51单片机——8X8点阵显示
2020-03-24来源: eefocus关键字:51单片机  8X8  点阵显示
74hc595.h:
#ifndef __74hc595_H__
#define __74hc595_H__
/************************************位定义************************************/
sbit DATA_IN = P1^0;         //串行数据输入
sbit ST_CK = P1^1;         //存储寄存器时钟输入
sbit SH_CK = P1^2;         //移位寄存器时钟输入
/***********************************函数声明***********************************/
void Ser_IN(unsigned char Data); //串行数据输入
void Par_OUT(void); //串行数据输出
unsigned char i;
for(i = 0; i < 8; i++)
SH_CK = 0; //CLOCK_MAX=100MHz
DATA_IN = Data & 0x80;
Data <<= 1;
SH_CK = 1;
void Par_OUT(void)
ST_CK = 0;
ST_CK = 1;
#endif
8x8LED.c
#include
#include "74hc595.h"
unsigned char  i;
unsigned int  m,n;
#define  num  sizeof(Digit_Tab) //代码长度
unsigned char code table[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
unsigned char code Digit_Tab[]= {//取模方式 阴码 列扫描 逆向
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x06,0x18,0x60,0x1D,0x60,0x18,0x06,0x00,
0x06,0x18,0x60,0x1C,0x60,0x18,0x06,0x00,
0x0B,0x1F,0x60,0x1C,0x60,0x18,0x06,0x00,
0x00,0x00,0x00,0x40,0x00,0x00,0x00,0x00,
0x00,0x04,0x04,0x7E,0x4E,0x24,0x00,0x00,
0x00,0x44,0x28,0x10,0x28,0x44,0x00,0x00,
0x7C,0x02,0x02,0x7C,0x02,0x02,0x7C,0x00,
0x00,0x3C,0x42,0x42,0x42,0x24,0x00,0x00,
0x00,0x3E,0x40,0x40,0x40,0x3E,0x00,0x00,
0x0A,0x3C,0x42,0x4C,0x42,0x24,0x00,0x00,
0x00,0x3C,0x42,0x42,0x42,0x3C,0x00,0x00,
0x88,0x49,0x2A,0x1F,0xB9,0x49,0x8E,0x00,
0x0A,0xFF,0x1A,0x22,0x2B,0xFE,0x2B,0x22,
0x00,0x3E,0x2E,0x2A,0x7F,0xAA,0xAA,0xBF,
0x00,0x08,0x09,0x89,0x8D,0x7B,0x09,0x08,
void Display(void)
    Ser_IN((table[i]));       //列扫描数据
    Ser_IN(Digit_Tab[i + n]); //查表取出行扫描数据
Par_OUT();       //输出显示
i++;
    if(i == 8)
        i = 0;
                //循环扫描
m++;
    if(m == 300)
        m = 0;
        n++;
    }                   //滚动速度控制
if(n == num - 7)
        n = 0;           //循环显示
void Timer0_init(void)
    TMOD = 0xf8;
    TH0  = 0xcc;
    TL0  = 0x00;
    IE   = 0x82;
    TR0  = 1;
void Timer0_intservice(void) interrupt 1 using 0
    TH0 = 0xf8;
    TL0 = 0xcc;
Display();
void main (void)
Timer0_init();
while(1);
关键字:51单片机  8X8  点阵显示 编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic492473.html 本网站转载的所有的文章、图片、音频视频文件等资料的版权归版权所有人所有,本站采用的非本站原创文章及图片等内容无法一一联系确认版权者。如果本网所选内容的文章作者及编辑认为其作品不宜公开自由传播,或不应无偿使用,请及时通过电子邮件或电话通知我们,以迅速采取适当措施,避免给双方造成不必要的经济损失。
上一篇:单片机开发 --- 8X8LED点阵
下一篇:单片机实验——8X8LED点阵显示技术(二)
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
9课:单片机数据传递类指令
(R1)=12H(A)=30H(34H)=34HMOV 45H,34HMOV DPTR,#6712HMOV 12H,DPHMOV R0,DPLMOV A,@R0(45H)=34H(DPTR)=6712H(12H)=67H(R0)=12H(A)=67H说明:用括号括起来代表内容,如(23H)则代表内部RAM23H单元中的值,(A)则代表累加器A单元中的值。进入DOS状态,进入WAVE所在的目录,例D:WAVE键入MCS51,出现如下画面<单片机数据传递指令>图1按File->Open,出现对话框后,在Name处输入一个文件名(见图2),如果是下面列表中已存在的,则打开这个文件,如果不存在这个文件,则新建一个文件(见图
发表于 2020-03-10
9课:单片机数据传递类指令
8课:单片机寻址方式与指令系统
通过前面的学习,我们已经了解了单片机内部的结构,并且也已经知道,要控制单片机,让它为我们干学,要用指令,我们已学了几条指令,但很零散,从现在开始,我们将要系统地学习8051单片机的指令部份。一、概述1、指令的格式我们已知,要让计算机做事,就得给计算机以指令,并且我们已知,计算机很“笨”,只能懂得数字,如前面我们写进机器的75H,90H,00H等等,所以指令的第一种格式就是机器码格式,也说是数字的形式。但这种形式实在是为难我们人了,太难记了,于是有另一种格式,助记符格式,如MOV P1,#0FFH,这样就好记了。 这两种格式之间的关系呢,我们不难理解,本质上它们完全等价,只是形式不一样而已。2、汇编我们写指令使用汇编格式,而计算机
发表于 2020-03-10
7课:单片机的特殊功能寄存器
通过前面的学习,我们已知单片机的内部有ROM、有RAM、有并行I/O口,那么,除了这些东西之外,单片机内部究竟还有些什么,这些个零碎的东西怎么连在一起的,让我们来对单片机内部的寄存器作一个完整的功能分析吧!下图中我们能看出,在51单片机内部有一个CPU用来运算、控制,有四个并行I/O口,分别是P0、P1、P2、P3,有ROM,用来存放程序,有RAM,用来存放中间结果,此外还有定时/计数器,串行I/O口,中断系统,以及一个内部的时钟电路。在一个51单片机的内部包含了这么多的东西。对上面的图进行进一步的分析,我们已知,对并行I/O口的读写只要将数据送入到对应I/O口的锁存器就能了,那么对于定时/计数器,串行I/O口
发表于 2020-03-10
7课:单片机的特殊功能寄存器
6课:单片机并行口结构
”。2、输入结构这是并行口的一位的输出结构示意图,再看,除了输出之外,还有两根线,一根从外部管脚接入,另一根从锁存器的输出接出,分别标明读管脚和读锁存器。这两根线是用于从外部接收信号的,为什么要两根呢?原来,在51单片机中输入有两种方式,分别称为‘读管脚’和‘读锁存器’,第一种方式是将管脚作为输入,那是真正地从外部管脚读进输入的值,第二种方式是该管脚处于输出状态时,有时需要改变这一位的状态,则并不需要真正地读管脚状态,而只是读入锁存器的状态,然后作某种变换后再输出。请注意输入结构图,如果将这一根引线作为输入口使用,我们并不能保证在任何时刻都能得到正确的结果(为什么?)参考图2输入示意图。接在外部的开关如果打开,则应当是输入1,而如果闭合开关
发表于 2020-03-10
6课:单片机并行口结构
5课:单片机延时程序分析
是多长时间吧。设一个单片机工作于12M晶体震荡器,它的时钟周期是1/12(微秒)。它的一个机器周期是12*(1/12)也就是1微秒。(请计算一个工作于6M晶体震荡器的单片机,它的机器周期是多少)。MCS-51单片机的所有指令中,有一些完成得比较快,只要一个机器周期就行了,有一些完成得比较慢,得要2个机器周期,还有两条指令要4个机器周期才行。这也不难再解,不是吗?我让你扫地的执行要完成总得比要你完成擦黑板的指令时间要长。为了恒量指令执行时间的长短,又引入一个新的概念:指令周期。所谓指令周期就是指执行一条指令的时间。INTEL对每一条指令都给出了它的指令周期数,这些数据,大部份不需要我们去记忆,但是有一些指令是需要记住的,如DJNZ指令是双周
发表于 2020-03-10
5课:单片机延时程序分析
单片机模拟I2C总线及24C02(I2C EEPROM)读写实例
;*//************************************************************************//* Name:AT24C02存储器的读写程序,用到I2C总线,含相对独立的I2C总线读写函数 *//* Language: C51单片机编程语言                                          *//* Platform: Win98,Intel Celeron 433 Processor,伟福仿真器,仿真8751     *//* Author
发表于 2020-03-10
小广播
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2020 EEWORLD.com.cn, Inc. All rights reserved
