【STM32平衡小车】PC端上位机协议及代码
最新更新时间:1970-01-01来源: eefocus关键字:STM32  平衡小车  PC端 手机看文章 扫描二维码
随时随地手机看文章
一、代码再现
DataScope_DP.c
#include "DataScope_DP.h"
unsigned char DataScope_OutPut_Buffer[42] = {0};    //串口发送缓冲区
//函数说明:将单精度浮点数据转成4字节数据并存入指定地址
//附加说明:用户无需直接操作此函数
//target:目标单精度数据
//buf:待写入数组
//beg:指定从数组第几个元素开始写入
//函数无返回
void Float2Byte(float *target,unsigned char *buf,unsigned char beg)
    unsigned char *point;
    point = (unsigned char*)target;   //得到float的地址
    buf[beg]   = point[0];//同时也也可以看出STM32是小端模式
    buf[beg+1] = point[1];
    buf[beg+2] = point[2];
    buf[beg+3] = point[3];
//函数说明:将待发送通道的单精度浮点数据写入发送缓冲区
//Data:通道数据
//Channel:选择通道(1-10)
//函数无返回
void DataScope_Get_Channel_Data(float Data,unsigned char Channel)
if ( (Channel > 10) || (Channel == 0) ) return;  //通道个数大于10或等于0,直接跳出,不执行函数
else
switch (Channel)
case 1:  Float2Byte(&Data,DataScope_OutPut_Buffer,1); break;
case 2:  Float2Byte(&Data,DataScope_OutPut_Buffer,5); break;
case 3:  Float2Byte(&Data,DataScope_OutPut_Buffer,9); break;
case 4:  Float2Byte(&Data,DataScope_OutPut_Buffer,13); break;
case 5:  Float2Byte(&Data,DataScope_OutPut_Buffer,17); break;
case 6:  Float2Byte(&Data,DataScope_OutPut_Buffer,21); break;
case 7:  Float2Byte(&Data,DataScope_OutPut_Buffer,25); break;
case 8:  Float2Byte(&Data,DataScope_OutPut_Buffer,29); break;
case 9:  Float2Byte(&Data,DataScope_OutPut_Buffer,33); break;
case 10: Float2Byte(&Data,DataScope_OutPut_Buffer,37); break;
//函数说明:生成 DataScopeV1.0 能正确识别的帧格式
//Channel_Number,需要发送的通道个数
//返回发送缓冲区数据个数
//返回0表示帧格式生成失败
unsigned char DataScope_Data_Generate(unsigned char Channel_Number)
if ( (Channel_Number > 10) || (Channel_Number == 0) ) { return 0; }  //通道个数大于10或等于0,直接跳出,不执行函数
else
DataScope_OutPut_Buffer[0] = '$';  //帧头
switch(Channel_Number)
case 1:   DataScope_OutPut_Buffer[5]  =  5; return  6;
case 2:   DataScope_OutPut_Buffer[9]  =  9; return 10;
case 3:   DataScope_OutPut_Buffer[13] = 13; return 14;
case 4:   DataScope_OutPut_Buffer[17] = 17; return 18;
case 5:   DataScope_OutPut_Buffer[21] = 21; return 22;
case 6:   DataScope_OutPut_Buffer[25] = 25; return 26;
case 7:   DataScope_OutPut_Buffer[29] = 29; return 30;
case 8:   DataScope_OutPut_Buffer[33] = 33; return 34;
case 9:   DataScope_OutPut_Buffer[37] = 37; return 38;
case 10:  DataScope_OutPut_Buffer[41] = 41; return 42;
return 0;
DataScope_DP.h
#ifndef __DATA_PRTOCOL_H
#define __DATA_PRTOCOL_H
extern unsigned char DataScope_OutPut_Buffer[42];    //待发送帧数据缓存区
void DataScope_Get_Channel_Data(float Data,unsigned char Channel);    // 写通道数据至 待发送帧数据缓存区
unsigned char DataScope_Data_Generate(unsigned char Channel_Number);  // 发送帧数据生成函数
#endif
Minibalance.c
#include "sys.h"
unsigned char i;          //计数变量
unsigned char Send_Count; //串口需要发送的数据个数
static float a;
int main(void)
Stm32_Clock_Init(9);            //系统时钟设置
delay_init(72);                 //延时初始化
uart_init(72,128000);           //初始化串口1
while(1)
a+=0.1;
if(a>3.14)  a=-3.14;
DataScope_Get_Channel_Data(500*sin(a), 1 );
DataScope_Get_Channel_Data(500*tan(a), 2 );
DataScope_Get_Channel_Data(500*cos(a), 3 );
DataScope_Get_Channel_Data(100*a , 4 );
DataScope_Get_Channel_Data(0, 5 );
DataScope_Get_Channel_Data(0, 6 );
DataScope_Get_Channel_Data(0, 7 );
DataScope_Get_Channel_Data(0, 8 );
DataScope_Get_Channel_Data(0, 9 );
DataScope_Get_Channel_Data(0, 10);
Send_Count = DataScope_Data_Generate(10);
for( i = 0 ; i < Send_Count; i++)
while((USART1->SR&0X40)==0);
USART1->DR = DataScope_OutPut_Buffer[i];
delay_ms(50); //20HZ
二、快速上手
波特率 128000
代码:
①处对应10个通道要显示的数据。
②处对应要显示的总共通道数!
三、代码解读
协议:
上位机通信的数据帧长度固定为 4*N+1,帧数据字节之间传输延时不可超过 1ms,否则将认为当前帧结束,UI 刷新没有限制显示延时。
串口发送缓冲区一共开了42个字节,其实用到的只有41个。每个channel占用4个,共10个channel,再加一个帧头$。 然后用哪个通道,就不断哪个通道对应的4字节就行。比如我一直用4通道(1~10),那么对应的串口发送缓冲区的位置是13-16!
知道上面两条,以上的代码就很好理解了!
平台是基于STM32F103C8T6,资料可从这里下载链接:链接,提取码:qskh
关键字:STM32  平衡小车  PC端 编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic548610.html
上一篇:【STM32基础学习】八种GPIO模式总结
下一篇:【STM32平衡小车】APP调试协议及代码分析
STM32输入捕获--“PWM输入模式”(可拓展多路同时捕获)
前言博文基于STM32F103ZET6和标准固件库V3.5.0在MDK5环境下开发;本博文只讨论输入捕获的PWM输入模式,这个模式是STM32输入捕获检测脉宽和频率的一种硬件处理机制,说白了就是STM32芯片专门用来进行对PWM进行捕获的一个功能;此方法相比较于传统的PWM的捕获方法,大大减小了代码量,提高了检测效率,而实际上对于PWM信号的检测还有其他方法(下面我会介绍,就是原子教程提供的方法),并且关于繁琐的寄存器的介绍这里就不多说了,有兴趣的话可以直接去我的另外一个博客里去看: https://blog.csdn.net/wuyuzun/article/details/73135662 ;(备注:此链接里的博客里有一个配套
发表于 2021-11-26
<font color='red'>STM32</font>输入捕获--“PWM输入模式”(可拓展多路同时捕获)
STM32 程序卡死在启动文件startup_stm32fxxxx.s的SysTick_Handler中
出现的问题硬件调试的时候发现程序一直在启动文件下面箭头这行。显然是跟SysTick_Handler有关由于我使用了FreeRTOS,所以需要SysTick为系统时基单元,所以需要SysTick_Handler,但是我却没有定义此中断函数,所以导致上面的程序一直进入不了以SysTick_handler命名的中断函数;填上就好了;解决问题添加SysTick_Handler函数:
发表于 2021-11-26
<font color='red'>STM32</font> 程序卡死在启动文件startup_stm32fxxxx.s的SysTick_Handler中
STM32中断挂起和RTOS任务挂起的区别
中断挂起可以理解为:将中断设置为就绪状态,一旦符合条件,立即执行中断并进入中断函数;比如A和B的抢占优先级相同,A的响应优先级高于B,那么当产生A和B中断的事件发生时,先执行A,并同时将B挂起,一旦A执行完毕,立即执行B。RTOS的任务挂起以FreeROTS为例,因为某些原因不能立即执行的任务,可以将其挂起,这个挂起使得任务暂时无法参与任务调度。只有将任务唤醒之后才能继续参与;
发表于 2021-11-26
解决STM32 SD卡官方库移植时 获取不到SD Status寄存器值的问题
前言SD卡内部的SD Status寄存器和Card Status寄存器从名字上来看好像都是状态寄存器,但实际上所要呈现的工程是不同的,这一点要注意;本博文主要说内容是怎样正确的获取SD Status寄存器的值;如有不足之处,还请多多指教;问题SD Status寄存器表如下,我想获取其中的AU_SIZE的值([400:0]这段位域内没有信息,我这里忽略了)如下图,AU_SIZE的值本身应该在0x01~0x09之间,但是我用串口打印出来的值却是0;获取SD Status寄存器的函数代码如下:/**   * @brief SD Card Status   */typedef struct{
发表于 2021-11-25
解决<font color='red'>STM32</font> SD卡官方库移植时 获取不到SD Status寄存器值的问题
SD卡存储容量的计算过程
前言SD卡底层驱动代码量不小,功能稍微有点复杂,其他的功能不说了;本博文主要介绍SD卡V1.0和V2.0版本的SD卡的容量结算;在对SD卡进行FATFS文件系统(最新R0.13c版本)移植时,接口函数DRESULT disk_ioctl (BYTE pdrv, BYTE cmd, void *buff )会获取SD卡的三个重要信息作为f_fdisk和f_mkfs函数为整个SD卡分区和挂载文件系统的依据;下面的代码来自于STM32官方提供的固件库的SD卡例程,但是:例程里边有错误的地方需要修改,如果不修改有可能会影响到FatFS系统移植时分区的问题,在博文的最后有特别指出;CSD寄存器(Card-Specific Data
发表于 2021-11-25
SD卡存储容量的计算过程
STM32 HardFault_Handler 硬件错误 解决办法
在用Keil对STM32的程序进行仿真时程序有时会跑飞,停止仿真程序会停在HardFault_Handler函数里的死循环while(1)中。这说明STM32出现了硬件错误。STM32出现硬件错误可能有以下原因:(1)数组越界操作;(2)内存溢出,访问越界;(3)堆栈溢出,程序跑飞;(4)中断处理错误;遇到这种情况,可以通过以下2种方式来定位到出错代码段。方法1:1.1在硬件中断函数HardFault_Handler里的while(1)处打调试断点,程序执行到断点处时点击“STOP”停止仿真。1.2 在Keil菜单栏点击“View”——“Registers Window”,在寄存器查看窗口查找R14(LR)的值。如果R14(LR
发表于 2021-11-25
<font color='red'>STM32</font> HardFault_Handler 硬件错误 解决办法
推荐帖子
关于Vxworks的疑问
本人刚进公司,被分到做vxworks软件,原来没有接触过vxworks,所以也不是很了解,请各位帮忙讲解一下,主要是vxworks是做什么的,它的应用平台,当前形势,以及怎么去学,主要按那个方向去学习,如果将来想跳槽应该跳哪个方向的,谢谢哈^-^关于Vxworks的疑问
hoyden 实时操作系统RTOS
【求助】430 JTAG下载问题
小弟初次用430,下载不了程序,显示cannotloadprogrambecauseflashemulationtoolnotfound.检查线路没有问题!请教是什么问题!先谢了啊!【求助】430JTAG下载问题
ltby00 微控制器 MCU
多速率数字信号处理发展史上的开山之作----经典
R.E.CrochiereandL.R.Rabiner MultirateDigitalSignalProcessing Prentice-Hall,1983,ISBN0-13-605162-6. Thisbookistheonlyrealreferenceforfilterbanksandmultiratesystems,asopposedtobeingatutorial. PeterKootsookosnotes
analog010 DSP 与 ARM 处理器
CH554评测:三,跑一下HID
HID是HumanInterfaceDevice的缩写,由其名称可以了解HID设备是直接与人交互的设备,例如键盘、鼠标与游戏杆等。不过HID设备并不一定要有人机接口,只要符合HID类别规范的设备都是HID设备。 交换的数据存储在称为报表(report)的结构内,设备的固件必须支持HID报表的格式。主机在控制与中断传输中传送与要求报表,来传送与接收数据。报表的格式非常有弹性,可以处理任何类别的数据。 设备除了HID接口之外,它可能同时还包含有其他的USB接口。例如影像显示设备可能使用HID
ddllxxrr 单片机
基于DSPE1的硬件开发平台设计
基于DSPE1的硬件开发平台设计基于DSPE1的硬件开发平台设计
maker 单片机
现在是做JAVA开发的(计算机专业出身的),想转硬件开发,大家给我指一条学习路线吧,谢谢各位了。
现在是做JAVA开发的(计算机专业出身的),想转硬件开发,大家给我指一条学习路线吧,谢谢各位了。现在是做JAVA开发的(计算机专业出身的),想转硬件开发,大家给我指一条学习路线吧,谢谢各位了。
hzwwqq 嵌入式系统
小广播
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
电子工程世界版权所有 京B2-20211791 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2021 EEWORLD.com.cn, Inc. All rights reserved
