基于51单片机可修改错误功能的计算器工作原理解析
2020-05-23来源: eefocus关键字:51单片机  错误功能  计算器  工作原理
utiliTIes.h
#ifndefUTILITIES_H_INCLUDED
#defineUTILITIES_H_INCLUDED
typedefunsignedcharuchar,BYTE,uint8;
typedefunsignedintuint,WORD,uint16;
typedefunsignedlongulong,DWORD,uint32;
typedefcharint8;
typedefintint16;
typedeflongint32;
typedefunsignedchar*uchar_p;
typedefunsignedint*uint_p;
typedefunsignedlong*ulong_p;
typedefchar*char_p;
typedefint*int_p;
typedeflong*long_p;
#endif//UTILITIES_H_INCLUDED
keyBoard.c
#include
#include“utilities.h”
sbitKEY_OUT_3=P2^0;
sbitKEY_OUT_2=P2^1;
sbitKEY_OUT_1=P2^2;
sbitKEY_OUT_0=P2^3;
sbitKEY_IN_0=P2^4;
sbitKEY_IN_1=P2^5;
sbitKEY_IN_2=P2^6;
sbitKEY_IN_3=P2^7;
ucharcodekeyCodeMap[4][4]={//矩阵按键编号到标准键盘键码的映射表
{0x31,0x32,0x33,0x26},//数字键1、数字键2、数字键3、向上键
{0x34,0x35,0x36,0x25},//数字键4、数字键5、数字键6、向左键
{0x37,0x38,0x39,0x28},//数字键7、数字键8、数字键9、向下键
{0x30,0x1B,0x0D,0x27}//数字键0、ESC键、回车键、向右键
ucharpdatakeyState[4][4]={//全部矩阵按键的当前状态
{1,1,1,1},{1,1,1,1},{1,1,1,1},{1,1,1,1}
externvoidkeyAction(ucharkeyCode);
voidkeyDriver(){
uchari,j;
staticucharbackup[4][4]={
for(i=0;i《4;i++)
for(j=0;j《4;j++)
if(keyState[i][j]!=backup[i][j]){
if(keyState[i][j]==0)
keyAction(keyCodeMap[i][j]);
backup[i][j]=keyState[i][j];
voidkeyScan(){
staticuchari=0;
staticucharkeyBuf[4][4]={
{0xFF,0xFF,0xFF,0xFF},{0xFF,0xFF,0xFF,0xFF},
ucharj;
keyBuf[i][0]=(keyBuf[i][0]《《1)|KEY_IN_0;
keyBuf[i][1]=(keyBuf[i][1]《《1)|KEY_IN_1;
keyBuf[i][2]=(keyBuf[i][2]《《1)|KEY_IN_2;
keyBuf[i][3]=(keyBuf[i][3]《《1)|KEY_IN_3;
for(j=0;j《4;j++){
if(keyBuf[i][j]==0x00)
keyState[i][j]=0;
elseif(keyBuf[i][j]==0xFF)
keyState[i][j]=1;
switch(i){
case0:KEY_OUT_0=1;KEY_OUT_1=0;break;
case1:KEY_OUT_1=1;KEY_OUT_2=0;break;
case2:KEY_OUT_2=1;KEY_OUT_3=0;break;
case3:KEY_OUT_3=1;KEY_OUT_0=0;break;
default:break;
i=++i&0x03;
digitalTube.c
#include
ucharcodeLEDChar[]={//数码管显示字符转换表
0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,
0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E
ucharLEDBuff[6]={//数码管显示缓冲区
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF
voidshowNumber(ulongnum){
chari;
ucharbuf[6];
for(i=0;i《6;i++){
buf[i]=num%10;
num/=10;
for(i=5;i》0;i--){
if(buf[i]==0)
LEDBuff[i]=0xFF;
else
break;
for(;i》=0;i--)
LEDBuff[i]=LEDChar[buf[i]];
voidLEDScan(){
staticuchari=0;
P0=0xFF;
P1=(P1&0xF8)|i;
P0=LEDBuff[i];
if(i《5)
i++;
else
i=0;
timer.c
#include
#defineTIMER0
#defineTIMER0_MOD1
#ifdefined(TIMER0)
ucharT0RH=0;
ucharT0RL=0;
#ifdefined(TIMER0_MOD1)
voidsetTmr0(uintms){
ulongtmp;
tmp=11059326/12;
tmp=tmp*ms/1000;
tmp=65536-tmp;
tmp+=28;
T0RL=tmp;
T0RH=tmp》》8;
#endif//defined
#endif//defined
calculator.c
加减乘除计算器,能实现连续的运算,并且提供修改功能:
对于算符来说,以最后输入的算符为准。
测试样例:
12+256*9-53/2
3 + - * 5
关键字:51单片机  错误功能  计算器  工作原理 编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic498005.html 本网站转载的所有的文章、图片、音频视频文件等资料的版权归版权所有人所有,本站采用的非本站原创文章及图片等内容无法一一联系确认版权者。如果本网所选内容的文章作者及编辑认为其作品不宜公开自由传播,或不应无偿使用,请及时通过电子邮件或电话通知我们,以迅速采取适当措施,避免给双方造成不必要的经济损失。
上一篇:51单片机中的定时计数器的主体结构及功能解析
下一篇:最后一页
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
51单片机实验8:led点阵(1):点亮一个点
开发板led点阵模块电路图如下:74HC595:74HC595是一个8位串行输入、并行输出的位移缓存器。芯片第11角为数据输入时钟线,上升沿有效。芯片第12脚为输出存储器锁存时钟线,上升沿有效。芯片第13脚为输出有效(低电平)。芯片第14脚为串行数据输入。为表示出输入74HC595的8位二进制数,开发板加入了led模块(图一中绿色所示)。若要使led发光,则需将JP595接vcc。OE为输出有效控制端,低电平有效,所以务必将JOE短接片短接到GND端。_nop_();函数为延时一个机器周期,所对应头文件为intrins.h#include<reg52.h>#include<intrins.h>#define
发表于 2020-05-08
51单片机 4个独立按键控制LED灯 (protues仿真)(C语言版)
}}void main(){while(1){key();}}四、运行程序后成功后,打开proteus右键单击单片机AT89C51,找到编辑,然后添加hex文件
发表于 2020-05-08
51单片机课程设计——led点阵广告牌程序设计
上学期期末的课设题目是led点阵广告牌,当时的要求如下:(1)能够显示不同字符的LED点阵广告牌;(2)按键切换不同的显示效果(如闪烁,静止,平移等);(3)按键切换不同的显示内容;(4)能够显示图形或自定义字符;(5)其他功能(创新部分);(6)系统调试、分析、总结与功能实现。当时用的是我用是的普中科技的STC90C51RD+的单片机,不过只要是51单片机,换哪个51内核的芯片都可以,只要电路和程序匹配就可以。我用的那款普中科技的51单片机可以直接连线决定线路的布置,不需要自己去重新焊一个电路板。然后我根据任务要求连接了电路,写了对应的程序,还有proteus仿真。另外,觉得有趣可以点个赞;有什么有趣的想法可以评论一下,我感兴趣
发表于 2020-05-08
51单片机 基于LED点阵的9~0倒计数
#include <reg52.h>sbit ADDR0 = P1^0;sbit ADDR1 = P1^1;sbit ADDR2 = P1^2;sbit ADDR3 = P1^3;sbit ENLED = P1^4;unsigned char code image[11][8] = {{0xC3, 0x81, 0x99, 0x99, 0x99, 0x99, 0x81, 0xC3}, //数字0{0xEF, 0xE7, 0xE3, 0xE7, 0xE7, 0xE7, 0xE7, 0xC3}, //数字1{0xC3, 0x81, 0x9D, 0x87, 0xC3, 0xF9, 0xC1, 0x81}, //数字2{0xC3,
发表于 2020-05-07
基于51单片机智能红外温控风扇设计
1、设计需求及目标本产品采用单片机+最小系统+数码管显示模块+数码管驱动模块+温度采集模块+人体感应模块+风扇模块+按键模块等构成;功能描述:(1)采用DS18B20温度传感器测温,人体感应模块检测是否有人。(2)共3个按键:1键切换/设置、2键加、3键减。(3)本设计共三种模式:自动模式、手动模式和自然风模式。(4)自动模式,按一下1键可以设置温度上限,再按下设置温度下限,均可以按键加减调整。数码管第一位不显示,后三位显示温度值。人体感应模块检测有人时,温度小于下限风扇不转,温度在上下限之间50%转动,大于上限时,风扇全速转动。人离开后,延迟几秒风扇停止转动,起到节能环保的作用。(5)手动模式,数码管第一位显示风扇档位,后三位
发表于 2020-05-07
基于51单片机智能红外温控风扇设计
C51单片机数码管动态显示
数码管作为最廉价的输出设备,在各种自动化设备中有很大的应用,最简单普通的显示方式为动态刷新显示,称为假动态显示,即通过分时扫描每一位,利于人眼的视觉停留现象,造成一种静态显示的效果,如下图所示:C51单片机由于运行速度很慢,在高刷新频率下,单片机的资源耗费很厉害,这样单片机就不可以再进行大量的计算工作,实际上,单片机在刷新时,只需要周期性的改变GPIO口的状态就可以了,剩下的时间其实都是在空转的状态下,我们能不能将这个空转的状态拿来用呢?当然是可以的啦,这里,我们利用单片机的定时器周期地产能中断,在中断内进行数码管的刷新工作,就可以将等待中断的这个CPU时间拿来做别的事情了。硬件电路:代码贴过来:主函数#include "
发表于 2020-05-07
C51单片机数码管动态显示
小广播
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2020 EEWORLD.com.cn, Inc. All rights reserved
