mc9s12 c语言,飞思卡尔mc9s12的prm文件详解之二
2021-07-22来源: eefocus关键字:mc9s12  c语言  飞思卡尔  prm文件
关于Codewarrior 中的 .prm 文件
要讨论单片机的地址映射,就必须要接触.prm文件,本篇的讨论基于 Codewarrior 5.0 编译器,单片机采用MC9S12XS128。
通过项目模板建立的新项目中都有一个名字为“project.prm”的文件,位于Project Settings->Linker Files文件夹下。一个标准的基于XS128的.prm文件起始内容如下:
.prm文件范例:
/* This is a linker parameter file for the MC9S12XS128 */
/*This file is setup to use the HCS12X core only.If you plan to also use the XGATE in your project, best create a new project with the'New Project Wizard' (File|New... menu in the CodeWarrior IDE) and choose the appropriateproject parameters.*/
NAMES /* CodeWarrior will pass all the needed files to the linker by command line. But here you may add your dditional files */
END
SEGMENTS /* here all RAM/ROM areas of the device are listed. Used in PLACEMENT below. All addresses are logical' */
/* Register space */
/* IO_SEG = PAGED 0x0000 TO 0x07FF; intentionally not defined */
/* non-paged RAM */
RAM = READ_WRITE DATA_NEAR 0x2000 TO 0x3FFF;
/* non-banked FLASH */
ROM_4000 = READ_ONLY DATA_NEAR IBCC_NEAR 0x4000 TO 0x7FFF;
ROM_C000 = READ_ONLY DATA_NEAR IBCC_NEAR 0xC000 TO 0xFEFF;
/* VECTORS = READ_ONLY 0xFF00 TO 0xFFFF; intentionally not defined: used for VECTOR commands below */
//OSVECTORS = READ_ONLY 0xFF10 TO 0xFFFF; /* OSEK interrupt vectors (use your vector.o) */
/* paged EEPROM 0x0800 TO 0x0BFF; addressed through EPAGE */
EEPROM_00 = READ_ONLY DATA_FAR IBCC_FAR 0x000800 TO 0x000BFF;
EEPROM_01 = READ_ONLY DATA_FAR IBCC_FAR 0x010800 TO 0x010BFF;
EEPROM_02 = READ_ONLY DATA_FAR IBCC_FAR 0x020800 TO 0x020BFF;
EEPROM_03 = READ_ONLY DATA_FAR IBCC_FAR 0x030800 TO 0x030BFF;
EEPROM_04 = READ_ONLY DATA_FAR IBCC_FAR 0x040800 TO 0x040BFF;
EEPROM_05 = READ_ONLY DATA_FAR IBCC_FAR 0x050800 TO 0x050BFF;
EEPROM_06 = READ_ONLY DATA_FAR IBCC_FAR 0x060800 TO 0x060BFF;
EEPROM_07 = READ_ONLY DATA_FAR IBCC_FAR 0x070800 TO 0x070BFF;
/* paged RAM: 0x1000 TO 0x1FFF; addressed through RPAGE */
/* RAM_FE = READ_WRITE 0xFE1000 TO 0xFE1FFF; intentionally not defined: equivalent to RAM: 0x2000..0x2FFF */
/* RAM_FF = READ_WRITE 0xFF1000 TO 0xFF1FFF; intentionally not defined: equivalent to RAM: 0x3000..0x3FFF */
/* paged FLASH: 0x8000 TO 0xBFFF; addressed through PPAGE */
PAGE_F8 = READ_ONLY DATA_FAR IBCC_FAR 0xF88000 TO 0xF8BFFF;
PAGE_F9 = READ_ONLY DATA_FAR IBCC_FAR 0xF98000 TO 0xF9BFFF;
PAGE_FA = READ_ONLY DATA_FAR IBCC_FAR 0xFA8000 TO 0xFABFFF;
PAGE_FB = READ_ONLY DATA_FAR IBCC_FAR 0xFB8000 TO 0xFBBFFF;
PAGE_FC = READ_ONLY DATA_FAR IBCC_FAR 0xFC8000 TO 0xFCBFFF;
/* PAGE_FD = READ_ONLY 0xFD8000 TO 0xFDBFFF; intentionally not defined: equivalent to ROM_4000 */
PAGE_FE = READ_ONLY DATA_FAR IBCC_FAR 0xFE8000 TO 0xFEBFFF;
/* PAGE_FF = READ_ONLY 0xFF8000 TO 0xFFBFFF; intentionally not defined: equivalent to ROM_C000 */
END
PLACEMENT /* here all predefined and user segments are placed into the SEGMENTS defined above. */
_PRESTART, /* Used in HIWARE format: jump to _Startup at the code start */
STARTUP, /* startup data structures */
ROM_VAR, /* constant variables */
STRINGS, /* string literals */
VIRTUAL_TABLE_SEGMENT, /* C++ virtual table segment */
//.ostext, /* eventually OSEK code */
DEFAULT_ROM, NON_BANKED, /* runtime routines which must not be banked */
COPY /* copy down information: how to initialize variables */
/* in case you want to use ROM_4000 here as well, make sure
that all files (incl. library files) are compiled with the
option: -OnB=b */
INTO ROM_C000 /*, ROM_4000*/ ;
OTHER_ROM INTO PAGE_FE, PAGE_FC, PAGE_FB, PAGE_FA, PAGE_F9, PAGE_F8;
//.stackstart, /* eventually used for OSEK kernel awareness: Main-Stack Start */
SSTACK, /* allocate stack first to avoid overwriting variables on overflow */
//.stackend, /* eventually used for OSEK kernel awareness: Main-Stack End */
PAGED_RAM, /* there is no need for paged data accesses on this derivative */
DEFAULT_RAM /* all variables, the default RAM location */
INTO RAM;
DISTRIBUTE DISTRIBUTE_INTO
ROM_4000, PAGE_FE, PAGE_FC, PAGE_FB, PAGE_FA, PAGE_F9, PAGE_F8;
CONST_DISTRIBUTE DISTRIBUTE_INTO
DATA_DISTRIBUTE DISTRIBUTE_INTO
RAM;
//.vectors INTO OSVECTORS; /* OSEK vector table */
END
ENTRIES /* keep the following unreferenced variables */
/* OSEK: always allocate the vector table and all dependent objects */
//_vectab OsBuildNumber _OsOrtiStackStart _OsOrtiStart
END
STACKSIZE0x100 /* size of the stack (will be allocated in DEFAULT_RAM) */
/* use these definitions in plane of the vector table ('vectors') above */
VECTOR 0 _Startup /* reset vector: this is the default entry point for a C/C++ application. */
//VECTOR 0 Entry /* reset vector: this is the default entry point for an Assembly application. */
//INIT Entry /* for assembly applications: that this is as well the initialization entry point */
1 .prm文件组成结构
按所含的信息的不同.prm文件有六个组成部分构成,这里仅讨论和内存空间映射关系紧密的三个部分,其他的不做讨论。
· SEGMENTS… END
定义和划分芯片所有可用的内存资源,包括程序空间和数据空间。一般我们将程序空间定义成ROM,把数据空间定义成RAM,但这些名字都不是系统保留的关键词,可以由用户随意修改。用户也可以把内存空间按地址和属性随意分割成大小不同的块,每块可以自由命名。例如同样是RAM,可以使用不同的属性,使其有复位后变量清零和不清零之分。
关于内存划分的具体方法在后面详解。
· PLACEMENT… END
将指派源程序中所定义的各种段,如数据段DATA_SEG、CONST_SEG和代码段CODE_SEG 被具体放置到哪一个内存块中。它是将源程序中的定义描述和实际物理内存挂钩的桥梁。
· STACKSIZE
定义系统堆栈长度,其后给出的长度字节数可以根据实际应用需要进行修改。堆栈的实际定位取决于RAM内存的划分和使用情况。默认的情况下,堆栈放在RAM区域的起始部分。当然,堆栈的定义不只有这种方式,还可以使用STACKTOP关键字。后面将详细讨论。
2内存划分的具体方式
由SEGMENTS开始到END为止,中间可以添加任意多行内存划分的定义,每一行用分号结尾。定义行的语法型式为:
[块名] = [属性1] [属性2] ,… ,[属性n] [起始地址] TO [结束地址];
其中,
· “块名”的定义和C语言变量定义相同,是以英文字母开头的一个字符串,用户可以自己任意定义块名。
· “属性”用户是不能自己定义的,因为属性名指定了上面所说的“块名”所对应的不同的内存类型和访问方式,而不同物理内存的类型和访问方式是一定的。
对于“属性1”,Codewarrior 5.0中可以有三种不同的类型,对于只读的Flash-ROM区属性一定是READ_ONLY,对于可读写的RAM区属性可以是READ_WRITE,也可以是NO_INIT。它们两者的关键区别是ANSI-C的初始化代码会把定位在READ_WRITE块中的所有全局和静态变量自动清零,而NO_INIT块中的变量将不会被自动清零。当然只是复位时不清零,掉电时还是清零的,但是对于单片机系统,变量在复位时不被自动清零这一特性有时是很关键的,在某些应用中有特殊的用途。
对于“属性2 … 属性n”,根据上面给出的.prm的范例文件可以看出来,可能的形式有“DATA_FAR”、“DATA_NEAR”、“IBCC_FAR”、“IBCC_NEAR”四种类型。其中,“DATA_FAR”和“DATA_NEAR”相对应,当内存区域包含变量或者是常量时(通常是RAM、Flash和EEPROM),必须指明上面两种属性中的一种,由于涉及到内存的分页,可以这样理解:“DATA_FAR”属性指定的内存块为可以保存数据的非固定页,而“DATA_NEAR”属性指定的内存块为可以保存数据的固定页;同理“IBCC_FAR”和“IBCC_NEAR”相对应,当内存区域包含代码时(Flash和EEPROM),必须指明上面两种属性中的一种,“IBCC_FAR”属性指定的内存块为可以保存代码的非固定页,而“IBCC_NEAR”属性指定的内存块为可以保存代码的固定页
讨论到这里,细心的读者已经发现,在上面的.prm文件范例中,RAM的属性有“DATA_FAR”和“DATA_NEAR”两种,Flash的属性中也是四种都有,但是EEPROM中却只有“DATA_FAR”和“IBCC_FAR”两种,这正好验证了上一篇文章(飞思卡尔16位单片机的资源配置)中所提到的,RAM、Flash中都有固定页,但是EEPROM中全部是非固定页。
· 起始地址和结束地址决定了一内存块的物理位置,对于固定页,用4位16进制数表示,而对于非固定页,则用6位16进制表示,多出来的两位其实是寄存器EPAGE、RPAGE或PPAGE的值,可见,对于分页的资源,是通过寄存器(EPAGE、RPAGE或PPAGE)和16位的地址总线的组合来进行寻址的。
“TO”是系统保留的关键字,必须大写。
下面,根据上面范例提供的内容,举几个例子:
例1 RAM = READ_WRITE DATA_NEAR 0x2000 TO 0x3FFF;
上面这句话的意思是:分配0x2000-0x3FFF的区域的块名为“RAM”(当然可以定义别的名称),由上一篇文章而知,这一区域的物理内存的性质为RAM,属性应该为“READ_WRITE”,并且这一区域中的两页都为固定页,所以为“DATA_NEAR”。
例2 将8K字节RAM的后面4K字节定义成非自动清零的数据保留区,则应如下定义:
SEGMENTS
RAM = READ_WRITE DATA_NEAR 0x2000 TO 0x2FFF;
RAM_NO_INIT = NO_INIT DATA_NEAR 0x3000 TO 0x3FFF;
END
注意,各部分RAM的分配地址不应该存在重叠的部分,否则会发生错误。
例3 EEPROM_00 = READ_ONLY DATA_FAR IBCC_FAR 0x000800 TO 0x000BFF;
XS128单片机中的EEPROM由Data-Flash模拟,所以属性为READ_ONLY。EEPROM全部为非固定页,所以用“DATA_FAR”、“IBCC_FAR”。后面的起始地址和结束地址分别为6位的16进制数,前两位的“00”实质指的是EEPROM分页寄存器EPAGE的值为0x00。
用SEGMENTS只是从单片机的物理内存这一角度对其进行空间划分。源程序本身并不知道物理内存被分割和属性定义的这些细节。它们两者之间必须通过下面的PLACEMENT建立联系。
3程序段和数据段的放置
PLACEMENT-END内所描述的信息是告诉连接器源程序中所定义的各类段应该被具体放置到哪一个内存块中去。其语法型式为:
[段名1], [段名2],... , [段名n] INTO [内存块名1],[内存块名2],… ,[内存块名n];
[段名1], [段名2],... , [段名n] DISTRIBUTE_INTO [内存块名1],[内存块名2],… ,[内存块名n];
其中
· 段名就是在源程序中用“#pragma”声明的数据段、常数段或代码段的名字。如果用缺省名“DEFAULT”, 则默认的数据段名为DEFAULT_RAM,代码段和常数段名为DEFAULT_ROM。若程序中定义的段名没有在PLACEMENT中提及,则将被视同为DEFAULT。几个相同性质但不同名字的段可以被放置到同一个内存块中,相互之间用逗号分隔。
· INTO 是系统保留的关键词,在这里为“放入”的意思。
· DISTRIBUTE_INTO 也是系统的保留关键字。Codewarrior 具有内存自动优化的功能,但是在“Small memory”模式中,这种功能不会被启用,只有当16-bit的地址空间不能存放下所有的变量和代码时,才会启用这种功能。
在SEGMENTS-END区域中,当在内存模块的属性中加上“DATA_FAR”、“DATA_NEAR”、“IBCC_FAR”、“IBCC_NEAR”四种属性中的任何一种时,那么在PLACEMENT-END区域中,就需要指定段名“DISTRIBUTE”, “CONST_DISTRIBUTE”, “DATA_DISTRIBUTE”(系统默认的,非关键字,用户可以自行更改)所分配的内存空间,这就需要使用“DISTRIBUTE_INTO”关键字。
关于内存自动优化功能,可以参考freescale的官方技术手册“TN 262.pdf”。
· 内存块名就是前面介绍的用SEGMENTS划分好的不同的内存块名字。
利用这样直观的定位描述文本可以方便灵活的将数据或代码定位到芯片内存任意可能的位置,实现某些特殊目的的应用。
下面的例子,说明了各种段名、PLACEMENT 和SEGMENTS之间的对应关系。
例4定义非自动清零的数据段
SEGMENTS
END
PLACEMENT
DATA_PERSISTENT INTO RAM_NO_INIT;
END
//源程序编写:
#pragma DATA_SEG DATA_PERSISTENT //定义复位时非自定清零数据段
byte sysState;
#pragma DATA_SEG DEFAULT
4堆栈的设置
关于堆栈的设置,Codewarrior提供了两种方式:“STACKSIZE”命令方式和“STACKTOP”命令方式。这两种方式在同一个.prm文件中,不能同时存在。当用户只关心堆栈的大小而不关心堆栈的存放位置时,推荐使用STACKSIZE方式。
系统默认的方式为使用STACKSIZE方式。
STACKSIZE命令方式:
当使用STACKSIZE命令方式时,如果在PLACEMENT-END部分声明了“SSTACK INTO RAM”,这样的话,堆栈区就被放在RAM区域的起始部分,下面的例子说明了这种方式:
例5
SEGMENTS
END
PLACEMENT
SSTACK, PAGED_RAM, DEFAULT_RAM INTO RAM;
END
STACKSIZE0x100
上面的例子将堆栈区域存放的地址为0x20FF-0x2000,初始的堆栈指针指向栈顶地址0x20FF。
相反,如果在PLACEMENT-END部分没有声明“SSTACK INTO RAM”,则堆栈被分配在RAM区域中已分配空间的后面。请参见例6。
例6
SEGMENTS
END
PLACEMENT
END
STACKSIZE0x100
在这个例子中,如果RAM区域中已经分配的变量占用了4个字节(从0x2000到0x2003),则堆栈放在这四个字节的后面,从0x2103到0x2004,初始的堆栈指针指向0x2103。
STACKYOP命令方式:
当使用STACKTOP命令方式时,如果在PLACEMENT-END部分声明了“SSTACK INTO RAM”,同样,堆栈区就被放在RAM区域的起始部分,初始的栈顶则由STACKTOP指定。若没有相应的声明,则初始的栈顶由STACKTOP指定,而堆栈的大小则根据处理器的不同由编译器自行设定,其大小足够装下处理器的PC寄存器的值。
关键字:mc9s12  c语言  飞思卡尔  prm文件 编辑:什么鱼 引用地址:http://news.eeworld.com.cn/mcu/ic542660.html
上一篇:MC9S12XS128MAL Bootloader(1)
下一篇:MC9S12XS128 MAL BootLoader(2)
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
飞思卡尔MC9S12系列 ATD驱动
今天带着大家了解下MC9S12XS128 A/D模块,以及相关驱动的开发。什么是模数(A/D)转换器能够把模拟 量变成数字量的器件称为模数(A/D )转换器。MC9S12XS内置的ATD模块概述MC9S12XS128 内置的ATD (也记做A/D )模块是16 通道、12 位精度、多路输入复用、逐次逼近型的模数转换器。下面一起看下ATD模块具有的基本特征ATD模块具有以下基本特征:l8 位/10 位/12 位可选转换精度;l 停止模式下转换使用内部时钟;l 转换完成后为低功耗状态;l 自动和可编程数值比较,可设定大于或者小于等于设定值时中断申请;l 可编程采样时间;l 左对齐/ 右对齐转换数值;l 外部触发功能;l 转换完成中断申请
发表于 2021-07-21
<font color='red'>飞思卡尔</font>MC9S12系列 ATD驱动
如何加密你的MC9S12(X)设备
前言我们可以使用BDM设备很方便地烧写单片机程序、查看内存、调试程序。但是反过来想,我辛辛苦苦写的程序,写的算法,别人不也可以使用BDM设备很方便的读出来看么!虽然别人只能看到二进制代码,或者说汇编代码,但是到底经过分析还是能知道你的程序怎么写的,这还得了!!!幸好,MC9S12(X)提供了加密功能(手册上对应Secure这个单词),BDM是无法读取处于加密状态的单片机的内存的,也就很好的保护了我们的知识成果。最近我闲着无聊,研究了下这个加密功能,顺便出个小教程分享给大家研究成果,内容基于自己的理解,可能有很多不严谨或者错误的地方,敬请指出。教程中顺便把之前写的几个小模块串起来演示了一遍。另外,这里所讲的基于
发表于 2021-07-16
如何加密你的<font color='red'>MC9S12</font>(X)设备
MC9S12 芯片配置
代码是在内部存储器还是外部存储器中执行。在这种模式下,内部操作在外部总线接口上可见。 Emulation of Single-Chip Mode:开发者使用这种模式对系统进行仿真模拟,其中用户在实际应用中使用的是normal single-chip mode。 Special Test Mode:只有飞思卡尔内部使用。 1低功耗模式:微控制器具有两个主要的低功耗模式。访问相关的节点获得模块行为信息来决定统进入停止,伪停止和等待模式。一个重要系统时钟信息来源是Clock 和 复位S12CRG模块。 System Stop Modes:如果CPU执行停止指令,并且 XGATE
发表于 2021-07-16
<font color='red'>MC9S12</font> 芯片配置
【飞思卡尔 MC9S12】内部D-Flash模拟EEPROM
;      (-10)#define FLASH_MGSTAT_ERROR                  (-11)#define FLASH_BUSY_ERROR                    (-12)  #define FLASH_SUCCESS (1)   //erase multiple sectorint HDL_Flash
发表于 2021-07-16
飞思卡尔MC9S12(X)系列的内存资源分配和.prm文件的结构
页为固定的Flash页(非分页),中间的一页(0x8000-0xBFFF)为窗口区,通过设置PPAGE寄存器,可以映射到其他的分页Flash。 对于RAM和Flash来说,其实固定页和其他的分页资源是统一编址的,不同的是固定页不可以通过寄存器(RPAGE、PPAGE)改变映射,而其他的页必须通过寄存器的设置来选择映射不同的页。二、.prm文件结构详解 1 .prm 文件组成结构 按所含的信息的不同.prm文件有六个组成部分构成,这里仅讨论和内存空间映射关系紧密的三个部分,其他的不做讨论。· SEGMENTS ……END 定义和划分芯片所有可用的内存资源,包括程序空间和数据空间。一般我们将程序空间定义成ROM,把数据
发表于 2021-07-16
飞思卡尔MC9S12(X)系列的内存资源分配和.<font color='red'>prm</font><font color='red'>文件</font>的结构
9. 从0学ARM Cortex-A9 LED汇编、C语言驱动编写
在于:当GPIO引脚处于第三态(即不是输出高电平,也不是输出低电平,而是呈高阻态,即相当于没接芯片)时,它的电平状态由上拉电阻、下拉电阻确定。本例不用设置。四、驱动编写下面我们分别用汇编和C语言来给LED编写驱动程序。1. 汇编代码大家如果掌握了我之前讲解的汇编指令的知识点,那么这个代码很容易就能看明白:.globl _start.arm_start: LDR R0,=0x11000C20 @将配置寄存器GPX1CON的地址写入到R0 LDR R1,[R0]  @读取寄存器GPX1CON的值保存到R1 BIC R1,R1,#0x0000000f @将R1的3:0位清0,目的是不覆盖到其他bit的值 ORR R1,R1
发表于 2021-08-04
9. 从0学ARM Cortex-A9 LED汇编、<font color='red'>C语言</font>驱动编写
小广播
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
电子工程世界版权所有 京B2-20211791 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2021 EEWORLD.com.cn, Inc. All rights reserved
