基于dsPIC33F GS系列的1KVA离线UPS参考设计方
最新更新时间:2011-10-28来源: 互联网关键字:基于dsPIC33F  UPS 手机看文章 扫描二维码
随时随地手机看文章
Microchip 公司的dsPIC33F GS系列是高性能数字信号处理器(DSC), 具有40 MIPS性1,以及4路硬件DMA,多达85个可编程数字I/O引脚,丰富外设特性,多达9个PWM产生器,4个高速模拟比较器和高速10位ADC等,主要用在AC/DC转换器,汽车中的HID,电池充电器,DC/DC转换器,数字照明和UPS等.本文介绍采用dsPIC33F GS系列的1KVA 离线UPS参考设计各部件的基本原理,方框图,电指标和详细的电路图.
Microchip’s Digital Pure Sine Wave Uninterruptible Power Supply (UPS) Reference Design is based on the dsPIC33F “GS” series of digital-power Digital Signal Controllers (DSCs). This reference design demonstrates how digital-power techniques when applied to UPS applications enable easy modifications through software, the use of smaller magnetics, intelligent battery charging, higher efficiency, compact designs, reduction in audible and electrical noise via a purer sine-wave output, USB communication and low-cost overall bill-of-materials. This reference design is Royalty Free.
An Uninterruptible Power Supply, or UPS, is an electronic device that provides an alternative electric power supply to connected electronic equipment when the primary power source is not available.
Unlike auxiliary power, a UPS can provide instant power to connected equipment, which can protect sensitive electronic devices by allowing them to shut down properly and preventing extensive physical damage. However, a UPS can only supply energy for a limited amount of time, typically 15 to 20 minutes.
Although its use can extend to a virtually unlimited list of applications, in past years the UPS has become even more popular as a means of protecting computers and telecommunication equipment, thus preventing serious hardware damage and data loss.
图1.离线UPS方框图
1 kVA 离线UPS参考设计
图2.离线UPS参考设计外形图
图3.离线UPS参考设计方框图
图4.推挽转换器方框图
图5.数字反激开关模式充电器方框图
图6.线性充电器方框图
图7.开关模式充电器方框图
图8. 铁磁共振变压器充电器方框图
图9.SCR充电器方框图
图10.离线UPS方框图
离线UPS参考设计电指标:
图11.离线UPS参考设计电路图(1)
图12.离线UPS参考设计电路图(2)
图13.离线UPS参考设计电路图(3)
图14.离线UPS参考设计电路图(4)
图15.离线UPS参考设计电路图(5)
图16.离线UPS参考设计电路图(6)
图17.离线UPS参考设计电路图(7)
关键字:基于dsPIC33F  UPS 编辑:神话 引用地址:基于dsPIC33F GS系列的1KVA离线UPS参考设计方
上一篇:在数据转换系统中校准增益误差的方法
下一篇:闪烁灯电路的设计图解
推荐阅读最新更新时间:2023-10-13 10:55
实现UPS高可靠性的技术措施
      1引言   产品长期运行的可靠性,所有用户都是非常关心的。众所周知,可靠性是衡量产品质量的重要指标。尤其是UPS这类特殊产品,作为电脑系统的“保镖”、“心脏”,其可靠性更显得重要,也是一些特殊用户极为关注的。   产品可靠性的内容包括固有可靠性及使用可靠性两个方面。固有可靠性是指产品从设计到制造整个过程所确定的内在可靠性,它是产品的固有属性;使用可靠性是指产品在实际使用过程中的人为因素及环境因素(包括安装技巧、维护技术、环境状况、操作人员素质等)对产品的寿命及功能发挥产生的重大影响。   产品可靠性的数量指标有:可靠性、失效率、平均寿命、有效寿命、维修度、有效度、重要度等。对于UPS这类可修复的产品,我
[电源管理]
实现<font color='red'>UPS</font>高可靠性的技术措施
对于UPS漏电保护探讨
  由于工作需要,在我们研制的供电系统中,既要求具有漏电保护的功能,又要求电源具有不间断的能力。所以,我们在每个供电系统中采用了一台3kVA高频在线式不间断电源和一台30mA的定时漏电保护断路器。在一个供电系统调试过程中,多次出现过下述现象:市电正常时,高频在线式不间断电源空载启动,当输出继电器动作,切断旁路,接通逆变电路时,市电断路器的漏电保护动作,从而切断了市电。似乎验证了目前的一种说法;UPS的前端不能加装带有漏电保护的断路器。为此,对其进行了探讨。   l UPS正常开机工作   市电正常时,高频在线式不间断 电源 空载启动,当UPS接到开机命令后,开机电路开始工作。主电路首先通过旁路输出。当CPU检测到逆变器工作正常
[电源管理]
对于<font color='red'>UPS</font>漏电保护探讨
用于双变换UPS的全桥IGBT
UPS设计的趋势 近二十年来,不间断电源随着信息设备的广泛使用而迅速普及,大量使用于信息设备和数据的保护。从不间断电源自身发展来看,很大程度依赖于电力电子技术发展,更依赖于电力电子器件的发展,如磁性材料,IGBT,Power MOSFET。在中大功率产品中IGBT取代GTO使得高频,高效率的SPWM逆变器进入商业应用,也使得有源PFC整流成为可能。在小功率方面,IGBT和POWER MOSFET,取代了BJT,使得效率大幅提高,体积重量大大降低,成本也有革命性的下降。 在众多的UPS电路拓朴结构中,带输出变压器的双变换电路结构具有很强的生命力,它诞生于双极型三极管年代,十多年来整机电路原理没有什么突破,只是在控制电路和用户界面做
[电源管理]
用于双变换<font color='red'>UPS</font>的全桥IGBT
UPS电源科学使用方法还应配合正确维护方式
UPS 电源 的科学使用 任何电源在使用过程中都有它独特的一套规章制度和方法,供我们大家使用,科学的使用方法可以让ups电源的寿命更长,今天我们就来详细说说关于UPS电源的使用,而且ups电源有一套严格科学的作规程,以方便大家可以更加深入的了解 第一:定期对UPS电源进行维护工作:清除机内的积尘,测量蓄电池组的 电压 ,更换不合格的电池,检查风扇运转情况及检测调节UPS的系统参数等。 第二:(5)禁止超负载使用,厂家建议:UPS电源的最大启动负载最好控制在80%之内,如果超载使用,在逆变状态下,时常会击穿逆变 三极管 。实践证明:对于绝大多数UPS电源而言,将其负载控制在30%~60%额定输出功率范
[电源管理]
UPS不间断电源常用词汇
安时数(AH): 反映电池容量大小的指标之一,其定义是按规定的电流进行放电的时间。相同电压的电池,安时数大的容量大;相同安时数的电池,电压高的容量大。通常以电压和安时数共同表示电池的容量,如12V/7AH、12V24AH、12V/65AH、12V/100AH。 避雷器: 用来吸收雷击波的器件,工作原理是,雷击产生瞬间高电压进入电路,引起避雷器导通吸收雷击电流,将电路电压箝位在安全范围之内。可做为避雷器件的元件有多种,如压敏电阻、放电管等。 注:雷击电压是大气与大地之间的高压放电,因此,避雷器要有良好的接地才能起作用。 保险丝: 一种过热熔断型的小型器件,超载或负载短路时引起电流过大会烧断保险丝,保护电子设备不受过电
[电源管理]
UPS在有线电视前端中的使用
前端机房是有线电视系统的心脏,是各路电视信号的处理、分配传输的集散地。我台前端机房现向网络用户传送广播电视节目31套,24小时不间断播出,并由机房供电器向东西南北四条主干线的部分放大器供给60V的工作电源,机房供电质量的优劣直接影响着系统的安全运行和对用户的服务质量,前端机房要有稳定而不间断的电源才能保证安全优质播出。所以保证前端机房的供电不间断是十分重要的。   1 采用UPS电源的提出   我台前端机房的供电是和盟委、广电大院共用一条输电线路,锅炉用电设备的启动,大功率发射机的运转,以及和民用电高峰的重合,经常发生大幅度的电压波动和严重杂波干扰,经常烧断跌落保险造成断电。另外,供电部门的停电维修经常安排在双休日期间进行
[电源管理]
UPS不间断电源通用维修技术标准
1.标准适用范围 本标准适用于直流环节中有电储能装置的交流电子间接变流系统,能满足用户对供电连续性和供电质量要求的各种型式静止型UPS。 2.工作条件 2.1环境温度 UPS运行的环境温度为10℃~+35℃,有蓄电池场合的环境温度要求20℃±5℃。 2.2环境相对湿度 最小相对湿度范围为20%~80%(无凝露) 3.安全要求 3.1绝缘电阻 UPS的输入端、输出端对地,施加500V直流电压,绝缘电阻应大于 2MΩ。 3.2对地漏电流 UPS机壳对地的漏电流应不大于3.5mA。 4.基本项目的检查 5.蓄电池检查 6.功能切换试验 7.保护性能试验
[电源管理]
<font color='red'>UPS</font>不间断电源通用维修技术标准
UPS:有没有变压器很重要么?
新一代无变压器不间断电源(UPS)的诞生让人们的脑海中出现一个问题,那就是这两种类型的UPS各有何优缺点。注意,本文对比的是无变压器UPS与自身带有内部变压器的三相双转换单元(three-phase dual conversion units)。 在过去的五到七年里,无变压器UPS一直统治者小型三相(3万伏安及以下)市场。相比于上一代有变压器的UPS来说,无变压器的UPS体积更小、更轻,而且成本也更低。这种设计的额定功率很快地上升到10万伏安,随之又达到30万伏安。若是用于多模块系统,甚至可以达到100万伏安或更高。 IGBT与无变压器UPS 这里,我们先回顾一下以前的历史:以往的UPS是基于
[电源管理]
小广播
最新电源管理文章
换一换 更多 相关热搜器件
站点相关:
词云: 1 2 3 4 5 6 7 8 9 10
