TIDRV8818步进马达驱动解决方案
最新更新时间:2012-04-24来源: 21IC关键字:马达  驱动步进  评估模块 手机看文章 扫描二维码
随时随地手机看文章
TI公司的DRV8818是用于打印机,扫描仪和其它自动化设备的步进马达驱动器,集成了两个H桥驱动器和用来控制步进马达的微步距分度器逻辑.微步距马达驱动器采用PWM,可提供1/8步操作,每个绕组的电流高达2.5A,主要用在打印机,纺织机械,定位/跟踪,工厂自动化和机器人.本文介绍了DRV8818主要特性, 方框图和马达驱动电路以及评估模块DRV8818EVM方框图,电路图和材料清单.
The DRV8818 provides an integrated stepper motor driver solution for printers, scanners, and other automated equipment applications. The device has two H-bridge drivers, as well as microstepping indexer logic to control a stepper motor.
The output driver block for each consists of N-channel power MOSFETs configured as full H-bridges to drive the motor windings.
A simple step/direction interface allows easy interfacing to controller circuits. Pins allow configuration of the motor in full-step, half-step, quarter-step, or eighth-step modes. Decay mode and PWM off time are programmable.
Internal shutdown functions are provided for over current protection, short circuit protection, under-voltage lockout and overtemperature.
DRV8818主要特性:
Pulse Width Modulation (PWM) Microstepping Motor Driver
Built-In Microstepping Indexer
Up to 2.5-A Current Per Winding
Microstepping Indexer Provides up to 1/8-Step Operation
Low 0.37-Ω (HS + LS) MOSFET On-Resistance (at 25°)
Programmable Mixed Decay, Blanking, and Off Time
Pin-Compatible Upgrade to DRV8811 With Lower Rds(on)
Thermally Enhanced Surface Mount Package
DRV8818应用:
• Printers
• Textile Machinery
• Positioning/Tracking
• Factory Automation
• Robotics
图1.DRV8818方框图
图2.DRV8818马达驱动电路
评估模块DRV8818EVM
The DRV8818EVM is a complete solution for evaluating the DRV8818 micro-stepping, bipolar stepper driver. It includes a USB link to provide easy control from a personal computer (PC), a MSP430 microcontroller that interprets serial commands from the PC and generates control signals to the driver device, and the DRV8818 device with access to all signals for a complete evaluation.
图3.评估模块DRV8818EVM外形图
图4.评估模块DRV8818EVM方框图
图5.评估模块DRV8818EVM电路图(1)
图6.评估模块DRV8818EVM电路图(2)
评估模块DRV8818EVM材料清单:
关键字:马达  驱动步进  评估模块 编辑:探路者 引用地址:TIDRV8818步进马达驱动解决方案
上一篇:高调光比LED恒流驱动电路的设计方案
下一篇:灵活运用OPC驱动增强通讯效率和可靠性
推荐阅读最新更新时间:2023-10-18 16:40
基于TB6560的步进电机驱动电路设计
引言 步进电机是一种将电脉冲转化为角位移的执行机构。驱动器接收到一个脉冲信号后,驱动步进电机按设定的方向转动一个固定的角度。首先,通过控制脉冲个数来控制角位移量,从而达到准确定位的目的;其次,通过控制脉冲顿率来控制电机转动的速度和加速度,从而达到涮速的目的。目前,步进电机具有惯量低、定位精度高、无累积误差、控制简单等特点,在机电一体化产品中应用广泛,常用作定位控制和定速控制。步进电机驱动电路常用的芯片有L297和L298组合应用、3977、8435等,这些芯片一般单相驱动电流在2 A左右,无法驱动更大功率电机,限制了其应用范围。本文基于东芝公司2008年推出的步进电机驱动芯片TB6560提出了一种步进电机驱动电路的设计方案。 1
[工业控制]
基于TB6560的<font color='red'>步进</font>电机<font color='red'>驱动</font>电路设计
恒力矩步进电机驱动器分析设计
  0 引言   得益于电子技术突飞猛进的发展,单片机、驱动芯片很多,国内许多厂家制作的步进电机驱动器性能很好,但是客户对驱动器基本要求是一样的:性价比高、控制简单、安全可靠等。笔者设计了一种基于L298+L297的恒流斩波两相步进驱动器,该驱动器本身带有脉冲信号源方便用户进行一些简单控制,设置和使用。在整、半步控制时,能维持恒力矩输出,比市场上同类产品性能更优越。而且驱动器斩波电流较大,恒转矩输出,工作可靠,内建有脉冲信号源方便用户进行一些简单控制,设置和使用非常方便。   1 L297功能分析   L297芯片采用模拟/数字电路兼容的I2L工艺,20脚DIP封装,通常以5V供电,全部信号TTL/CMOS兼容,是非常
[嵌入式]
技术文章—直流马达在车身电子上的应用
摘要 车内系统的电子产品含量持续成长,原因是市场对自动化、安全性、能耗优化和高质量体验的要求越来越高。在此背景之下,使用直流马达的应用数量也不断上扬。 本文将分析车用直流马达的市场趋势,并说明何以从诊断功能、交换时间的优化、减轻重量和(最重要的一点)提升可靠度各方面来看,固态驱动器(SSD)都是比较好的设计架构。 我们还会特别加以说明,为何在所有专为车用直流马达控制所设计的全集成电路当中,新推出的VIPower™ M0-7 H桥系列能够成为同等级最佳选择。 . 市场趋势 预估车用直流马达系统的需求将稳定成长,未来5年的年成长率约在3.1%左右。车身周边的需求主要来于自车门锁、电动后照镜、座椅调整、
[汽车电子]
技术文章—直流<font color='red'>马达</font>在车身电子上的应用
教你如何用51单片机驱动步进电机
前言 步进电机是一种无刷电机,可将电脉冲转换为机械旋转。顾名思义,它根据输入脉冲逐步旋转,是现代数字程序控制系统中的主要执行元件。 步进电机相比其他电机来说,一般具有5个比较明显的特征: 第一,可实现精细,正确的定位 第二,可通过脉冲信号简单控制 第三,体积小型,高转矩 第四,可自行保持停止位置 第五,可进行大惯性负载 广泛应用于工业、医疗、消费电子应用。简而言之,用于任何需要精确旋转或定位对象的地方。 在单片机领域应用比较广泛,在此和大家分享一个小项目。 -操作 步进电机内部线圈原理图: 步进电机通常具有多个励磁线圈(相)和一个带齿转子。电机的步长由相数和转子上的齿数决定。步长是转子一步的角位移。比
[单片机]
新型步进电机驱动电路的研制
1 引言   在实时控制领域,16位单片机由于其运算速度和精度已得到广泛的应用,尤其在工业过程控制及仪表中,16位单片机对于步进电机的精确控制具有特别重要的意义。在对某型船用燃油机的油门控制器的研制过程中,步进电机作为执行元件,如何提高步进电机的运动平稳性、抗干扰性、可靠性成为研究的核心问题。   对于基于16位单片机的步进电机控制系统来说,驱动电源的输出直接作用于步进电机的绕组,因而驱动电源性能好坏直接影响步进电机的运行性能。 2 对步进电机驱动电源的核心要求   由于步进电机的驱动电流比较大,所以单片机与步进电机的连接需要专门的功率放大电路和驱动电路。油门控制要求响应速度快,运动曲线复杂,所以要求步进电机提高运行特性和反应速
[电源管理]
新型<font color='red'>步进</font>电机<font color='red'>驱动</font>电路的研制
TDK推出电动汽车新型马达控制角度传感器
    TDK展出了用于混合动力车及电动汽车马达控制的角度传感器。该产品采用了GMR元件。与目前使用线圈和磁铁的主流角度传感器相比,其特点是传感器精度高达0.35度,并且尺寸较小。   角度传感器和安装于马达轴的金属圆盘配套使用。传感器采用圆弧形状,内置有4个GMR元件。各GMR元件后侧配备有永久磁铁。金属圆盘呈微椭圆形,当马达轴旋转时,由于圆盘和传感器之间的距离会改变,因此磁场也会由此发生变化。通过GMR元件可检测出磁场变化,以此来掌握角度。   该公司表示,对于混合动力车及电动汽车,为起动时动作顺畅,有需求希望能以0.5~0.8度的测量精度检测静止时的马达角度。今后,将面向高级车型的混合动力车及电动汽车销售该传感器。目前
[汽车电子]
51ROBOT与柯马达成战略合作协议
2019年3月14日,自动化解决方案的全球领导者柯马(COMAU)与工业机器人一站式服务平台51ROBOT战略合作签约仪式在柯马(上海)工程有限公司举行。通过此次签约仪式,51ROBOT将成为柯马机器人及自动化产品事业部在中国华东区的首家经销商。 51ROBOT与柯马签约仪式现场 柯马总部位于意大利都灵,具有45年工厂验证的经验,36个地点、15个制造工厂和5个创新中心,分布在17个国家,有超过9,000名员工。经销商和合作伙伴的全球网络让柯马可以快速响应不同规模的世界范围内的客户需求。 柯马意大利总部 随着工业机器人和自动化行业的不断发展,客户对于工业机器人的关注不再只限于产品的质量,产品的相关配套设备及服务也成为他们关注的
[机器人]
单片机驱动步进电机程序
NS-6型实验板驱动步进电机 控制输出为P1口 由8050,8550做功率输出驱动PH266-E1.2按K1键,电机由慢变快作加速度顺时针旋转按K2键,电机由慢变快作加速度逆时针旋转 注:本试验只为初学者掌握单片机驱动步进电机的原理,其硬件配置只做为短时间试验演示不可持续过长时间,亦不可实际中使用 电路如下图: ? ;尼士单片机 ;任风逍遥 ;步进电机驱动程序 ;2004/8/8 ;NS-1试验板驱动步进电机 ;K1驱动步进电机顺时针转动,K2驱动步进电机逆时针转动 org 000h ajmp aa org 010h ;马达正转 aa: mov 20h,#50 JB P3.6,Bb;如果P3.6为1
[单片机]
小广播
最新电源管理文章
