STM32启动过程详解
发布者:心怀梦想最新更新时间:2017-09-13 来源: eefocus关键字:STM32  启动过程 手机看文章 扫描二维码
随时随地手机看文章
一、STM32启动文件详细解析
STM32启动文件详细解析(V3.5.0) 以:startup_stm32f10x_hd.s为例
  1. ;******************** (C) COPYRIGHT 2011 STMicroelectronics ********************
  2. ;* File Name          : startup_stm32f10x_hd.s
  3. ;* Author             : MCD Application Team
  4. ;* Version            : V3.5.0
  5. ;* Date               : 11-March-2011
  6. ;* Description        : STM32F10x High Density Devices vector table for MDK-ARM
  7. ;*                      toolchain.
  8. ;*                      This module performs:
  9. ;*                      - Set the initial SP
  10. ;*                      - Set the initial PC == Reset_Handler
  11. ;*                      - Set the vector table entries with the exceptions ISR address
  12. ;*                      - Configure the clock system and also configure the external
  13. ;*                        SRAM mounted on STM3210E-EVAL board to be used as data
  14. ;*                        memory (optional, to be enabled by user)
  15. ;*                      - Branches to __main in the C library (which eventually
  16. ;*                        calls main()).
  17. ;*                      After Reset the CortexM3 processor is in Thread mode,
  18. ;*                      priority is Privileged, and the Stack is set to Main.
  19. ;* <<< Use Configuration Wizard in Context Menu >>>
  20. ;*******************************************************************************
  21. ; THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  22. ; WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
  23. ; AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
  24. ; INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
  25. ; CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
  26. ; INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  27. ;*******************************************************************************
  28.
  29. ; Amount of memory (in bytes) allocated for Stack
  30. ; Tailor this value to your application needs
  31.  Stack Configuration                     ;栈定义
  32. ;    Stack Size (in Bytes) <0x0-0xFFFFFFFF:8>
  33. ;
  34.
  35. Stack_Size      EQU     0x00000400              ;EQU伪指令,作用是左边的符号名代表右边的表达式
  36.
  37.                 AREA    STACK, NOINIT, READWRITE, ALIGN=3   ;定义栈段:名称为STACK,未初始化,可读写,ELF 的栈段按2^3=8对齐
  38. Stack_Mem       SPACE   Stack_Size              ;分配一片连续的存储区域并初始化为 0,栈空间:0x400个字节
  39. __initial_sp                            ;栈空间顶地址
  40.
  41.
  42.  Heap Configuration                  ;堆定义
  43. ;     Heap Size (in Bytes) <0x0-0xFFFFFFFF:8>
  44. ;
  45.
  46. Heap_Size       EQU     0x00000200
  47.                 AREA    HEAP, NOINIT, READWRITE, ALIGN=3
  48.
  49. __heap_base                         ;堆空间起始地址
  50. Heap_Mem        SPACE   Heap_Size               ;堆空间:0x200个字节
  51. __heap_limit                            ;堆空间结束地址
  52.
  53.
  54.     PRESERVE8                       ;PRESERVE8 指令指定当前文件保持堆栈八字节对齐
  55.     THUMB                           ;告诉汇编器下面是32位的Thumb指令,如果需要汇编器将插入位以保证对齐
  56.
  57. ; Vector Table Mapped to Address 0 at Reset         ;中断向量表定义
  58.                                 ;实际上是在CODE区(假设STM32从FLASH启动,则此中断向量表起始地址即为0x8000000)
  59.                 AREA    RESET, DATA, READONLY           ;定义一块数据段,只可读,段名字是RESET
  60.                 EXPORT  __Vectors               ;EXPORT:在程序中声明一个全局的标号__Vectors,该标号可在其他的文件中引用
  61.                 EXPORT  __Vectors_End               ;在程序中声明一个全局的标号__Vectors_End
  62.                 EXPORT  __Vectors_Size              ;在程序中声明一个全局的标号__Vectors_Size
  63.
  64.                                     ;DCD(DCDU)用于分配一片连续的字存储单元并用指定的数据初始化。
  65. __Vectors       DCD     __initial_sp               ; Top of Stack   ;该处物理地址值存储__initial_sp所表示的地址值,即为 __Vetors 标号所表示的值
  66.                 DCD     Reset_Handler              ; Reset Handler
  67.                 DCD     NMI_Handler                ; NMI Handler
  68.                 DCD     HardFault_Handler          ; Hard Fault Handler
  69.                 DCD     MemManage_Handler          ; MPU Fault Handler
  70.                 DCD     BusFault_Handler           ; Bus Fault Handler
  71.                 DCD     UsageFault_Handler         ; Usage Fault Handler
  72.                 DCD     0                          ; Reserved
  73.                 DCD     0                          ; Reserved
  74.                 DCD     0                          ; Reserved
  75.                 DCD     0                          ; Reserved
  76.                 DCD     SVC_Handler                ; SVCall Handler
  77.                 DCD     DebugMon_Handler           ; Debug Monitor Handler
  78.                 DCD     0                          ; Reserved
  79.                 DCD     PendSV_Handler             ; PendSV Handler
  80.                 DCD     SysTick_Handler            ; SysTick Handler
  81.
  82.                 ; External Interrupts                   ;以下为外部中断向量表
  83.                 DCD     WWDG_IRQHandler            ; Window Watchdog
  84.                 DCD     PVD_IRQHandler             ; PVD through EXTI Line detect
  85.                 DCD     TAMPER_IRQHandler          ; Tamper
  86.                 DCD     RTC_IRQHandler             ; RTC
  87.                 DCD     FLASH_IRQHandler           ; Flash
  88.                 DCD     RCC_IRQHandler             ; RCC
  89.                 DCD     EXTI0_IRQHandler           ; EXTI Line 0
  90.                 DCD     EXTI1_IRQHandler           ; EXTI Line 1
  91.                 DCD     EXTI2_IRQHandler           ; EXTI Line 2
  92.                 DCD     EXTI3_IRQHandler           ; EXTI Line 3
  93.                 DCD     EXTI4_IRQHandler           ; EXTI Line 4
  94.                 DCD     DMA1_Channel1_IRQHandler   ; DMA1 Channel 1
  95.                 DCD     DMA1_Channel2_IRQHandler   ; DMA1 Channel 2
  96.                 DCD     DMA1_Channel3_IRQHandler   ; DMA1 Channel 3
  97.                 DCD     DMA1_Channel4_IRQHandler   ; DMA1 Channel 4
  98.                 DCD     DMA1_Channel5_IRQHandler   ; DMA1 Channel 5
  99.                 DCD     DMA1_Channel6_IRQHandler   ; DMA1 Channel 6
  100.                 DCD     DMA1_Channel7_IRQHandler   ; DMA1 Channel 7
  101.                 DCD     ADC1_2_IRQHandler          ; ADC1 & ADC2
  102.                 DCD     USB_HP_CAN1_TX_IRQHandler  ; USB High Priority or CAN1 TX
  103.                 DCD     USB_LP_CAN1_RX0_IRQHandler ; USB Low  Priority or CAN1 RX0
  104.                 DCD     CAN1_RX1_IRQHandler        ; CAN1 RX1
  105.                 DCD     CAN1_SCE_IRQHandler        ; CAN1 SCE
  106.                 DCD     EXTI9_5_IRQHandler         ; EXTI Line 9..5
  107.                 DCD     TIM1_BRK_IRQHandler        ; TIM1 Break
  108.                 DCD     TIM1_UP_IRQHandler         ; TIM1 Update
  109.                 DCD     TIM1_TRG_COM_IRQHandler    ; TIM1 Trigger and Commutation
  110.                 DCD     TIM1_CC_IRQHandler         ; TIM1 Capture Compare
  111.                 DCD     TIM2_IRQHandler            ; TIM2
  112.                 DCD     TIM3_IRQHandler            ; TIM3
  113.                 DCD     TIM4_IRQHandler            ; TIM4
  114.                 DCD     I2C1_EV_IRQHandler         ; I2C1 Event
  115.                 DCD     I2C1_ER_IRQHandler         ; I2C1 Error
  116.                 DCD     I2C2_EV_IRQHandler         ; I2C2 Event
  117.                 DCD     I2C2_ER_IRQHandler         ; I2C2 Error
  118.                 DCD     SPI1_IRQHandler            ; SPI1
  119.                 DCD     SPI2_IRQHandler            ; SPI2
  120.                 DCD     USART1_IRQHandler          ; USART1
  121.                 DCD     USART2_IRQHandler          ; USART2
  122.                 DCD     USART3_IRQHandler          ; USART3
  123.                 DCD     EXTI15_10_IRQHandler       ; EXTI Line 15..10
  124.                 DCD     RTCAlarm_IRQHandler        ; RTC Alarm through EXTI Line
  125.                 DCD     USBWakeUp_IRQHandler       ; USB Wakeup from suspend
  126.                 DCD     TIM8_BRK_IRQHandler        ; TIM8 Break
  127.                 DCD     TIM8_UP_IRQHandler         ; TIM8 Update
  128.                 DCD     TIM8_TRG_COM_IRQHandler    ; TIM8 Trigger and Commutation
  129.                 DCD     TIM8_CC_IRQHandler         ; TIM8 Capture Compare
  130.                 DCD     ADC3_IRQHandler            ; ADC3
  131.                 DCD     FSMC_IRQHandler            ; FSMC
  132.                 DCD     SDIO_IRQHandler            ; SDIO
  133.                 DCD     TIM5_IRQHandler            ; TIM5
  134.                 DCD     SPI3_IRQHandler            ; SPI3
  135.                 DCD     UART4_IRQHandler           ; UART4
  136.                 DCD     UART5_IRQHandler           ; UART5
  137.                 DCD     TIM6_IRQHandler            ; TIM6
  138.                 DCD     TIM7_IRQHandler            ; TIM7
  139.                 DCD     DMA2_Channel1_IRQHandler   ; DMA2 Channel1
  140.                 DCD     DMA2_Channel2_IRQHandler   ; DMA2 Channel2
  141.                 DCD     DMA2_Channel3_IRQHandler   ; DMA2 Channel3
  142.                 DCD     DMA2_Channel4_5_IRQHandler ; DMA2 Channel4 & Channel5
  143. __Vectors_End                   ;Vectors结束
  144.
  145. __Vectors_Size  EQU  __Vectors_End - __Vectors      ;得到向量表的大小,304个字节也就是0x130个字节
  146.
  147.                 AREA    |.text|, CODE, READONLY     ;定义一个代码段,可读,段名字是.text
  148.                                     ;|.text|  用于表示由 C 编译程序产生的代码段,或用于以某种方式与 C 库关联的代码段
  149. ; Reset handler                     ;利用PROC、ENDP这一对伪指令标记程序开始、结束,把程序段分为若干个过程,使程序的结构加清晰
  150. Reset_Handler   PROC
  151.                 EXPORT  Reset_Handler             [WEAK];WEAK声明其他的同名标号优先于该标号被引用,就是说如果外面声明了的话,调用外面的对应函数
  152.                 IMPORT  __main              ;IMPORT:伪指令用于通知编译器要使用的标号在其他的源文件中定义
  153.                 IMPORT  SystemInit
  154.                 LDR     R0, =SystemInit         ;系统初始化
  155.                 BLX     R0              ;带链接的跳转,切换指令集,跳到SystemInit
  156.                 LDR     R0, =__main         ;__main为运行时库提供的函数;完成堆栈,堆的初始化等工作,会调用下面定义的__user_initial_stackheap
  157.                 BX      R0              ;切换指令集,main函数不返回跳到__main,进入C的世界
  158.                 ENDP
  159.
  160. ; Dummy Exception Handlers (infinite loops which can be modified)
  161.
  162. NMI_Handler     PROC
  163.                 EXPORT  NMI_Handler                [WEAK];不可屏蔽中断处理函数
  164.                 B       .
  165.                 ENDP
  166. HardFault_Handler\                   ;\意为换行
  167.                 PROC
  168.                 EXPORT  HardFault_Handler          [WEAK];硬件错误处理函数
  169.                 B       .
  170.                 ENDP
  171. MemManage_Handler\
  172.                 PROC
  173.                 EXPORT  MemManage_Handler          [WEAK]
  174.                 B       .
  175.                 ENDP
  176. BusFault_Handler\
  177.                 PROC
  178.                 EXPORT  BusFault_Handler           [WEAK]
  179.                 B       .
  180.                 ENDP
  181. UsageFault_Handler\
  182.                 PROC
  183.                 EXPORT  UsageFault_Handler         [WEAK]
  184.                 B       .
  185.                 ENDP
  186. SVC_Handler     PROC
  187.                 EXPORT  SVC_Handler                [WEAK]
  188.                 B       .
  189.                 ENDP
  190. DebugMon_Handler\
  191.                 PROC
  192.                 EXPORT  DebugMon_Handler           [WEAK]
  193.                 B       .
  194.                 ENDP
  195. PendSV_Handler  PROC
  196.                 EXPORT  PendSV_Handler             [WEAK]
  197.                 B       .
  198.                 ENDP
  199. SysTick_Handler PROC
  200.                 EXPORT  SysTick_Handler            [WEAK]
  201.                 B       .
  202.                 ENDP
  203.
  204. Default_Handler PROC
  205.                             ;输出异常向量表标号,方便外部实现异常的具体功能,[WEAK]是弱定义的意思,如果外部定义了,优先执行外部定义,否则下面的函数定义
  206.                 EXPORT  WWDG_IRQHandler            [WEAK]
  207.                 EXPORT  PVD_IRQHandler             [WEAK]
  208.                 EXPORT  TAMPER_IRQHandler          [WEAK]
  209.                 EXPORT  RTC_IRQHandler             [WEAK]
  210.                 EXPORT  FLASH_IRQHandler           [WEAK]
  211.                 EXPORT  RCC_IRQHandler             [WEAK]
  212.                 EXPORT  EXTI0_IRQHandler           [WEAK]
  213.                 EXPORT  EXTI1_IRQHandler           [WEAK]
  214.                 EXPORT  EXTI2_IRQHandler           [WEAK]
  215.                 EXPORT  EXTI3_IRQHandler           [WEAK]
  216.                 EXPORT  EXTI4_IRQHandler           [WEAK]
  217.                 EXPORT  DMA1_Channel1_IRQHandler   [WEAK]
  218.                 EXPORT  DMA1_Channel2_IRQHandler   [WEAK]
  219.                 EXPORT  DMA1_Channel3_IRQHandler   [WEAK]
  220.                 EXPORT  DMA1_Channel4_IRQHandler   [WEAK]
  221.                 EXPORT  DMA1_Channel5_IRQHandler   [WEAK]
  222.                 EXPORT  DMA1_Channel6_IRQHandler   [WEAK]
  223.                 EXPORT  DMA1_Channel7_IRQHandler   [WEAK]
  224.                 EXPORT  ADC1_2_IRQHandler          [WEAK]
  225.                 EXPORT  USB_HP_CAN1_TX_IRQHandler  [WEAK]
  226.                 EXPORT  USB_LP_CAN1_RX0_IRQHandler [WEAK]
  227.                 EXPORT  CAN1_RX1_IRQHandler        [WEAK]
  228.                 EXPORT  CAN1_SCE_IRQHandler        [WEAK]
  229.                 EXPORT  EXTI9_5_IRQHandler         [WEAK]
  230.                 EXPORT  TIM1_BRK_IRQHandler        [WEAK]
  231.                 EXPORT  TIM1_UP_IRQHandler         [WEAK]
  232.                 EXPORT  TIM1_TRG_COM_IRQHandler    [WEAK]
  233.                 EXPORT  TIM1_CC_IRQHandler         [WEAK]
  234.                 EXPORT  TIM2_IRQHandler            [WEAK]
  235.                 EXPORT  TIM3_IRQHandler            [WEAK]
  236.                 EXPORT  TIM4_IRQHandler            [WEAK]
  237.                 EXPORT  I2C1_EV_IRQHandler         [WEAK]
  238.                 EXPORT  I2C1_ER_IRQHandler         [WEAK]
  239.                 EXPORT  I2C2_EV_IRQHandler         [WEAK]
  240.                 EXPORT  I2C2_ER_IRQHandler         [WEAK]
  241.                 EXPORT  SPI1_IRQHandler            [WEAK]
  242.                 EXPORT  SPI2_IRQHandler            [WEAK]
  243.                 EXPORT  USART1_IRQHandler          [WEAK]
  244.                 EXPORT  USART2_IRQHandler          [WEAK]
  245.                 EXPORT  USART3_IRQHandler          [WEAK]
  246.                 EXPORT  EXTI15_10_IRQHandler       [WEAK]
  247.                 EXPORT  RTCAlarm_IRQHandler        [WEAK]
  248.                 EXPORT  USBWakeUp_IRQHandler       [WEAK]
  249.                 EXPORT  TIM8_BRK_IRQHandler        [WEAK]
  250.                 EXPORT  TIM8_UP_IRQHandler         [WEAK]
  251.                 EXPORT  TIM8_TRG_COM_IRQHandler    [WEAK]
  252.                 EXPORT  TIM8_CC_IRQHandler         [WEAK]
  253.                 EXPORT  ADC3_IRQHandler            [WEAK]
  254.                 EXPORT  FSMC_IRQHandler            [WEAK]
  255.                 EXPORT  SDIO_IRQHandler            [WEAK]
  256.                 EXPORT  TIM5_IRQHandler            [WEAK]
  257.                 EXPORT  SPI3_IRQHandler            [WEAK]
  258.                 EXPORT  UART4_IRQHandler           [WEAK]
  259.                 EXPORT  UART5_IRQHandler           [WEAK]
  260.                 EXPORT  TIM6_IRQHandler            [WEAK]
  261.                 EXPORT  TIM7_IRQHandler            [WEAK]
  262.                 EXPORT  DMA2_Channel1_IRQHandler   [WEAK]
  263.                 EXPORT  DMA2_Channel2_IRQHandler   [WEAK]
  264.                 EXPORT  DMA2_Channel3_IRQHandler   [WEAK]
  265.                 EXPORT  DMA2_Channel4_5_IRQHandler [WEAK]
  266.                             ;如下只是定义一些空函数
  267. WWDG_IRQHandler
  268. PVD_IRQHandler
  269. TAMPER_IRQHandler
  270. RTC_IRQHandler
  271. FLASH_IRQHandler
  272. RCC_IRQHandler
  273. EXTI0_IRQHandler
  274. EXTI1_IRQHandler
  275. EXTI2_IRQHandler
  276. EXTI3_IRQHandler
  277. EXTI4_IRQHandler
  278. DMA1_Channel1_IRQHandler
  279. DMA1_Channel2_IRQHandler
  280. DMA1_Channel3_IRQHandler
  281. DMA1_Channel4_IRQHandler
  282. DMA1_Channel5_IRQHandler
  283. DMA1_Channel6_IRQHandler
  284. DMA1_Channel7_IRQHandler
  285. ADC1_2_IRQHandler
  286. USB_HP_CAN1_TX_IRQHandler
  287. USB_LP_CAN1_RX0_IRQHandler
  288. CAN1_RX1_IRQHandler
  289. CAN1_SCE_IRQHandler
  290. EXTI9_5_IRQHandler
  291. TIM1_BRK_IRQHandler
  292. TIM1_UP_IRQHandler
  293. TIM1_TRG_COM_IRQHandler
  294. TIM1_CC_IRQHandler
  295. TIM2_IRQHandler
  296. TIM3_IRQHandler
  297. TIM4_IRQHandler
  298. I2C1_EV_IRQHandler
  299. I2C1_ER_IRQHandler
  300. I2C2_EV_IRQHandler
  301. I2C2_ER_IRQHandler
  302. SPI1_IRQHandler
  303. SPI2_IRQHandler
  304. USART1_IRQHandler
  305. USART2_IRQHandler
  306. USART3_IRQHandler
  307. EXTI15_10_IRQHandler
  308. RTCAlarm_IRQHandler
  309. USBWakeUp_IRQHandler
  310. TIM8_BRK_IRQHandler
  311. TIM8_UP_IRQHandler
  312. TIM8_TRG_COM_IRQHandler
  313. TIM8_CC_IRQHandler
  314. ADC3_IRQHandler
  315. FSMC_IRQHandler
  316. SDIO_IRQHandler
  317. TIM5_IRQHandler
  318. SPI3_IRQHandler
  319. UART4_IRQHandler
  320. UART5_IRQHandler
  321. TIM6_IRQHandler
  322. TIM7_IRQHandler
  323. DMA2_Channel1_IRQHandler
  324. DMA2_Channel2_IRQHandler
  325. DMA2_Channel3_IRQHandler
  326. DMA2_Channel4_5_IRQHandler
  327.                 B       .
  328.
  329.                 ENDP
  330.
  331.                 ALIGN                   ;默认是字对齐方式,也说明了代码是4字节对齐的
  332.
  333. ;*******************************************************************************
  334. ; User Stack and Heap initialization 用户堆栈初始化
  335. ;*******************************************************************************
  336.                  IF      :DEF:__MICROLIB        ;判断是否使用DEF:__MICROLIB(micro lib),如果勾选了micro lib
  337.
  338.                  EXPORT  __initial_sp           ;将栈顶地址、堆起始地址、堆结束地址赋予全局属性,使外部程序可用
  339.                  EXPORT  __heap_base
  340.                  EXPORT  __heap_limit
  341.
  342.                  ELSE                   ;如果没有勾选micro lib
  343.
  344.                  IMPORT  __use_two_region_memory    ;两区堆栈空间,堆和栈有各自的空间地址
  345.                  EXPORT  __user_initial_stackheap
  346.
  347. __user_initial_stackheap                ;标号__user_initial_stackheap,表示用户堆栈初始化程序入口
  348.                             ;此处是初始化两区的堆栈空间,堆是从由低到高的增长,栈是由高向低生长的,两个是互相独立的数据段,并不能交叉使用。
  349.                  LDR     R0, =  Heap_Mem        ;保存堆起始地址
  350.                  LDR     R1, =(Stack_Mem + Stack_Size)  ;保存栈结束地址
  351.                  LDR     R2, = (Heap_Mem +  Heap_Size)  ;保存堆结束地址
  352.                  LDR     R3, = Stack_Mem        ;保存栈起始地址
  353.                  BX      LR
  354.
  355.                  ALIGN
  356.
  357.                  ENDIF
  358.
  359.                  END                    ;END命令指示汇编器,已到达一个源文件的末尾
  360.
  361. ;******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE*****
二、STM32 中断向量表的位置 、重定向
知道怎么跳到main函数了,那么,中断发生后,又是怎么跑到中断入口地址的呢?
从stm32f10x.s可以看到,已经定义好了一大堆的中断响应函数,这就是中断向量表,标号__Vectors,表示中断向量表入口地址,例如:
AREA    RESET, DATA, READONLY ; 定义只读数据段,实际上是在CODE区(假设STM32从FLASH启动,则此中断向量表起始地址即为0x8000000)
  1.          EXPORT  __Vectors
  2.  OS_CPU_SysTickHandler
  3. IMPORT  OS_CPU_PendSVHandler
  4. rs       DCD     __initial_sp              ; Top of Stack
  5.          DCD     Reset_Handler             ; Reset Handler
  6.          DCD     NMI_Handler               ; NMI Handler
  7.          DCD     HardFault_Handler         ; Hard Fault Handler
  8.          DCD     MemManage_Handler         ; MPU Fault Handler
  9.          DCD     BusFault_Handler          ; Bus Fault Handler
  10.          DCD     UsageFault_Handler        ; Usage Fault Handler
这个向量表的编写是有讲究的,跟硬件一一对应不能乱写的,CPU找入口地址就靠它了,bin文件开头就是他们的地址,参考手册RM0008的10.1.2节可以看到排列。
我们再结合CORTEX-M3的特性,他上电后根据boot引脚来决定PC位置,比如boot设置为flash启动,则启动后PC跳到0x08000000。此时CPU会先取2个地址,第一个是栈顶地址,第二个是复位异常地址,故有了上面的写法,这样就跳到reset_handler。
那么这个reset_handler的实际地址是多少.?下面的一堆例如Nmi_handler地址又是多少呢?发生中断是怎么跑到这个地址的呢?下面挨个讲解。
1、我们可以通过反向来得知这些入口地址,查看工程下的map文件就可以看到了,这个地址跟keil里面设置的target->flash起始地址息息相关,实际上我们不太需要关心,让编译器分配,中断向量表放的就是他们的地址。
2、对比ARM7/ARM9内核,Cortex-M3内核则是固定了中断向量表的位置而起始地址是可变化的。
3、进到C语言后会先配置NVIC,NVIC_SetVectorTable()里面可以配置中断向量表的起始地址和偏移,主要是告诉CPU该向量表是位于Flash还是Ram,偏移是多少。例如设置为位于Flash内,偏移就是烧入的程序地址,可在Keil target中设置。这样CPU就知道入口地址了。
4、发生中断后,CPU找到中断向量表地址,然后根据偏移(对号入座)再找到中断地址,这样就跳过去了。
我们截一个图说明一下,map文件:
对应的bin文件,看是不是放的上面地址:
显然,200039c0就是栈顶地址,而08006F21就是reset_handler地址!
如何定位?以放到0x20000000为例
1、keil设置ram起始为0x20000100,我们在0x20000000~0x20000100放中断向量表,其他给程序用
2、设置NVIC_SetVectorTable(NVIC_VectTab_FLASH,0);
3、跳到C时把中断向量表拷贝到0x20000000
关键字:STM32  启动过程 引用地址:STM32启动过程详解
上一篇:stm32编程配置一个I/O为EXTI中断的步骤
下一篇:STM32 ADC的规则通道和注入通道的区别
推荐阅读最新更新时间:2024-03-16 15:36
STM32的GPIO引脚即输入又输出
要想实现STM引脚即输入又输出,需要: 引脚配置成开漏输出 外部需要上拉 在输入的时候,要先将STM的引脚置高 内部上拉电阻主要是用于推挽输出和单纯的输入模式,这两种情况只能是输出或者输入模式,而开漏模式同时支持输出和输入查询,必须外接上拉电阻。
[单片机]
stm32程序下载成功但是不运行
调试stm32程序,发现如下问题: STM32编写程序,当程序中没有sd卡部分时,程序正常下载,正常运行。当程序中运行sd卡加文件系统时程序能正常下载但是不能正常的运行。发现问题就要解决问题呀,好了大家一起来和我解决问题吧!​ 根据自己问题,上网查找解决办法,最终将问题锁定在堆栈设置问题上。(堆栈设置的空间不够大) 解决办法:在​stm32的程序目录下查找STM32F10x.s(或者是startup_stm32f10x_hd,这取决于你是用的寄存器还是函数库) 在打开文件,在文件的开头很醒目的位置,发现了关于堆栈的设置。​​ 从中我们可以看出来对于栈(stack)的大小设置为0x200,堆(heap)的大小为
[单片机]
<font color='red'>stm32</font>程序下载成功但是不运行
再造STM32---第二部分:再识 STM32
本系列是基于STM32F429野火库进行学习。 2.1 STM32的字面含义 1、 ST— 意法半寻体,是一个公司名,即SOC厂商 2、 M— Microelectronics的缩写,表示微控制器, 大家注意微控制器(STM32)和微处理器(跑Linux)的区别 3、 32— 32bit的意思,表示这是一个32bit的微控制器 2.2 STM32诞生的背景: 1、技术的更替,这个是最主要的原因 2、市场的需求(成本、性能、功耗、 GUI、操作系统),传统的8/16位的微控制器,久经岁月的洗礼,如今虽有余晖,当面对这些需求时更显的是捉襟见肘 3、 ST的努力(产品线丰富、开发简单易上手—基于固件库开发),让STM32在众多的
[单片机]
再造STM32---第二部分:再识 <font color='red'>STM32</font>
STM32+AD7606芯片源代码
基于STN32F407的AD7606芯片ADC采样例程,使用FSMC接口 单片机源程序如下: #include bsp.h /* 如果要用ST的固件库,必须包含这个文件 */ /* 定义例程名和例程发布日期 */ #define EXAMPLE_NAME F4-029_AD7606模块例程 #define EXAMPLE_DATE 02-01 #define DEMO_VER 1.0 /* 仅允许本文件内调用的函数声明 */ static void PrintfLogo(void); /* *************************************
[单片机]
STM32三线检测八个按键(74HC165)
STM32三线检测八个按键是典型的IO扩展应用(并转串),思路和学习51单片机时一致,下面直接上图和代码! 简述: 1.74HC165使用1、2、9脚,15脚可直接接地 2.按键低电平为按下 PA1- SL 并行数据加载 PA2- CLK 时钟 PA3- DAT 串行数据输出 代码: #include 74HC165.h #include delay.h void Init_74HC165(void) { GPIO_InitTypeDef GPIO_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); GP
[单片机]
<font color='red'>STM32</font>三线检测八个按键(74HC165)
STM32-IIC通信(基于AT24C02的软件IIC通信)
IIC是什么? IIC是一种通信是一种由 PHILIPS 公司开发的两线式串行总线。IIC是用来传输数据的,也是一种通信协议。 IIC的特点: IIC总线简单而有效,占用的PCB(印制电路板)空间很小,芯片引脚数量少,设计成本低。IIC总线支持多主控(Multi-Mastering)模式,任何能够进行发送和接收的设备都可以成为主设备。主控能够控制数据的传输和时钟频率,在任意时刻只能有一个主控。高速 IIC 总线一般可达 400kbps 以上。 IIC的通信时序: I2C 总线在传送数据过程中共有三种类型信号, 它们分别是:开始信号、结束信号和应答信号。 开始信号:SCL 为高电平时,SDA 由高电平向低电平跳变,开
[单片机]
STM32开发中的位带操作机制
为了像51单片机一样能够对某个管脚单独操作,引入了位带操作这样的操作机制。 如下图,位带(Bit band)区就是就是你想单独操作的IO的区域,比如PA1、PA2。而位带别名区就是你给每一位重新起了个名字的那一片地址区域。可以看下表,M3内核存储器映射表,你能看到1M内存的BitBand区,还有与之对应的32M内存的BitBand别名区,因为你将每一位膨胀成为了一个32位的地址,所以相应的别名区的内存也会是位带区的32倍。 想进行位带操作,应该先去找该位对应的别名区的地址,找到了这个地址,对这个地址进行操作,那么实际上也就是对该位进行操作了。 官方给出了如下相应的计算公式: AliasAddr=0x42000000+((A‐0
[单片机]
<font color='red'>STM32</font>开发中的位带操作机制
142条STM32遇到的坑,你知道几个?
1、AHB系统总线分为APB1(36MHz)和APB2(72MHz),其中2 1,意思是APB2接高速设备。 2、Stm32f10x.h相当于reg52.h(里面有基本的位操作定义),另一个为stm32f10x_conf.h专门控制外围器件的配置,也就是开关头文件的作用 3、HSE Osc(High Speed External Oscillator)高速外部晶振,一般为8MHz,HSI RC(High Speed InternalRC)高速内部RC,8MHz 4、LSE Osc(Low Speed External Oscillator)低速外部晶振,一般为32.768KHz,LSI RC(Low Speed InternalR
[单片机]
142条<font color='red'>STM32</font>遇到的坑,你知道几个?
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
