4.3 W Power Factor Corrected LED Driver (Non-Isolated Buck Boost) Using LinkSwitchTM-PL LNK458KG
This document is an engineering report describing a non-isolated LED driver (power supply) utilizing a LNK458KG from the LinkSwitch-PL family of devices.
The DER-297 provides a single constant current output with an output power of 4.5 W.
The board can be easily configured for output voltages from 35 V to 100 V as shown in the example table below.
The key design goals were high efficiency and small size, enabling the driver to fit into candelabra and B10 sized lamps and maximize efficacy.
The board was optimized to operate over the low AC input voltage range (85 VAC to 132 VAC, 47 Hz to 63 Hz). LinkSwitch-PL based designs provide a high power factor (>0.95) meeting current international requirements.
The form factor of the board was chosen to meet the requirements for standard B10 LED replacement lamps. The output is non-isolated and requires the mechanical design of the enclosure to isolate the output of the supply and the LED load from the user.
The design was not optimized for operation with phase controlled (TRIAC) dimmers but this is possible with some modification will reduce efficiency.
The document contains the power supply specification, schematic, bill of materials, transformer documentation, printed circuit layout, design spreadsheet and performance data.
LED驱动参考设计主要特性:
Single-stage power factor corrected and accurate constant current (CC) output
Low cost, low component count and small PCB footprint solution
Highly energy efficient, >86 % at 115 VAC input for 48 V and >87 % for 96 V output
Superior performance and end user experience
Fast start-up time (<300 ms) – no perceptible delay
Integrated protection and reliability features
Single shot no-load protection / output short-circuit protected with auto-recovery
Auto-recovering thermal shutdown with large hysteresis protects both components and PCB
No damage during brown-out conditions
PF >0.95 at 115 VAC
%A THD <15% at 115 VAC
Meets IEC ring wave, differential line surge and EN55015 conducted E
图1. LED驱动参考设计外形图
48 V, 90 mA参考设计指标:
48 V, 60 mA参考设计指标:
96 V, 45 mA参考设计指标:
图2.48 V, 90 mA参考设计电路图
图3.48 V, 60 mA参考设计电路图
图4.96 V, 45mA参考设计电路图
48 V, 90 mA参考设计材料清单:
48 V, 60 mA参考设计材料清单:
Make the following changes to modify the design from 48 V, 90 mA to 48 V, 60 mA.
96 V, 45 mA参考设计材料清单:
Make the following changes to modify design from 48 V, 90 mA to 96 V, 45 mA.
详情请见:
http://www.powerint.com/sites/default/files/PDFFiles/der297.pdf
上一篇:OnSemiNCP1631300WSLIMLCDTV电源解决方案
下一篇:STSTM32L15232位MCU开发评估方案
推荐阅读最新更新时间:2023-10-18 16:29
Vishay线上图书馆
- 选型-汽车级表面贴装和通孔超快整流器
- 你知道吗?DC-LINK电容在高湿条件下具有高度稳定性
- microBUCK和microBRICK直流/直流稳压器解决方案
- SOP-4小型封装光伏MOSFET驱动器VOMDA1271
- 使用薄膜、大功率、背接触式电阻的优势
- SQJQ140E车规级N沟道40V MOSFET
- MathWorks 和 NXP 合作推出用于电池管理系统的 Model-Based Design Toolbox
- 意法半导体先进的电隔离栅极驱动器 STGAP3S为 IGBT 和 SiC MOSFET 提供灵活的保护功能
- 全新无隔膜固态锂电池技术问世:正负极距离小于0.000001米
- 东芝推出具有低导通电阻和高可靠性的适用于车载牵引逆变器的最新款1200 V SiC MOSFET
- 【“源”察秋毫系列】 下一代半导体氧化镓器件光电探测器应用与测试
- 采用自主设计封装,绝缘电阻显著提高!ROHM开发出更高电压xEV系统的SiC肖特基势垒二极管
- 艾迈斯欧司朗发布OSCONIQ® C 3030 LED:打造未来户外及体育场照明新标杆
- 氮化镓取代碳化硅?PI颠覆式1700V InnoMux2先来打个样
- 从隔离到三代半:一文看懂纳芯微的栅极驱动IC
