STC15F2K60S2 22.1184MHz
Keil uVision V5.29.0.0
PK51 Prof.Developers Kit Version:9.60.0.0
上位机:Vofa+ 1.3.10
移植自AHRS —— LOXO,算法作者:SOH Madgwick
传感器的方向
源码
所用MCU为STC15F2K60S2 使用内部RC时钟,22.1184MHz
stdint.h见【51单片机快速入门指南】1:基础知识和工程创建
软件I2C程序见【51单片机快速入门指南】4: 软件 I2C
串口部分见【51单片机快速入门指南】3.3:USART 串口通信
MPU6050驱动程序见【51单片机快速入门指南】4.3: I2C读取MPU6050陀螺仪的原始数据
HMC5883L/QMC5883L驱动程序见【51单片机快速入门指南】4.4:I2C 读取HMC5883L / QMC5883L 磁力计
磁力计的椭球拟合校准见【51单片机快速入门指南】4.4.1:python串口接收磁力计数据并进行最小二乘法椭球拟合
beta要按需调整,我这里取1.0
Madgwick_9.c
// Implementation of Madgwick's IMU and AHRS algorithms.
// See: http://www.x-io.co.uk/node/8#open_source_ahrs_and_imu_algorithms
// Date Author Notes
// 29/09/2011 SOH Madgwick Initial release
// 02/10/2011 SOH Madgwick Optimised for reduced CPU load
// 19/02/2012 SOH Madgwick Magnetometer measurement is normalised
// Header files
#include #include "MPU6050.h" //--------------------------------------------------------------------------------------------------- // Definitions #define beta 1.0f // 2 * proportional gain (Kp) //--------------------------------------------------------------------------------------------------- // Variable definitions float q0 = 1.0f, q1 = 0.0f, q2 = 0.0f, q3 = 0.0f; // quaternion of sensor frame relative to auxiliary frame float Pitch = 0.0f, Roll = 0.0f, Yaw = 0.0f; //==================================================================================================== // Functions float sampleFreq = 1; float GYRO_K = 1; void MPU6050_Madgwick_Init(float loop_ms) { sampleFreq = 1000. / loop_ms; //sample frequency in Hz switch((MPU_Read_Byte(MPU_GYRO_CFG_REG) >> 3) & 3) { case 0: GYRO_K = 1./131/57.3; break; case 1: GYRO_K = 1./65.5/57.3; break; case 2: GYRO_K = 1./32.8/57.3; break; case 3: GYRO_K = 1./16.4/57.3; break; } } //--------------------------------------------------------------------------------------------------- // Fast inverse square-root // See: http://en.wikipedia.org/wiki/Fast_inverse_square_root float invSqrt(float x) { float halfx = 0.5f * x; float y = x; long i = *(long*)&y; i = 0x5f3759df - (i>>1); y = *(float*)&i; y = y * (1.5f - (halfx * y * y)); return y; } //--------------------------------------------------------------------------------------------------- // AHRS algorithm update //--------------------------------------------------------------------------------------------------- // IMU algorithm update void MadgwickAHRSupdate_6(float gx, float gy, float gz, float ax, float ay, float az) { float recipNorm; float s0, s1, s2, s3; float qDot1, qDot2, qDot3, qDot4; float _2q0, _2q1, _2q2, _2q3, _4q0, _4q1, _4q2 ,_8q1, _8q2, q0q0, q1q1, q2q2, q3q3; //将陀螺仪AD值转换为 弧度/s gx = gx * GYRO_K; gy = gy * GYRO_K; gz = gz * GYRO_K; // Rate of change of quaternion from gyroscope qDot1 = 0.5f * (-q1 * gx - q2 * gy - q3 * gz); qDot2 = 0.5f * (q0 * gx + q2 * gz - q3 * gy); qDot3 = 0.5f * (q0 * gy - q1 * gz + q3 * gx); qDot4 = 0.5f * (q0 * gz + q1 * gy - q2 * gx); // Compute feedback only if accelerometer measurement valid (avoids NaN in accelerometer normalisation) if(!((ax == 0.0f) && (ay == 0.0f) && (az == 0.0f))) { // Normalise accelerometer measurement recipNorm = invSqrt(ax * ax + ay * ay + az * az); ax *= recipNorm; ay *= recipNorm; az *= recipNorm; // Auxiliary variables to avoid repeated arithmetic _2q0 = 2.0f * q0; _2q1 = 2.0f * q1; _2q2 = 2.0f * q2; _2q3 = 2.0f * q3; _4q0 = 4.0f * q0; _4q1 = 4.0f * q1; _4q2 = 4.0f * q2; _8q1 = 8.0f * q1; _8q2 = 8.0f * q2; q0q0 = q0 * q0; q1q1 = q1 * q1; q2q2 = q2 * q2; q3q3 = q3 * q3; // Gradient decent algorithm corrective step s0 = _4q0 * q2q2 + _2q2 * ax + _4q0 * q1q1 - _2q1 * ay; s1 = _4q1 * q3q3 - _2q3 * ax + 4.0f * q0q0 * q1 - _2q0 * ay - _4q1 + _8q1 * q1q1 + _8q1 * q2q2 + _4q1 * az; s2 = 4.0f * q0q0 * q2 + _2q0 * ax + _4q2 * q3q3 - _2q3 * ay - _4q2 + _8q2 * q1q1 + _8q2 * q2q2 + _4q2 * az; s3 = 4.0f * q1q1 * q3 - _2q1 * ax + 4.0f * q2q2 * q3 - _2q2 * ay; recipNorm = invSqrt(s0 * s0 + s1 * s1 + s2 * s2 + s3 * s3); // normalise step magnitude s0 *= recipNorm; s1 *= recipNorm; s2 *= recipNorm; s3 *= recipNorm; // Apply feedback step qDot1 -= beta * s0; qDot2 -= beta * s1; qDot3 -= beta * s2; qDot4 -= beta * s3; } // Integrate rate of change of quaternion to yield quaternion q0 += qDot1 * (1.0f / sampleFreq); q1 += qDot2 * (1.0f / sampleFreq); q2 += qDot3 * (1.0f / sampleFreq); q3 += qDot4 * (1.0f / sampleFreq); // Normalise quaternion recipNorm = invSqrt(q0 * q0 + q1 * q1 + q2 * q2 + q3 * q3); q0 *= recipNorm; q1 *= recipNorm; q2 *= recipNorm; q3 *= recipNorm; Pitch = asin(-2.0f * (q1*q3 - q0*q2))* 57.3f; Roll = atan2(q0*q1 + q2*q3, 0.5f - q1*q1 - q2*q2) * 57.3f; Yaw = atan2(q1*q2 + q0*q3, 0.5f - q2*q2 - q3*q3)* 57.3f; } void MadgwickAHRSupdate_9(float gx, float gy, float gz, float ax, float ay, float az, float mx, float my, float mz) { float recipNorm; float s0, s1, s2, s3; float qDot1, qDot2, qDot3, qDot4; float hx, hy; float _2q0mx, _2q0my, _2q0mz, _2q1mx, _2bx, _2bz, _4bx, _4bz, _2q0, _2q1, _2q2, _2q3, _2q0q2, _2q2q3, q0q0, q0q1, q0q2, q0q3, q1q1, q1q2, q1q3, q2q2, q2q3, q3q3; // Use IMU algorithm if magnetometer measurement invalid (avoids NaN in magnetometer normalisation) if((mx == 0.0f) && (my == 0.0f) && (mz == 0.0f)) { MadgwickAHRSupdate_6(gx, gy, gz, ax, ay, az); return; } //将陀螺仪AD值转换为 弧度/s gx = gx * GYRO_K; gy = gy * GYRO_K; gz = gz * GYRO_K; // Rate of change of quaternion from gyroscope qDot1 = 0.5f * (-q1 * gx - q2 * gy - q3 * gz); qDot2 = 0.5f * (q0 * gx + q2 * gz - q3 * gy); qDot3 = 0.5f * (q0 * gy - q1 * gz + q3 * gx); qDot4 = 0.5f * (q0 * gz + q1 * gy - q2 * gx); // Compute feedback only if accelerometer measurement valid (avoids NaN in accelerometer normalisation) if(!((ax == 0.0f) && (ay == 0.0f) && (az == 0.0f))) { // Normalise accelerometer measurement recipNorm = invSqrt(ax * ax + ay * ay + az * az); ax *= recipNorm; ay *= recipNorm; az *= recipNorm; // Normalise magnetometer measurement recipNorm = invSqrt(mx * mx + my * my + mz * mz); mx *= recipNorm; my *= recipNorm; mz *= recipNorm; // Auxiliary variables to avoid repeated arithmetic _2q0mx = 2.0f * q0 * mx; _2q0my = 2.0f * q0 * my; _2q0mz = 2.0f * q0 * mz; _2q1mx = 2.0f * q1 * mx; _2q0 = 2.0f * q0; _2q1 = 2.0f * q1; _2q2 = 2.0f * q2; _2q3 = 2.0f * q3; _2q0q2 = 2.0f * q0 * q2; _2q2q3 = 2.0f * q2 * q3; q0q0 = q0 * q0; q0q1 = q0 * q1; q0q2 = q0 * q2; q0q3 = q0 * q3; q1q1 = q1 * q1; q1q2 = q1 * q2; q1q3 = q1 * q3; q2q2 = q2 * q2; q2q3 = q2 * q3; q3q3 = q3 * q3; // Reference direction of Earth's magnetic field hx = mx * q0q0 - _2q0my * q3 + _2q0mz * q2 + mx * q1q1 + _2q1 * my * q2 + _2q1 * mz * q3 - mx * q2q2 - mx * q3q3; hy = _2q0mx * q3 + my * q0q0 - _2q0mz * q1 + _2q1mx * q2 - my * q1q1 + my * q2q2 + _2q2 * mz * q3 - my * q3q3; _2bx = sqrt(hx * hx + hy * hy); _2bz = -_2q0mx * q2 + _2q0my * q1 + mz * q0q0 + _2q1mx * q3 - mz * q1q1 + _2q2 * my * q3 - mz * q2q2 + mz * q3q3; _4bx = 2.0f * _2bx; _4bz = 2.0f * _2bz; // Gradient decent algorithm corrective step s0 = -_2q2 * (2.0f * q1q3 - _2q0q2 - ax) + _2q1 * (2.0f * q0q1 + _2q2q3 - ay) - _2bz * q2 * (_2bx * (0.5f - q2q2 - q3q3) + _2bz * (q1q3 - q0q2) - mx) + (-_2bx * q3 + _2bz * q1) * (_2bx * (q1q2 - q0q3) + _2bz * (q0q1 + q2q3) - my) + _2bx * q2 * (_2bx * (q0q2 + q1q3) + _2bz * (0.5f - q1q1 - q2q2) - mz); s1 = _2q3 * (2.0f * q1q3 - _2q0q2 - ax) + _2q0 * (2.0f * q0q1 + _2q2q3 - ay) - 4.0f * q1 * (1 - 2.0f * q1q1 - 2.0f * q2q2 - az) + _2bz * q3 * (_2bx * (0.5f - q2q2 - q3q3) + _2bz * (q1q3 - q0q2) - mx) + (_2bx * q2 + _2bz * q0) * (_2bx * (q1q2 - q0q3) + _2bz * (q0q1 + q2q3) - my) + (_2bx * q3 - _4bz * q1) * (_2bx * (q0q2 + q1q3) + _2bz * (0.5f - q1q1 - q2q2) - mz); s2 = -_2q0 * (2.0f * q1q3 - _2q0q2 - ax) + _2q3 * (2.0f * q0q1 + _2q2q3 - ay) - 4.0f * q2 * (1 - 2.0f * q1q1 - 2.0f * q2q2 - az) + (-_4bx * q2 - _2bz * q0) * (_2bx * (0.5f - q2q2 - q3q3) + _2bz * (q1q3 - q0q2) - mx) + (_2bx * q1 + _2bz * q3) * (_2bx * (q1q2 - q0q3) + _2bz * (q0q1 + q2q3) - my) + (_2bx * q0 - _4bz * q2) * (_2bx * (q0q2 + q1q3) + _2bz * (0.5f - q1q1 - q2q2) - mz); s3 = _2q1 * (2.0f * q1q3 - _2q0q2 - ax) + _2q2 * (2.0f * q0q1 + _2q2q3 - ay) + (-_4bx * q3 + _2bz * q1) * (_2bx * (0.5f - q2q2 - q3q3) + _2bz * (q1q3 - q0q2) - mx) + (-_2bx * q0 + _2bz * q2) * (_2bx * (q1q2 - q0q3) + _2bz * (q0q1 + q2q3) - my) + _2bx * q1 * (_2bx * (q0q2 + q1q3) + _2bz * (0.5f - q1q1 - q2q2) - mz); recipNorm = invSqrt(s0 * s0 + s1 * s1 + s2 * s2 + s3 * s3); // normalise step magnitude s0 *= recipNorm; s1 *= recipNorm; s2 *= recipNorm; s3 *= recipNorm; // Apply feedback step qDot1 -= beta * s0; qDot2 -= beta * s1; qDot3 -= beta * s2; qDot4 -= beta * s3; } // Integrate rate of change of quaternion to yield quaternion q0 += qDot1 * (1.0f / sampleFreq); q1 += qDot2 * (1.0f / sampleFreq); q2 += qDot3 * (1.0f / sampleFreq); q3 += qDot4 * (1.0f / sampleFreq); // Normalise quaternion recipNorm = invSqrt(q0 * q0 + q1 * q1 + q2 * q2 + q3 * q3); q0 *= recipNorm; q1 *= recipNorm; q2 *= recipNorm; q3 *= recipNorm; Pitch = asin(-2.0f * (q1*q3 - q0*q2))* 57.3f; Roll = atan2(q0*q1 + q2*q3, 0.5f - q1*q1 - q2*q2) * 57.3f; Yaw = atan2(q1*q2 + q0*q3, 0.5f - q2*q2 - q3*q3)* 57.3f; } //==================================================================================================== // END OF CODE //====================================================================================================
上一篇:【51单片机快速入门指南】4.5:I2C 与 TCA6416实现双向 IO 扩展
下一篇:【51单片机快速入门指南】4.4.2:Mahony AHRS 九轴姿态融合获取四元数、欧拉角
设计资源 培训 开发板 精华推荐
最新视频课程更多
- 文字母位置交换并不回影响阅读,奇妙的发现
- 超级“牛人”谈如何通过46级考试
- 香主有必要写一个使stm32--ucosii在iar上的调试使用说明呀
- C8051F版数字湿度计调试3---硬件SMbus与SHT21通信
- 如何用数组一次提取多个串口数据。。。。求大神。。。。。
- EEWORLD DIY——低功耗蓝牙、USB双模机械键盘(6)<END>
- 获奖名单:罗彻斯特电子|半导体全周期解决方案提供商。参与活动,赢取京东卡!
- 5000元现金+价值300美元混合信号示波器套件,挺震撼的奖品啊~~
- 自己的应用程序如何调用系统本身控制面板中的日期设定声音调节等程序?(急)
- [求助]如何得到WCE中NTP时刻同步信息(附部分代码)
