CypressCY3269N照明解决方案
最新更新时间:2012-03-28来源: 21IC关键字:电源管理  LED驱动器  DC/DC转换器 手机看文章 扫描二维码
随时随地手机看文章
    Cypress 公司的CY3269N照明开发方案采用CY8CLED04 EZ-Color™ HB LED 控制器,用来开发智能的LED照明,用户采用手指触摸能开发出从整个房间到大型建筑物的照明显示,具有暖色,中色或冷白光的可变色彩温度,目标应用在LCD背光,通用照明,建筑物照明和大型显示屏等.本文介绍了CY8CLED04 HB LED 控制器主要特性,逻辑框图,以及CY3269N照明开发套件,开发板电路图和材料清单.
    Cypress’s EZ-Color family of devices offers the ideal control solution for high brightness LED applications requiring intelligent dimming control. EZ-Color devices combine the power and flexibility of Programmable System-on-Chip (PSoC®); with Cypress’s precise illumination signal modulation (PrISM™) modulation technology providing lighting designers a fully customizable and integrated lighting solution platform.
    The EZ-Color family supports a range of independent LED channels from 4 channels at 32 bits of resolution each, up to 16 channels at 8 bits of resolution each. This enables lighting designers the flexibility to choose the LED array size and color quality. PSoC Designer software, with lighting specific drivers, can significantly cut development time and simplify implementation of fixed color points through temperature, optical, and LED binning compensation. EZ-Color’s virtually limitless analog and digital customization enable simple integration of features in addition to intelligent lighting, such as CapSense, battery charging, image stabilization, and motor control during the development process. These features, along with Cypress’s best-in-class quality and design support, make EZ-Color the ideal choice for intelligent HB LED control applications.
    CY8CLED04主要特性:
■ HB LED Controller
❐ Configurable dimmers support up to four independent LED channels
❐ 8- to 32-bits of resolution per channel
❐ Dynamic reconfiguration enables led controller plus other features: CapSense®, Battery Charging, and Motor Control
■ Visual embedded design
❐ LED-Based drivers
• Binning compensation
• Temperature feedback
• Optical feedback
• DMX512
■ PrISM™ modulation technology
❐ Reduces radiated EMI
❐ Reduces low frequency blinking
■ Advanced peripherals (PSoC® blocks)
❐ Four digital PSoC blocks provide:
• 8 to 32-bit timers, counters, and PWMs
• Full-duplex UART
• Multiple SPI Masters or Slaves
• Connectable to all GPIO pins
❐ Six Rail-to-Rail analog PSoC blocks provide:
• Up to 14-bit ADCs
• Up to 9-bit DACs
• Programmable gain amplifiers (PGA)
• Programmable filters and comparators
❐ Complex peripherals by combining blocks
❐ Capacitive sensing application capability
■ Complete development tools
❐ Free development software
• PSoC Designer™
❐ Full featured, in-circuit emulator (ICE) and programmer
❐ Full speed emulation
❐ Complex breakpoint structure
❐ 128 KB trace memory
■ Programmable pin configurations
❐ 25 mA sink, 10 mA source on all GPIO
❐ Pull-up, pull-down, high Z, strong, or open drain drive modes on all GPIO
❐ Up to 12 analog inputs on GPIO
❐ Four 30 mA analog outputs on GPIO
❐ Configurable interrupt on all GPIO
■ Flexible on-chip memory
❐ 16K flash program storage 50,000 erase/write cycles
❐ 1K SRAM data storage
❐ In-system serial programming (ISSP)
❐ Partial flash updates
❐ Flexible protection modes
❐ EEPROM emulation in flash
■ Full speed USB (12 Mbps)
❐ Four uni-directional endpoints
❐ One bi-directional control endpoint
❐ USB 2.0 compliant
❐ Dedicated 256 byte buffer
❐ No external crystal required
CY8CLED04目标应用:
■ LCD Backlight
■ Large Signs
■ General Lighting
■ Architectural Lighting
■ Camera/Cell Phone Flash
■ Flashlights
    The PSoC Core
    The PSoC Core is a powerful engine that supports a rich feature set. The core includes a CPU, memory, clocks, and configurable General Purpose I/O (GPIO).
    The M8C CPU core is a powerful processor with speeds up to 68 MHz, providing a four MIPS 8-bit Harvard-architecture microprocessor. The CPU uses an interrupt controller with up to 20 vectors, to simplify programming of real time embedded events. Program execution is timed and protected using the included Sleep and watchdog timers (WDT).
    Memory encompasses 16K of flash for program storage, 1K of SRAM for data storage, and up to 2K of EEPROM emulated using the flash. Program flash uses four protection levels on blocks of 64 bytes, allowing customized software IP protection.
    The EZ-Color family incorporates flexible internal clock generators, including a 24 MHz internal main oscillator (IMO) accurate to 8 percent over temperature and voltage. The 24 MHz IMO can also be doubled to 48 MHz for use by the digital system.
    A low power 32 kHz internal low speed oscillator (ILO) is provided for the sleep timer and WDT. The clocks, together with programmable clock dividers (as a system resource), provide the flexibility to integrate almost any timing requirement into the EZ-Color device. In USB systems, the IMO self-tunes to ± 0.25% accuracy for USB communication.
    EZ-Color GPIOs provide connection to the CPU, digital and analog resources of the device. Each pin’s drive mode may be selected from eight options, allowing great flexibility in external interfacing. Every pin can also generate a system interrupt on high level, low level, and change from last read.
图1.CY8CLED04 逻辑框图
    CY3269N照明开发套件
    Cypress Semiconductor’s CY3269N Lighting Starter Demonstration Kit leverages two key Cypress technologies for development of intelligent LED lighting fixtures. At the simple touch of a finger, users can illuminate anything from an entire room to a large architectural lighting display with warm, neutral, or cool white light of variable color temperature. Users can create rich and vibrant colored light to set moods, accents, and customize the overall feel of any venue with little effort. The CY3269N Lighting Starter Demonstration Kit showcases two world-leading Cypress technologies: EZ-Color and CapSense, which enable tunable white light control, color mixing, and capacitive touch sensing.
    CY3269N照明开发套件包括:
    CY3269N Lighting Starter Demonstration board
9 V Battery
Five EZ-Color CY8CLED04-68LTXI Samples
Quick Start Guide
图2.CY3269N照明开发板外形图
图3.CY3269N照明开发板电路图
CY3269N照明开发板材料清单(BOM):
详情请见:
http://www.cypress.com/?docID=33549
关键字:电源管理  LED驱动器  DC/DC转换器 编辑:探路者 引用地址:CypressCY3269N照明解决方案
上一篇:NXPSSL210923WLED驱动解决方案
下一篇:安森美针对不同低压便携设备背光或闪光应用的LED驱动器方案
推荐阅读最新更新时间:2023-10-18 16:35
替代MR16 LED应用的 LED驱动器GreenPoint参考设计
近年来,高亮度发光二极管(HB-LED)市场快速发展,LED效能(efficacy,单位为流明/瓦或lm/W)增加了一倍以上,使用更加适用于众多新应用,如我们在手持电筒、建筑照明及街道照明等应用中可以发现诸多革命性的新产品。但LED要成为比白炽灯和紧凑型荧乐灯性价比更高的照明系统,仍然面临着挑战。实际上,就许多应用而言,都涉及到基于宽输入电压范围的电源来为HB-LED供电的挑战。其中,轨道照明等通用照明应用尤为如此,这些应用采用可能很松散稳压的12 Vac或12 Vdc电源。然而,LED需要以电流源而非电压源驱动,因为根据工艺容限及温度的不同,HB-LED的正向电压(额定值3.4 V)变化幅度可能超过±20%。 此外,就当前的1
[电源管理]
替代MR16 LED应用的 <font color='red'>LED驱动器</font>GreenPoint参考设计
基于dsPIC33FJ设计的PSFB砖形DC-DC转换器技术
本文介绍了dsPIC33FJ系列主要特性,方框图和CPU 核方框图,DSP 引擎方框图,数字PFC框图以及多种应用框图。此外还介绍了相移全桥(PSFB) 1/4砖形DC-DC转换器参考设计主要特性和指标,详细电路图与材料清单(BOM)。 Microchip 公司的dsPIC33FJ06GS101/X02和dsPIC33FJ16GSX02/X04包括有广泛的DSP功能和高性能16位MCU架构。3.0-3.6V的性能达到40MIPS,具有16位宽的数据通路,24位宽指令,广泛应用在AC/DC转换器,汽车HID,电池充电器,DC/DC转换器,数字照明,电磁炉,可再生能源/纯正弦波逆变器和UPS。 dsPIC33FJ系列主要特性:
[电源管理]
基于dsPIC33FJ设计的PSFB砖形<font color='red'>DC</font>-<font color='red'>DC转换器</font>技术
如何使用RGB LED驱动器实现人机交互界的设计
中介绍如何使用 RGB 提升人机交互体验,详细剖析全新一代RGB 驱动器LP50系列的设计亮点,并指导用户使用LP50实现人机交互界面的快速开发。
[机器人]
内窥镜图像处理要求及解决方案
  我们通常需要检查限定领域内部的区域。在医疗领域中,内窥镜用于透视体内以检查器官。内窥镜可以通过一个细小的切口检查胃肠道、呼吸道和泌尿管道以及内部器官。内窥镜通过其或坚或韧的长管来采集图像。用于切、抓和其它功能的附加仪器通常连接在内窥镜上,进行能够改善医疗并缩短康复时间的微创手术。被用于技术应用以检查限定区域的物品通常被称为管道镜。管道镜用于检查机械内部、建筑墙体以及搜索倒塌建筑中的伤员。   内窥镜或管道镜具有以下4个基本要求:   照亮主体的光源;   引导光照的管道;   能采集从主体反射的光的镜头或光纤系统;   能采集、处理和存储或显示图像的图像采集系统。   TI广泛的产品系列支持
[医疗电子]
内窥镜图像处理要求及解决方案
便携产品用新型电源DC-DC转换器
    为了减小体积和重量,低功耗便携产品如PDA、掌上电脑、寻呼机和便携式测量仪表等大多采用数量有限的电池供电。这就存在两个重要问题:首先是随着电池放电,其端电压会明显降低;其次是电池具有一定内阻,而且随着放电内阻逐渐增大,在负载发生变化时造成输出电压的变化。为保证系统稳定、可靠地工作,需要一个稳定的电源电压。     由于大多数情况需要提升电池电压,简单的三端线性稳压器无法满足要求,只能采用升压型开关稳压器。但是传统的开关电源设计电路复杂、体积庞大、自身功耗较大,无法在体积和功耗要求严格的便携式产品中使用。针对这个问题,Maxim公司研制了一系列高集成度电源管理方案。其中,新近推出的MAX1678、
[应用]
电流模式控制DC/DC转换器中的电流检测电路设计
电流检测电路是电流模式控制所必需的, 通过检测功率开关管上的电流,然后输出一个电流感应信号与斜坡补偿信号进行叠加并转换成一个电压信号, 再与误差放大器的输出进行比较,从而实现电流模式开关转换器电流内环的控制。其实现方法有很多种, 常见的有两种,一种是与功率管串联一个电阻Rsen,另一种是与功率管并联一个并联检测管复制比例电流, 并联检测管复制比例电流的检测方法,又有两种主要的实现结构, 一种是采用运放的结构, 另一种是利用反馈的方式。如果采用运放, 显然会增加电路的复杂性,而且也会增加功耗。本文根据具有反馈控制电流源的原理来设计电流检测电路中的反馈网络。 1 反馈控制电流源的原理 电路原理图及电流源动态特性曲线如
[测试测量]
电流模式控制<font color='red'>DC</font>/<font color='red'>DC转换器</font>中的电流检测电路设计
泰科的DC/DC转换器适用于IBA应用
泰科电子(Tyco Electronics)公司近日推出EUK240系列DC/DC转换器EUK240,输出功率达240W,采用1/8砖封装。该产品支持5:1固定比例输出的中间总线架构应用。 EUK240电源模块是隔离的DC/DC转换器,输入电压范围在36Vdc至60Vdc之间,提供单一固定比例的输出电压。最大输出电流达34A,在全部输入范围内均可输出240W的功率。该模块的输入与输出间完全隔离,允许多极性配置和接地连接,其内置的滤波器可减少外围元件数量。 EUK240可在55℃、1m/s的输入电压范围内输出240W功率,9.6V时效率高达96%,是采用负载点转换器IBA应用的理想解决方案。此外该模块还具有远程开/关逻辑
[新品]
具APD电流监视器的90V 升压型DC/DC转换器
2007 年 2 月 8 日 - 北京 - 凌力尔特公司( Linear Technology Corporation )推出固定频率、电流模式升压型 DC/DC 转换器 LT3482 ,该器件具有内置倍压器,用于偏置光接收器中的雪崩光电二极管( APD )。 LT3482 可以用 2.5V 至 16V 的输入提供高达 90V 的输出。该器件具有高压侧 APD 电流监视功能,在 - 40 o C 至 85 o C 的温度范围内实现优于 10% 的相对准确度。集成的电源开关、肖特基二极管和 APD 电流监视器全部在采
[新品]
小广播
最新电源管理文章
换一换 更多 相关热搜器件
