code image[11][8] = {{0xC3, 0x81, 0x99, 0x99, 0x99, 0x99, 0x81, 0xC3}, //数字0{0xEF, 0xE7, 0xE3, 0xE7, 0xE7, 0xE7, 0xE7, 0xC3}, //数字1{0xC3, 0x81, 0x9D, 0x87, 0xC3, 0xF9, 0xC1, 0x81}, //数字2{0xC3,
发表于 2020-05-07
基于51单片机智能红外温控风扇设计
1、设计需求及目标本产品采用单片机+最小系统+数码管显示模块+数码管驱动模块+温度采集模块+人体感应模块+风扇模块+按键模块等构成;功能描述:(1)采用DS18B20温度传感器测温,人体感应模块检测是否有人。(2)共3个按键:1键切换/设置、2键加、3键减。(3)本设计共三种模式:自动模式、手动模式和自然风模式。(4)自动模式,按一下1键可以设置温度上限,再按下设置温度下限,均可以按键加减调整。数码管第一位不显示,后三位显示温度值。人体感应模块检测有人时,温度小于下限风扇不转,温度在上下限之间50%转动,大于上限时,风扇全速转动。人离开后,延迟几秒风扇停止转动,起到节能环保的作用。(5)手动模式,数码管第一位显示风扇档位,后三位
发表于 2020-05-07
基于51单片机智能红外温控风扇设计
C51单片机数码管动态显示
数码管作为最廉价的输出设备,在各种自动化设备中有很大的应用,最简单普通的显示方式为动态刷新显示,称为假动态显示,即通过分时扫描每一位,利于人眼的视觉停留现象,造成一种静态显示的效果,如下图所示:C51单片机由于运行速度很慢,在高刷新频率下,单片机的资源耗费很厉害,这样单片机就不可以再进行大量的计算工作,实际上,单片机在刷新时,只需要周期性的改变GPIO口的状态就可以了,剩下的时间其实都是在空转的状态下,我们能不能将这个空转的状态拿来用呢?当然是可以的啦,这里,我们利用单片机的定时器周期地产能中断,在中断内进行数码管的刷新工作,就可以将等待中断的这个CPU时间拿来做别的事情了。硬件电路:代码贴过来:主函数#include "
发表于 2020-05-07
C51单片机数码管动态显示
小广播
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2020 EEWORLD.com.cn, Inc. All rights reserved
