MEGA16读AD7705程序
发布者:Yaqi最新更新时间:2016-10-28 来源: eefocus关键字:MEGA16  读AD7705 手机看文章 扫描二维码
随时随地手机看文章
#include
#include
#define uchar unsigned char
#define uint unsigned int
#define Add_key  PINC
#define CS_1        (PORTB|= (1<<4 ))
#define CS_0        (PORTB&= ~(1<<4 ))
#define LED_1       (PORTB|= (1<<0 ))
#define LED_0       (PORTB&= ~(1<<0 ))
#define LED1_1       (PORTB|= (1<<1 ))
#define LED1_0       (PORTB&= ~(1<<1 ))
#define DRDY        (PINB& 0x08)
#define ADDR        (PINC& 0x01)
#define SPE_1       (SPCR|= (1<<6 ))
uint value,value1,value2;
//**********************短延时程序50us**************************//
void delay50us(uint t)
    uint j;
    for(;t>0;t--)
        for(j=0;j<70;j++)
//**********************短延时程序5us**************************//
void delay5us(uint t)
    uint j;
    for(;t>0;t--)
        for(j=0;j<7;j++)
//**********************长延时程序50ms**************************//
void delay50ms(uint t)
        uint i;
        for(;t>0;t--)
                for(i=0;i<52642;i++)
//**************************端口初始化*************************//
void IO_Init(void)
 DDRC=0x00;
 PORTC=0x00;
  DDRB=0b10110111;   //PB3\PB6输入
 PORTB=0b11110111; //MISO输入加上拉电阻
void spi_init(void)
 SPCR = 0b01011111; //使能SPI,MSB先发送,主机,SCK空闲高,模式三,128分频
 SPSR = 0x00; //setup SPI,主机倍频
 //CS_0;    //使能SPI器件
//******************SPI写寄存器函数*******************************//
void WriteToReg_ADC(uint byteword)
   CS_0;    //使能SPI器件
  //SPE_1;
  SPDR=byteword;       //发送数据
  while(!(SPSR & (1<    CS_1;    //禁止SPI器件
//  delay5us(10);
//******************SPI读函数*******************************//
unsigned char Read_Byte_SPI(void)
    SPDR = 0xff;  //发送数据,给AD7705提供脉冲
    while (!(SPSR &(1<     return SPDR;
//******************SPI读数据寄存器函数*******************************//
uint Read_ADC16BitValue(void)
    uchar temp1=0;
    uint temp=0;
         CS_0;    //使能SPI器件
        temp=Read_Byte_SPI();
        temp=temp<<8;
        temp1=Read_Byte_SPI();
        temp=temp|temp1;
         CS_1;    //禁止SPI器件
        return temp;
//******************绿灯闪烁******************************//
void greenled(void)
           LED_0;
          delay50us(50);
          LED_1;
          delay50us(50);
          LED_0;
          delay50us(50);
          LED_1;
          delay50us(50);
void yellowled(void)
           LED1_0;
          delay50us(50);
          LED1_1;
          delay50us(50);
          LED1_0;
          delay50us(50);
          LED1_1;
          delay50us(50);
//**************************AD初始化*************************//
void ADC_Init(void)
  uchar i;
   for(i=10;i>0;i--)
    {WriteToReg_ADC(0xff);}  //持续DIN高电平写操作,恢复AD7705接口
 WriteToReg_ADC(0x20);       //通道1,下一个写时钟寄存器
 WriteToReg_ADC(0x0c);       //写时钟寄存器设置更新速率为200hz
 WriteToReg_ADC(0x10);       //通道1,下一个写设置寄存器
 WriteToReg_ADC(0x44);       //自校准,增益1,单极,无缓冲
 delay50us(100);              //延时
//WriteToReg_ADC(0x21);       //通道2,下一个写时钟寄存器
// WriteToReg_ADC(0x0c);       //写时钟寄存器设置更新速率为200hz
// WriteToReg_ADC(0x11);       //通道2,下一个写设置寄存器
//WriteToReg_ADC(0x44);       //自校准,增益1,单极,无缓冲
// delay50us(100);
//***************************读取****************************//
void ceshi(void)
  if(DRDY==0)     //数据准备好
           WriteToReg_ADC(0x38);       //下一操作为读数据寄存器1
           value1=Read_ADC16BitValue();//读取
          LED_1;                 //进入AD,指示等灭
           yellowled();           //黄灯闪烁
  greenled();               //绿灯闪烁
void main(void)
        delay50us(100);   //延时等待外围器件稳定
        IO_Init();
        spi_init();
        ADC_Init();
        while(1)
         ceshi();         //读取AD数据
AD7705精度在16位,第一次用16位的AD,很好....先前一直不能正确读取数值.是因为AD7705坏了,损坏的原因是设计上的失误,我把REF IN+接地了,REF IN-接参考电压..后来重新焊接了一个板子,把REF IN+修改了.就好了,哎,不是问题的问题!!
大家看下面的图,REF IN+接错了,其它的还是比较准确的,程序已经测试过了,谁要用的着的,可以看看,
MEGA16读AD7705程序 - 潇洒一回 - 芯的起点
两个通道依次读取,注意写通讯寄存器的数值,
#include
#include
uchar ch_flag=0;
    uint j;
    for(;t>0;t--)
        for(j=0;j<70;j++)
    uint j;
    for(;t>0;t--)
        for(j=0;j<7;j++)
        uint i;
        for(;t>0;t--)
void IO_Init(void)
 DDRC=0x00;
 PORTC=0x00;
void spi_init(void)
 //CS_0;    //使能SPI器件
//******************SPI写寄存器函数 8BIT*******************************//
void WriteToReg_ADC(uchar byteword)
   CS_0;    //使能SPI器件
  //SPE_1;
//  delay5us(10);
//******************SPI读函数 8BIT*******************************//
//******************SPI读数据寄存器函数 16BIT****************************//
    uchar temp1=0;
    uint temp=0;
         CS_0;    //使能SPI器件
        temp=temp<<8;
        temp=temp|temp1;
         CS_1;    //禁止SPI器件
        return temp;
void greenled(void)
           LED_0;
          delay50us(50);
          LED_1;
          delay50us(50);
          LED_0;
          delay50us(50);
          LED_1;
          delay50us(50);
           LED1_0;
          delay50us(50);
          LED1_1;
          delay50us(50);
          LED1_0;
          delay50us(50);
          LED1_1;
          delay50us(50);
void ADC_Init(void)
  uchar i;
   for(i=10;i>0;i--)
 WriteToReg_ADC(0x0a);       //写时钟寄存器设置更新速率为200hz
 WriteToReg_ADC(0x40);       //自校准,增益1,双极,缓冲
 delay50us(100);
//***************************按照通道1读取****************************//
void Read_ch1(void)
  uint temp1=0;
  if(DRDY==0)     //数据准备好
           temp1=Read_ADC16BitValue();//读取
           LED_1;                 //进入AD,指示等灭
           yellowled();           //黄灯闪烁
    greenled();               //绿灯闪烁
        value1=temp1;
        WriteToReg_ADC(0x39);// 下一操作为读数据寄存器2
//***************************按照通道2读取****************************//
void Read_ch2(void)
  uint temp2=0;
  if(DRDY==0)     //数据准备好
           temp2=Read_ADC16BitValue();//读取
           LED_1;                 //进入AD,指示等灭
           yellowled();           //黄灯闪烁
    greenled();               //绿灯闪烁
        value2=temp2;
//********************获取两个通道模拟量数值***************//
void get_ad(void)
  if(DRDY==0)     //数据准备好
    ch_flag++;
        if(ch_flag==0x03)
        {ch_flag=0x00;}
  if(ch_flag==0x01)
  { Read_ch1();}
  if(ch_flag==0x02)
  { Read_ch2();}
//***********************主程序*********************************//
void main(void)
        IO_Init();
        spi_init();
        ADC_Init();
        while(1)
   get_ad();
        greenled(); greenled(); greenled();               //绿灯闪烁
关键字:MEGA16  读AD7705 引用地址:MEGA16读AD7705程序
上一篇:带SPI接口的16位AD7705驱动程序
下一篇:KS0108 128*64 LCD C语言驱动
推荐阅读最新更新时间:2024-03-16 15:18
基于AVR单片机Megal6的电子时钟设计
1 引言   数字钟能长期、连续、可靠、稳定地工作;同时还具有体积小,功耗低等特点,便于携带,使用方便。数字钟是采用数字电路实现对“时、分、秒”数字显示的计时装置,广泛应用于个人家庭、车站、码头、办公室等公共场所,已成为人们日常生活中不可缺少的必需品。由于数字集成电路的发展和石英晶体振荡器的广泛应用,使得数字钟的精度远远超过老式钟表,钟表的数字化给人们生产生活带来了极大的方便,而且大大地扩展了钟表原先的报时功能。传统MCS51系列单片机的所有数据处理都基于一个累加器,因此累加器与程序存储器、数据存储器之间的数据转换就成了单片机的瓶颈;在AVR单片机中,寄存器由32个通用工作寄存器组成,并且任何一个寄存器都能充当累加器,从
[单片机]
AVR笔记8:mega16再次锁死
今天尝试使用11.0592MHz外部晶振来设置USART的波特率,没想到理解错误,把熔丝位设置为外部RC振荡CKSEL=1000,下载完成后就知道出问题了,有了上次芯片锁死的经历,这次就也不慌了,知道问题出在哪儿,借来函数信号发射器,给13引脚的XTAL1加入1MHz的脉冲,成功的解锁了。然后再次上网查这方面的资料,发现因这样出错的还不少,使用外部晶振,得将熔丝位设置为CKSEL=1111,这样才是正确的。 虽然,在尝试的过程中出现了一些不大不小的错误,但是通过尝试进步了,学到东西了,还是比较兴奋地。不能因为害怕出现问题或者是犯错,而不敢去尝试,人总是在不断的尝试中成长起来的。 【转载】马潮老师 AVR芯片锁
[单片机]
MEGA16单片机_AD转换程序
AD转换,编程的寄存器有: ADMUX:多工选择寄存器。参考电压、对齐方式、模拟通道及增益选择位 ADCSR(A):使能、中断标志、中断使能、预分频值等 ADCL、ADCH:数据寄存器 SFI0R:特殊功能寄存器 //////////////////////////////////////////////////////////////////////////////////////////////////// #ifndef __AD_H__ #define __AD_H__ #include iom16v.h #include macros.h #define uchar unsigned char #d
[单片机]
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
