输入子系统的原理分析强烈推荐观看韦东山老师的视频讲座,讲的非常清楚,我这里是按照输入子系统的方式实现的按键驱动,下面是源码,放在这里做个备份:
- #include
- #include
- #include
- #include
- #include
- #include
- static struct input_dev *buttons_dev;
- static struct timer_list timer;
- struct button_desc* button_desc = NULL;
- struct button_desc{
- char* name;
- unsigned int pin;
- unsigned int irq;
- unsigned int val;
- static struct button_desc buttons_desc[8] = {
- [0] = {
- .name = "S1",
- .pin = S5PV210_GPH0(0),
- .irq = IRQ_EINT(0),
- .val = KEY_L,
- [1] = {
- .name = "S2",
- .pin = S5PV210_GPH0(1),
- .irq = IRQ_EINT(1),
- .val = KEY_S,
- [2] = {
- .name = "S3",
- .pin = S5PV210_GPH0(2),
- .irq = IRQ_EINT(2),
- .val = KEY_C,
- [3] = {
- .name = "S4",
- .pin = S5PV210_GPH0(3),
- .irq = IRQ_EINT(3),
- .val = KEY_ENTER,
- [4] = {
- .name = "S5",
- .pin = S5PV210_GPH0(4),
- .irq = IRQ_EINT(4),
- .val = KEY_LEFTCTRL,
- [5] = {
- .name = "S6",
- .pin = S5PV210_GPH0(5),
- .irq = IRQ_EINT(5),
- .val = KEY_MINUS,
- [6] = {
- .name = "S7",
- .pin = S5PV210_GPH2(6),
- .irq = IRQ_EINT(22),
- .val = KEY_CAPSLOCK,
- [7] = {
- .name = "S8",
- .pin = S5PV210_GPH2(7),
- .irq = IRQ_EINT(23),
- .val = KEY_SPACE,
- static void timer_function(unsigned long data){
- if(button_desc == NULL)
- return;
- if(gpio_get_value(button_desc->pin)){
- input_event(buttons_dev, EV_KEY, button_desc->val, 0);
- else{
- input_event(buttons_dev, EV_KEY, button_desc->val, 1);
- input_sync(buttons_dev);
- static irqreturn_t irq_handler(int irq, void *devid){
- button_desc = (struct button_desc*)devid;
- mod_timer(&timer, jiffies + HZ/100);
- return IRQ_RETVAL(IRQ_HANDLED);
- static int buttons_init(void){
- int i;
- buttons_dev = input_allocate_device();
- if(buttons_dev == NULL){
- printk(KERN_ERR "Error: allocate input device failed! ");
- return -ENOMEM;
- __set_bit(EV_KEY, buttons_dev->evbit);
- __set_bit(EV_REP, buttons_dev->evbit);
- __set_bit(KEY_L, buttons_dev->keybit);
- __set_bit(KEY_S, buttons_dev->keybit);
- __set_bit(KEY_C, buttons_dev->keybit);
- __set_bit(KEY_SPACE, buttons_dev->keybit);
- __set_bit(KEY_MINUS, buttons_dev->keybit);
- __set_bit(KEY_ENTER, buttons_dev->keybit);
- __set_bit(KEY_LEFTCTRL, buttons_dev->keybit);
- __set_bit(KEY_CAPSLOCK, buttons_dev->keybit);
- printk("1 ");
- if(input_register_device(buttons_dev)){
- goto error_1;
- printk("2 ");
- init_timer(&timer);
- timer.function = timer_function;
- add_timer(&timer);
- printk("3 ");
- for(i = 0; i != 8; ++i){
- if(request_irq(buttons_desc[i].irq, irq_handler,
- IRQF_TRIGGER_RISING|IRQF_TRIGGER_FALLING, buttons_desc[i].name, &buttons_desc[i])){
- goto error_2;
- printk("4 ");
- return 0;
- error_2:
- for(--i; i >= 0; --i){
- free_irq(buttons_desc[i].irq, &buttons_desc[i]);
- input_unregister_device(buttons_dev);
- error_1:
- input_free_device(buttons_dev);
- return -EBUSY;
- static void buttons_exit(void){
- int i;
- module_init(buttons_init);
- module_exit(buttons_exit);
- MODULE_LICENSE("GPL");
很显然,基于输入子系统的按键驱动比起直接编写的字符驱动设备要简单的多,不过按键消抖还是要加的,上面的代码加上了按键消抖。如果在开发过程中遇到了什么问题,还是欢迎留言讨论。
上一篇:S5PV210(TQ210)学习笔记——LCD驱动编写
下一篇:S5PV210(TQ210)学习笔记——按键驱动程序
推荐阅读最新更新时间:2024-03-16 14:29
