解惑“永动机”:电源转换效率达230%的LED技术
最新更新时间:2012-10-23来源: 电子发烧友关键字:电源转换  效率  LED技术 手机看文章 扫描二维码
随时随地手机看文章
  据美国媒体近日报导,美国麻省理工学院(MIT)的研究人员通过一种插座转换设备使发光二极管(LED)能够比其消耗的电功率释放出更多光功率,电源转换效率可达到100%以上。
  LED发光原理是将电能转换为光。目前,设计出既明亮又高效的LED灯的最大障碍之一,是增加LED灯的输出功率反而导致其效率下降。而麻省理工学院的研究人员解释说,他们的研究成果大大降低了外施的电压。根据计算,当电压减少到一半,输入功率降低了4倍,而发出的光功率与电压保持一致,也达到一半。换言之,当输出功率下降时LED发光率却在增加。
  在实验中,研究人员减少了LED的输入功率,仅30皮瓦,而测量到输出达69皮瓦的光量,效率高达230%。将相同的物理机制作用于任何LED,在外施电压作用下,电子和空穴有一定的概率产生光子。研究人员并没有像其他的研究一样试图增加这种概率,而是利用发生于设备里原子晶格的振动所散发的少量余热产生更多电力。
  这种利用余热发光的过程可使LED稍微冷却,其操作类似一个热电冷却器。虽然在室温条件下,冷却不足以提供实用性的温度,但它有可能被用于设计不产生热量的灯。当作为热泵时,该设备可有助于固态冷却应用程式,甚至是发电机设备。
  理论上,这个低压策略能够在低电压下产生任意高效的光子,研究人员希望该技术能提供一种新的测试节能极限电磁波通讯的方法。虽然在科学上这个方法很有趣,但其还不会立即促使超效率的LED商业化,因为示范项目仅能用很低的输入功率产生少量的光。
  首先解释一下大家对于“永动机”的疑惑,一位英文网站的工程师作了如下解读:No perpetual motion machine is created here. The article failed to mention the real reason why the LED can exceed 100% efficiency. Here is why:
  It’s nice research, but it’s sort of “cheating” in an honest way. Efficiency mentioned here is how much electricity is converted into light by this LED. Let’s say, you inject 10 electrons, and they turn into 8 photons which escaped the LED, so you get a 80% efficient LED. The 2 missing electrons are “wasted”。 So, in order to get to 100% efficiency and beyond, you find another way to make up for those 2 missing electrons. MIT team used the well-known thermoelectric effect which converts heat to electricity, which in return makes up for those “wasted” electrons. As a result, this LED has over 100% efficiency. You now see why they choose to do the experiment as very low voltage, because low voltage means less electrons injects, so fewer “wasted” electrons you need to make up.
  Therefore, the over 100% efficiency is kinda of “cheating” in an honest way. What’s supplying this ultra low voltage LED electrons are not electricity alone, but also ambient temperature in form of thermo energy. The quoted efficiency in this article is a ratio between photon generated by TWO sources of energy and input from ONE source of energy. Of course, the efficiency can be much higher than 100%.
  It’s that simple, but I do not in anyway wish to undermine the importance of this research. It’s good work. I just don’t wish others who does not have background on this specific topic to misunderstood the importance and message of this research work.
  为了帮助工程师朋友们更好地了解这个技术报道,特别找了一些英文方面的报道供大家参考:
  Scientists Create 230-Percent Efficient LED Bulbs
  Light bulbs have always required more electricity than they need to produce light because the energy conversion process—changing electricity to light—was inefficient. But an MIT research team has just shown that an LED can actually give off more light than what it consumes in electricity.
  Incandescent bulbs are the poster child of inefficient energy conversion. The devices heated a filament with an electrical current which not only produced light, but a lot of waste heat as well. Fluorescent bulbs, CFL‘s, and even conventional LED’s all generate the same waste heat to varying (albeit much smaller) degrees but none has ever reached 100-percent efficiency—a mark known as “unity efficiency.”
  The team from MIT posited that while the bulb‘s energy requirements decrease at an exponential rate (halving the voltage reduces the input power by a factor of four), the lumen output would decrease linearly (halve the voltage and the lumens drop by half as well)。 This means that at some point, the amount of lumens the bulb is emitting would be more than the amount of energy spent—essentially “free” light.
  Granted, this point occurs only when using minuscule amounts of electricity to power incredibly dim bulbs. In their experiments, the team was able to generate 69 picowatts of light from just 30 picowatts of energy. They did so by harnessing waste heat, which is caused by vibrations in the bulb’s atomic lattice, to compensate for the losses in electrical power. The device also reacts to ambient heat in the room to increase its efficiency and power the bulb.
  This process cools the bulb slightly and could eventually be employed to manufacture “cold” bulbs that don‘t generate any heat, only light. And, since the same physical mechanism from these tiny bulbs can be applied to any LED, they likely will be.
  MIT Researchers Create LED Light That Exceeds 100-Percent Efficiency
  Light bulbs have always been pretty inefficient, even those that have a rep for using less juice, like LEDs. Because of the energy conversion process, they consume more energy than they actually need to illuminate. But what if we told you that there was a light bulb out there, just waiting to be invented, that could produce more energy than it consumes? A group of researchers at MIT have figured out how to develop LED lights that wildly eclipse the efficiency of any other bulb. In fact, they successfully tested a LED light with an efficiency of 230 percent!
  The key to increasing the power conversion efficiency, according to MIT researcher Parthiban Santhanam and his co-authors, is to decrease the applied voltage. When the voltage is halved, the input power is decreased by a factor of four. (The inverse is also true — the brighter LED lights are, the less efficient they become.) In effect, if you decrease the input power enough, the LED’s efficiency can increase to more than 100 percent, thus achieving what’s known as “unity efficiency.” When that happens, the light bulb will produce as much or more energy than it takes to power it, giving you the ultimate bang for your buck.
  The only problem? As you may have guessed, significantly lowering the input power creates a very weak LED bulb. In their tests, the MIT researchers succeeded in generating about 70 picowatts of light from 30 picowatts of energy — an efficiency of 230 percent! That’s a remarkable achievement, but still a miniscule amount of light. For now, there really isn’t any practical application for a super-efficient 70-picowatt bulb, but according to PhysOrg, the researchers hope the breakthrough could open the door to new advances in energy-efficiency electromagnetic communication.
  Read more: MIT Researchers Create More Than 100-Percent Efficient LED Light | Inhabitat - Sustainable Design Innovation, Eco Architecture, Green Building
关键字:电源转换  效率  LED技术 编辑:探路者 引用地址:解惑“永动机”:电源转换效率达230%的LED技术
上一篇:光耦在LED电源驱动芯片上的应用
下一篇:LED照明电源电路设计典型问答
推荐阅读最新更新时间:2023-10-17 15:05
嵌入式无线应用的可靠性和功率效率优化设计
嵌入式无线技术是嵌入式进程或系统与无线通信接口的组合。方兴未艾的嵌入式无线系统,正催生出各种新型工业、商业和住宅建筑自动化应用,并且还为消费、医疗和农业系统带来了诸多具有新功能和特性丰富的产品。低功耗或者功率是所有这些低数据率应用的一个非常重要的需求,甚至是大多数情况下的一个主要需求。但是,衡量嵌入式无线应用的功耗并非如将各部分功耗简单相加即可,尽管通常情况下,这是对给定应用选择组件的典型方法。这种以可量化的标准来比较的基本方法,无法充分反映各组件在系统中的真实关系和工作状态。因此,必须专注于无线系统的功耗,了解给定无线解决方案在节能方面的表现。 提高可靠性有助于降低无线系统的功耗,但这个系统属性通常会被忽视。在这里,可靠性指得是
[嵌入式]
嵌入式无线应用的可靠性和功率<font color='red'>效率</font>优化设计
日产汽车“ePower”发电专用发动机实现最高水平50%热效率
日产汽车开发出了一种混合动力发动机,其热效率达到世界最高水平的50%。与即将投入使用的搭载e-power的混合动力汽车(HV)相比,油耗有望改善25%。该公司计划在2030年早期在主要市场推出的新型汽车全部改为电动汽车。提高发动机的热效率与电动汽车(EV)开发一起被列为重要技术,加快开发。 e - power是只做为引擎发电使用,用马达驱动的结构。利用能发电的特点重新设计了发动机。通过重新设计燃烧室等,开发出了用较少的燃料有效燃烧的技术。与此同时,电池的进化也确立了在热效率和输出功率最高的状态下恒定运转发动机的技术,实现了50%的热效率。 汽油车只能依靠发动机驱动,需要根据情况改变输出功率,因此热效率的提高受到了限制。汽油
[嵌入式]
采用优化高电压IGBT设计高效率太阳能逆变器
随着绿色电力运动势头不减,包括家电、照明和电动工具等应用,以至其他工业用设备都在尽可能地利用太阳能的优点。为了有效地满足这些产品的需求,电源设计师正通过最少数量的器件、高度可靠性和耐用性,以高效率把太阳能源转换成所需的交流或者直流电压。         要为这些应用以高效率生产所需的交流输出电压和电流,太阳能逆变器就需要控制、驱动器和输出功率器件的正确组合。要达到这个目标,在这里展示了一个针对500W功率输出进行优化,并且拥有120V及60Hz频率的单相正弦波的直流到交流逆变器设计。在这个设计中,有一个DC/DC电压转换器连接到光伏电池板,为这个功率转换器提供200V直流输入。不过在这里没有提供太阳能电池板的详细资料,因为那
[嵌入式]
三菱电机研发LED前照灯光学模块 发光效率高可提高汽车设计灵活性
据外媒报道,三菱电机公司(Mitsubishi Electric Corporation)研发出了一种紧凑型光学模块,可为LED前大灯提供高光输出。研发出的核心组件是一个特殊的系统,结合了聚光透镜与投影透镜,以实现更高效的LED前灯。 虽然新系统只有20毫米高,但可与40到60毫米的大型投影透镜达到相同的高度,该模块灯光分布情况佳,汽车制造商用于设计时有极大的灵活性,还可以增加驾驶安全性和舒适性,同时降低能耗。上述功能一起使该模块成为下一代智能移动出行的理想解决方案。 车头灯光学系统收集LED光源投射的光,形成光束,适用于具有清晰明暗截止线的近光灯。传统的车头灯光学系统使用具有涂层镜面的反射器,易于造成反射损耗、效率低并且由于
[汽车电子]
技术文章—使用固定比率转换器提高供电网络效率
绝大多数机电负载或半导体负载都需要稳定的 DC-DC 电压转换及严格的稳压,才能可靠运行。执行该功能的 DC-DC 转换器通常称作负载点 (PoL) 稳压器,设计时具有最大输入电压及最小输入电压规格,其规格定义了它们的稳定工作范围。这些稳压器的供电网络 (PDN) 的复杂性可能会因负载的数量和类型、整体系统架构、负载功率级、电压等级(转换级)以及隔离和稳压要求的不同而不同。 许多电源系统设计人员将稳压的 DC-DC 转换器视为整体设计的关键。但将合适的电压提供给负载点稳压器,不一定都需要 PDN 稳压,或者对于中间配电母线电压而言 PDN 稳压并不那么重要。考虑这一点时,电源系统工程师应该考虑应用固定比率 DC-DC 转换器,
[电源管理]
技术文章—使用固定比率转换器提高供电网络<font color='red'>效率</font>
夏普开发出转换效率最高的光伏电池 效能达36.9%
日前从日本工业和消费电子制造商夏普公司一份声明中获悉,夏普公司已经开发出世界上截止目前转换效率最高的光伏电池。 夏普公司称,该光伏电池采用卫星先驱技术,能够把36.9%的光的能量转化成电力。
[新能源]
Andes Core N801省电效率的MCU处理器【晶心】
(台湾 新竹)亚洲首家原创性32-bit CPU IP与系统芯片设计平台的晶心科技 (Andes),今天(4月28日)于北京首度正式发表最新入门款32位处理器–最佳省电效率的Andes Core™ N801,以因应8位MCU应用升级的庞大需求。 该产品不仅在省电效率(Power Efficiency)方面可达75 DMIPS/m Watt,高于一般8位 MCU 70倍以上的效率,而且只需14 K Gates。在适当的组态下,效能甚至可高达1.2 DMIPS/MHz,高于一般8位 MCU 10倍以上的效能。在硬件架构方面,除法器为基本配备,乘法器则可选择快速或小型的。除此之外,不需外加中断控制器就可支持多达16组向
[单片机]
Andes Core N801省电<font color='red'>效率</font>的MCU处理器【晶心】
ANT8908/ANT8918内置高效率升压兼容HT8691R,10.5W单通道G类音频功率放大器
ANT8908是一款高集成度、内置高效率升压的高信噪比,低底噪,具有ALC(防破音)功能的G 类音频功率放大器。升压供电端支持10级限流可调,在功放工作期间,可实时软件调整限流值,防止电池过度放电。在锂电池3.7V供电时,驱动单通道2Q负载可以输出10.5W恒定功率。 ANT8908/ANT8918内置高效率升压兼容HT8691R,10.5W单通道G类音频功率放大器。 ALC功能能够自动检测输出失真,动态调整放大器增益,可以避免因为音乐等输入信号幅度过大,或者电池电压波动而引起的输出削顶失真,显著提高音乐品质并且可以提高听感。 AB类工作模式,可以确保在带有收音机功能的应用中无任何干扰。AB/D类切换功能同IC使能管
[嵌入式]
ANT8908/ANT8918内置高<font color='red'>效率</font>升压兼容HT8691R,10.5W单通道G类音频功率放大器
小广播
热门活动
换一批
更多
最新电源管理文章
换一换 更多 相关热搜器件
