TITPS59650IntelIMVP-7系列处理器电源解决方案
最新更新时间:2012-05-11来源: 21IC关键字:DC/DC转换器  Intel  IMVP-7 手机看文章 扫描二维码
随时随地手机看文章
TI公司的TPS51650和TPS59650是集成了两个栅极驱动器的双路 VID全兼容的IMVP-7降压控制器,支持CPU和GPU输出,CPU通路具有一相,二相或三相,GPU通路具有一相或二相,8位 AC具有0.250V到1.52V的输出,转换电压范围3V到28V,主要用在IMVP-7 VCORE以及适配器,电池,NVDC或3V,5V和12V电源.本文介绍了TPS51650和TPS59650主要特性,方框图,多种典型应用电路,以及TPS59650EVM-753评估模块主要特性和指标,方框图,电路,材料清单和PCB元件布局图.
The TPS51650 and TPS59650 are dual-channel, fully SVID compliant IMVP-7 step-down controllers with two integrated gate drivers. Advanced control features such as D-CAP+ architecture with overlapping pulse support (undershoot reduction, USR) and overshoot reduction (OSR) provide fast transient response, lowest output capacitance and high efficiency. All of these controllers also support single-phase operation for light loads. The full compliment of IMVP-7 I/O is integrated into the controllers including dual PGOOD signals, ALERT and VR_HOT. Adjustable control of VCORE slew rate and voltage positioning round out the IMVP-7 features. In addition, the controllers’ CPU channel includes two high-current FET gate drivers to drive high-side and low-side N-channel FETs with exceptionally high speed and low switching loss.
TPS51650和TPS59650主要特性:
Intel IMVP-7 Serial VID (SVID) Compliant
Supports CPU and GPU Outputs
CPU Channel One-Phase, Two-Phase, or Three-Phase
One-Phase or Two-Phase GPU Channel
Full IMVP-7 Mobile Feature Set Including Digital Current Monitor
8-Bit DAC with 0.250-V to 1.52-V Output Range
Optimized Efficiency at Light and Heavy Loads
VCORE Overshoot Reduction (OSR)
VCORE Undershoot Reduction (USR)
Accurate, Adjustable Voltage Positioning
8 Independent Frequency Selections per Channel (CPU/GPU
Patent Pending AutoBalance™ Phase Balancing
Selectable 8-Level Current Limit
3-V to 28-V Conversion Voltage Range
Two Integrated Fast FET Drivers w/Integrated Boost FET
Selectable Address (TPS59650 only)
Small 6 × 6 , 48-Pin, QFN, PowerPAD Package
TPS51650和TPS59650应用:
IMVP-7 VCORE Applications for Adapter, Battery, NVDC or 3-V, 5-V, and 12-V Rails
图1.TPS51650和TPS59650方框图
图2.TPS51650带电感DCR电流检测的三相CPU,2相GPU应用电路图
图3.带电感DCR电流检测的一相GPU应用电路图
图4.带电感DCR电流检测的三相CPU应用电路图
图5.带电感DCR电流检测的2相CPU应用电路图
图6.带电感DCR电流检测的2相CPU和GPU不能的应用电路图
TPS59650EVM-753评估模块
The TPS59650EVM-753 is designed to use a 9V-20V Input bus to produce 6 regulated outputs for IMVP7 SVID CPU/GPU Power System. The TPS59650EVM-753 is specially designed to demonstrate the TPS59650 full IMVP7 mobile feature while providing GUI communication programing and a number of test points to evaluate the static and dynamic performance of TPS59650.
TPS59650EVM-753评估模块典型应用:
• IMVP7 Vcore Applications for Adapter, Battery, NVDC or 3V/5V/12V rails
TPS59650EVM-753评估模块主要特性:
• Complete solution for 9V-20V Input Intel IMVP7 SVID Power System
• GUI communication to demonstrate full IMVP7 Mobile feature
• 3-Phase CPU Vcore can support up to 94A output current
• 2-Phase GPU Vcore can support up to 46A output current
• 8 Selectable Switching frequency for CPU and GPU power
• 8 Levels selectable current limit for CPU and GPU power
• Switches or Jumpers for each output enable
• On Board Dynamic Load for CPU, GPU Vcore and VCCIO output
• High efficiency and high density by using TI power block MOSFET
• Convenient test points for probing critical waveforms
• Eight Layer PCB with 1oz copper SLUU896–
图8.TPS59650EVM-753电源系统框图
图9.TPS59650EVM-753外形图
TPS59650EVM-753电性能指标:
图10.TPS59650EVM-753电路图(1)
图11.TPS59650EVM-753电路图(2)
图12.TPS59650EVM-753电路图(3)
图13.TPS59650EVM-753电路图(4)
图14.TPS59650EVM-753电路图(5)
图15.TPS59650EVM-753电路图(6)
图16.TPS59650EVM-753电路图(7)
图17.TPS59650EVM-753电路图(8)
图18.TPS59650EVM-753电路图(9)
图19.TPS59650EVM-753电路图(10)
图20.TPS59650EVM-753电路图(11)
图21.TPS59650EVM-753电路图(12)
图22.TPS59650EVM-753电路图(13)
图23.TPS59650EVM-753电路图(14)
TPS59650EVM-753材料清单:
图24.TPS59650EVM-753 PCB元件布局图:顶层
图24.TPS59650EVM-753 PCB元件布局图:底层
详情请见:
http://www.ti.com/lit/ds/slusav7/slusav7.pdf
http://www.ti.com/lit/ug/sluu896/sluu896.pdf
关键字:DC/DC转换器  Intel  IMVP-7 编辑:探路者 引用地址:TITPS59650IntelIMVP-7系列处理器电源解决方案
上一篇:可使TPS61150/1支持18V高输入电源电压的应用方案
下一篇:高分辨率显示屏解析
推荐阅读最新更新时间:2023-10-18 16:44
Mouser供货采用22nm架构的第4代Intel处理器
2013年8月21日 – Mouser Electronics即日起供货第4代Intel® Core™处理器(前身为Haswell)。该款处理器采用22nm架构和Tri-Gate技术,最大程度地提高了每瓦性能。 该处理器设计灵活,可用于桌面、移动或嵌入式产品。 该处理器降低了闲置状态的功耗,耗电量是上一代的1/20; 使用Intel® Rapid Start,只需 3 秒即可将处理器从休眠状态唤醒。 Intel®无线显示技术可用于将便携式产品中的内容流传输至兼容的HDTV中。 针对嵌入式应用,我们还提供散热设计功耗低至35W的处理器。 采用Intel® Turbo Boost技术时,桌面性能处理器可获得高达3.9GHz
[手机便携]
英特尔与瑞芯微合作案为何震动平板电脑市场?
    英特尔(Intel)日前宣布和中国芯片设计业者瑞芯微电子(Rockchip)达成策略协议,双方携手拓展产品的广度与加快开发速度,将英特尔架构(Intel Architecture)与通讯解决方案拓展至全球入门级Android平板电脑市场。 在协议内容中,两家公司将推出英特尔品牌的移动系统单芯片(SoC)平台;此四核心平台将内含Intel Atom (凌动)处理器,并结合英特尔的3G数据机技术。英特尔新款四核心SoFIA 3G元件预计将于2015上半年问世,主要锁定入门与超值型平板电脑市场。 英特尔将借此扩大整合式移动SoC平台中的SoFIA系列产品阵容,将版图拓展到入门级与超值型Android移
[手机便携]
DC/DC转换器中电感器对待机时间的影响评测
DC/DC是开关电源芯片。开关电源,指利用电容、电感的储能的特性,通过可控开关(MOSFET等)进行高频开关的动作,将输入的电能储存在电容(感)里,当开关断开时,电能再释放给负载,提供能量。其输出的功率或电压的能力与占空比(由开关导通时间与整个开关的周期的比值)有关。开关电源可以用于升压和降压。我们常用的DC-DC产品有两种。一种为电荷泵 (Charge Pump),一种为电感储能DC-DC转换器。本文详细讲解了这两种DC/DC产品的相关知识。   相比较前几年2.8V~3.3V的核心电压需求,近来越来越多的芯片可以在1.2V~1.8V的低压下顺畅运行。这样,在主要使用锂(聚合物)电池或镍氢电池作为系统工作能源的便携式产品中
[模拟电子]
<font color='red'>DC</font>/<font color='red'>DC转换器</font>中电感器对待机时间的影响评测
英特尔第一财季利润飙升 因PC芯片销售强劲
英特尔公司(Intel Co., INTC)第一财政季度利润飙升45%,因高端处理器芯片的销售表现强劲,抵消了该公司通常盈利能力最强业务成本高企的负面影响。 该公司第一财季收入增长8%至148亿美元,主要受益于销售个人电脑芯片的个人电脑业务的改善,这块业务当季营业利润同比大增61%,销售额增长5.7%至79.8亿美元。 不过,英特尔销售数据中心服务器芯片的数据中心部门利润受挫,因之前转向更先进制造工艺的做法最初导致成本增加。该公司数据中心部门营业利润下降16%,收入增长5.8%至42.3亿美元。 该股盘后下跌近4%。英特尔股价表现通常落后于其他半导体公司,今年迄今已累计下跌约2%。 整体而言,英特尔第一财季每股收益61美分。剔除重
[半导体设计/制造]
英特尔收购智能眼镜公司 拓展可穿戴业务
英特尔一直没有放慢对可穿戴智能技术的投资,此前曾推出了专用芯片并实施了相关的业务并购,以此抢滩可穿戴智能设备市场。如今,多种迹象显示,可穿戴智能设备市场增长非常迅猛,在此势头之下,英特尔周三又宣布,该公司已经收购了加拿大可穿戴智能设备公司Recon。Recon是谷歌(微博)眼镜的强大竞争对手之一,已经为体育迷们生产了一系列高科技的智能眼镜。事实上,早在2013年,英特尔就已经对Recon公司进行了大量投资。 Recon公司的Recon Jet智能眼镜起步价格为699美元,此产品可以通过内部设置为用户提供跑步或骑自行车的时间与距离等信息。另外,这款智能眼镜还配置了视频拍摄功能。 目前,英
[物联网]
英特尔:针对AMD 90亿美元造45纳米芯片基地
在全球计算机微处理器市场,英特尔和AMD正在进行着针锋相对较量。 目前,AMD公司65纳米制造工艺的Barcelona 四核处理器( K8L)已经从样品开始进行大规模生产,但英特尔公司也不甘示弱,正在加紧构建它的三个45纳米微处理器工厂。三个工厂一个是美国俄勒冈州的D-1D工厂,一个是亚利桑那州的Fab 32工厂,另一个`是以色列的Fab 28工厂。 英特尔公司表示,三个工厂的投资总额超过了90亿美元。正是为了筹建三处新的芯片基地,英特尔开始在全球范围内大打裁员牌,预计裁员数量大约在10000-12000名,包括印度市场在内,英特尔计划削减全球市场上的行销队伍。 英特尔公司表示,未来三个新建基地将集中进行45纳米制程处理器的研
[焦点新闻]
处理器双雄争霸ARM将击败Intel
ARM与英特尔( Intel )之间在处理器架构与生态系统方面的战争,正以多种形式重塑这个产业;预期将产生变化的,包括运算装置外观设计(form factor)、编程模型(programming model) 、成本(costs)、功耗预算(power budget)…等等。 举例来说,有两家ARM核心处理器供应商──AMD与Nvidia──已经开始提供各自的伺服器平台,因此有部分伺服器厂商可能就会透过垂直整合来差异化产品,有的则是与特定SoC供应商合作开发客制化解决方案;笔者猜想,英特尔未来也会依循其中一种方式,或以上两种方式都采用。 伺服器领域的发展情势可能远超过人们所预期、不仅仅是一场战争,而且会带来非常深远的影
[手机便携]
退出5G芯片战场,Intel专注于网络基础设施
英特尔公司今天宣布计划退出5G智能手机调制解调器业务,并完成对其它调制解调器业务机会的评估,包括PC、物联网设备及其它以数据为中心的设备。英特尔还将继续投资其5G网络基础设施业务。 英特尔将继续履行对现有4G智能手机调制解调器产品线的客户承诺,但不会在智能手机领域推出5G调制解调器产品,包括最初计划于2020年推出的产品。 “我们对于5G和网络‘云化’的机遇感到兴奋,但对于智能手机调制解调器业务而言,显然已经没有明确的盈利和获取回报的路径。”英特尔公司首席执行官 司睿博 (Bob Swan)表示。“5G依然是英特尔的战略重点,我们的团队已经开发了一系列有价值的无线产品套件和知识产权。我们正在评估我们的选择,让创造的价值得以
[物联网]
小广播
最新电源管理文章
