mini2440开发板之使用nfs无法启动的问题(Virtualbox桥接网络)
2020-05-26来源: eefocus关键字:mini2440  nfs  无法启动  Virtualbox  桥接网络
今天晚上研究了一下如何通过super-vivi来使用nfs网络文件系统来启动mini2440开发板,一开始一直无法成功,折腾了半天总算搞定了,总结一下:
1、首先,介绍一下我的开发环境。
物理机:win10;
虚拟机:ubuntu 12.04;
模拟器:virtualbox 5.20;
我的步骤是,按照用户手册的说明,先用super-vivi引导系统,输入q进入命令行模式,然后输入nfs启动命令(如下),最后输入boot启动系统。
param set linux_cmd_line "console=ttySAC0 root=/dev/nfs nfsroot=192.168.100.108:/opt/FriendlyARM/mini2440/rootfs ip=192.168.100.230:192.168.100.108:192.168.100.1:255.255.255.0:sbc2440.arm9.net:eth0:off"
但是,系统始终无法启动。每次都提示:
Copy linux kernel from 0x00060000 to 0x30008000, size = 0x00500000 ... done
zImage magic = 0x016f2818
Setup linux parameters at 0x30000100
linux command line is: "console=ttySAC0 root=/dev/nfs nfsroot=192.168.100.108:/opt/FriendlyARM/mini2440/rootfs ip=192.168.100.230:192.168.100.108:192.168.100.1:255.255.255.0:mini2440.arm9.net:eth0:off"
MACH_TYPE = 1999
NOW, Booting Linux......
Uncompressing Linux................................................................................................................................................... done, booting the kernel.
Linux version 2.6.32.2-FriendlyARM (root@LEON) (gcc version 4.4.3 (ctng-1.6.1) ) #1 Sat Jan 4 21:10:09 CST 2014
.......【此处略去N个字】.........
eth0: link down
IP-Config: Complete:
     device=eth0, addr=192.168.100.230, mask=255.255.255.0, gw=192.168.100.1,
     host=mini2440, domain=, nis-domain=arm9.net,
     bootserver=192.168.100.108, rootserver=192.168.100.108, rootpath=
Looking up port of RPC 100003/2 on 192.168.100.108
eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
rpcbind: server 192.168.100.108 not responding, timed out
Root-NFS: Unable to get nfsd port number from server, using default
Looking up port of RPC 100005/1 on 192.168.100.108
Root-NFS: Unable to get mountd port number from server, using default
Root-NFS: Server returned error -5 while mounting /opt/FriendlyARM/mini2440/rootfs
VFS: Unable to mount root fs via NFS, trying floppy.
VFS: Cannot open root device "nfs" or unknown-block(2,0)
Please append a correct "root=" boot option; here are the available partitions:
1f00             256 mtdblock0 (driver?)
1f01             128 mtdblock1 (driver?)
1f02            5120 mtdblock2 (driver?)
1f03           60032 mtdblock3 (driver?)
1f04           65536 mtdblock4 (driver?)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
可以看到,上述log中最关键的地方就是”rpcbind: server 192.168.100.108 not responding, timed out“这句话了。它的意思就是,开发板尝试通过局域网连接到目标系统的nfs,但是目标无响应,超时了。这就意味着,要么就是ubuntu系统的nfs没有挂载成功,要么就是开发板没有连入局域网,要么就是ubuntu系统没有连入局域网。于是一个一个来排查吧。
2、首先排查第一个问题,确认一下ubuntu的nfs文件系统是否挂载成功了。这个问题,可直接参考我的另一篇博客(如何在ubuntu 12.04系统下开启nfs网络文件系统)中提到的第5点。我确认了我的系统,没有问题。
3、然后排查第二个问题,确认一下mini2440开发板是否成功连入局域网。可参见我的另一篇博客(mini2440开发板linux系统下的网络参数设置)中的第3点。我确认了我的开发板,没有问题。
4、上述两个方面都验证过了,都没问题,那问题肯定就出在第3个方面了。也就是说,是ubuntu系统没有连入到局域网中,导致开发板无法接入到nfs文件系统。换句话说,就是ubuntu系统和mini2440开发板并没有处于同一个局域网中。
一开始我意识到这一点时,我还怀疑是不是因为我的笔记本没有使用网线,而用的是无线网络。所以我把笔记本的无线网卡禁用掉,然后特地找了一根网线来试试。结果仍然一样。这就证明跟无线/有线并没有什么关系,应该是其他方面的问题。
然后我就去网上查阅各位大神的博客、论坛等。偶然间看到一篇文章里提到了virtualbox下的虚拟机网络模式配置,提到了桥接模式和ip地址设置,不然无法上网。我立马灵光一闪,感觉可能跟我的虚拟机网络模式和ip地址配置有点关系。
因为我在这之前只是确认了一下物理机的ip地址是192.168.100.108,然后就简单的以为我的虚拟机也是这个ip地址,然后就把这个ip地址写入到nfs的启动参数中,配置给mini2440。但是,物理机和虚拟机的IP地址是不一样的。我的nfs目录是挂载在虚拟机ubuntu的系统下,而不是物理机win10的系统下。因此我需要获取到虚拟机ubuntu系统的ip地址。可是此时在ubuntu系统下运行ifconfig命令时,得到的ip地址信息却是127.0.0.1之类的信息。这显然是不对的!而且,此时从虚拟机ping物理机是OK的,但是从物理机ping虚拟机是失败的,这样肯定是无法从外面挂载虚拟机里的nfs文件系统的。那该怎么办呢?
5、这就要回到virtualbox的网络模式的配置问题上面了。如下图,将virtualbox的网卡模式设置为桥接模式(至于具体原因,请自行百度)。
virtualbox网卡模式设置
6、重新启动虚拟机,输入ifconfig命令查询,发现其ip地址变成了:
leon@Ubuntu:~$ ifconfig
eth3      Link encap:以太网  硬件地址 08:00:27:ea:ba:41
          inet 地址:192.168.100.104  广播:192.168.100.255  掩码:255.255.255.0
          inet6 地址: fe80::a00:27ff:feea:ba41/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  跃点数:1
          接收数据包:242 错误:0 丢弃:0 过载:0 帧数:0
          发送数据包:126 错误:0 丢弃:0 过载:0 载波:0
          碰撞:0 发送队列长度:1000
          接收字节:42431 (42.4 KB)  发送字节:17387 (17.3 KB)
lo        Link encap:本地环回
          inet 地址:127.0.0.1  掩码:255.0.0.0
          inet6 地址: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  跃点数:1
          接收数据包:24 错误:0 丢弃:0 过载:0 帧数:0
          发送数据包:24 错误:0 丢弃:0 过载:0 载波:0
          碰撞:0 发送队列长度:0
          接收字节:3519 (3.5 KB)  发送字节:3519 (3.5 KB)
这就说明修改成功了。此时的虚拟机已经跟物理机一样并存于局域网中了,它的ip地址,就可以直接提供给mini2440使用了。
7、于是,将此时的虚拟机的ip地址,录入到mini2440的nfs启动参数中:
param set linux_cmd_line "console=ttySAC0 root=/dev/nfs nfsroot=192.168.100.104:/opt/FriendlyARM/mini2440/rootfs ip=192.168.100.230:192.168.100.104:192.168.100.1:255.255.255.0:sbc2440.arm9.net:eth0:off"
然后输入boot,便可以看到mini2440成功启动了!
MACH_TYPE = 1999
eth0: link down
     bootserver=192.168.100.104, rootserver=192.168.100.104, rootpath=
Looking up port of RPC 100003/2 on 192.168.100.104
Looking up port of RPC 100005/1 on 192.168.100.104
VFS: Mounted root (nfs filesystem) on device 0:11.
Freeing init memory: 156K
hwclock: settimeofday() failed: Invalid argument
Try to bring eth0 interface up......NFS root ...Done
Please press Enter to activate this console.
8、哈哈,搞定,收工!
篇后语:
1、开发板和目标系统一定要处于同一个局域网下。当然,所谓同一个局域网,可以是通过有线的网线连入同一个路由器,也可以是通过无线网卡连入同一个路由器。但是一定要保证二者的IP地址处于同一个网段,网关和掩码也是一样的。
2、nfs文件系统如果搭建于虚拟机下,则一定要将虚拟机的网络模式设置为桥接模式,否则虚拟机将无法满足上述第一点。
关键字:mini2440  nfs  无法启动  Virtualbox  桥接网络 编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic498309.html 本网站转载的所有的文章、图片、音频视频文件等资料的版权归版权所有人所有,本站采用的非本站原创文章及图片等内容无法一一联系确认版权者。如果本网所选内容的文章作者及编辑认为其作品不宜公开自由传播,或不应无偿使用,请及时通过电子邮件或电话通知我们,以迅速采取适当措施,避免给双方造成不必要的经济损失。
上一篇:一起学mini2440裸机开发(六)--UART原理与基础实验
下一篇:mini2440 sd卡加载过程详解
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
一起学mini2440裸机开发(三)--S3C2440时钟学习
前言首先,我们应该知道一点,mini2440开发板在没有开启时钟前,整个开发板全靠一个12MHz的外部晶振提供频率来工作运行的,也就是说CPU、内存、UART、ADC等所有需要用到时钟频率的硬件都工作在12MHz下,而S3C2440A可以正常工作在400MHz下,可想而知两者速度相差会有多大了。如果CPU工作在12MHz频率下,开发板的使用效率非常低,所有依赖系统时钟工作的硬件,其工作效率也很低,比如,我们电脑里面经常提到的超频,超频就是让CPU工作在更高的频率下,让电脑运算速度更快,虽然频率是越高越好,但是由于硬件特性决定了任何一个设备都不可能无止境的超频,电脑超频时要考虑到CPU或主板发热过大,烧坏的危险,同样开发板的主板
发表于 2020-05-14
成功在mini2440上移植ffmpeg
在mini2440上,整个移植过程分三个步骤:(1)编译x264;(2)编译ffmpeg;(3)移植成功后,进行测试,即使用ffmpeg录像。(1)编译x264官网上下了个最新的x264,地址http://www.videolan.org/developers/x264.html。我下载的文件是last_x264.tar.bz2。解压命令为#tar -jxv -f last_x264.tar.bz2,解压后的目录为x264-snapshot-20130313-2245。进入解压后的目录,执行命令./configure --disable-asm,则会生成config.mak。之后就需要修改这个config.mak文件了,改写
发表于 2020-05-14
arm mini2440 基于v4l2 ffmpeg x264的视频远程监控
网络上盛传的基于mini2440的摄像头监控一般是基于 MJPEG-Streamer。这种方法利用的是V4L2的底层驱动,然后配合mjpeg这种格式的流传输,然后通过浏览器浏览视频和控制。下面用一个更接近真实的IP-camera的方案来实现。首先先看一下网友sunkwei写的《基于v4l2的webcam应用,本地预监》http://blog.csdn.net/sunkwei/article/details/6530343文本照搬他的代码,只是将他的webcam_server交叉编译到arm上,webcam_shower编译到pc上。这种方案是用的V4L2的视频驱动,然后配合ffmpeg、x264的软件编解码,通过udp上传至pc
发表于 2020-05-14
MINI2440裸机流水灯
概述流水灯是每个嵌入式开发者接触到一款新的控制器时最先实现的程序,本文记录了在友善之臂MINI2440平台上实现流水灯的过程。实现原理通过查看友善之臂提供的MINI2440原理图我们可以知道,MINI2440开发板上四个LED为共阳极接法,四个LED的N极与S3C2440的连接关系如下:LED1 >> GPB5LED2 >> GPB6LED3 >> GPB7LED4 >> GPB8当上述4个IO端口输出低电平时即可点亮对应的LED灯。编写程序及Makefile我们知道,S3C2440内部具有4KB的SRAM,当从NOR Flash启动时,这部分区域的起始地址为0x40000000
发表于 2020-05-14
MINI2440裸机流水灯
二、mini2440裸机程序之按键检测实验
开发板:mini2440, NandFlash:K9F2G08U0B 256M大小,CPU:S3C2440A  。开发环境:MDK4.11仿真器:Jlink v8这是我用csdn发表的第一个文章,之前使用过arm-linux-gcc裸机开发mini2440,但是很多函数什么的不能直接调用(我的技术问题),准备重新整理一下ARM裸机,整理好之后准备下一阶段学习。关于软件MDK4.11和它的注册机,我传不上去,说是由于文件太大,又想要的直接留言邮箱要就行了。下面开始我们的第一个LED灯的点亮程序吧!1、新建一个项目工程双击MDK图标进入开发环境,如下图,  单击Project/New uVision
发表于 2020-05-14
mini2440第一个裸机程序——点亮LED
手头的Mini2440搁置了两年半之后,我再次决定拿出它,重新尝试嵌入式Linux的学习。我使用的是友善之臂的Mini2440开发板、韦东山的《嵌入式Linux应用开发完成手册》及其视频教程。所以,本篇文章中所涉及到的各种软件均可在以下两处找到:0. Mini2440开发板的配套光盘韦东山JZ2440开发板的光盘JZ2440是韦东山出品的开发板,作为《嵌入式Linux应用开发完全手册》的配套硬件,它和Mini2440相差无几,所以我这里用的是Mini2440。一、目标动手之前先确定好一个小目标——这一次,我们的目标是在Mini2440上点亮LED,怎么样,听起来很简单吧。但是做起来,可并不是很简单喏,主要是因为会涉及到比较多的软件
发表于 2020-05-14
小广播
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2020 EEWORLD.com.cn, Inc. All rights reserved
