16-string, White and RGB LED Drivers with Adaptive Configuration, EEPROM, and SPI/I2C/SMBus Serial Interface
The MSL2164/MSL2166 compact, high-power LED string drivers use external current control MOSFETs to sink up to 350mA per string, with matching better than ±0.8%. The MSL2164/MSL2166 drive 16 parallel strings of LEDs and offer fault detection and management of open-circuit and short-circuit LEDs.
The MSL2164/MSL2166 feature a 20MHz SPI serial interface. Both devices support video frame-by-frame LED string intensity control for up to eight interconnected devices, allowing active area dimming and phase-shifted PWM outputs. They also include an advanced PWM engine that synchronizes PWM dimming to the video signal supporting forward, center, reverse and inverse PWM modes for reduced motion blur and waterfall noise.
The MSL2164/MSL2166 adaptively control any topology DC-DC or AC/DC converter that power the LED strings. The patent-pending “Efficiency Optimizers” minimize power use while maintaining LED current accuracy.
A unique combination of LED current control and pulse width dimming management offers simple full-screen brightness control, versatile area dimming and a consistent white point. Full-scale LED regulation current is set for each string using current sense resistors and a 10-bit register that controls global string current. The 12-bit global intensity register controls PWM dimming of all strings, and each string uses a 12-bit register to control individual string PWM dimming.
The MSL2164/MSL2166 monitor the LED strings for open-circuit, short-circuit, loss-of-sync and over-temperature faults, and provide a hardware fault output (FLTB) to notify the microcontroller. Detailed fault status and control are available through the serial interface. Additionally, the MSL2164/MSL2166 include on-chip EEPROMs that allow customizing of the register power-up states via the serial interface.
The MSL2164/MSL2166 are offered in a 9 x 9 x 0.85mm, 64-pin TQFN package and operate over the -40℃ to 85℃ temperature range.
MSL2164/MSL2166主要特性:
• 12-Bit PWM String Dimming
• Forward, Center, Reverse and Inverse PWM Modes
• Fast 20MHz SPI Supports Up to 8 Devices per Bus
• 8-Bit Adaptive Power Correction Maximizes Efficiency for Up to 3 String Power Supplies
• External Current Regulation MOSFETs for High Voltage and/or Current
• Drives Up to 16 Parallel LED Strings Per Device, Cascade Additional Devices for More Strings
• Supports Adaptive, Real-Time Area Dimming for Highest Dynamic Range in LCD TVs and Monitors
• Easily Implements Scrolling, 3D, and Local Dimming Algorithms
• Programmable String Phase Reduces Motion Blur and Improves Efficiency
• Global Intensity Control via SPI Serial Interface
• 0.8% String to String Matching
• PWM Dimming Synchronized to VSYNC and HSYNC Including Frequency Multipliers and Dividers
• Second Set of PWM Registers Select Alternate Brightness and Timing
• Configurable Power-up Defaults Through Internal EEPROM
• LED Open Circuit and Short Circuit Fault Detection
• Individual Fault Detection Enabled for Each String
• Over-Temperature Shutdown Protection
• Broadcast Write Simplifies Configuration
• -40℃ To +85℃ Operating Temperature Range
MSL2164/MSL2166应用:
Long-Life, Efficient LED Backlighting for:
• Televisions and Desktop Monitors
• Medical and Industrial Instrumentation
• Automotive Audio-visual Displays
Channel Signs
Architectural Lighting
图1. MSL2164/MSL2166方框图
图2. MSL2164典型应用电路图
上一篇:手持设备LCD背光LED驱动方案浅述
下一篇:标准LED VS 高能LED
推荐阅读最新更新时间:2023-10-18 16:26
Vishay线上图书馆
- 选型-汽车级表面贴装和通孔超快整流器
- 你知道吗?DC-LINK电容在高湿条件下具有高度稳定性
- microBUCK和microBRICK直流/直流稳压器解决方案
- SOP-4小型封装光伏MOSFET驱动器VOMDA1271
- 使用薄膜、大功率、背接触式电阻的优势
- SQJQ140E车规级N沟道40V MOSFET
- Vicor高性能电源模块助力低空航空电子设备和 EVTOL的发展
- Bourns 推出两款厚膜电阻系列,具备高功率耗散能力, 采用紧凑型 TO-220 和 DPAK 封装设计
- Bourns 全新高脉冲制动电阻系列问世,展现卓越能量消散能力
- Nexperia推出新款120 V/4 A半桥栅极驱动器,进一步提高工业和汽车应用的鲁棒性和效率
- 英飞凌推出高效率、高功率密度的新一代氮化镓功率分立器件
- Vishay 新款150 V MOSFET具备业界领先的功率损耗性能
- 强茂SGT MOSFET第一代系列:创新槽沟技术 车规级60 V N通道 突破车用电子的高效表现
- 面向车载应用的 DC/DC 电源
- Vishay推出适用于恶劣环境的紧凑型密封式SMD微调电阻器
