stm32f103ADC测试程序,16路ADC采样+DMA传送数据
2020-08-04来源: 51hei关键字:stm32f103  ADC测试  ADC采样  DMA传送数据
#include "adc.h"
#include "delay.h"
16路ADC采样DMA传输
调用Adc_Init()函数初始化设备,ADC循环采样
数据被DMA搬运到ADC_Value[ADC_CH_NUM]数组中
滤波后的数据在ADC_AfterFilter[ADC_CH_NUM]中
u16 ADC_Value[ADC_CH_NUM] = {0};
u16 ADC_AfterFilter[ADC_CH_NUM] = {0};
void  Adc_Init(void)
        ADC_InitTypeDef ADC_InitStructure;
  DMA_InitTypeDef  DMA_InitStructure;
        GPIO_InitTypeDef GPIO_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA |RCC_APB2Periph_GPIOB|
        RCC_APB2Periph_GPIOC|RCC_APB2Periph_ADC1,ENABLE );          //使能ADC1通道时钟
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1,ENABLE);
        RCC_ADCCLKConfig(RCC_PCLK2_Div6);   //设置ADC分频因子6 72M/6=12,ADC最大时间不能超过14M
        //PA1-PA7 作为模拟通道输入引脚
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|
                                        GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;                //模拟输入引脚
        GPIO_Init(GPIOA, &GPIO_InitStructure);
                //PC4-C5 作为模拟通道输入引脚
        GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5;
        GPIO_Init(GPIOC, &GPIO_InitStructure);
                        //PB0-B1 作为模拟通道输入引脚
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
  /* DMA channel1 configuration */
DMA_DeInit(DMA1_Channel1);
/*定义DMA外设基地址,即为存放转换结果的寄存器*/
DMA_InitStructure.DMA_PeripheralBaseAddr =(u32)&(ADC1->DR);
/*定义内存基地址*/
DMA_InitStructure.DMA_MemoryBaseAddr =(u32)ADC_Value;
/*定义AD外设作为数据传输的来源*/
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
/*指定DMA通道的DMA缓存的大小,即需要开辟几个内存空间,由ADC_CH_NUM这个宏决定*/
DMA_InitStructure.DMA_BufferSize = ADC_CH_NUM;
        /*设定寄存器地址固定*/
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
/*设定内存地址递加,即每次DMA都是将该外设寄存器中的值传到开辟的内存空间中*/
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
/*设定外设数据宽度 半字*/
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
        /*设定内存的的宽度 半字*/
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
        /*设定DMA工作再循环缓存模式*/
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
/*设定DMA选定的通道软件优先级*/
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
DMA_Init(DMA1_Channel1, &DMA_InitStructure);
/* Enable DMA channel1 */
DMA_Cmd(DMA1_Channel1, ENABLE);
        ADC_DeInit(ADC1);  //复位ADC1
        ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;        //ADC工作模式:ADC1和ADC2工作在独立模式
        ADC_InitStructure.ADC_ScanConvMode = ENABLE ;        //模数转换工作在扫描模式
        ADC_InitStructure.ADC_ContinuousConvMode = ENABLE ;        //模数转换工作在连续转换模式
        ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;        //转换由软件而不是外部触发启动
        ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;        //ADC数据右对齐
        ADC_InitStructure.ADC_NbrOfChannel = ADC_CH_NUM;        //顺序进行规则转换的ADC通道的数目
        ADC_Init(ADC1, &ADC_InitStructure);        //根据ADC_InitStruct中指定的参数初始化外设ADCx的寄存器
        /*ADC通道编号*/
        ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 3, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 4, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 5, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 6, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_6, 7, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_7, 8, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 9, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_9, 10, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_10,11, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_11,12, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_12,13, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_13,14, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_14,15, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_15,16, ADC_SampleTime_55Cycles5);
  ADC_DMACmd(ADC1, ENABLE);
        ADC_Cmd(ADC1, ENABLE);        //使能指定的ADC1
        ADC_ResetCalibration(ADC1);        //使能复位校准
        while(ADC_GetResetCalibrationStatus(ADC1));        //等待复位校准结束
        ADC_StartCalibration(ADC1);         //开启AD校准
        while(ADC_GetCalibrationStatus(ADC1));         //等待校准结束
        ADC_SoftwareStartConvCmd(ADC1, ENABLE);                //使能指定的ADC1的软件转换启动功能
关键字:stm32f103  ADC测试  ADC采样  DMA传送数据 编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic505243.html 本网站转载的所有的文章、图片、音频视频文件等资料的版权归版权所有人所有,本站采用的非本站原创文章及图片等内容无法一一联系确认版权者。如果本网所选内容的文章作者及编辑认为其作品不宜公开自由传播,或不应无偿使用,请及时通过电子邮件或电话通知我们,以迅速采取适当措施,避免给双方造成不必要的经济损失。
上一篇:STM32 AT24C128简单读写程序
下一篇:stm32F407的按键FIFO应用
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
STM32F103停机模式测试
环境:主机:WIN7开发环境:MDK4.72MCU:STM32F101源代码://定义IO初始化结构体GPIO_InitTypeDef GPIO_InitStructure;    //设置zigbee模块进入低功耗模式inf_zigbee_sleep();    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |
发表于 2020-09-24
STM32F103 AFIO时钟疑问
在stm32F103系列中:AFIO是重映射辅助时钟,如果仅仅是使用第二功能(如uart,spi,),不需要打开,使用第二功能打开GPIO和第二功能时钟。我反复测试是这样的AFIO时钟由RCC_APB2ENR寄存器的位0控制;APB2外设时钟使能寄存器(RCC_APB2ENR)  的第0位AFIOEN 辅助功能IO时钟使能在那些时候,需要开启呢? --------------------------------- 配置stm32的事件输出/外部中断/重映射的时候.就必须开启AFIO时钟. 假如使用的管脚里头默认复用的外设功能并不需要开AFIO时钟
发表于 2020-09-16
<font color='red'>STM32F103</font> AFIO时钟疑问
STM32f103时钟系统简介
STM32F10X_CL    __IO uint32_t AHBRSTR;  __IO uint32_t CFGR2;#endif /* STM32F10X_CL */#if defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || defined (STM32F10X_HD_VL)     uint32_t RESERVED0;  __IO uint32_t CFGR2;#endif /* STM32F10X_LD_VL || STM32F
发表于 2020-08-25
<font color='red'>STM32f103</font>时钟系统简介
STM32F103+NRF24L01航模遥控器制作
摇杆数值ADC读取后通过DMA存到数组中,TIM3中断函数中对数据进行处理发送,同时对电池电压进行采集,OLED显示PIT、THR、电压等信息。#include "stm32f10x.h"#include "sys.h"#include "i2c.h"#include "delay.h"#include "usart.h"#include "remote.h"#include "oled0561.h"#include "ADC_DMA_Config.h"#include
发表于 2020-08-17
<font color='red'>STM32F103</font>+NRF24L01航模遥控器制作
ULN2003驱动28BYJ-48步进电机STM32F103寄存器版
电机1先逆时针旋转90度,再顺时针旋转90度。电机2逆时针旋转90度,再顺时针旋转90度◆硬件资源:    1,ULN2003驱动模块    2,28BYJ-48步进电机电机1:    // IN4: PC9   d    // IN3: PC8   c    // IN2: PC7   b    // IN1: PC6   a    3,28BYJ-48步进电机电机2:    // IN4: P
发表于 2020-08-14
stm32f103单片机的串口IAP升级程序
使用stm32f103r8t6 实现IAP升级代码精简但是很实用可以用来制作远程升级单片机源程序如下:/********************************************************************************* 文件名:                 mian.c** 版本:                  1.0** 工作环境:
发表于 2020-08-13
<font color='red'>stm32f103</font>单片机的串口IAP升级程序
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2020 EEWORLD.com.cn, Inc. All rights reserved
